我在尝试用MQ-R(T113)通过rtl8189上网,但是通过buildroot编译出来的似乎不能正常挂载,请教大佬们该如何解决。
Buildroot:https://github.com/mangopi-sbc/buildroot-d1x-t113
启动日志如下:
[ 0.000000] Linux version 5.4.61 (darren@darren-ubuntu18) (arm-linux-gnueabi-gcc (Linaro GCC 7.2-2017.11) 7.2.1 20171011, GNU ld (Linaro_Binutils-2017.11) 2.28.2.20170706) #1 SMP PREEMPT Tue Jun 14 23:36:02 CST 2022
[ 0.000000] OF: fdt: Machine model: sun8iw20
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] cma: Reserved 8 MiB at 0x47800000
[ 0.000000] On node 0 totalpages: 32512
[ 0.000000] Normal zone: 256 pages used for memmap
[ 0.000000] Normal zone: 32512 pages, LIFO batch:7
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] percpu: Embedded 15 pages/cpu s30796 r8192 d22452 u61440
[ 0.000000] pcpu-alloc: s30796 r8192 d22452 u61440 alloc=15*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32256
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x02500000 clk_ignore_unused initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p5 init=/sbin/init partitions=ext4 cma=8M gpt=1 androidboot.hardware=sun8iw20p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05(05/20/2022-05:59:29) disp_reserve=522240,0x448ed000 androidboot.dramsize=128
[ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Memory: 106952K/130048K available (7168K kernel code, 352K rwdata, 2448K rodata, 1024K init, 177K bss, 14904K reserved, 8192K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] Tasks RCU enabled.
[ 0.000000] random: get_random_bytes called from start_kernel+0x248/0x3d0 with crng_init=0
[ 0.000006] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.008018] Switching to timer-based delay loop, resolution 41ns
[ 0.014195] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023961] Console: colour dummy device 80x30
[ 0.028460] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038832] pid_max: default: 32768 minimum: 301
[ 0.043582] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050919] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059296] CPU: Testing write buffer coherency: ok
[ 0.064542] /cpus/cpu@0 missing clock-frequency property
[ 0.069869] /cpus/cpu@1 missing clock-frequency property
[ 0.075222] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.081495] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.088182] rcu: Hierarchical SRCU implementation.
[ 0.093476] smp: Bringing up secondary CPUs ...
[ 0.099251] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.099405] smp: Brought up 1 node, 2 CPUs
[ 0.109224] SMP: Total of 2 processors activated (96.00 BogoMIPS).
[ 0.115421] CPU: All CPU(s) started in SVC mode.
[ 0.120547] devtmpfs: initialized
[ 0.135811] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.144024] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.153879] futex hash table entries: 512 (order: 3, 32768 bytes, linear)
[ 0.161148] pinctrl core: initialized pinctrl subsystem
[ 0.167761] NET: Registered protocol family 16
[ 0.173810] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.219566] rtc_ccu: sunxi ccu init OK
[ 0.225738] ccu: sunxi ccu init OK
[ 0.229597] r_ccu: sunxi ccu init OK
[ 0.283205] iommu: Default domain type: Translated
[ 0.289550] sunxi iommu: irq = 24
[ 0.294030] SCSI subsystem initialized
[ 0.298181] usbcore: registered new interface driver usbfs
[ 0.303778] usbcore: registered new interface driver hub
[ 0.309560] usbcore: registered new device driver usb
[ 0.314764] mc: Linux media interface: v0.10
[ 0.319378] videodev: Linux video capture interface: v2.00
[ 0.326112] sunxi-msgbox-amp 3003000.msgbox: invalid resource
[ 0.333293] Advanced Linux Sound Architecture Driver Initialized.
