# ./tinymix contents
Number of controls: 13
ctl type num name value
0 INT 1 DAC Playback Volume 63 (range 0->63)
1 INT 1 Headphone Playback Volume 0 (range 0->63)
2 BOOL 2 Headphone Playback Switch Off, Off
3 INT 1 Mic1 Playback Volume 3 (range 0->7)
4 INT 1 Mic1 Boost Volume 4 (range 0->7)
5 INT 1 ADC Gain Capture Volume 3 (range 0->7)
6 BOOL 2 DAC Playback Switch Off, Off
7 BOOL 2 DAC Reversed Playback Switch Off, Off
8 BOOL 2 Mic1 Playback Switch Off, Off
9 BOOL 2 Mixer Capture Switch Off, Off
10 BOOL 2 Mixer Reversed Capture Switch Off, Off
11 BOOL 2 Mic1 Capture Switch Off, Off
12 ENUM 2 Headphone Source Playback Route , DACMixer, , DACMixer
# tinymix set1 1
unknown command 'set1' (see --help)
# tinymix set 11
Segmentation fault
# tinymix set 1 1
Error: 2 values given, but control only takes 1
# tinymix set 2 1
Segmentation fault
# tinymix set 1 1
# tinymix set 1 1
# tinymix set 1 1
不清楚是为什么
