楼主 # 2022-05-15 21:46:26
liefyuan
已发帖子: 69
全志V3s (板子是mangopi v3s)主线linux5.2.0加载ESP8089wifi .ko报错:
硬件:mangopi v3s
linux kernel: linux5.2.0
原理图:
设备树:使用的licheepi的
 * Copyright (C) 2016 Icenowy Zheng <icenowy@aosc.xyz>
 * This file is dual-licensed: you can use it either under the terms
 * of the GPL or the X11 license, at your option. Note that this dual
 * licensing only applies to this file, and not this project as a
 * whole.
 *  a) This file is free software; you can redistribute it and/or
 *     modify it under the terms of the GNU General Public License as
 *     published by the Free Software Foundation; either version 2 of the
 *     License, or (at your option) any later version.
 *     This file is distributed in the hope that it will be useful,
 *     but WITHOUT ANY WARRANTY; without even the implied warranty of
 *     MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
 *     GNU General Public License for more details.
 * Or, alternatively,
 *  b) Permission is hereby granted, free of charge, to any person
 *     obtaining a copy of this software and associated documentation
 *     files (the "Software"), to deal in the Software without
 *     restriction, including without limitation the rights to use,
 *     copy, modify, merge, publish, distribute, sublicense, and/or
 *     sell copies of the Software, and to permit persons to whom the
 *     Software is furnished to do so, subject to the following
 *     conditions:
 *     The above copyright notice and this permission notice shall be
 *     included in all copies or substantial portions of the Software.
 *     THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND,
 *     EXPRESS OR IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES
 *     OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
 *     NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT
 *     HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER LIABILITY,
 *     WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING
 *     FROM, OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR
 *     OTHER DEALINGS IN THE SOFTWARE.
#include "sun8i-v3s-licheepi-zero.dts"
	model = "Lichee Pi Zero with Dock";
	compatible = "licheepi,licheepi-zero-dock", "licheepi,licheepi-zero",
		     "allwinner,sun8i-v3s";
	aliases {
		ethernet0 = &emac;
	leds {
		/* The LEDs use PG0~2 pins, which conflict with MMC1 */
		status = "disabled";
&codec {
	allwinner,audio-routing =
		"Headphone", "HP",
		"Headphone", "HPCOM",
		"MIC1", "Mic",
		"Mic",  "HBIAS";
&emac {
	phy-handle = <&int_mii_phy>;
	phy-mode = "mii";
	allwinner,leds-active-low;
&mmc1 {
	broken-cd;
	bus-width = <4>;
	vmmc-supply = <&reg_vcc3v3>;
&lradc {
	vref-supply = <&reg_vcc3v0>;
	button-200 {
		label = "Volume Up";
		linux,code = <KEY_VOLUMEUP>;
		channel = <0>;
		voltage = <200000>;
	button-400 {
		label = "Volume Down";
		linux,code = <KEY_VOLUMEDOWN>;
		channel = <0>;
		voltage = <400000>;
	button-600 {
		label = "Select";
		linux,code = <KEY_SELECT>;
		channel = <0>;
		voltage = <600000>;
	button-800 {
		label = "Start";
		linux,code = <KEY_OK>;
		channel = <0>;
		voltage = <800000>;
&i2c0 {
	gt911: touchscreen@14 {
        	compatible = "goodix,gt911";
        	reg = <0x14>;
        	interrupt-parent = <&pio>;
        	interrupts = <1 1 IRQ_TYPE_EDGE_FALLING>; /* (PB1) */
        	pinctrl-names = "default";
        	irq-gpios = <&pio 1 1 GPIO_ACTIVE_HIGH>; /* (PB1) */
        	reset-gpios = <&pio 1 0 GPIO_ACTIVE_HIGH>; /* RST (PB0) */
        	/* touchscreen-swapped-x-y */
#include "sun8i-v3s.dtsi"
	model = "Lichee Pi Zero";
	compatible = "licheepi,licheepi-zero", "allwinner,sun8i-v3s";
	aliases {
		serial0 = &uart0;
	chosen {
	leds {
		compatible = "gpio-leds";
		blue_led {
			label = "licheepi:blue:usr";
			gpios = <&pio 6 1 GPIO_ACTIVE_LOW>; /* PG1 */
		green_led {
			label = "licheepi:green:usr";
			gpios = <&pio 6 0 GPIO_ACTIVE_LOW>; /* PG0 */
			default-state = "on";
		red_led {
			label = "licheepi:red:usr";
			gpios = <&pio 6 2 GPIO_ACTIVE_LOW>; /* PG2 */
&ehci0 {
&mmc0 {
	broken-cd;
	bus-width = <4>;
/*&i2c0 {
	ns2009: ns2009@48 {
		compatible = "nsiway,ns2009";
		reg = <0x48>;
&ohci0 {
&uart0 {
	pinctrl-0 = <&uart0_pb_pins>;
&usb_otg {
	dr_mode = "otg";
&usbphy {
	usb0_id_det-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>;
加载esp8089.ko之后出现的问题:
# insmod esp8089.ko
[ 6037.164266]
[ 6037.164266] ***** EAGLE DRIVER VER:bdf5087c3deb*****
[ 6037.164266]
[ 6037.172352] debugfs: Directory 'esp_debug' with parent '/' already present!