[ 0.340097] Bluetooth: Core ver 2.22
[ 0.343854] NET: Registered protocol family 31
[ 0.348304] Bluetooth: HCI device and connection manager initialized
[ 0.354710] Bluetooth: HCI socket layer initialized
[ 0.359604] Bluetooth: L2CAP socket layer initialized
[ 0.364723] Bluetooth: SCO socket layer initialized
[ 0.369935] pwm module init!
[ 0.374460] input: sunxi-keyboard as /devices/virtual/input/input0
[ 0.382133] clocksource: Switched to clocksource arch_sys_counter
[ 0.397615] sun8iw20-pinctrl pio: initialized sunXi PIO driver
[ 0.417602] thermal_sys: Registered thermal governor 'user_space'
[ 0.417609] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.424495] NET: Registered protocol family 2
[ 0.435993] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.444448] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.452143] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.459214] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.465774] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.472363] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.479567] NET: Registered protocol family 1
[ 0.486631] Initialise system trusted keyrings
[ 0.491312] workingset: timestamp_bits=30 max_order=15 bucket_order=0
[ 0.506541] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.547408] Key type asymmetric registered
[ 0.551526] Asymmetric key parser 'x509' registered
[ 0.556465] io scheduler mq-deadline registered
[ 0.560999] io scheduler kyber registered
[ 0.565114] atomic64_test: passed
[ 0.570120] [DISP]disp_module_init
[ 0.574228] disp 5000000.disp: Adding to iommu group 0
[ 0.579996] [DISP] disp_init,line:2386:
[ 0.580001] smooth display screen:0 type:1 mode:4
[ 0.604904] do not get the node of hdmi
[ 0.609070] display_fb_request,fb_id:0
[ 0.617859] Freeing logo buffer memory: 512K
[ 0.622774] disp_al_manager_apply ouput_type:1
[ 0.627358] [DISP] lcd_clk_config,line:732:
[ 0.627370] disp 0, clk: pll(144000000),clk(144000000),dclk(24000000) dsi_rate(144000000)
[ 0.627370] clk real:pll(288000000),clk(288000000),dclk(48000000) dsi_rate(0)
[ 0.632776] [DISP]disp_module_init finish
[ 0.647881] sun8iw20-pinctrl pio: pio supply vcc-pd not found, using dummy regulator
[ 0.653373] sunxi_sid_init()551 - insmod ok
[ 0.664072] pwm-regulator: supplied by regulator-dummy
[ 0.670799] sun8iw20-pinctrl pio: pio supply vcc-pe not found, using dummy regulator
[ 0.678991] uart uart0: get regulator failed
[ 0.683357] uart uart0: uart0 supply uart not found, using dummy regulator
[ 0.690572] uart0: ttyS0 at MMIO 0x2500000 (irq = 34, base_baud = 1500000) is a SUNXI
[ 0.698468] sw_console_setup()1808 - console setup baud 115200 parity n bits 8, flow n
[ 0.706474] printk: console [ttyS0] enabled
[ 0.715372] printk: bootconsole [earlycon0] disabled
[ 0.726673] sun8iw20-pinctrl pio: pio supply vcc-pg not found, using dummy regulator
[ 0.735725] uart uart3: get regulator failed
[ 0.740499] uart uart3: uart3 supply uart not found, using dummy regulator
[ 0.748562] uart3: ttyS3 at MMIO 0x2500c00 (irq = 35, base_baud = 1500000) is a SUNXI
[ 0.758420] misc dump reg init
[ 0.764979] libphy: Fixed MDIO Bus: probed
