楼主 # 2022-06-17 01:30:41
varzhou
已发帖子: 109
夜深了,活跃一下V3S的SPI使用多个CS的问题
看了论坛中大佬的说法,5.x内核是ok的,但是我加上之后一直提示cs被already use,所以仔细查看了内核,原来是reg属性搞的鬼
贴修改
硬件连接:
SPI--》PC0", "PC1", "PC3"
CS0 -->"PC2"
CS1 --> "PB4"
注意IO占用问题。
sun8i0v3s.dtsi中
			spi0_pins: spi0-pins {
				pins = "PC0", "PC1", "PC2","PC3";//CLK MOSI MISO CS WP
				function = "spi0";
		spi0: spi@1c68000 {
			compatible = "allwinner,sun8i-h3-spi";
			reg = <0x01c68000 0x1000>;
			interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
			clocks = <&ccu CLK_BUS_SPI0>, <&ccu CLK_SPI0>;
			clock-names = "ahb", "mod";
			num-cs = <2>;
/*			pinctrl-names = "default";*/
/*			pinctrl-0 = <&spi0_pins spi0_pin_lcd>;*/
			resets = <&ccu RST_BUS_SPI0>;
			status = "disabled";
			#address-cells = <1>;
			#size-cells = <0>;
//以上基本无改动
&pio {
	spi0_cs_pins: spi0_cs_pins {
	    pins = "PC2", "PB4";
	    function = "gpio_out";
&spi0 {
	pinctrl-0 = <&spi0_pins &spi0_cs_pins>;
	cs-gpios = <&pio 2 2 GPIO_ACTIVE_HIGH>, <&pio 1 4 GPIO_ACTIVE_HIGH>;
	flash: W25M02GV@0 {
		#size-cells = <1>;
		compatible = "spi-nand";
		reg = <0>;
		partitions {
            #size-cells = <1>;
            partition@0 {
                label = "u-boot";
                reg = <0x000000 0x100000>;
                read-only;
            partition@100000 {
                label = "dtb";
                reg = <0x100000 0x10000>;
                read-only;
            partition@110000 {
                label = "kernel";
                reg = <0x110000 0x400000>;
                read-only;
            partition@510000 {
                label = "rootfs";
                reg = <0x510000 0xAF0000>;
	st7789v: st7789v@1{
		compatible = "sitronix,st7789v";
		reg = <1>;
        spi-cpol;
        spi-cpha;
		dc-gpios = <&pio 1 5 GPIO_ACTIVE_LOW>;
		//backlight
        rotate = <270>;
        fps = <60>;
        buswidth = <8>;
以上改动后,内核配置上ST7789V驱动即可ok
战术撤退
#1 2022-06-17 09:43:09
所在地: 你猜
已发帖子: 3,388
Re: 夜深了,活跃一下V3S的SPI使用多个CS的问题
感谢楼主热心分享
#2 2022-06-18 10:09:04
abnerl
已发帖子: 64
@varzhou
Linux SPI只有一个设备的话,CS会始终有效,如何才能做到SPI发完数据,CS自动失效,再次传输数据时CS自动有效,就是说CS不用的时候自动失效,用的时候自动有效
楼主 #3 2022-06-18 17:05:50
varzhou
已发帖子: 109
abnerl 说:
@varzhou
你说的无效和有效是说CS用的时候是CS,不用时候是其他功能IO的意思吗?
#4 2022-06-19 14:48:00
wh201906
已发帖子: 50
可能是说有数据的时候CS拉低没数据的时候CS拉高?因为有些设备的SPI接口要检测到CS的上升沿才会把数据读进去
#5 2022-06-20 12:34:00
abnerl
已发帖子: 64
wh201906 说:
理解完全正确,这类设备也不少
#6 2022-06-20 12:34:50
abnerl
已发帖子: 64
@varzhou
是说有数据的时候CS拉低没数据的时候CS拉高,因为有些设备的SPI接口要检测到CS的上升沿才会把数据读进去,CS拉高无效期间,不会做GPIO用途,只是让选择失效而已
楼主 #7 2022-06-22 09:32:27
varzhou
已发帖子: 109
abnerl 说:
@varzhou
加上spi-cs-high属性就好了
楼主 #8 2022-06-22 09:34:06
varzhou
已发帖子: 109
abnerl 说:
@varzhou
具体code中表现为:
if (of_find_property(nc, "spi-cs-high", NULL))
                spi->mode |= SPI_CS_HIGH;
#9 2022-06-24 12:18:00
abnerl
已发帖子: 64
@varzhou
这是设备树指定CS极性,并不会在SPI数据传输完后,拉到相反电平,试过不行,用的IMX8芯片
楼主 #10 2022-06-27 11:47:07
varzhou
已发帖子: 109
abnerl 说:
@varzhou
验证是可以的,但是在构造spi的xfer时候,需要设计.cs_change = 1,才能生效
        if (xfer->cs_change) {
            if (list_is_last(&xfer->transfer_list,
                     &msg->transfers)) {
                keep_cs = true;
            } else {
                spi_set_cs(msg->spi, false);
                udelay(10);
                spi_set_cs(msg->spi, true);
#11 2022-06-27 18:34:07
abnerl
已发帖子: 64
@varzhou
  NXP芯片好像没有这种自动拉CS到反向操作,我是在驱动里改了一下,加了一句类似
spi_set_cs(msg->spi, false);这个操作
