楼主 #1 2017-10-12 10:15:22
陆闻天
已发帖子: 34
请问ESP32解码mp3有什么合适方案?
最近公司想做一款类似儿童早教机的产品,
请大家不吝推荐
#2 2017-10-12 10:23:53
已发帖子: 9,370
Re: 请问ESP32解码mp3有什么合适方案?
软解或者加超贵的vs1053
楼主 #3 2017-10-12 10:37:26
陆闻天
已发帖子: 34
软解或者加超贵的vs1053
那有mp3解码库推荐吗?
#4 2017-10-12 10:39:52
已发帖子: 9,370
https://www.helixcommunity.org/projects/datatype/mp3dec
fixed-point
试一试这个:
Memory Usage
ROM = 13446 Bytes (const globals)
RAM = 23816 Bytes (heap)
Total Data Memory = 37262 Bytes
Code Size = 21000 Bytes (approximately - depends on compiler)
楼主 #5 2017-10-12 10:50:50
陆闻天
已发帖子: 34
可以先在Windows下用电脑编译试一试, 毕竟MSVC调试更方便。
#6 2017-10-12 17:17:56
已发帖子: 9,370
陆闻天 说:
搞定mp3解码, 抄的, 编译环境MSVC2015, 有需要的拿去用吧.
#define READBUF_SIZE 4000
char readBuf[READBUF_SIZE];
short output[READBUF_SIZE*10];
int main()
    HMP3Decoder hMP3Decoder;
    MP3FrameInfo mp3FrameInfo;
    hMP3Decoder = MP3InitDecoder();
    if (hMP3Decoder == 0)
        // This means the memory allocation failed. This typically happens if there is not
        // enough heap memory. Recompile the code with additional heap memory.
        while (1);
    char* input = &readBuf[0];
    FILE* mp3File = fopen("d:\\tkzc.mp3", "rb");
    /* Reset counters */
    int bytesLeft = 0;
    int outOfData = 0;
    char* readPtr = readBuf;
    int br = fread(readBuf, 1, READBUF_SIZE, mp3File);
    bytesLeft += br;
    if ((br <= 0)) return -1;
    while (1)
        /* find start of next MP3 frame - assume EOF if no sync found */
        int offset = MP3FindSyncWord(readPtr, bytesLeft);
        if (offset < 0)
            outOfData = 1;
            break;
            readPtr += offset;                         //data start point
            bytesLeft -= offset;                 //in buffer
            int errs = MP3Decode(hMP3Decoder, &readPtr, &bytesLeft, output, 0);
            if (bytesLeft < READBUF_SIZE)
                memmove(readBuf, readPtr, bytesLeft);
                int br = fread(readBuf + bytesLeft, 1, READBUF_SIZE - bytesLeft, mp3File);
                if ((br <= 0)) break;
                if (br < READBUF_SIZE - bytesLeft)
                    memset(readBuf + bytesLeft + br, 0, READBUF_SIZE - bytesLeft - br);
                bytesLeft = READBUF_SIZE;
                readPtr = readBuf;
            MP3GetLastFrameInfo(hMP3Decoder, &mp3FrameInfo);
    fclose(mp3File);
#7 2017-10-13 21:02:50
沉鱼
已发帖子: 161
好帖好帖,软解码mp3有着落了