[ 0.769855] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.777208] sunxi-ehci: EHCI SUNXI driver
[ 0.782076] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.789039] sunxi-ohci: OHCI SUNXI driver
[ 0.794180] usbcore: registered new interface driver uas
[ 0.800215] usbcore: registered new interface driver usb-storage
[ 0.807022] usbcore: registered new interface driver ums-alauda
[ 0.813750] usbcore: registered new interface driver ums-cypress
[ 0.820498] usbcore: registered new interface driver ums-datafab
[ 0.827290] usbcore: registered new interface driver ums_eneub6250
[ 0.834270] usbcore: registered new interface driver ums-freecom
[ 0.841019] usbcore: registered new interface driver ums-isd200
[ 0.847711] usbcore: registered new interface driver ums-jumpshot
[ 0.854579] usbcore: registered new interface driver ums-karma
[ 0.861149] usbcore: registered new interface driver ums-onetouch
[ 0.868073] usbcore: registered new interface driver ums-realtek
[ 0.874849] usbcore: registered new interface driver ums-sddr09
[ 0.881532] usbcore: registered new interface driver ums-sddr55
[ 0.888215] usbcore: registered new interface driver ums-usbat
[ 0.894813] usbcore: registered new interface driver idmouse
[ 0.901932] sunxi_gpadc_init,2151, success
[ 0.906917] sunxi_gpadc_setup: get channel scan data failed
[ 0.913456] input: sunxi-gpadc0 as /devices/virtual/input/input1
[ 0.921437] sunxi-rtc 7090000.rtc: errata__fix_alarm_day_reg_default_value(): ALARM0_DAY_REG=0, set it to 1
[ 0.933535] sunxi-rtc 7090000.rtc: registered as rtc0
[ 0.939324] sunxi-rtc 7090000.rtc: setting system clock to 1970-01-01T00:00:04 UTC (4)
[ 0.948215] sunxi-rtc 7090000.rtc: sunxi rtc probed
[ 0.954153] i2c /dev entries driver
[ 0.958181] IR NEC protocol handler initialized
[ 0.963702] sun8iw20-pinctrl pio: pio supply vcc-pb not found, using dummy regulator
[ 0.972668] sunxi-rc-recv 7040000.s_cir: sunxi_irrx_resource_get: get ir protocol failed
[ 0.981785] Registered IR keymap rc_map_sunxi
[ 0.986848] rc rc0: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0
[ 0.995555] rc rc0: lirc_dev: driver sunxi-rc-recv registered at minor = 0, raw IR receiver, no transmitter
[ 1.006688] input: sunxi-ir as /devices/platform/soc@3000000/7040000.s_cir/rc/rc0/s_cir_rx
[ 1.016976] sunxi cedar version 1.1
[ 1.021086] sunxi-cedar 1c0e000.ve: Adding to iommu group 0
[ 1.027386] VE: failed to get alias ve id
[ 1.027386]
[ 1.033535] VE: sunxi_cedar_probe power-domain init!!!
[ 1.039268] VE: install start!!!
[ 1.039268]
[ 1.044827] VE: cedar-ve the get irq is 41
[ 1.044827]
[ 1.051288] VE: ve_debug_proc_info:(ptrval), data:(ptrval), lock:(ptrval)
[ 1.051288]
[ 1.060556] VE: install end!!!
[ 1.060556]
[ 1.065629] VE: sunxi_cedar_probe
[ 1.070911] sunxi-wdt 20500a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.080070] Bluetooth: HCI UART driver ver 2.3
[ 1.085054] Bluetooth: HCI UART protocol H4 registered
[ 1.090800] Bluetooth: HCI UART protocol BCSP registered
[ 1.096733] Bluetooth: XRadio Bluetooth LPM Mode Driver Ver 1.0.10
[ 1.103960] [XR_BT_LPM] bluesleep_probe: bt_wake polarity: 1
[ 1.110346] [XR_BT_LPM] bluesleep_probe: host_wake polarity: 1
[ 1.116880] [XR_BT_LPM] bluesleep_probe: wakeup source is disabled!
