楼主 # 2022-05-20 17:16:34
jkl
已发帖子: 269
全志r528有人玩过吗?LVDS驱动搞的有点蒙了,一直不对,这是我目前的配置,大家帮忙看看?
&disp {
    disp_init_enable         = <1>;
    disp_mode                = <0>;
    screen0_output_type      = <1>;
    screen0_output_mode      = <4>;
    screen1_output_type      = <3>;
    screen1_output_mode      = <10>;
    screen1_output_format    = <0>;
    screen1_output_bits      = <0>;
    screen1_output_eotf      = <4>;
    screen1_output_cs        = <257>;
    screen1_output_range     = <2>;
    screen1_output_scan      = <0>;
    screen1_output_aspect_ratio = <8>;
    dev0_output_type         = <1>;
    dev0_output_mode         = <4>;
    dev0_screen_id           = <0>;
    dev0_do_hpd              = <0>;
    dev1_output_type         = <4>;
    dev1_output_mode         = <10>;
    dev1_screen_id           = <1>;
    dev1_do_hpd              = <1>;
    def_output_dev           = <0>;
    fb0_format               = <0>;
    fb0_width                = <0>;
    fb0_height               = <0>;
    fb1_format               = <0>;
    fb1_width                = <0>;
    fb1_height               = <0>;
    chn_cfg_mode             = <1>;
    disp_para_zone           = <1>;
    /*VCC-LCD*/
/*    dc1sw-supply = <&reg_dc1sw>;*/
    /*VCC-DSI*/
/*    eldo3-supply = <&reg_eldo3>;*/
    /*VCC-PD*/
/*    dcdc1-supply = <&reg_dcdc1>;*/
&lcd0 {
    lcd_used            = <1>;
    lcd_driver_name     = "default_lcd";
    lcd_backlight       = <50>;
    lcd_if              = <3>;
    lcd_x               = <800>;
    lcd_y               = <600>;
    lcd_width           = <150>;
    lcd_height          = <94>;
    lcd_dclk_freq       = <35>;
    lcd_pwm_used        = <1>;
    lcd_pwm_ch          = <7>;
    lcd_pwm_freq        = <50000>;
    lcd_pwm_pol         = <1>;
    lcd_pwm_max_limit   = <255>;
    lcd_bl_en           = <&pio PD 20 GPIO_ACTIVE_HIGH>;
    lcd_hbp             = <20>;
    lcd_ht              = <1418>;
    lcd_hspw            = <10>;
    lcd_vbp             = <10>;
    lcd_vt              = <814>;
    lcd_vspw            = <5>;
    lcd_lvds_if         = <0>;
    lcd_lvds_colordepth = <1>;
    lcd_lvds_mode       = <1>;
    lcd_frm             = <1>;
    lcd_hv_clk_phase    = <0>;
    lcd_hv_sync_polarity= <0>;
    lcd_gamma_en        = <0>;
    lcd_bright_curve_en = <0>;
    lcd_cmap_en         = <0>;
    deu_mode            = <0>;
    lcdgamma4iep        = <22>;
    smart_color         = <90>;
    pinctrl-0 = <&lvds0_pins_a>;
    pinctrl-1 = <&lvds0_pins_b>;
#1 2022-05-23 09:55:53
shaoxi2010
已发帖子: 399
Re: 全志r528有人玩过吗?LVDS驱动搞的有点蒙了,一直不对,这是我目前的配置,大家帮忙看看?
一直不对是什么现象哦,有没有用点屏器试过?
#2 2022-05-23 10:42:49
hellojoyjoy
调屏时,可以先把uboot的显示给关闭了。
#3 2022-05-23 13:15:17
musich
已发帖子: 260
我的 V3S, RGB屏还没搞定, 留院观察中.
楼主 #4 2022-05-26 10:31:35
jkl
已发帖子: 269
屏是正常的,追踪了一下代码,发现 default_pancel.c文件中的 static s32 LCD_open_flow(u32 sel) 函数一直没有被调用,但是我关机重启LCD_close_flow函数调用了:
    printk("%s %d %s\n",__FILE__,__LINE__,__FUNCTION__);
    /* open lcd power, and delay 50ms */
    LCD_OPEN_FUNC(sel, LCD_power_on, 30);
    /* open lcd power, than delay 200ms */
    LCD_OPEN_FUNC(sel, LCD_panel_init, 50);
    /* open lcd controller, and delay 100ms */
    LCD_OPEN_FUNC(sel, sunxi_lcd_tcon_enable, 100);
    /* open lcd backlight, and delay 0ms */
    LCD_OPEN_FUNC(sel, LCD_bl_open, 0);
static s32 LCD_close_flow(u32 sel)
    /* close lcd backlight, and delay 0ms */
    LCD_CLOSE_FUNC(sel, LCD_bl_close, 0);
    /* close lcd controller, and delay 0ms */
    LCD_CLOSE_FUNC(sel, sunxi_lcd_tcon_disable, 0);
    LCD_CLOSE_FUNC(sel, LCD_panel_exit, 200);
    /* close lcd power, and delay 500ms */
    LCD_CLOSE_FUNC(sel, LCD_power_off, 500);
TCON的相关配置是在open函数中注册的,这块函数一直没被调用,这可能是哪里有问题?
