楼主 # 2022-05-19 00:08:04
鱼尾
所在地: 杭州
已发帖子: 47
f1c100s音频驱动Error: Driver 'sun4i-codec' is already registered, aborting
参考这个链接https://whycan.com/viewtopic.php?id=2041在主线linux5.2 上配置了驱动
但是开始报错 Error: Driver 'sun4i-codec' is already registered, aborting
不知道为什么被注册了有没有大佬帮忙看看什么问题
楼主 #1 2022-05-19 00:08:38
鱼尾
所在地: 杭州
已发帖子: 47
Re: f1c100s音频驱动Error: Driver 'sun4i-codec' is already registered, aborting
▒▒ 0
switch to partitions #0, OK
mmc0 is current device
Scanning mmc 0:1...
Found U-Boot script /boot.scr
reading /boot.scr
730 bytes read in 20 ms (35.2 KiB/s)
## Executing script at 80c50000
6426 bytes read in 26 ms (241.2 KiB/s)
reading zImage
4178696 bytes read in 221 ms (18 MiB/s)
   Loading Device Tree to 816fb000, end 816ff919 ... OK
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 5.2.0-licheepi-nano (root@yuwei-VirtualBox) (gcc version 7.2.1 20171011 (Linaro GCC 7.2-2017.11)) #2 Thu May 19 00:02:44 CST 2022
[    0.000000] CPU: ARM926EJ-S [41069265] revision 5 (ARMv5TEJ), cr=0005317f
[    0.000000] CPU: VIVT data cache, VIVT instruction cache
[    0.000000] OF: fdt: Machine model: Lichee Pi Nano
[    0.000000] Memory policy: Data cache writeback
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 16256
[    0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/mmcblk0p2 rw
[    0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
[    0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Memory: 55172K/65536K available (6144K kernel code, 244K rwdata, 1584K rodata, 1024K init, 241K bss, 10364K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] random: get_random_bytes called from start_kernel+0x254/0x42c with crng_init=0
[    0.000053] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000138] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.000763] Console: colour dummy device 80x30
[    0.000867] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[    0.070258] pid_max: default: 32768 minimum: 301
[    0.070727] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.070775] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.072510] CPU: Testing write buffer coherency: ok
[    0.074695] Setting up static identity map for 0x80100000 - 0x80100058
[    0.077158] devtmpfs: initialized
[    0.083303] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.083372] futex hash table entries: 256 (order: -1, 3072 bytes)
[    0.083692] pinctrl core: initialized pinctrl subsystem
[    0.086402] NET: Registered protocol family 16
[    0.087835] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.090082] cpuidle: using governor menu
[    0.148072] SCSI subsystem initialized
[    0.148461] usbcore: registered new interface driver usbfs
[    0.148629] usbcore: registered new interface driver hub
[    0.148837] usbcore: registered new device driver usb
[    0.149394] pps_core: LinuxPPS API ver. 1 registered
[    0.149422] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.149498] PTP clock support registered
[    0.150065] Advanced Linux Sound Architecture Driver Initialized.
[    0.152023] clocksource: Switched to clocksource timer
[    0.184749] NET: Registered protocol family 2
[    0.186463] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[    0.186546] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[    0.186605] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[    0.186655] TCP: Hash tables configured (established 1024 bind 1024)
[    0.187030] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    0.187099] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    0.187672] NET: Registered protocol family 1
[    0.189399] RPC: Registered named UNIX socket transport module.
[    0.189441] RPC: Registered udp transport module.
[    0.189456] RPC: Registered tcp transport module.