[ 1.116880]
[ 1.125533] [XR_BT_LPM] bluesleep_probe: uart_index(1)
[ 1.134495] sunxi-mmc 4020000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 1.144447] sunxi-mmc 4020000.sdmmc: ***ctl-spec-caps*** 8
[ 1.150673] sunxi-mmc 4020000.sdmmc: No vmmc regulator found
[ 1.157013] sunxi-mmc 4020000.sdmmc: No vqmmc regulator found
[ 1.163430] sunxi-mmc 4020000.sdmmc: No vdmmc regulator found
[ 1.169843] sunxi-mmc 4020000.sdmmc: No vd33sw regulator found
[ 1.176401] sunxi-mmc 4020000.sdmmc: No vd18sw regulator found
[ 1.182938] sunxi-mmc 4020000.sdmmc: No vq33sw regulator found
[ 1.189440] sunxi-mmc 4020000.sdmmc: No vq18sw regulator found
[ 1.196459] sunxi-mmc 4020000.sdmmc: Got CD GPIO
[ 1.201897] sunxi-mmc 4020000.sdmmc: set cd-gpios as 24M fail
[ 1.208606] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.219738] sunxi-mmc 4020000.sdmmc: no vqmmc,Check if there is regulator
[ 1.239867] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.264264] sunxi-mmc 4020000.sdmmc: detmode:gpio irq
[ 1.269924] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.272816] sunxi-mmc 4021000.sdmmc: SD/MMC/SDIO Host Controller Driver(v4.21 2021-11-18 10:02)
[ 1.284685] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.291399] sunxi-mmc 4021000.sdmmc: ***ctl-spec-caps*** 8
[ 1.305109] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.308874] sunxi-mmc 4021000.sdmmc: No vmmc regulator found
[ 1.323374] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.326695] sunxi-mmc 4021000.sdmmc: No vqmmc regulator found
[ 1.344646] sunxi-mmc 4021000.sdmmc: No vdmmc regulator found
[ 1.351051] sunxi-mmc 4021000.sdmmc: No vd33sw regulator found
[ 1.357568] sunxi-mmc 4021000.sdmmc: No vd18sw regulator found
[ 1.364084] sunxi-mmc 4021000.sdmmc: No vq33sw regulator found
[ 1.370585] sunxi-mmc 4021000.sdmmc: No vq18sw regulator found
[ 1.377119] sunxi-mmc 4021000.sdmmc: Cann't get pin bias hs pinstate,check if needed
[ 1.386541] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.388518] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.397679] sunxi-mmc 4021000.sdmmc: no vqmmc,Check if there is regulator
[ 1.411189] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.425750] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.426688] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.437539] sunxi-mmc 4020000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 1.460700] mmc0: new high speed SDHC card at address aaaa
[ 1.461588] sunxi-mmc 4021000.sdmmc: detmode:manually by software
[ 1.468146] mmcblk0: mmc0:aaaa SC16G 14.8 GiB
[ 1.475006] usbcore: registered new interface driver usbhid
[ 1.484920] usbhid: USB HID core driver
[ 1.489225] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.489691] exFAT: Version 1.3.0
[ 1.505756] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 1.506503] usbcore: registered new interface driver snd-usb-audio
[ 1.524327] sunxi-mmc 4021000.sdmmc: card claims to support voltages below defined range
[ 1.533857] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 1.536281] [AUDIOCODEC][sunxi_codec_parse_params][2412]:digital_vol:0, lineout_vol:26, mic1gain:31, mic2gain:31 pa_msleep:120, pa_level:1, pa_pwr_level:1
[ 1.536281]
[ 1.542435] GPT:626727 != 31116287
[ 1.559485] [AUDIOCODEC][sunxi_codec_parse_params][2448]:adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:0, dachpf:0
[ 1.563303] GPT:Alternate GPT header not at the end of the disk.
[ 1.574525] [AUDIOCODEC][sunxi_internal_codec_probe][2609]:codec probe finished
[ 1.580662] GPT:626727 != 31116287
[ 1.590127] debugfs: Directory '203034c.dummy_cpudai' with parent 'audiocodec' already present!
[ 1.592697] GPT: Use GNU Parted to correct GPT errors.
