楼主 # 2021-07-28 13:02:47
xfdr0805
已发帖子: 328
分享在V3S RTL8723DS 上调试蓝牙音频的一点经验
## 全志V3S上通过蓝牙播放音乐
`我使用的是RTL8723DS模块,引脚与BS是兼容的,内核使用的是5.10, Bluez使用的是5.55 终端是UART0,蓝牙串口使用的是UART2,板子是参照licheepi 自己画的`
[参考链接](https://gitee.com/yocop/drv_bt_rtl8723ds)
[BT参考链接](https://github.com/Poco-Ye/rtl8723DS-BT-uart-driver)
[WIFI参考链接](https://github.com/lwfinger/rtl8723ds)
1. 首先在buildroot里勾选上bluez5-utils,bluez-tools及blue-alsa
2. 在内核里勾选
        [*]UART(H4) protocol support
        [/*]Realtek Three-wireUART(H5) protocol support
    系统启动时会显示如下信息:
        [    0.000000] Linux version 5.10.19 (xfdr@virtualbox) (arm-linux-gnueabihf-gcc (Linaro GCC 7.5-2019.12) 7.5.0, GNU ld (Linaro_Binutils-2019.12) 2.28.2.20170706) #13 SMP Fri Jul 23 12:00:59 CST 2021
        [    0.000000] cma: Reserved 16 MiB at 0x41c00000
        [    0.000000] Zone ranges:
        [    0.000000]   Normal   [mem 0x0000000040000000-0x0000000043ffffff]
        [    0.000000]   HighMem  empty
        [    0.000000]   node   0: [mem 0x0000000040000000-0x0000000043ffffff]
        [    0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x0000000043ffffff]
        [    0.000000] percpu: Embedded 15 pages/cpu s31052 r8192 d22196 u61440
        [    0.000000] Kernel command line: console=ttyS0,115200 panic=5 console=ttyS0 rootwait vt.global_cursor_default=0 root=/dev/mmcblk0p2 earlyprintk rw
        [    0.000000] Memory: 34900K/65536K available (8192K kernel code, 918K rwdata, 2244K rodata, 1024K init, 284K bss, 14252K reserved, 16384K cma-reserved, 0K highmem)
        [    0.000000] GIC: Using split EOI/Deactivate mode
        [    0.000000] random: get_random_bytes called from start_kernel+0x328/0x4c0 with crng_init=0
        [    0.000022] Switching to timer-based delay loop, resolution 41ns
        [    0.000278] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
        [    0.000593] Console: colour dummy device 80x30
        [    0.000661] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
        [    0.000684] pid_max: default: 32768 minimum: 301
        [    0.000852] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.000873] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.001748] CPU: Testing write buffer coherency: ok
        [    0.002186] /cpus/cpu@0 missing clock-frequency property
        [    0.002218] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
        [    0.002989] Setting up static identity map for 0x40100000 - 0x40100060
        [    0.003218] rcu: Hierarchical SRCU implementation.
        [    0.003764] smp: Bringing up secondary CPUs ...
        [    0.003792] smp: Brought up 1 node, 1 CPU
        [    0.003802] SMP: Total of 1 processors activated (48.00 BogoMIPS).
        [    0.003811] CPU: All CPU(s) started in HYP mode.
        [    0.003818] CPU: Virtualization extensions available.
        [    0.004452] devtmpfs: initialized
        [    0.008373] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
        [    0.008733] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
        [    0.008771] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
        [    0.009561] pinctrl core: initialized pinctrl subsystem
        [    0.011091] NET: Registered protocol family 16
        [    0.012326] DMA: preallocated 256 KiB pool for atomic coherent allocations
        [    0.013612] thermal_sys: Registered thermal governor 'step_wise'
        [    0.014006] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
        [    0.014032] hw-breakpoint: maximum watchpoint size is 8 bytes.
        [    0.036802] SCSI subsystem initialized
        [    0.037553] usbcore: registered new interface driver usbfs
        [    0.037622] usbcore: registered new interface driver hub
        [    0.037689] usbcore: registered new device driver usb
        [    0.037967] mc: Linux media interface: v0.10
        [    0.038015] videodev: Linux video capture interface: v2.00
        [    0.038161] pps_core: LinuxPPS API ver. 1 registered
        [    0.038174] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
        [    0.038198] PTP clock support registered
        [    0.038880] Advanced Linux Sound Architecture Driver Initialized.
        [    0.039575] Bluetooth: Core ver 2.22
        [    0.039667] NET: Registered protocol family 31
        [    0.039679] Bluetooth: HCI device and connection manager initialized
        [    0.039703] Bluetooth: HCI socket layer initialized
        [    0.039717] Bluetooth: L2CAP socket layer initialized
        [    0.039750] Bluetooth: SCO socket layer initialized
        [    0.040956] clocksource: Switched to clocksource arch_sys_counter
        [    0.052288] NET: Registered protocol family 2
        [    0.053034] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
        [    0.053084] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
        [    0.053112] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
        [    0.053136] TCP: Hash tables configured (established 1024 bind 1024)
        [    0.053298] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.053357] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
        [    0.053602] NET: Registered protocol family 1
        [    0.054648] RPC: Registered named UNIX socket transport module.
        [    0.054681] RPC: Registered udp transport module.
        [    0.054690] RPC: Registered tcp transport module.
        [    0.054698] RPC: Registered tcp NFSv4.1 backchannel transport module.
        [    0.056301] Initialise system trusted keyrings
        [    0.056732] workingset: timestamp_bits=30 max_order=14 bucket_order=0
        [    0.063874] NFS: Registering the id_resolver key type
        [    0.063951] Key type id_resolver registered
        [    0.063960] Key type id_legacy registered
        [    0.064015] ntfs: driver 2.1.32 [Flags: R/W].