[    0.189470] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.191824] NetWinder Floating Point Emulator V0.97 (double precision)
[    0.194257] Initialise system trusted keyrings
[    0.194940] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.219706] NFS: Registering the id_resolver key type
[    0.219792] Key type id_resolver registered
[    0.219813] Key type id_legacy registered
[    0.226202] Key type asymmetric registered
[    0.226250] Asymmetric key parser 'x509' registered
[    0.226452] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[    0.226485] io scheduler mq-deadline registered
[    0.226505] io scheduler kyber registered
[    0.238860] suniv-f1c100s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.457896] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.464282] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[    0.466147] printk: console [ttyS0] disabled
[    0.486414] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 22, base_baud = 6250000) is a 16550A
[    0.897234] printk: console [ttyS0] enabled
[    0.905701] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    0.924403] SCSI Media Changer driver v0.25
[    0.930077] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.936753] ehci-platform: EHCI generic platform driver
[    0.942392] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.948630] ohci-platform: OHCI generic platform driver
[    0.954398] usbcore: registered new interface driver usb-storage
[    0.961108] udc-core: couldn't find an available UDC - added [g_cdc] to list of pending drivers
[    0.970245] i2c /dev entries driver
[    0.975724] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    1.013915] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    1.023671] usbcore: registered new interface driver usbhid
[    1.029249] usbhid: USB HID core driver
[    1.050328] Error: Driver 'sun4i-codec' is already registered, aborting...
[    1.058083] NET: Registered protocol family 17
[    1.062923] Key type dns_resolver registered
[    1.069834] Loading compiled-in X.509 certificates
[    1.085716] suniv-f1c100s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pd not found, using dummy regulator
[    1.097242] sun4i-backend 1e60000.display-backend: Couldn't find matching frontend, frontend features disabled
[    1.108155] sun4i-drm display-engine: bound 1e60000.display-backend (ops 0xc073b534)
[    1.117196] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc073a18c)
[    1.124980] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.131581] [drm] No driver support for vblank timestamp query.
[    1.138940] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.362856] mmc0: host does not support reading read-only switch, assuming write-enable
[    1.365263] mmc0: new high speed SDHC card at address 0001
[    1.369725] mmcblk0: mmc0:0001 SD 29.1 GiB
[    1.391978] Console: switching to colour frame buffer device 100x30
[    1.394786]  mmcblk0: p1 p2
[    1.452310] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[    1.460210] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.478546] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.485429] ALSA device list:
[    1.488481]   #0: Loopback 1
[    1.492477] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.501096] cfg80211: failed to load regulatory.db
[    1.545918] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    1.554300] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    1.563846] devtmpfs: mounted
[    1.572069] random: fast init done
[    1.576949] Freeing unused kernel memory: 1024K
[    1.581686] Run /sbin/init as init process
[    1.759720] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting logging: OK
Initializing random number generator... [    2.135403] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting system message bus: [    2.256050] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[    2.263774] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
done
Starting network: OK
Welcome to Buildroot
buildroot login: root
# ls
# [  206.242168] random: crng init done
[  206.245593] random: 2 urandom warning(s) missed due to ratelimiting