[ 1.592777] mmcblk0: p1 p2 p3 p4 p5
[ 1.602654] [SNDCODEC][sunxi_card_init][583]:card init finished
[ 1.619467] sunxi-codec-machine 2030340.sound: 2030000.codec <-> 203034c.dummy_cpudai mapping ok
[ 1.630611] input: audiocodec sunxi Audio Jack as /devices/platform/soc@3000000/2030340.sound/sound/card0/input3
[ 1.642819] [SNDCODEC][sunxi_card_dev_probe][836]:register card finished
[ 1.651134] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: register device finished!
[ 1.659649] sunxi-rpaf-dsp soc@3000000:rpaf-dsp@203034c: [rpaf_dsp0] probe finished!
[ 1.668340] [SNDCODEC][sunxi_hs_init_work][259]:resume-->report switch
[ 1.672576] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: id:sunxi,dsp-msgbox new channel: 0x1 -> 0x101!
[ 1.686951] rpmsg_hifi 3003000.msgbox.sunxi,dsp-msgbox.1.257: rpmsg hifi[0] client driver is probed
[ 1.699190] NET: Registered protocol family 10
[ 1.704217] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.704326] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 1.716711] Segment Routing with IPv6
[ 1.731529] sunxi-mmc 4021000.sdmmc: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 1.732338] NET: Registered protocol family 17
[ 1.748508] Bluetooth: RFCOMM TTY layer initialized
[ 1.754059] Bluetooth: RFCOMM socket layer initialized
[ 1.759896] Bluetooth: RFCOMM ver 1.11
[ 1.764141] 8021q: 802.1Q VLAN Support v1.8
[ 1.768996] mmc1: new high speed SDIO card at address 0001
[ 1.769546] Registering SWP/SWPB emulation handler
[ 1.780885] Loading compiled-in X.509 certificates
[ 1.805677] sunxi-i2c sunxi-i2c3: sunxi-i2c3 supply twi not found, using dummy regulator
[ 1.815614] sunxi-i2c sunxi-i2c3: probe success
[ 1.863421] get ehci0-controller wakeup-source is fail.
[ 1.869383] sunxi ehci0-controller don't init wakeup source
[ 1.875755] [sunxi-ehci0]: probe, pdev->name: 4101000.ehci0-controller, sunxi_ehci: 0xc0c797e8, 0x:c886d000, irq_no:3a
[ 1.887792] [sunxi-ehci0]: Not init ehci0
[ 1.892695] get ohci0-controller wakeup-source is fail.
[ 1.898675] sunxi ohci0-controller don't init wakeup source
[ 1.904945] [sunxi-ohci0]: probe, pdev->name: 4101400.ohci0-controller, sunxi_ohci: 0xc0c79a78
[ 1.914610] [sunxi-ohci0]: Not init ohci0
[ 1.919480] get ehci1-controller wakeup-source is fail.
[ 1.925452] sunxi ehci1-controller don't init wakeup source
[ 1.931714] [sunxi-ehci1]: probe, pdev->name: 4200000.ehci1-controller, sunxi_ehci: 0xc0c79d08, 0x:c8877000, irq_no:3c
[ 1.943950] sunxi-ehci 4200000.ehci1-controller: 4200000.ehci1-controller supply hci not found, using dummy regulator
[ 1.957410] sunxi-ehci 4200000.ehci1-controller: EHCI Host Controller
[ 1.964714] sunxi-ehci 4200000.ehci1-controller: new USB bus registered, assigned bus number 1
[ 1.974682] sunxi-ehci 4200000.ehci1-controller: irq 60, io mem 0x04200000
[ 2.012150] sunxi-ehci 4200000.ehci1-controller: USB 2.0 started, EHCI 1.00
[ 2.020826] hub 1-0:1.0: USB hub found
[ 2.025116] hub 1-0:1.0: 1 port detected
[ 2.030357] get ohci1-controller wakeup-source is fail.