        [    0.163771] Key type asymmetric registered
        [    0.163804] Asymmetric key parser 'x509' registered
        [    0.163906] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
        [    0.163922] io scheduler mq-deadline registered
        [    0.163931] io scheduler kyber registered
        [    0.168836] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
        [    0.169687] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pb not found, using dummy regulator
        [    0.170628] pwm-backlight backlight: supply power not found, using dummy regulator
        [    0.171287] pwm-backlight backlight: invalid default brightness level: 100, using 6
        [    0.239906] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
        [    0.244637] printk: console [ttyS0] disabled
        [    0.264964] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 45, base_baud = 1500000) is a U6_16550A
        [    0.932953] printk: console [ttyS0] enabled
        [    0.938208] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pe not found, using dummy regulator
        [    0.968606] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 46, base_baud = 1500000) is a U6_16550A
        [    0.999932] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 47, base_baud = 1500000) is a U6_16550A
        [    1.014962] panel-simple panel: supply power not found, using dummy regulator
        [    1.022545] panel-simple panel: Specify missing connector_type
        [    1.030391] libphy: Fixed MDIO Bus: probed
        [    1.035212] CAN device driver interface
        [    1.039657] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
        [    1.046143] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
        [    1.052210] dwmac-sun8i 1c30000.ethernet: No regulator found
        [    1.057984] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
        [    1.064221] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
        [    1.071527] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
        [    1.078747] dwmac-sun8i 1c30000.ethernet: COE Type 2
        [    1.083730] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
        [    1.090514] dwmac-sun8i 1c30000.ethernet: Normal descriptors
        [    1.096184] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
        [    1.101867] dwmac-sun8i 1c30000.ethernet: device MAC address d6:56:90:e0:09:09
        [    1.109732] libphy: stmmac: probed
        [    1.114430] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
        [    1.121248] libphy: mdio_mux: probed
        [    1.124869] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
        [    1.131286] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
        [    1.139085] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
        [    1.145759] ehci-platform: EHCI generic platform driver
        [    1.151239] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
        [    1.157465] ohci-platform: OHCI generic platform driver
        [    1.164161] input: 1c22800.lradc as /devices/platform/soc/1c22800.lradc/input/input0
        [    1.173440] rotary-encoder rotary@0: gray
        [    1.178460] input: rotary@0 as /devices/platform/rotary@0/input/input1
        [    1.187134] sun6i-rtc 1c20400.rtc: registered as rtc0
        [    1.192416] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T01:26:51 UTC (5211)
        [    1.200591] sun6i-rtc 1c20400.rtc: RTC enabled
        [    1.205482] i2c /dev entries driver
        [    1.210476] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input2
        [    1.220426] Driver for 1-wire Dallas network protocol.
        [    1.227208] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
        [    1.235342] Bluetooth: HCI UART driver ver 2.3
        [    1.239793] Bluetooth: HCI UART protocol H4 registered
        [    1.245041] Bluetooth: HCI UART protocol Three-wire (H5) registered
        [    1.252426] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
        [    1.263407] sun8i-v3s-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
        [    1.274623] ledtrig-cpu: registered to indicate activity on CPUs
        [    1.281222] sun4i-ss 1c15000.crypto: Die ID 7
        [    1.288761] usbcore: registered new interface driver usbhid
        [    1.294484] usbhid: USB HID core driver
        [    1.299370] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
        [    1.306740] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
        [    1.316119] sun4i-codec 1c22c00.codec: Failed to register our card
        [    1.324501] NET: Registered protocol family 17
        [    1.328998] can: controller area network core
        [    1.333627] NET: Registered protocol family 29
        [    1.338086] can: raw protocol
        [    1.341133] can: broadcast manager protocol
        [    1.345329] can: netlink gateway - max_hops=1
        [    1.350297] Bluetooth: RFCOMM TTY layer initialized
        [    1.355353] Bluetooth: RFCOMM socket layer initialized
        [    1.360538] Bluetooth: RFCOMM ver 1.11
        [    1.364363] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
        [    1.369672] Bluetooth: BNEP filters: protocol multicast
        [    1.374928] Bluetooth: BNEP socket layer initialized
        [    1.379890] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
        [    1.385825] Bluetooth: HIDP socket layer initialized
        [    1.391148] Key type dns_resolver registered
        [    1.395595] Registering SWP/SWPB emulation handler
        [    1.400448] Loading compiled-in X.509 certificates
        [    1.437437] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc097c610)
        [    1.445077] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc097891c)
        [    1.453961] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
        [    1.465480] sunxi-mmc 1c10000.mmc: card claims to support voltages below defined range
        [    1.475874] mmc1: new high speed SDIO card at address 0001
        [    1.493616] mmc0: host does not support reading read-only switch, assuming write-enable
        [    1.495706] mmc0: new high speed SDHC card at address 0002
        [    1.496918] mmcblk0: mmc0:0002 MSD20 3.73 GiB
        [    1.499651]  mmcblk0: p1 p2 p3
        [    1.507412] Console: switching to colour frame buffer device 100x30
        [    1.566756] sun4i-drm display-engine: [drm] fb0: sun4i-drmdrmfb frame buffer device
        [    1.576864] debugfs: Directory '1c22c00.codec' with parent 'V3s Audio Codec' already present!
        [    1.591054] ALSA device list:
        [    1.594055]   #0: V3s Audio Codec
        [    1.612781] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
        [    1.621158] VFS: Mounted root (ext4 filesystem) on device 179:2.
        [    1.629553] devtmpfs: mounted
        [    1.633946] Freeing unused kernel memory: 1024K
        [    1.638711] Run /sbin/init as init process
        [    1.690069] random: fast init done
        [    1.792914] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
        Starting syslogd: OK
        Starting klogd: OK
        Running sysctl: OK
        Starting mdev... OK
        [    3.206544] cfg80211: Loading compiled-in X.509 certificates for regulatory database
        [    3.248879] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
        [    3.258062] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
        [    3.266896] cfg80211: failed to load regulatory.db
        [    3.359658] 8723ds: module is from the staging directory, the quality is unknown, you have been warned.
