I'm using F1C200S development board and I want to connect it to wifi. After doing a little search I found that I can use esp8266 as a wifi module but it's usually interfaced using SDIO or SPI. but the problem is that I'm using both these ports already. so my question is can I interface esp8266 with f1c200s using uart? as serial IP? and if so... how?
but if I used AT command @ ESP8266 I won't be able to show the WLAN0 as Network Interface right ?
and I won't be able to use ssh using WiFi
非常突破,最重要的是 - 很有前途:)
