楼主 # 2022-04-03 09:20:20
stutian
纯小白在使用荔枝zero配置网络时提问
insmod: can't insert '/root/r8723bs.ko': File exists
wpa_supplicant v2.6
random: Trying to read entropy from /dev/random
Initializing interface 'wlan0' conf '/etc/wpa_supplicant.conf' driver 'default' ctrl_interface 'N/A' bridge 'N/A'
Configuration file '/etc/wpa_supplicant.conf' -> '/etc/wpa_supplicant.conf'
Reading configuration file '/etc/wpa_supplicant.conf'
ctrl_interface='/var/run/wpa_supplicant'
ctrl_interface_group='0'
ap_scan=1
Priority group 5
   id=0 ssid='home'
nl80211: Supported cipher 00-0f-ac:1
nl80211: Supported cipher 00-0f-ac:5
nl80211: Supported cipher 00-0f-ac:2
nl80211: Supported cipher 00-0f-ac:4
nl80211: Supported cipher 00-0f-ac:6
nl80211: Using driver-based off-channel TX
nl80211: interface wlan0 in phy phy0
nl80211: Set mode ifindex 4 iftype 2 (STATION)
nl80211: Subscribe to mgmt frames with non-AP handle 0x1965d8
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0104
nl80211: Register frame command failed (type=208): ret=-114 (Operation already in progress)
nl80211: Register frame match - hexdump(len=2): 01 04
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=040a
nl80211: Register frame match - hexdump(len=2): 04 0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=040b
nl80211: Register frame match - hexdump(len=2): 04 0b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=040c
nl80211: Register frame match - hexdump(len=2): 04 0c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=040d
nl80211: Register frame match - hexdump(len=2): 04 0d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=090a
nl80211: Register frame match - hexdump(len=2): 09 0a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=090b
nl80211: Register frame match - hexdump(len=2): 09 0b
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=090c
nl80211: Register frame match - hexdump(len=2): 09 0c
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=090d
nl80211: Register frame match - hexdump(len=2): 09 0d
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0409506f9a09
nl80211: Register frame match - hexdump(len=6): 04 09 50 6f 9a 09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=7f506f9a09
nl80211: Register frame match - hexdump(len=5): 7f 50 6f 9a 09
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0801
nl80211: Register frame match - hexdump(len=2): 08 01
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=06
nl80211: Register frame match - hexdump(len=1): 06
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0a07
nl80211: Register frame match - hexdump(len=2): 0a 07
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0a11
nl80211: Register frame match - hexdump(len=2): 0a 11
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0a1a
nl80211: Register frame match - hexdump(len=2): 0a 1a
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=1101
nl80211: Register frame match - hexdump(len=2): 11 01
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=1102
nl80211: Register frame match - hexdump(len=2): 11 02
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0505
nl80211: Register frame match - hexdump(len=2): 05 05
nl80211: Register frame type=0xd0 (WLAN_FC_STYPE_ACTION) nl_handle=0x1965d8 match=0500
nl80211: Register frame match - hexdump(len=2): 05 00
nl80211: Failed to register Action frame processing - ignore for now
rfkill: Cannot open RFKILL control device
nl80211: RFKILL status not available
netlink: Operstate: ifindex=4 linkmode=1 (userspace-control), operstate=5 (IF_OPER_DORMANT)
Add interface wlan0 to a new radio phy0
nl80211: Regulatory information - country=00
nl80211: 2402-2472 @ 40 MHz 20 mBm
nl80211: 2457-2482 @ 20 MHz 20 mBm (no IR)
nl80211: 2474-2494 @ 20 MHz 20 mBm (no OFDM) (no IR)
nl80211: 5170-5250 @ 80 MHz 20 mBm (no IR)
nl80211: 5250-5330 @ 80 MHz 20 mBm (DFS) (no IR)
nl80211: 5490-5730 @ 160 MHz 20 mBm (DFS) (no IR)
nl80211: 5735-5835 @ 80 MHz 20 mBm (no IR)
nl80211: 57240-63720 @ 2160 MHz 0 mBm
nl80211: Added 802.11b mode based on 802.11g information
wlan0: Own MAC address: 3c:33:00:5a:8b:e2
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=0 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=1 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=2 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=3 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=4 set_tx=0 seq_len=0 key_len=0
wpa_driver_nl80211_set_key: ifindex=4 (wlan0) alg=0 addr=(nil) key_idx=5 set_tx=0 seq_len=0 key_len=0
wlan0: RSN: flushing PMKID list in the driver
nl80211: Flush PMKIDs
wlan0: Setting scan request: 0.100000 sec
wlan0: WPS: UUID based on MAC address: 175cf6fc-d6f7-52b3-8f08-c86ea9c26228
EAPOL: SUPP_PAE entering state DISCONNECTED
EAPOL: Supplicant port status: Unauthorized
nl80211: Skip set_supp_port(unauthorized) while not associated
EAPOL: KEY_RX entering state NO_KEY_RECEIVE
EAPOL: SUPP_BE entering state INITIALIZE
EAP: EAP entering state DISABLED
Using existing control interface directory.
ctrl_interface_group=0
ctrl_iface bind(PF_UNIX) failed: Address already in use
ctrl_iface exists and seems to be in use - cannot override it
Delete '/var/run/wpa_supplicant/wlan0' manually if it is not used anymore
Failed to initialize control interface '/var/run/wpa_supplicant'.
You may have another wpa_supplicant process already running or the file was
left by an unclean termination of wpa_supplicant in which case you will need
to manually remove this file before starting wpa_supplicant again.
Failed to add interface wlan0
wlan0: Request to deauthenticate - bssid=00:00:00:00:00:00 pending_bssid=00:00:00:00:00:00 reason=3 state=DISCONNECTED
nl80211: Data frame filter flags=0x0
nl80211: Failed to open /proc/sys/net/ipv6/conf/wlan0/drop_unicast_in_l2_multicast: No such file or directory
nl80211: Failed to set IPv6 unicast in multicast filter
wlan0: State: DISCONNECTED -> DISCONNECTED
nl80211: Set wlan0 operstate 0->0 (DORMANT)
netlink: Operstate: ifindex=4 linkmode=-1 (no change), operstate=5 (IF_OPER_DORMANT)
EAPOL: External notification - portEnabled=0
EAPOL: External notification - portValid=0
wlan0: WPA: Clear old PMK and PTK
wlan0: Cancelling scan request
wlan0: Cancelling authentication timeout
Off-channel: Clear pending Action frame TX (pending_action_tx=(nil)
Remove interface wlan0 from radio phy0
Remove radio phy0
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211: Remove monitor interface: refcount=0
netlink: Operstate: ifindex=4 linkmode=0 (kernel-control), operstate=6 (IF_OPER_UP)
nl80211: Unsubscribe mgmt frames handle 0x8891ed51 (mode change)
udhcpc: started, v1.27.2
udhcpc: sending discover
udhcpc: sending select for 192.168.0.104
udhcpc: lease of 192.168.0.104 obtained, lease time 7200
deleting routers
adding dns 202.101.224.69
adding dns 202.101.226.69
问题1:在配置RTL8723BS的时候启动时出现这些内容,并且这段内容会打印三次,但是网络已经连接成功了,那这个是有什么错误吗?还是说不影响正常使用没关系的?
问题2:如果没有错误,是正常的这么吧这些内容去掉?