楼主 #2 2022-05-19 00:09:45
鱼尾
所在地: 杭州
已发帖子: 47
/dts-v1/;
#include "suniv-f1c100s.dtsi"
    model = "Lichee Pi Nano";
    compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
    aliases {
        serial0 = &uart0;
    chosen {
    panel: panel {
        compatible = "lg,lb070wv8", "simple-panel";
        #address-cells = <1>;
        #size-cells = <0>;
        enable-gpios = <&pio 4 6 GPIO_ACTIVE_HIGH>;
        power-supply = <&reg_vcc3v3>;
        port@0 {
            reg = <0>;
            #size-cells = <0>;
            panel_input: endpoint@0 {
                reg = <0>;
    reg_vcc3v3: vcc3v3 {
        regulator-name = "vcc3v3";
&be0 {
&de {
&tcon0 {
    pinctrl-names = "default";
    pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
    tcon0_out_lcd: endpoint@0 {
        reg = <0>;
&mmc0 {
    vmmc-supply = <&reg_vcc3v3>;
    bus-width = <4>;
    broken-cd;
&uart0 {
    pinctrl-0 = <&uart0_pe_pins>;
&codec {
    allwinner,audio-routing =
        "Headphone", "HP",
        "Headphone", "HPCOM",
        "MIC", "Mic";
楼主 #3 2022-05-19 00:10:31
鱼尾
所在地: 杭州
已发帖子: 47
* Copyright 2018 Mesih Kilinc <mesihkilinc@gmail.com>
#include <dt-bindings/clock/suniv-ccu-f1c100s.h>
#include <dt-bindings/reset/suniv-ccu-f1c100s.h>
    #size-cells = <1>;
    interrupt-parent = <&intc>;
    clocks {
        osc24M: clk-24M {
            #clock-cells = <0>;
            compatible = "fixed-clock";
            clock-frequency = <24000000>;
        osc32k: clk-32k {
            #clock-cells = <0>;
            clock-frequency = <32768>;
    cpus {
        cpu {
            device_type = "cpu";
    de: display-engine {
        compatible = "allwinner,suniv-f1c100s-display-engine";
        allwinner,pipelines = <&fe0>;
        status = "disabled";
    soc {
        compatible = "simple-bus";
        #size-cells = <1>;
        ranges;
        sram-controller@1c00000 {
            compatible = "allwinner,suniv-f1c100s-system-control",
                     "allwinner,sun4i-a10-system-control";
            reg = <0x01c00000 0x30>;
            #size-cells = <1>;
            ranges;
            sram_d: sram@10000 {
                compatible = "mmio-sram";
                reg = <0x00010000 0x1000>;
                #size-cells = <1>;
                otg_sram: sram-section@0 {
                    compatible = "allwinner,suniv-f1c100s-sram-d",
                             "allwinner,sun4i-a10-sram-d";
                    reg = <0x0000 0x1000>;
        tcon0: lcd-controller@1c0c000 {
            compatible = "allwinner,suniv-f1c100s-tcon";
            reg = <0x01c0c000 0x1000>;
            interrupts = <29>;
            clocks = <&ccu CLK_BUS_LCD>,
                 <&ccu CLK_TCON>;
            clock-names = "ahb",
                      "tcon-ch0";
            clock-output-names = "tcon-pixel-clock";
            resets = <&ccu RST_BUS_LCD>;
            reset-names = "lcd";
            ports {
                #size-cells = <0>;
                tcon0_in: port@0 {
                    #size-cells = <0>;
                    reg = <0>;
                    tcon0_in_be0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&be0_out_tcon0>;
                tcon0_out: port@1 {
                    #size-cells = <0>;
                    reg = <1>;
        ccu: clock@1c20000 {
            compatible = "allwinner,suniv-f1c100s-ccu";
            reg = <0x01c20000 0x400>;
            clock-names = "hosc", "losc";
            #clock-cells = <1>;
            #reset-cells = <1>;
            compatible = "allwinner,suniv-f1c100s-ic";
            reg = <0x01c20400 0x400>;
            interrupt-controller;
            #interrupt-cells = <1>;
        pio: pinctrl@1c20800 {
            compatible = "allwinner,suniv-f1c100s-pinctrl";
            reg = <0x01c20800 0x400>;
            gpio-controller;
            #interrupt-cells = <3>;
            #gpio-cells = <3>;
            uart0_pe_pins: uart0-pe-pins {
                pins = "PE0", "PE1";
                function = "uart0";
            lcd_rgb666_pins: lcd-rgb666-pins {
                pins = "PD0", "PD1", "PD2", "PD3", "PD4",