        Saving random seed: [    3.742299] random: dd: uninitialized urandom read (512 bytes read)
        OK
        Starting system message bus: [    3.812938] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
        [    3.820155] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
        done
        Starting bluetoothd: OK
        Starting network: OK
        [    6.200965] random: crng init done
        [    6.204396] random: 3 urandom warning(s) missed due to ratelimiting
        Starting sshd: OK
        Welcome to Buildroot for the LicheePi Zero
        licheepi-zero login:
3. UART2默认速率是9600可以使用cat /dev/ttyS2来测试串口是否正常
4. 使用rtk_hciattach绑定uart端口
        rtk_hciattach -n -s 115200 /dev/ttyS2 rtk_h5 &
`注意这个过程需要加载固件才行,如果固件不存在、不匹配或者错误就会失败。需要把固件放到提示的位置`
5. 固件及配置文件加载完后
        Realtek Bluetooth :Init Process finished
        Realtek Bluetooth post process
        Device setup complete
`出现这个说明蓝牙模块初始化完成 此时hci0蓝牙端口已经生成,使用hciconfig工具可以查看端口及状态`
6. hciconfig -a
        hci0:   Type: Primary  Bus: UART
            BD Address: 34:20:03:AA:A3:7E  ACL MTU: 1021:8  SCO MTU: 255:12
            UP RUNNING PSCAN ISCAN
            RX bytes:165747 acl:159 sco:0 events:1160 errors:0
            TX bytes:16622 acl:158 sco:0 commands:225 errors:0
            Features: 0xff 0xff 0xff 0xfe 0xdb 0xfd 0x7b 0x87
            Packet type: DM1 DM3 DM5 DH1 DH3 DH5 HV1 HV2 HV3
            Link policy: RSWITCH HOLD SNIFF PARK
            Link mode: SLAVE ACCEPT
            Class: 0x040428
            Service Classes: Rendering
            Device Class: Audio/Video, HiFi Audio Device
            HCI Version: 4.1 (0x7)  Revision: 0xaa7a
            LMP Version: 4.1 (0x7)  Subversion: 0x8cb2
            Manufacturer: Realtek Semiconductor Corporation (93)
7. bluealsa -p a2dp-sink &
    `建立bluez与alsa之前的桥梁,否则无法播放音频,只能连接上`
8. bluetoothd启动需要加载一些配置文件在/etc/bluetooth/main.conf 不加载也可以
        #Default adaper name
        #Defaults to 'BlueZ X.YZ'
        Name = Sonavox-BT
        #Default device class. Only the major and minor device class bits are
        #considered. Defaults to '0x000000'.
        Class = 0x000428
        #How long to stay in discoverable mode before going back to non-discoverable
        #The value is in seconds. Default is 180, i.e. 3 minutes.
        #0 = disable timer, i.e. stay discoverable forever
        DiscoverableTimeout = 0
        #How long to stay in pairable mode before going back to non-discoverable
        #The value is in seconds. Default is 0.
        #0 = disable timer, i.e. stay pairable forever
        PairableTimeout = 0
        #Automatic connection for bonded devices driven by platform/user events.
        #If a platform plugin uses this mechanism, automatic connections will be
        #enabled during the interval defined below. Initially, this feature
        #intends to be used to establish connections to ATT channels. Default is 60.
        AutoConnectTimeout = 60
9. 使用蓝牙界的瑞士军刀bluetoothctl来调试蓝牙
10. 下面是可用的命令
  Available commands:
        advertise                                         Advertise Options Submenu
        scan                                              Scan Options Submenu
        gatt                                              Generic Attribute Submenu
        list                                              List available controllers
        show [ctrl]                                       Controller information
        select <ctrl>                                     Select default controller
        devices                                           List available devices
        paired-devices                                    List paired devices
        system-alias <name>                               Set controller alias
        reset-alias                                       Reset controller alias
        power <on/off>                                    Set controller power
        pairable <on/off>                                 Set controller pairable mode
        discoverable <on/off>                             Set controller discoverable mode
        discoverable-timeout [value]                      Set discoverable timeout
        agent <on/off/capability>                         Enable/disable agent with given capability
        default-agent                                     Set agent as the default one
        advertise <on/off/type>                           Enable/disable advertising with given type
        set-alias <alias>                                 Set device alias
        scan <on/off>                                     Scan for devices
        info [dev]                                        Device information
        pair [dev]                                        Pair with device
        cancel-pairing [dev]                              Cancel pairing with device
        trust [dev]                                       Trust device
        untrust [dev]                                     Untrust device
        block [dev]                                       Block device
        unblock [dev]                                     Unblock device
        remove <dev>                                      Remove device
        connect <dev>                                     Connect device
        disconnect [dev]                                  Disconnect device
        menu <name>                                       Select submenu
        version                                           Display version
        quit                                              Quit program
        exit                                              Quit program
        help                                              Display help about this program
        export                                            Print environment variables
11. 操作记录如下: trust dev 之后,再连接就不再提示密码了,直接连接上
        [bluetooth]# discoverable on
        Changing discoverable on succeeded
        [bluetooth]# pairable on
        Changing pairable on succeeded
        [CHG] Device D8:8F:76:51:A7:87 Connected: yes
        Request confirmation
        [agent] Confirm passkey 151930 (yes/no): yes
        Authorize service
        [agent] Authorize service 0000110d-0000-1000-8000-00805f9b34fb (yes/no):
        [CHG] Device D8:8F:76:51:A7:87 ServicesResolved: yes
        [agent] Authorize service 0000110d-0000-1000-8000-00805f9b34fb (yes/no): yes
        Authorize service
        [agent] Authorize service 0000110e-0000-1000-8000-00805f9b34fb (yes/no): yes
        [ 2681.328397] input: iPhone (AVRCP) as /devices/virtual/input/#input5
        [iPhone]# list
        Controller 34:20:03:AA:A3:7E Sonavox-BT [default]
        [iPhone]# devices
        Device D8:8F:76:51:A7:87 iPhone
        [iPhone]# info
        Device D8:8F:76:51:A7:87 (public)
                Alias: iPhone
                Class: 0x007a020c
                Icon: phone
                Paired: yes
                Trusted: no
                Blocked: no
                Connected: yes
                LegacyPairing: no
                UUID: Vendor specific           (00000000-deca-fade-deca-deafdecacafe)
                UUID: Service Discovery Serve.. (00001000-0000-1000-8000-00805f9b34fb)
                UUID: Audio Source              (0000110a-0000-1000-8000-00805f9b34fb)
                UUID: A/V Remote Control Target (0000110c-0000-1000-8000-00805f9b34fb)
                UUID: Advanced Audio Distribu.. (0000110d-0000-1000-8000-00805f9b34fb)
                UUID: A/V Remote Control        (0000110e-0000-1000-8000-00805f9b34fb)
                UUID: NAP                       (00001116-0000-1000-8000-00805f9b34fb)
                UUID: Handsfree Audio Gateway   (0000111f-0000-1000-8000-00805f9b34fb)
                UUID: Phonebook Access Server   (0000112f-0000-1000-8000-00805f9b34fb)
                UUID: Message Access Server     (00001132-0000-1000-8000-00805f9b34fb)
                UUID: PnP Information           (00001200-0000-1000-8000-00805f9b34fb)
                UUID: Generic Access Profile    (00001800-0000-1000-8000-00805f9b34fb)
                UUID: Generic Attribute Profile (00001801-0000-1000-8000-00805f9b34fb)
                UUID: Current Time Service      (00001805-0000-1000-8000-00805f9b34fb)