[ 6037.179391] ESP8089 reset via GPIO 0
[ 6048.487708] esp_sdio_init ------ RETRY ------
[ 6048.492255] ESP8089 reset via GPIO 0
[ 6048.707737] ESP8089 reset via GPIO 0
[ 6060.007706] esp_sdio_init ------ RETRY ------
[ 6060.012250] ESP8089 reset via GPIO 0
[ 6060.227738] ESP8089 reset via GPIO 0
[ 6071.527710] esp_sdio_init ------ RETRY ------
[ 6071.532249] ESP8089 reset via GPIO 0
[ 6071.747749] ESP8089 reset via GPIO 0
[ 6083.047715] esp_sdio_init ------ RETRY ------
[ 6083.052250] ESP8089 reset via GPIO 0
[ 6083.267797] eagle sdio can not power up!
[ 6083.279314]
[ 6083.279314] ***** EAGLE DRIVER VER:bdf5087c3deb*****
[ 6083.279314]
[ 6083.287253] debugfs: Directory 'esp_debug' with parent '/' already present!
[ 6083.294340] ESP8089 reset via GPIO 0
[ 6094.567707] esp_sdio_init ------ RETRY ------
[ 6094.572245] ESP8089 reset via GPIO 0
[ 6094.787736] ESP8089 reset via GPIO 0
[ 6106.087714] esp_sdio_init ------ RETRY ------
[ 6106.092250] ESP8089 reset via GPIO 0
[ 6106.307733] ESP8089 reset via GPIO 0
[ 6117.607708] esp_sdio_init ------ RETRY ------
[ 6117.612243] ESP8089 reset via GPIO 0
[ 6117.827737] ESP8089 reset via GPIO 0
[ 6129.127704] esp_sdio_init ------ RETRY ------
[ 6129.132240] ESP8089 reset via GPIO 0
[ 6129.347722] eagle sdio can not power up!
insmod: can't insert 'esp8089.ko': No such device
#1 2022-05-15 21:53:54
所在地: 你猜
已发帖子: 3,387
Re: 全志V3s (板子是mangopi v3s)主线linux5.2.0加载ESP8089wifi .ko报错:
驱动可能需要传一个gpio进去。
楼主 #2 2022-05-15 22:08:31
liefyuan
已发帖子: 69
驱动可能需要传一个gpio进去。
您是说加载模块的时候吗?
这样吗?
insmod esp8089.ko reset via GPIO 0
楼主 #3 2022-05-15 22:14:22
liefyuan
已发帖子: 69
驱动可能需要传一个gpio进去。
# insmod esp8089.ko reset via GPIO 0
[ 8426.078282] esp8089: unknown parameter 'reset' ignored
[ 8426.083446] esp8089: unknown parameter 'via' ignored
[ 8426.088514] esp8089: unknown parameter 'GPIO' ignored
[ 8426.093563] esp8089: unknown parameter '0' ignored
[ 8426.098678]
[ 8426.098678] ***** EAGLE DRIVER VER:bdf5087c3deb*****
[ 8426.098678]
[ 8426.106608] debugfs: Directory 'esp_debug' with parent '/' already present!
[ 8426.113646] ESP8089 reset via GPIO 0
[ 8437.607699] esp_sdio_init ------ RETRY ------
[ 8437.612244] ESP8089 reset via GPIO 0
[ 8437.827788] ESP8089 reset via GPIO 0
[ 8449.127694] esp_sdio_init ------ RETRY ------
[ 8449.132234] ESP8089 reset via GPIO 0
[ 8449.347724] ESP8089 reset via GPIO 0
[ 8460.647704] esp_sdio_init ------ RETRY ------
[ 8460.652249] ESP8089 reset via GPIO 0
[ 8460.867733] ESP8089 reset via GPIO 0
[ 8472.167701] esp_sdio_init ------ RETRY ------
[ 8472.172240] ESP8089 reset via GPIO 0
[ 8472.387717] eagle sdio can not power up!
[ 8472.399061] esp8089: unknown parameter 'reset' ignored
[ 8472.404223] esp8089: unknown parameter 'via' ignored
[ 8472.409276] esp8089: unknown parameter 'GPIO' ignored
[ 8472.414327] esp8089: unknown parameter '0' ignored
[ 8472.419446]
[ 8472.419446] ***** EAGLE DRIVER VER:bdf5087c3deb*****
[ 8472.419446]
[ 8472.427372] debugfs: Directory 'esp_debug' with parent '/' already present!