最近编辑记录 jkl (2022-05-26 10:37:17)
#5 2022-05-26 12:27:10
lanlanzhilian
已发帖子: 167
屏参数未验证
lcd_x               = <800>;
    lcd_y               = <600>;
    lcd_width           = <150>;
    lcd_height          = <94>;
    lcd_pwm_used        = <1>;
    lcd_pwm_ch          = <7>;
    lcd_pwm_pol         = <1>;
    lcd_hbp             = <100>;
    lcd_ht              = <920>;
    lcd_hspw            = <20>;
    lcd_vbp             = <20>;
    lcd_vt              = <625>;
    lcd_vspw            = <5>;
    lcd_lvds_if         = <0>;
    lcd_lvds_colordepth = <0>;
    lcd_lvds_mode       = <0>;
    lcd_frm             = <1>;
楼主 #6 2022-05-26 15:33:26
jkl
已发帖子: 269
我现在把uboot部分的lcd部分的配置去掉了, LCD_open_flow(u32 sel) 该函数被调用了,目前加载disp.ko模块:
root@TinaLinux:/# insmod disp.ko
[   34.456629] [DISP]disp_module_init
[   34.461321] disp 5000000.disp: Adding to iommu group 0
[   34.467668] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 3044 disp_probe
[   34.475476] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2224 disp_init
[   34.483263] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2346 disp_init
[   34.490996] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 26 bsp_disp_init
[   34.499602] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 38 bsp_disp_init
[   34.508261] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 40 bsp_disp_init
[   34.516867] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 44 bsp_disp_init
[   34.525449] drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c 3071 disp_init_lcd
[   34.543787] lcd_dclk_freq = 50
[   34.547710] lcd_if = 3
[   34.550891] lcd_hv_if = 1065
[   34.557254] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 46 bsp_disp_init
[   34.565903] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 86 bsp_disp_init
[   34.575232] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2374 disp_init
[   34.582987] drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c 145 lcd_init
[   34.590728] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2535 sunxi_disp_get_source_ops
[   34.600015] drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c 147 lcd_init
[   34.607745] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 23 LCD_cfg_panel_info
[   34.617036] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 81 LCD_cfg_panel_info
[   34.626301] drivers/video/fbdev/sunxi/disp2/disp/lcd/panels.c 149 lcd_init
[   34.634031] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2376 disp_init
[   34.641763] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2378 disp_init
[   34.649503] display_fb_request,fb_id:0
[   34.655416] [DISP] Fb_copy_boot_fb,line:1446:
[   34.655419] no boot_fb0
[   34.663626] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2380 disp_init
[   34.671471] disp_al_manager_apply ouput_type:0
[   34.672137] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 2386 disp_init
[   34.676818] [DISP] lcd_clk_config,line:734:
[   34.676828] disp 0, clk: pll(350000000),clk(350000000),dclk(50000000) dsi_rate(350000000)
[   34.676828]      clk real:pll(348000000),clk(348000000),dclk(49714285) dsi_rate(0)
[   34.685251] drivers/video/fbdev/sunxi/disp2/disp/dev_disp.c 3046 disp_probe
[   34.688932] drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c 777 lcd_clk_enable
[   34.708790] [DISP]disp_module_init finish
[   34.714465] drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c 783 lcd_clk_enable
root@TinaLinux:/# [   34.736624] drivers/video/fbdev/sunxi/disp2/disp/de/disp_lcd.c 791 lcd_clk_enable
[   34.745856] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 87 LCD_open_flow
[   34.754682] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 96 LCD_open_flow
[   34.763488] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 117 LCD_power_on
[   34.772288] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 1458 bsp_disp_lcd_pin_cfg
[   34.782344] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[   34.791266] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c 1462 bsp_disp_lcd_pin_cfg
[   34.800761] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 140 LCD_power_on
[   34.846488] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 171 LCD_panel_init
[   34.916477] drivers/video/fbdev/sunxi/disp2/disp/lcd/lcd_source.c43sunxi_lcd_tcon_enable
[   34.925553] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c1372bsp_disp_lcd_tcon_enable
[   34.935259] drivers/video/fbdev/sunxi/disp2/disp/de/disp_display.c1405bsp_disp_lcd_tcon_enable
[   35.046481] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 154 LCD_bl_open
[   35.055374] drivers/video/fbdev/sunxi/disp2/disp/lcd/default_panel.c 157 LCD_bl_open
[   35.064104] [DISP] disp_device_attached_and_enable,line:226:
[   35.064108] attached ok, mgr0<-->dev0
[   35.074614] [DISP] disp_device_attached_and_enable,line:229:
[   35.074622] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi:2, range:0 scan:8 ratio:-1062187512
用示波器测量波形和时钟目前还是不对