                UUID: Device Information        (0000180a-0000-1000-8000-00805f9b34fb)
                UUID: Battery Service           (0000180f-0000-1000-8000-00805f9b34fb)
                UUID: Vendor specific           (02030302-1d19-415f-86f2-22a2106a0a77)
                UUID: Vendor specific           (7905f431-b5ce-4e99-a40f-4b1e122d00d0)
                UUID: Vendor specific           (89d3502b-0f36-433a-8ef4-c502ad55f8dc)
                UUID: Vendor specific           (9fa480e0-4967-4542-9390-d343dc5d04ae)
                UUID: Vendor specific           (d0611e78-bbb4-4591-a5f8-487910ae4366)
                Modalias: bluetooth:v004Cp710Cd0E70
                Battery Percentage: 0x55 (85)
        [iPhone]# quit
        # cat /proc/bus/input/devices
        I: Bus=0019 Vendor=0001 Product=0001 Version=0100
        N: Name="1c22800.lradc"
        P: Phys=sun4i_lradc/input0
        S: Sysfs=/devices/platform/soc/1c22800.lradc/input/input0
        U: Uniq=
        H: Handlers=kbd event0
        B: PROP=0
        B: EV=3
        B: KEY=3 0 0 0 0 0 0 0 c0000 0 0 0
        I: Bus=0019 Vendor=0000 Product=0000 Version=0000
        N: Name="rotary@0"
        P: Phys=
        S: Sysfs=/devices/platform/rotary@0/input/input1
        U: Uniq=
        H: Handlers=event1
        B: PROP=0
        B: EV=5
        B: REL=1
        I: Bus=0018 Vendor=0000 Product=0000 Version=0000
        N: Name="ns2009_ts"
        P: Phys=input/ts
        S: Sysfs=/devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input2
        U: Uniq=
        H: Handlers=event2
        B: PROP=0
        B: EV=b
        B: KEY=400 0 0 0 0 0 0 0 0 0 0
        B: ABS=3
        I: Bus=0005 Vendor=004c Product=710c Version=0e70
        N: Name="iPhone (AVRCP)"
        P: Phys=34:20:03:aa:a3:7e
        S: Sysfs=/devices/virtual/input/input5
        U: Uniq=
        H: Handlers=kbd event3
        B: PROP=0
        B: EV=100007
        B: KEY=2fc800 1452 0 0 0 0 10300 49e8 c00 e1680 f f8100000 10000ffc
        B: REL=0
12. 通过AVRCP来控制手机上一曲,下一曲等 https://git.kernel.org/pub/scm/bluetooth/bluez.git/tree/doc/media-api.txt
    `注意这里的蓝牙地址是你手机的,不是蓝牙模块的,因为要控制的是你的手机进行一一曲,下一曲的,地址不对会提示错误,就是这个原因,另外我测试除了不能调节音量外,其它的都能控制,不知道为什么?`
        Error org.freedesktop.DBus.Error.UnknownObject: Method "Previous" with signature "" on interface "org.bluez.MediaControl1" doesn't exist
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.Pause
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.Play
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.Previous
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.Next
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.VolumeUp
        # dbus-send --system --print-reply --dest=org.bluez /org/bluez/hci0/dev_D8_8F_76_51_A7_87 org.bluez.MediaControl1.VolumeDown
        以下返回结果,可以看到"org.bluez.MediaControl1"已经注册了,但是提示已废弃,新的方法是"org.bluez.MediaPlay1",但是我这里用不了
        <node>
            <interface name="org.freedesktop.DBus.Introspectable">
                <method name="Introspect">
                    <arg name="xml" type="s" direction="out"/>
                </method>
            </interface>
            <interface name="org.bluez.Device1">
                <method name="Disconnect"></method>
                <method name="Connect"></method>
                <method name="ConnectProfile">
                    <arg name="UUID" type="s" direction="in"/>
                </method>
                <method name="DisconnectProfile">
                </method>
                <method name="Pair"></method>
                <method name="CancelPairing"></method>
                <property name="Address" type="s" access="read"></property>
                <property name="AddressType" type="s" access="read"></property>
                <property name="Name" type="s" access="read"></property>
                <property name="Alias" type="s" access="readwrite"></property>
                <property name="Class" type="u" access="read"></property>
                <property name="Appearance" type="q" access="read"></property>
                <property name="Icon" type="s" access="read"></property>
                <property name="Paired" type="b" access="read"></property>
                <property name="Trusted" type="b" access="readwrite"></property>
                <property name="Blocked" type="b" access="readwrite"></property>
                <property name="LegacyPairing" type="b" access="read"></property>
                <property name="RSSI" type="n" access="read"></property>
                <property name="Connected" type="b" access="read"></property>
                <property name="UUIDs" type="as" access="read"></property>
                <property name="Modalias" type="s" access="read"></property>
                <property name="Adapter" type="o" access="read"></property>
                <property name="ManufacturerData" type="a{qv}" access="read"></property>
                <property name="ServiceData" type="a{sv}" access="read"></property>
                <property name="TxPower" type="n" access="read"></property>
                <property name="ServicesResolved" type="b" access="read"></property>
                <property name="WakeAllowed" type="b" access="readwrite"></property>
            </interface>
            <interface name="org.freedesktop.DBus.Properties">
                <method name="Get">
                    <arg name="interface" type="s" direction="in"/>
                    <arg name="name" type="s" direction="in"/>
                    <arg name="value" type="v" direction="out"/>
                </method>
                <method name="Set">
                    <arg name="value" type="v" direction="in"/>
                </method>
                <method name="GetAll">
                    <arg name="properties" type="a{sv}" direction="out"/>
                </method>
                <signal name="PropertiesChanged">
                    <arg name="interface" type="s"/>
                    <arg name="changed_properties" type="a{sv}"/>
                    <arg name="invalidated_properties" type="as"/>
                </signal>
            </interface>
            <interface name="org.bluez.Network1">
                    <arg name="uuid" type="s" direction="in"/>
                    <arg name="interface" type="s" direction="out"/>
                </method>
                <property name="Interface" type="s" access="read"></property>
                <property name="UUID" type="s" access="read"></property>
            </interface>
            <interface name="org.bluez.MediaControl1">
                <method name="Play">
                    <annotation name="org.freedesktop.DBus.Deprecated" value="true"/>
                </method>
                <method name="Pause">
                </method>
                <method name="Stop">
                </method>
                <method name="Next">
                </method>
                <method name="Previous">
                </method>
                <method name="VolumeUp">
                </method>
                <method name="VolumeDown">
                </method>
                <method name="FastForward">
                </method>
                <method name="Rewind">
                </method>
                <property name="Player" type="o" access="read"></property>
            </interface>
            <interface name="org.bluez.Battery1">
                <property name="Percentage" type="y" access="read"></property>
            </interface>
            <node name="fd1"/>
            <node name="player2"/>
            <node name="sep1"/>
            <node name="sep2"/>
            <node name="sep3"/>
            <node name="sep4"/>
            <node name="sep5"/>
            <node name="sep6"/>
            <node name="service0006"/>
            <node name="service000a"/>
            <node name="service000f"/>
            <node name="service0014"/>
            <node name="service0018"/>
            <node name="service001e"/>
            <node name="service0023"/>
            <node name="service002d"/>
        </node>"
13. 另外在蓝牙连接成功时会在/dev/input/目录下注册一个event3
        U: Uniq=
        B: PROP=0
        B: EV=100007
        B: REL=0
        我偿试过使用sendevent 去操作/dev/input/event3 但是没有任何反应,不知道能不能这样操作?
