楼主 # 2022-06-13 06:07:28
Hossam
Interface f1c200s with Esp8266 through uart
I'm using F1C200S development board and I want to connect it to wifi. After doing a little search I found that I can use esp8266 as a wifi module but it's usually interfaced using SDIO or SPI. but the problem is that I'm using both these ports already. so my question is can I interface esp8266 with f1c200s using uart? as serial IP? and if so... how?
#1 2022-06-13 07:09:28
已发帖子: 3,393
Re: Interface f1c200s with Esp8266 through uart
可以使用 uart 连接 esp8266,你可以使用 AT firmware@esp8266
也可以通过gpio复用 spi: 百问网韦老师 D1 开发板 ---- 东山哪吒STU
楼主 #2 2022-06-13 19:41:02
Hossam
but if I used AT command @ ESP8266 I won't be able to show the WLAN0 as Network Interface right ?
and I won't be able to use ssh using WiFi
#3 2022-06-19 17:14:40
titishev
已发帖子: 19
非常突破,最重要的是 - 很有前途:)