[ 2.036376] sunxi ohci1-controller don't init wakeup source
[ 2.042634] [sunxi-ohci1]: probe, pdev->name: 4200400.ohci1-controller, sunxi_ohci: 0xc0c79f98
[ 2.052548] sunxi-ohci 4200400.ohci1-controller: 4200400.ohci1-controller supply hci not found, using dummy regulator
[ 2.064862] sunxi-ohci 4200400.ohci1-controller: OHCI Host Controller
[ 2.072174] sunxi-ohci 4200400.ohci1-controller: new USB bus registered, assigned bus number 2
[ 2.082084] sunxi-ohci 4200400.ohci1-controller: irq 61, io mem 0x04200400
[ 2.136834] random: fast init done
[ 2.157007] hub 2-0:1.0: USB hub found
[ 2.161270] hub 2-0:1.0: 1 port detected
[ 2.168116] sun8iw20-pinctrl pio: pin PB6 already requested by 2502c00.twi; cannot claim for pio:38
[ 2.178357] sun8iw20-pinctrl pio: pin-38 (pio:38) status -22
[ 2.184718] ERR: id gpio_request failed
[ 2.191359] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 2.202535] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[ 2.209993] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 2.212170] clk: Not disabling unused clocks
[ 2.219696] cfg80211: failed to load regulatory.db
[ 2.224436] ALSA device list:
[ 2.233182] #0: audiocodec
[ 2.236414] alloc_fd: slot 0 not NULL!
[ 2.249058] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
[ 2.258253] VFS: Mounted root (ext4 filesystem) readonly on device 179:5.
[ 2.268614] devtmpfs: mounted
[ 2.273632] Freeing unused kernel memory: 1024K
[ 2.322303] Run /sbin/init as init process
[ 2.463111] EXT4-fs (mmcblk0p5): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [ 2.786337] udevd[1083]: starting version 3.2.11
[ 2.806417] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.814977] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.822344] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.854364] udevd[1084]: starting eudev-3.2.11
[ 3.258841] 8189fs: loading out-of-tree module taints kernel.
[ 3.269759] 8189fs: module uses symbol (kernel_read) from namespace VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver, but does not import it.
[ 3.285134] 8189fs: Unknown symbol kernel_read (err -22)
done
Saving random seed: OK
Starting system message bus: done
Starting iptables: OK
Starting network: OK
Starting sntp: sntp 4.2.8p15@1.3728-o Tue Jun 14 15:12:05 UTC 2022 (1)
pool.ntp.org lookup error Temporary failure in name resolution
FAIL
Starting ntpd: OK
[ 8.772175] random: crng init done
[ 8.775990] random: 6 urandom warning(s) missed due to ratelimiting
ssh-keygen: generating new host keys: RSA DSA ECDSA ED25519
Starting sshd: OK
Starting vsftpd: OK
Starting swupdate: OK
Welcome to MangoPi Dual报错的位置应该是
[ 3.285134] 8189fs: Unknown symbol kernel_read (err -22)buildroot里面选的是
Symbol: BR2_PACKAGE_RTL8189FS [=y]
│ Type : bool
│ Prompt: rtl8189fs
│ Location:
│ -> Target packages
│ -> Hardware handling
│ Defined at package/rtl8189fs/Config.in:1