        # ./sendevent /dev/input/event3 1 116 1
        # ./sendevent /dev/input/event3 0 0 0
        # ./sendevent /dev/input/event3 1 114 1
14. 至此,BLUETOOTH,DLNA,AIRPLAYER都可以通过Alsa声卡一起同时播放了
最近编辑记录 xfdr0805 (2021-07-28 13:05:08)
#1 2021-07-28 20:58:13
已发帖子: 636
Re: 分享在V3S RTL8723DS 上调试蓝牙音频的一点经验
感谢分享
#2 2021-07-29 09:58:50
sblpp
已发帖子: 164
  • 不通过:与技术无关
楼主 #3 2021-07-30 09:50:37
xfdr0805
已发帖子: 328
蓝牙连接成功后,自动生成了一个event3  通过这个为什么不能控制手机呢?还是说我的手机变成了一个输入设备,按手机音量加减 也没事件输出啊?
# evtest /dev/input/event3
Input driver version is 1.0.1
Input device ID: bus 0x5 vendor 0x4c product 0x710c version 0xe70
Input device name: "iPhone (AVRCP)"
Supported events:
  Event type 0 (EV_SYN)
  Event type 1 (EV_KEY)
    Event code 2 (KEY_1)
    Event code 3 (KEY_2)
    Event code 4 (KEY_3)
    Event code 5 (KEY_4)
    Event code 6 (KEY_5)
    Event code 7 (KEY_6)
    Event code 8 (KEY_7)
    Event code 9 (KEY_8)
    Event code 10 (KEY_9)
    Event code 11 (KEY_0)
    Event code 28 (KEY_ENTER)
    Event code 52 (KEY_DOT)
    Event code 59 (KEY_F1)
    Event code 60 (KEY_F2)
    Event code 61 (KEY_F3)
    Event code 62 (KEY_F4)
    Event code 63 (KEY_F5)
    Event code 64 (KEY_F6)
    Event code 65 (KEY_F7)
    Event code 66 (KEY_F8)
    Event code 67 (KEY_F9)
    Event code 103 (KEY_UP)
    Event code 105 (KEY_LEFT)
    Event code 106 (KEY_RIGHT)
    Event code 108 (KEY_DOWN)
    Event code 113 (KEY_MUTE)
    Event code 114 (KEY_VOLUMEDOWN)
    Event code 115 (KEY_VOLUMEUP)
    Event code 138 (KEY_HELP)
    Event code 139 (KEY_MENU)
    Event code 163 (KEY_NEXTSONG)
    Event code 165 (KEY_PREVIOUSSONG)
    Event code 166 (KEY_STOPCD)
    Event code 167 (KEY_RECORD)
    Event code 168 (KEY_REWIND)
    Event code 171 (KEY_CONFIG)
    Event code 174 (KEY_EXIT)
    Event code 200 (KEY_PLAYCD)
    Event code 201 (KEY_PAUSECD)
    Event code 208 (KEY_FASTFORWARD)
    Event code 353 (KEY_SELECT)
    Event code 356 (KEY_POWER2)
    Event code 358 (KEY_INFO)
    Event code 362 (KEY_PROGRAM)
    Event code 364 (KEY_FAVORITES)
    Event code 395 (KEY_LIST)
    Event code 398 (KEY_RED)
    Event code 399 (KEY_GREEN)
    Event code 400 (KEY_YELLOW)
    Event code 401 (KEY_BLUE)
    Event code 402 (KEY_CHANNELUP)
    Event code 403 (KEY_CHANNELDOWN)
    Event code 405 (KEY_LAST)
  Event type 2 (EV_REL)
Key repeat handling:
  Repeat type 20 (EV_REP)
    Repeat code 0 (REP_DELAY)
      Value    300
    Repeat code 1 (REP_PERIOD)
      Value     33
Properties:
Testing ... (interrupt to exit)
#4 2021-07-31 15:34:06
TeveT
已发帖子: 149
无法用dbus 发送事件去上下曲 ,应当是bluealsa 的插件没打开
楼主 #5 2021-08-02 11:41:00
xfdr0805
已发帖子: 328
TeveT 说:
可以使用dbus发送事件,只是不太清楚,在蓝牙连接后自动生成的那个event是干什么的,看起来像个键盘
#6 2022-03-22 17:19:58
小杨
楼主,您好,请问一下您是自己设计的开发板吗?我现在是自己设计了开发板,主控是V3S,wifi/蓝牙模块用的也是 RTL8723DS,主线是linux3.14.y 。但是在ifconfig wlan0 up时候,串口一直循环发送 下面信息
[  155.448728] RTW: -871x_drv - drv_open, bup=1
[  155.453102] RTW: cfg80211_rtw_set_power_mgmt(wlan0) enabled:1, timeout:-1
[  155.459979] RTW: rtw_ndev_notifier_call(wlan0) state:1
[  155.465329] RTW: skip abnormal rx packet(5)
[  155.469638] RTW: skip abnormal rx packet(5)
[  155.473878] RTW: skip abnormal rx packet(5)
[  155.478142] RTW: skip abnormal rx packet(5)
[  155.482375] RTW: skip abnormal rx packet(5)
请问一下楼主,您有遇到这样的情况吗?
