楼主 # 2022-04-22 17:48:42
droptop
已发帖子: 23
D500N9325V1 LCD module with Linux on Lichee Pi Nano
Hi everyone,
Has anyone been able to get this LCD module to run on a Linux system? I trying to integrate it into Linux 4.5.
I've created a new panel_desc in panel-simple.c driver and added timings information from the datasheet. All I get is a screen with vertical lines of multiple colors. I suspect I've entered some of the timing data wrongly.
Attached are the module's datasheet, a diff of panel-simple.c showing my additions, and the screen output I'm getting. Any suggestions would be greatly appreciated.
Sincerely
D500N9325V1 SPEC.pdf
panel-simple.c.diff.txt
最近编辑记录 droptop (2022-04-22 17:50:58)