│ Depends on: BR2_LINUX_KERNEL [=y]
│ 离线
折腾了一下发现是rtl8189的驱动有点小问题,打了个patch就能识别了
diff --git a/os_dep/linux/os_intfs.c b/os_dep/linux/os_intfs.c
index 801e126..76ebff1 100644
--- a/os_dep/linux/os_intfs.c
+++ b/os_dep/linux/os_intfs.c
@@ -21,6 +21,7 @@ MODULE_LICENSE("GPL");
MODULE_DESCRIPTION("Realtek Wireless Lan Driver");
MODULE_AUTHOR("Realtek Semiconductor Corp.");
MODULE_VERSION(DRIVERVERSION);
+MODULE_IMPORT_NS(VFS_internal_I_am_really_a_filesystem_and_am_NOT_a_driver);
/* module param defaults */
int rtw_chip_version = 0x00;
diff --git a/os_dep/linux/rtw_cfgvendor.c b/os_dep/linux/rtw_cfgvendor.c
index 886d7a3..d07cbe6 100644
--- a/os_dep/linux/rtw_cfgvendor.c
+++ b/os_dep/linux/rtw_cfgvendor.c
@@ -1748,8 +1748,10 @@ static const struct wiphy_vendor_command rtw_vendor_cmds[] = {
.flags = WIPHY_VENDOR_CMD_NEED_WDEV | WIPHY_VENDOR_CMD_NEED_NETDEV,
.doit = rtw_cfgvendor_gscan_get_capabilities,
#if (LINUX_VERSION_CODE >= KERNEL_VERSION(5, 3, 0))
- .policy = VENDOR_CMD_RAW_DATA,
+ .policy = VENDOR_CMD_RAW_DATA,
+ .maxattr = 1
{然后记得MQ-R的引脚和MQ-DUAL的不一样 要改一下设备树
rfkill: rfkill@0 {
compatible = "allwinner,sunxi-rfkill";
chip_en;
power_en;
pinctrl-0 = <&wlan_pins_a>;
pinctrl-names = "default";
status = "disabled";
wlan: wlan@0 {
compatible = "allwinner,sunxi-wlan";
clock-names = "32k-fanout1";
clocks = <&ccu CLK_FANOUT1_OUT>;
wlan_busnum = <0x1>;
wlan_regon = <&pio PG 12 GPIO_ACTIVE_HIGH>;
wlan_hostwake = <&pio PG 10 GPIO_ACTIVE_HIGH>;
/*wlan_power = "VCC-3V3";*/
/*wlan_power_vol = <3300000>;*/
/*interrupt-parent = <&pio>;
interrupts = < PG 10 IRQ_TYPE_LEVEL_HIGH>;*/
wakeup-source;
bt: bt@0 {
compatible = "allwinner,sunxi-bt";
/*bt_power_num = <0x01>;*/
/*bt_power = "axp803-dldo1";*/
/*bt_io_regulator = "axp803-dldo1";*/
/*bt_io_vol = <3300000>;*/
/*bt_power_vol = <330000>;*/
bt_rst_n = <&pio PG 15 GPIO_ACTIVE_LOW>;
btlpm: btlpm@0 {
compatible = "allwinner,sunxi-btlpm";
uart_index = <0x1>;
bt_wake = <&pio PG 14 GPIO_ACTIVE_HIGH>;
bt_hostwake = <&pio PG 13 GPIO_ACTIVE_HIGH>;
};最后来个成功的log
Starting klogd: OK
Running sysctl: OK
Populating /dev using udev: [ 2.803465] udevd[1082]: starting version 3.2.11
[ 2.827674] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.838221] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.845604] random: udevd: uninitialized urandom read (16 bytes read)
[ 2.877616] udevd[1084]: starting eudev-3.2.11
[ 3.286062] 8189fs: loading out-of-tree module taints kernel.
[ 3.307545] RTL871X: module init start
[ 3.311867] RTL871X: rtl8189fs v4.3.24.8_22657.20170607
[ 3.358075] RTL871X: HW EFUSE
[ 3.361739] RTL871X: hal_com_config_channel_plan chplan:0x20
[ 3.546884] RTL871X: rtw_regsty_chk_target_tx_power_valid return _FALSE for band:0, path:0, rs:0, t:-1
[ 3.558479] RTL871X: rtw_ndev_init(wlan0) if1 mac_addr=94:a4:08:c1:33:fb
[ 3.568532] RTL871X: module init ret=0离线
楼主能测下带宽吗? 用iperf(Buildroot里打开)
@梦程
楼主,你好,请问能否详细说一下。特别是打补丁的那部分