#7 2022-04-01 20:15:02
小杨
楼主,您好,您可以分享一下您的RTL8723DS这个天线的原理图和PCB布局吗?借鉴一下您的天线布局布线,麻烦楼主了,谢谢。
PS:QQ(2985438804)
楼主 #8 2022-04-11 18:10:48
xfdr0805
已发帖子: 328
小杨 说:
PS:QQ(2985438804)
这个是Kicad里系统自带的天线 分左和右2种
#9 2024-01-18 19:15:00
joy95611
感谢分享, 最近正在折腾aic的蓝牙。想加录音的功能
#10 2024-01-23 09:17:02
wl989898
已发帖子: 38
github.com我这边为什么打不开了
#11 2024-04-24 17:23:21
8===D
已发帖子: 34
joy95611 说:
博主搞没搞过RTL的蓝牙
#13 2025-02-14 16:26:13
Ashuai
博主您好,我在licheepi 的主线linux 5.2.y 和4.10.y中编译 RTL8723DS 的wifi源码,加载驱动的过程中出现了错误,导致不能够正常显示wlan0 网卡。我的驱动版本是RTL8723DS_WiFi_linux_v5.13.5-91-gf00b2a755_COEX20220930-4541.20241203 。这里我贴一下我的5.2.y版本的启动过程。我的疑惑:1、是不是我的驱动版本不能适配linux内核的版本?2、看到您用的5.10内核,您的驱动版本是多少?您能否分享一下您的编译经验?
# insmod cfg80211.ko
[   30.093469] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   30.119448] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
# insmod 8723ds.ko
[   40.376919] RTW: module init start
[   40.384028] RTW: rtl8723ds v5.13.5-91-gf00b2a755.20241203_COEX20220930-4541
[   40.394595] RTW: build time: Feb 14 2025 15:06:41
[   40.402832] RTW: rtl8723ds BT-Coex version = COEX20220930-4541
[   40.412207] RTW: rtw_inetaddr_notifier_register
[   40.421393] RTW: == SDIO Card Info ==
[   40.428513] RTW:   card: (ptrval)
[   40.435103] RTW:   clock: 50000000 Hz
[   40.442061] RTW:   timing spec: sd high-speed
[   40.449690] RTW:   sd3_bus_mode: FALSE
[   40.456628] RTW:   func num: 1
[   40.462846] RTW:   func1: (ptrval) (*)
[   40.469718] RTW: ================
[   40.476037] RTW: CHIP TYPE: RTL8723D
[   40.483747] RTW: Chip Version Info: CHIP_8723D_T4_1T1R_RomVer(0)
[   40.495034] RTW: SetHwReg: bMacPwrCtrlOn=1
[   40.503008] RTW: sdio_power_on_check: val_mix:0x0000063f, res:0x0000063f
[   40.512851] RTW: sdio_power_on_check: 0x100 the result of cmd52 and cmd53 is the same.
[   40.524385] RTW: sdio_power_on_check: 0x1B8 test Pass.
[   40.532701] RTW: _InitPowerOn_8723DS: Normal Mode
[   40.540867] RTW: _InitPowerOn_8723DS: SPS Mode
[   40.548398] RTW: ReadAdapterInfo8723DS, 0x4e=0x42
[   40.555942] RTW: EEPROM type is E-FUSE
[   40.563094] RTW: hal_EfuseSwitchToBank: Efuse switch bank to 0
[   40.588390] RTW: hal_ReadEFuse_WiFi: data end at address=0xa9
[   40.596927] RTW: HW EFUSE
[   40.602279] RTW: 0x000: 29 81 40 7C  E1 88 07 00  A0 04 EC 35  12 C0 A2 D8
[   40.612155] RTW: 0x010: 25 25 25 25  25 25 26 26  26 26 26 00  FF FF FF FF
[   40.621945] RTW: 0x020: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.631668] RTW: 0x030: FF FF FF FF  FF FF FF FF  FF FF 22 22  22 22 22 22
[   40.641311] RTW: 0x040: 21 21 21 21  21 02 FF FF  FF FF FF FF  FF FF FF FF
[   40.650908] RTW: 0x050: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.660417] RTW: 0x060: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.669829] RTW: 0x070: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.679163] RTW: 0x080: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.688436] RTW: 0x090: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.697671] RTW: 0x0A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.706887] RTW: 0x0B0: FF FF FF FF  FF FF FF FF  20 35 1E 00  00 00 FF FF
[   40.716087] RTW: 0x0C0: FF 29 20 11  00 00 00 FF  00 FF 11 FF  FF FF FF FF
[   40.725284] RTW: 0x0D0: 3E 10 01 12  23 FF FF FF  20 04 4C 02  23 D7 21 02
[   40.734510] RTW: 0x0E0: 0C 00 22 04  00 08 00 32  FF 21 02 0C  00 22 2A 01
[   40.743787] RTW: 0x0F0: 01 00 00 00  00 00 00 00  00 00 00 00  02 00 FF FF
[   40.753075] RTW: 0x100: 00 00 00 00  00 00 00 00  00 00 00 00  00 00 00 00
[   40.762347] RTW: 0x110: 00 EB 00 6E  01 00 00 00  00 FF 78 22  88 BF C9 32
[   40.771579] RTW: 0x120: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.780797] RTW: 0x130: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.789915] RTW: 0x140: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.798927] RTW: 0x150: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.807855] RTW: 0x160: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.816735] RTW: 0x170: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.825601] RTW: 0x180: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.834403] RTW: 0x190: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.843150] RTW: 0x1A0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.851809] RTW: 0x1B0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.860389] RTW: 0x1C0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.868888] RTW: 0x1D0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.877282] RTW: 0x1E0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.885612] RTW: 0x1F0: FF FF FF FF  FF FF FF FF  FF FF FF FF  FF FF FF FF
[   40.896295] RTW: Hal_EfuseParseBTCoexistInfo_8723D: Enable BT-coex, ant_num=1
[   40.904879] RTW: hal_com_config_channel_plan chplan:0x20
[   40.911564] RTW: Hal_EfuseParseVoltage_8723D hwinfo[EEPROM_Voltage_ADDR_8723D] =a0
[   40.920606] RTW: Hal_EfuseParseVoltage_8723D pHalData->adjuseVoltageVal =a
[   40.929804] RTW: kfree Pwr Trim flag:1
[   40.935152] RTW: bb_gain(S1):1
[   40.939843] RTW: bb_gain(S0):0
[   40.945110] RTW: rtl8723d_FirmwareDownload fw: FW_NIC, size: 30830
[   40.953129] RTW: rtl8723d_FirmwareDownload: fw_ver=33 fw_subver=0004 sig=0x23d1, Month=12, Date=17, Hour=11, Minute=44
[   40.967526] RTW: rtl8723d_FirmwareDownload(): Shift for fw header!
[   40.976548] RTW: rtl8723d_FirmwareDownload by IO write!