[ 8472.434420] ESP8089 reset via GPIO 0
[ 8483.687696] esp_sdio_init ------ RETRY ------
[ 8483.692232] ESP8089 reset via GPIO 0
[ 8483.907724] ESP8089 reset via GPIO 0
[ 8495.207697] esp_sdio_init ------ RETRY ------
[ 8495.212233] ESP8089 reset via GPIO 0
[ 8495.427728] ESP8089 reset via GPIO 0
[ 8506.727701] esp_sdio_init ------ RETRY ------
[ 8506.732232] ESP8089 reset via GPIO 0
[ 8506.947728] ESP8089 reset via GPIO 0
[ 8518.247696] esp_sdio_init ------ RETRY ------
[ 8518.252238] ESP8089 reset via GPIO 0
[ 8518.467755] eagle sdio can not power up!
不行啊
#4 2022-05-15 22:27:32
所在地: 你猜
已发帖子: 3,387
liefyuan 说:
驱动可能需要传一个gpio进去。
您是说加载模块的时候吗?
这样吗?
不是, 要看下代码。
参考:
SDIO ESP8089开源Linux驱动现在可以直接编译通过了, 有没有朋友一起试一试
https://whycan.com/t_4326.html#p70252
楼主 #5 2022-05-15 23:50:55
liefyuan
已发帖子: 69
让板子重新上电其实就没有这个问题,可以正常加载模块的!
# insmod /lib/modules/esp8089.ko
[   33.142620]
[   33.142620] ***** EAGLE DRIVER VER:bdf5087c3deb*****
[   33.142620]
[   33.150803] ESP8089 reset via GPIO 0
[   33.367996] esp_sdio_dummy_probe enter
[   33.587670] esp_sdio_init power up OK
[   34.039162] esp_host:bdf5087c3deb
[   34.039162] esp_target: e826c2b3c9fd 57 18202
[   34.039162]
[   34.048460] esp_readwrite_file: file /system/lib/modules/test_results filp_open error
[   34.056547] first normal exit
[   34.059745] esp_sdio_remove enter
[   34.064033] sif_disable_irq release irq failed
[   34.187987] eagle_sdio: probe of mmc1:0001:1 failed with error -110
# [   34.888079] mmc1: card 0001 removed
[   34.942183] mmc1: queuing unknown CIS tuple 0x01 (3 bytes)
[   34.954824] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[   34.963661] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[   34.971008] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[   34.976546] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[   34.982568] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[   34.988163] mmc1: new high speed SDIO card at address 0001
[   35.352056] esp_host:bdf5087c3deb
[   35.352056] esp_target: e826c2b3c9fd 57 18202
[   35.352056]
# ifconfig wlan0 up
[   49.594517] esp_op_add_interface STA
# ifconfig
          RX packets:64 errors:0 dropped:0 overruns:0 frame:0
          TX packets:64 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:4736 (4.6 KiB)  TX bytes:4736 (4.6 KiB)
wlan0     Link encap:Ethernet  HWaddr AC:D0:74:C8:E9:F8
          UP BROADCAST MULTICAST  MTU:1500  Metric:1
#6 2022-05-17 09:36:53
qianniao29
已发帖子: 29
正好最近在调esp8089,研究了一下,用的这份代码 https://github.com/al177/esp8089, 指定复位引脚的的参数是esp_reset_gpio
insmod /lib/modules/esp8089.ko esp_reset_gpio=123
复位引脚接在esp8089的chip_en上,不过正确指定reset后就会出现楼主的现象,不指定还可以往下跑一段,加打印跟了一段,应该是加了reset之后,在给esp8089发第一条指令时超时无回复,导致出错。如果不加复位会在第二次probe时出现无响应,需要修改下esp_sdio_probe,添加卡在位状态重新检测。
// mmc_force_detect_change的实现
#ifndef MMC_HAS_FORCE_DETECT_CHANGE
void mmc_force_detect_change(struct mmc_host *host, unsigned long delay,
			     bool keep_power)
	host->caps &= ~MMC_CAP_NONREMOVABLE;
	host->caps |= MMC_CAP_NEEDS_POLL;
	mmc_detect_change(host, delay);
static int esp_sdio_probe(struct sdio_func *func, const struct sdio_device_id *id)
        if(sif_sdio_state == ESP_SDIO_STATE_FIRST_INIT){
		esp_dbg(ESP_DBG_ERROR, "first normal exit\n");
		sif_sdio_state = ESP_SDIO_STATE_FIRST_NORMAL_EXIT;
                mmc_force_detect_change(host, msecs_to_jiffies(100), true); //添加这行
		up(&esp_powerup_sem);
参考的 https://github.com/Icenowy/esp8089 这份代码,这份可以正常生成wlan0,并连接wifi,安装需要指定晶振频率( insmod esp8089.ko config=crystal_26M_en=1)。但这份没有reset,一旦wifi不正常只能重新上电。
测试两份代码,在没有rmmod的情况下reboot,都会出现无法再次正常初始化的情况,只能断电重启。
另外rmmod crash的问题可以参考4楼的链接,帖子里有修复。
