楼主 # 2022-04-07 00:56:04
8z00z8
芒果派 R3 在echo xxx > /sys/class/gpio/export 时,说已被占用
# l
total 0
drwxr-xr-x    2 root     root             0 Jan  1 00:00 .
drwxr-xr-x   44 root     root             0 Jan  1 00:00 ..
--w-------    1 root     root          4096 Jan  1 00:00 export
lrwxrwxrwx    1 root     root             0 Jan  1 00:00 gpiochip0 -> ../../deviorm/soc/1c20800.pinctrl/gpio/gpiochip0
--w-------    1 root     root          4096 Jan  1 00:00 unexport
# c
# ls
export     gpiochip0  unexport
# echo 133 > export
[  559.339394] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE5 already requested 0.csi; cannot claim for 1c20800.pinctrl:133
[  559.351183] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-133 (1c20800.pinctrl:1s -22
sh: write error: Invalid argument
# echo 132 > export
[  570.416007] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE4 already requested 0.csi; cannot claim for 1c20800.pinctrl:132
[  570.427781] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-132 (1c20800.pinctrl:1s -22
# mdev -s
# echo 134 > export
[ 2553.646357] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE6 already requested 0.csi; cannot claim for 1c20800.pinctrl:134
[ 2553.658140] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-134 (1c20800.pinctrl:1s -22
# echo 135 > export
[ 2558.647273] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin PE7 already requested 0.csi; cannot claim for 1c20800.pinctrl:135
[ 2558.659060] suniv-f1c100s-pinctrl 1c20800.pinctrl: pin-135 (1c20800.pinctrl:1s -22
#1 2022-04-07 01:16:02
cube
已发帖子: 288
Re: 芒果派 R3 在echo xxx > /sys/class/gpio/export 时,说已被占用
dts里面把csi disabled掉。
楼主 #2 2022-04-07 11:51:49
8z00z8
请教一下大神,dts文件太多,不知道找哪个,在哪里?用的buildroot-tiny200的buildroot
#3 2022-04-07 13:22:06
abnerl
已发帖子: 70
看启动参数设置,加载哪一个dtb文件有名字,就去改对应的同名dts文件,重新编译dtb文件即可
楼主 #4 2022-04-07 14:36:31
8z00z8
@abnerl
是在make uboot-menuconfig查看吗?
#5 2022-04-08 09:10:07
abnerl
已发帖子: 70
8z00z8 wrote:
@abnerl
可以,也可以在uboot启动时,终止查看环境变量
楼主 #6 2022-04-14 00:16:01
8z00z8
abnerl wrote:
8z00z8 wrote:
@abnerl
已解决,是因为修改设备树后,直接make,设备树并不会重新编译,要删除掉output/build/下面,uboot和对应版本Linux的.stamp_build,重新make才能生效