[   41.172302] RTW: polling_fwdl_chksum: Checksum report OK! (1, 0ms), REG_MCUFWDL:0x07070305
[   41.182762] RTW: rtl8723d_FirmwareDownload: download FW count:1
[   41.191676] RTW: _8051Reset8723: Finish
[   41.210060] RTW: _FWFreeToGo: Polling FW ready OK! (231, 20ms), REG_MCUFWDL:0x070703c6
[   41.220396] RTW: rtl8723d_FirmwareDownload success. write_fw:1, 250ms
[   41.229747] RTW:  <=== rtl8723d_FirmwareDownload()
[   41.237377] RTW: hal_read_mac_hidden_rpt OK! (1, 0ms), fwdl:1, id:0x19
[   41.247502] RTW: SetHwReg: bMacPwrCtrlOn=0
[   41.254745] RTW: rtw_hal_read_chip_info in 760 ms
[   41.262259] RTW: [RF_PATH] ver_id.RF_TYPE:RF_1T1R
[   41.269785] RTW: [RF_PATH] HALSPEC's rf_reg_trx_path_bmp:0x11, rf_reg_path_avail_num:1, max_tx_cnt:1
[   41.284865] RTW: [RF_PATH] PG's trx_path_bmp:0x00, max_tx_cnt:0
[   41.293997] RTW: [RF_PATH] Registry's trx_path_bmp:0x00, tx_path_lmt:0, rx_path_lmt:0
[   41.305184] RTW: [RF_PATH] HALDATA's trx_path_bmp:0x11, max_tx_cnt:1
[   41.315004] RTW: [RF_PATH] HALDATA's rf_type:RF_1T1R, NumTotalRFPath:1
[   41.325038] RTW: rtw_hal_rfpath_init trx_path_bmp:0x11(RF_1T1R), NumTotalRFPath:1, max_tx_cnt:1
[   41.337438] RTW: [TRX_Nss] HALSPEC - tx_nss:1, rx_nss:1
[   41.346309] RTW: [TRX_Nss] Registry - tx_nss:0, rx_nss:0
[   41.355214] RTW: [TRX_Nss] HALDATA - tx_nss:1, rx_nss:1
[   41.363965] RTW: rtw_hal_trxnss_init tx_nss:1, rx_nss:1
[   41.372691] RTW: txpath=0x1, rxpath=0x1
[   41.379961] RTW: txpath_1ss:0x1, num:1
[   41.389739] RTW: init_mlme_default_rate_set: support CCK
[   41.398732] RTW: init_mlme_default_rate_set: support OFDM
[   41.409385] RTW: rtw_alloc_macid((null)) if1, mac_addr:ff:ff:ff:ff:ff:ff macid:1
[   41.420539] RTW: rtw_init_pwrctrl_priv: IPS_mode=1, LPS_mode=2, LPS_level=1
[   41.431619] RTW: IQK FW offload:disable
[   41.438951] RTW: Init_ODM_ComInfo_8723d(): Fv=0 Cv=3
[   41.447389] RTW: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[   41.463369] RTW: phy_ConfigBBWithPgParaFile(): No File PHY_REG_PG.txt, Load from HWImg Array!
[   41.475563] RTW: default power by rate loaded
[   41.483462] RTW: phy_txpwr_by_rate_chk_for_path_dup duplicate 2.4G [A] to [B]
[   41.494187] RTW: init_channel_set_from_rtk_priv((null)) ChannelPlan ID:0x20, ch num:13
[   41.506116] RTW: rtw_macaddr_cfg mac addr:78:22:88:bf:c9:32
[   41.516256] RTW: bDriverStopped:True, bSurpriseRemoved:False, bup:0, hw_init_completed:0
[   41.528226] RTW: rtw_cfg80211_init_wiphy_band:rf_type=0
[   41.537164] RTW: [HT] HAL Support STBC = 0x01
[   41.545235] RTW: rtw_wiphy_alloc(phy0)
[   41.552648] RTW: rtw_wdev_alloc(padapter=(ptrval))
[   41.560955] RTW: rtw_wiphy_register(phy0)
[   41.568376] RTW: Register RTW cfg80211 vendor cmd(0x67) interface
[   41.577890] ------------[ cut here ]------------
[   41.586044] WARNING: CPU: 0 PID: 187 at net/wireless/core.c:868 wiphy_register+0x900/0xbc4 [cfg80211]
[   41.602293] Modules linked in: 8723ds(+) cfg80211
[   41.610497] CPU: 0 PID: 187 Comm: insmod Not tainted 5.2.0-licheepi-zero #2
[   41.621028] Hardware name: Allwinner sun8i Family
[   41.629337] [<c010ed14>] (unwind_backtrace) from [<c010b72c>] (show_stack+0x10/0x14)
[   41.640835] [<c010b72c>] (show_stack) from [<c06b2030>] (dump_stack+0x84/0x98)
[   41.651844] [<c06b2030>] (dump_stack) from [<c011db98>] (__warn+0xfc/0x114)
[   41.662629] [<c011db98>] (__warn) from [<c011dcc4>] (warn_slowpath_null+0x40/0x48)
[   41.674152] [<c011dcc4>] (warn_slowpath_null) from [<bf0013f4>] (wiphy_register+0x900/0xbc4 [cfg80211])
[   41.692921] [<bf0013f4>] (wiphy_register [cfg80211]) from [<bf0e1b4c>] (rtw_wiphy_register+0x38/0x74 [8723ds])
[   41.713808] [<bf0e1b4c>] (rtw_wiphy_register [8723ds]) from [<bf0e202c>] (rtw_cfg80211_dev_res_register+0xc/0x18 [8723ds])
[   41.736084] [<bf0e202c>] (rtw_cfg80211_dev_res_register [8723ds]) from [<bf0bd030>] (rtw_os_ndevs_register+0x14/0x150 [8723ds])
[   41.758901] [<bf0bd030>] (rtw_os_ndevs_register [8723ds]) from [<bf0bd1c0>] (rtw_os_ndevs_init+0x24/0x3c [8723ds])
[   41.780721] [<bf0bd1c0>] (rtw_os_ndevs_init [8723ds]) from [<bf0bf9f8>] (rtw_drv_init+0x8c/0x138 [8723ds])
[   41.800753] [<bf0bf9f8>] (rtw_drv_init [8723ds]) from [<c054ca24>] (sdio_bus_probe+0x100/0x114)
[   41.814180] [<c054ca24>] (sdio_bus_probe) from [<c0436484>] (really_probe+0x1dc/0x2c8)
[   41.826765] [<c0436484>] (really_probe) from [<c04366f0>] (driver_probe_device+0x60/0x160)
[   41.839755] [<c04366f0>] (driver_probe_device) from [<c0436998>] (device_driver_attach+0x58/0x60)