                       "PD5", "PD6", "PD7", "PD8", "PD9",
                       "PD10", "PD11", "PD12", "PD13", "PD14",
                       "PD15", "PD16", "PD17", "PD18", "PD19",
                       "PD20", "PD21";
                function = "lcd";
            mmc0_pins: mmc0-pins {
                pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
                function = "mmc0";
        timer@1c20c00 {
            compatible = "allwinner,suniv-f1c100s-timer";
            reg = <0x01c20c00 0x90>;
            interrupts = <13>;
            clocks = <&osc24M>;
        mmc0: mmc@1c0f000 {
            compatible = "allwinner,suniv-f1c100s-mmc",
                     "allwinner,sun7i-a20-mmc";
            reg = <0x01c0f000 0x1000>;
            clocks = <&ccu CLK_BUS_MMC0>,
                 <&ccu CLK_MMC0>,
                 <&ccu CLK_MMC0_OUTPUT>,
                 <&ccu CLK_MMC0_SAMPLE>;
                          "mmc",
                          "output",
                          "sample";
            resets = <&ccu RST_BUS_MMC0>;
            reset-names = "ahb";
            interrupts = <23>;
            pinctrl-0 = <&mmc0_pins>;
            #size-cells = <0>;
        wdt: watchdog@1c20ca0 {
            compatible = "allwinner,suniv-f1c100s-wdt",
                     "allwinner,sun4i-a10-wdt";
            reg = <0x01c20ca0 0x20>;
        uart0: serial@1c25000 {
            reg = <0x01c25000 0x400>;
            interrupts = <1>;
            reg-shift = <2>;
            reg-io-width = <4>;
        uart1: serial@1c25400 {
            reg = <0x01c25400 0x400>;
            interrupts = <2>;
            reg-shift = <2>;
            reg-io-width = <4>;
        uart2: serial@1c25800 {
            reg = <0x01c25800 0x400>;
            interrupts = <3>;
            reg-shift = <2>;
            reg-io-width = <4>;
        fe0: display-frontend@1e00000 {
            compatible = "allwinner,suniv-f1c100s-display-frontend";
            reg = <0x01e00000 0x20000>;
            interrupts = <30>;
            clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
                 <&ccu CLK_DRAM_DE_FE>;
            clock-names = "ahb", "mod",
                      "ram";
            resets = <&ccu RST_BUS_DE_FE>;
            ports {
                #size-cells = <0>;
                fe0_out: port@1 {
                    #size-cells = <0>;
                    reg = <1>;
                    fe0_out_be0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&be0_in_fe0>;
        be0: display-backend@1e60000 {
            compatible = "allwinner,suniv-f1c100s-display-backend";
            reg = <0x01e60000 0x10000>;
            reg-names = "be";
            interrupts = <31>;
            clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
                 <&ccu CLK_DRAM_DE_BE>;
                      "ram";
            resets = <&ccu RST_BUS_DE_BE>;
            reset-names = "be";
            assigned-clocks = <&ccu CLK_DE_BE>;
            assigned-clock-rates = <300000000>;
            ports {
                #size-cells = <0>;
                be0_in: port@0 {
                    #size-cells = <0>;
                    reg = <0>;
                    be0_in_fe0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&fe0_out_be0>;
                be0_out: port@1 {
                    #size-cells = <0>;
                    reg = <1>;
                    be0_out_tcon0: endpoint@0 {
                        reg = <0>;
                        remote-endpoint = <&tcon0_in_be0>;
        dma: dma-controller@1c02000 {
            compatible = "allwinner,suniv-dma";
            reg = <0x01c02000 0x1000>;
            interrupts = <18>;
            clocks = <&ccu CLK_BUS_DMA>;
            resets = <&ccu RST_BUS_DMA>;
            #dma-cells = <2>;
        codec: codec@1c23c00 {
            compatible = "allwinner,suniv-codec";
            reg = <0x01c23c00 0x400>;
            interrupts = <21>;
            clocks = <&ccu CLK_BUS_CODEC>,
                 <&ccu CLK_CODEC>;
            clock-names = "apb", "codec";
            resets = <&ccu RST_BUS_CODEC>;
            dmas = <&dma 0 12>, <&dma 0 12>;
            dma-names = "rx", "tx";
