楼主 # 2022-05-05 14:15:15
dml1048147924
所在地: 江苏无锡
已发帖子: 119
v3s sd卡启动 , 有报错
[    4.238313] EXT4-fs (mmcblk0p2): recovery complete
[    4.243141] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    4.251405] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    4.258995] devtmpfs: error mounting -2
[    4.264136] Freeing unused kernel memory: 1024K
[    4.269067] Kernel panic - not syncing: No working init found.  Try passing init= option to kernel. See Linux Documentation/admin-guide/init.rst for guidance.
[    4.283237] Rebooting in 5 seconds..
U-Boot SPL 2018.07 (May 10 2020 - 20:16:13 -0700)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2018.07 (May 10 2020 - 20:16:13 -0700) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
Loading Environment from FAT... *** Warning - bad CRC, using default environment
Failed (-5)
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
Net:   No ethernet found.
No controllers found
** Unable to read file logo.bin **
There is no valid bmp file at the given address
3563296 bytes read in 162 ms (21 MiB/s)
13463 bytes read in 2 ms (6.4 MiB/s)
   Loading Device Tree to 42df9000, end 42dff496 ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.18.8-licheepi-zero (v3s@ubuntu) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #38 SMP Wed Apr 27 15:58:23 CST 2022
[    0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=10c5387d
[    0.000000] CPU: div instructions available: patching division code
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: Lichee Pi Zero with Dock
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] random: get_random_bytes called from 0xc0800920 with crng_init=0
[    0.000000] percpu: Embedded 16 pages/cpu @(ptrval) s34444 r8192 d22900 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15883
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 54612K/64036K available (5120K kernel code, 280K rwdata, 1368K rodata, 1024K init, 224K bss, 9424K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
#1 2022-05-05 15:49:16
已发帖子: 3,389
Re: v3s sd卡启动 , 有报错
检查您的 bootargs 参数 init= 是啥
楼主 #2 2022-05-06 10:39:47
dml1048147924
所在地: 江苏无锡
已发帖子: 119
Re: v3s sd卡启动 , 有报错
刚开始报 的警告: warning bad CRC  是不是也有问题呀
#3 2022-05-08 20:41:47
8888888
Re: v3s sd卡启动 , 有报错
  • 不通过:其他