[   41.853439] [<c0436998>] (device_driver_attach) from [<c0436a20>] (__driver_attach+0x80/0xbc)
[   41.866859] [<c0436a20>] (__driver_attach) from [<c0434844>] (bus_for_each_dev+0x68/0xb4)
[   41.880001] [<c0434844>] (bus_for_each_dev) from [<c04357d4>] (bus_add_driver+0xec/0x1e0)
[   41.893175] [<c04357d4>] (bus_add_driver) from [<c0437248>] (driver_register+0x78/0x10c)
[   41.907596] [<c0437248>] (driver_register) from [<bf21f11c>] (rtw_drv_entry+0x11c/0x1000 [8723ds])
[   41.927751] [<bf21f11c>] (rtw_drv_entry [8723ds]) from [<c01026fc>] (do_one_initcall+0x54/0x1b4)
[   41.941719] [<c01026fc>] (do_one_initcall) from [<c019d82c>] (do_init_module+0x5c/0x20c)
[   41.954938] [<c019d82c>] (do_init_module) from [<c019ca20>] (load_module+0x1e08/0x22a4)
[   41.968057] [<c019ca20>] (load_module) from [<c019d108>] (sys_finit_module+0xc8/0xd8)
[   41.980975] [<c019d108>] (sys_finit_module) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[   41.994248] Exception stack(0xc31e3fa8 to 0xc31e3ff0)
[   42.004406] 3fa0:                   000c3008 bea88e7b 00000003 000c3008 00000000 bea88e7b
[   42.017808] 3fc0: 000c3008 bea88e7b 00000002 0000017b bea88e7b 00000000 b6fb0000 00000000
[   42.031141] 3fe0: bea88bc0 bea88bb0 00026408 b6e44a42
[   42.041345] ---[ end trace daecb6049275bd49 ]---
[   42.050943] ------------[ cut here ]------------
[   42.061718] WARNING: CPU: 0 PID: 187 at drivers/net/wireless/realtek/rtl8723ds/os_dep/linux/os_intfs.c:3752 rtw_os_ndevs_register+0x4c/0x150 [8723ds]
[   42.084914] Modules linked in: 8723ds(+) cfg80211
[   42.094458] CPU: 0 PID: 187 Comm: insmod Tainted: G        W         5.2.0-licheepi-zero #2
[   42.107548] Hardware name: Allwinner sun8i Family
[   42.116870] [<c010ed14>] (unwind_backtrace) from [<c010b72c>] (show_stack+0x10/0x14)
[   42.129234] [<c010b72c>] (show_stack) from [<c06b2030>] (dump_stack+0x84/0x98)
[   42.141010] [<c06b2030>] (dump_stack) from [<c011db98>] (__warn+0xfc/0x114)
[   42.152406] [<c011db98>] (__warn) from [<c011dcc4>] (warn_slowpath_null+0x40/0x48)
[   42.165696] [<c011dcc4>] (warn_slowpath_null) from [<bf0bd068>] (rtw_os_ndevs_register+0x4c/0x150 [8723ds])
[   42.186805] [<bf0bd068>] (rtw_os_ndevs_register [8723ds]) from [<bf0bd1c0>] (rtw_os_ndevs_init+0x24/0x3c [8723ds])
[   42.208729] [<bf0bd1c0>] (rtw_os_ndevs_init [8723ds]) from [<bf0bf9f8>] (rtw_drv_init+0x8c/0x138 [8723ds])
[   42.228840] [<bf0bf9f8>] (rtw_drv_init [8723ds]) from [<c054ca24>] (sdio_bus_probe+0x100/0x114)
[   42.242303] [<c054ca24>] (sdio_bus_probe) from [<c0436484>] (really_probe+0x1dc/0x2c8)
[   42.254921] [<c0436484>] (really_probe) from [<c04366f0>] (driver_probe_device+0x60/0x160)
[   42.267844] [<c04366f0>] (driver_probe_device) from [<c0436998>] (device_driver_attach+0x58/0x60)
[   42.281372] [<c0436998>] (device_driver_attach) from [<c0436a20>] (__driver_attach+0x80/0xbc)
[   42.294511] [<c0436a20>] (__driver_attach) from [<c0434844>] (bus_for_each_dev+0x68/0xb4)
[   42.307309] [<c0434844>] (bus_for_each_dev) from [<c04357d4>] (bus_add_driver+0xec/0x1e0)
[   42.320122] [<c04357d4>] (bus_add_driver) from [<c0437248>] (driver_register+0x78/0x10c)
[   42.334141] [<c0437248>] (driver_register) from [<bf21f11c>] (rtw_drv_entry+0x11c/0x1000 [8723ds])
[   42.353585] [<bf21f11c>] (rtw_drv_entry [8723ds]) from [<c01026fc>] (do_one_initcall+0x54/0x1b4)
[   42.367172] [<c01026fc>] (do_one_initcall) from [<c019d82c>] (do_init_module+0x5c/0x20c)
[   42.380022] [<c019d82c>] (do_init_module) from [<c019ca20>] (load_module+0x1e08/0x22a4)
[   42.392811] [<c019ca20>] (load_module) from [<c019d108>] (sys_finit_module+0xc8/0xd8)
[   42.405480] [<c019d108>] (sys_finit_module) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[   42.418460] Exception stack(0xc31e3fa8 to 0xc31e3ff0)
[   42.428207] 3fa0:                   000c3008 bea88e7b 00000003 000c3008 00000000 bea88e7b
[   42.441203] 3fc0: 000c3008 bea88e7b 00000002 0000017b bea88e7b 00000000 b6fb0000 00000000
[   42.454179] 3fe0: bea88bc0 bea88bb0 00026408 b6e44a42
[   42.464093] ---[ end trace daecb6049275bd4a ]---
[   42.473447] RTW: rtw_wdev_free(wdev=(ptrval))
[   42.482462] RTW: rtw_wiphy_free(phy0)
[   42.490761] RTW: rtw_dev_unload: bup==_FALSE
[   42.499567] RTW: +r871xu_dev_remove, hw_init_completed=0
[   42.514944] RTW: module init ret=0
# [   42.974870] random: crng init done
# ifconfig -a
          collisions:0 txqueuelen:1000
万分期待您的回复 smile
楼主 #14 2025-03-14 10:05:14
xfdr0805
已发帖子: 328
@Ashuai
你是咋编译的 ?
我记得是把驱动放在内核驱动目录编译是没有问题的
单独编译是编译不过去的
最近编辑记录 xfdr0805 (2025-03-14 10:05:37)
