楼主 # 2022-04-26 19:39:51
mhcsoft
求助: 有朋友在D1上点过双通道1920X1080的显示屏吗,改了如下配置一直没显示
下面是配置:
James wrote:
&lcd0 {
lcd_used = <1>;
lcd_driver_name = "default_lcd";
lcd_backlight = <150>;
lcd_if = <3>;
lcd_x = <1920>;
lcd_y = <1080>;
lcd_width = <150>;
lcd_height = <94>;
lcd_dclk_freq = <150>;
lcd_rb_swap = <0>;
lcd_pwm_used = <1>;
lcd_pwm_ch = <0>;
lcd_pwm_freq = <50000>;
lcd_pwm_pol = <1>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <20>;
lcd_ht = <2200>;
lcd_hspw = <10>;
lcd_vbp = <10>;
lcd_vt = <1125>;
lcd_vspw = <5>;
lcd_lvds_if = <1>;
lcd_lvds_colordepth = <0>;
lcd_lvds_mode = <0>;
lcd_frm = <1>;
lcd_io_phase = <0x0000>;
lcd_hv_clk_phase = <0>;
lcd_hv_sync_polarity = <0>;
lcd_gamma_en = <0>;
lcd_bright_curve_en = <0>;
lcd_cmap_en = <0>;
lcd_fsync_act_time = <1000>;
lcd_fsync_dis_time = <1000>;
deu_mode = <0>;
lcdgamma4iep = <22>;
smart_color = <90>;
pinctrl-0 = <&lvds0_pins_a>;
pinctrl-1 = <&lvds0_pins_b>;
lcd_bl_en = <&pio PD 20 GPIO_ACTIVE_HIGH>;
James wrote:
lvds0_pins_b: lvds0@1 {
pins = "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", "PD6", "PD7", "PD8", "PD9", \
"PD10", "PD11", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", "PD18", "PD19";
function = "io_disabled";
drive-strength = <30>;
bias-disable;
rgb24_pins_a: rgb24@0 {
pins = "PB2", "PB3", "PD0", "PD1", "PD2", "PD3", "PD4", "PD5", \
"PB4", "PB5", "PD6", "PD7", "PD8", "PD9", "PD10", "PD11", \
"PB6", "PB7", "PD12", "PD13", "PD14", "PD15", "PD16", "PD17", \
"PD18", "PD19", "PD20", "PD21";
function = "lcd0";
bias-disable;
楼主 #1 2022-04-26 19:41:33
mhcsoft
Re: 求助: 有朋友在D1上点过双通道1920X1080的显示屏吗,改了如下配置一直没显示
lvds0_pins_a: lvds0@0 {
				function = "lvds0";
				bias-disable;
				bias-disable;
pin脚贴错了
#2 2022-04-26 20:39:45
已发帖子: 3,408
一根一根线对照 pdf 手册再测量一下,先排除硬件问题。
我前面驱动15寸屏,因为错了一根线位置不亮。
