楼主 # 2022-04-26 19:39:51
mhcsoft
求助: 有朋友在D1上点过双通道1920X1080的显示屏吗,改了如下配置一直没显示
下面是配置:
James 说:
&lcd0 {
    lcd_used            = <1>;
    lcd_driver_name     = "default_lcd";
    lcd_backlight       = <150>;
    lcd_if              = <3>;
    lcd_x               = <1920>;
    lcd_y               = <1080>;
    lcd_width           = <150>;
    lcd_height          = <94>;
    lcd_dclk_freq       = <150>;
    lcd_rb_swap            = <0>;
    lcd_pwm_used        = <1>;
    lcd_pwm_ch          = <0>;
    lcd_pwm_freq        = <50000>;
    lcd_pwm_pol         = <1>;
    lcd_pwm_max_limit   = <255>;
    lcd_hbp             = <20>;
    lcd_ht              = <2200>;
    lcd_hspw            = <10>;
    lcd_vbp             = <10>;
    lcd_vt              = <1125>;
    lcd_vspw            = <5>;
    lcd_lvds_if         = <1>;
    lcd_lvds_colordepth = <0>;
    lcd_lvds_mode       = <0>;
    lcd_frm             = <1>;
    lcd_io_phase        = <0x0000>;
    lcd_hv_clk_phase    = <0>;
    lcd_hv_sync_polarity = <0>;
    lcd_gamma_en        = <0>;
    lcd_bright_curve_en = <0>;
    lcd_cmap_en         = <0>;
    lcd_fsync_act_time  = <1000>;
    lcd_fsync_dis_time  = <1000>;
    deu_mode            = <0>;
    lcdgamma4iep        = <22>;
    smart_color         = <90>;
    pinctrl-0 = <&lvds0_pins_a>;
    pinctrl-1 = <&lvds0_pins_b>;
    lcd_bl_en = <&pio PD 20 GPIO_ACTIVE_HIGH>;
James 说:
lvds0_pins_b: lvds0@1 {
                pins  = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", \
                "PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
                function = "io_disabled";
                drive-strength = <30>;
                bias-disable;
            rgb24_pins_a: rgb24@0 {
                pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
                    "PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
                    "PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
                    "PD18", "PD19", "PD20", "PD21";
                function = "lcd0";
                bias-disable;
楼主 #1 2022-04-26 19:41:33
mhcsoft
Re: 求助: 有朋友在D1上点过双通道1920X1080的显示屏吗,改了如下配置一直没显示
lvds0_pins_a: lvds0@0 {
				function = "lvds0";
				bias-disable;
				bias-disable;
pin脚贴错了
#2 2022-04-26 20:39:45
已发帖子: 3,392
一根一根线对照 pdf 手册再测量一下,先排除硬件问题。
我前面驱动15寸屏,因为错了一根线位置不亮。
