@muzhi大佬留下的帖子,找到了usb和串口
感谢@哇酷小二打赏了5个积分,下载了这个工具,尝试flash可以烧写,但是板载flash只有4mb,只能随便写点东西,开机自动进fel模式
尝试挂载tf卡,提示linux启动成功,但是并没有u盘弹出,目前串口线还没有接,看不到串口信息。
今天接上了串口,但还是无法挂载u盘,下面是开机的串口输出,小白看不太明白,有没有大佬帮看看
U-Boot 2018.01-05683-g5e86a9a-dirty (May 17 2019 - 03:40:11 -0400) Allwinner Technology
Model: Lichee Pi Nano
DRAM: 32 MiB
MMC: SUNXI SD/MMC: 0
SF: unrecognized JEDEC id bytes: c8, 40, 16
*** Warning - spi_flash_probe_bus_cs() failed, using default environment
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Net: No ethernet found.
No controllers found
## Loading init Ramdisk from Legacy Image at 80d00000 ...
Image Name:
Image Type: ARM Linux RAMDisk Image (uncompressed)
Data Size: 1840690 Bytes = 1.8 MiB
Load Address: 00000000
Entry Point: 00000000
Verifying Checksum ... OK
Loading Ramdisk to 8153e000, end 816ff632 ... OK
Loading Device Tree to 81539000, end 8153de2c ... OK
[ 0.000000] Linux version 4.19.0-rc3-licheepi-nano+ (root@ubuntu) (gcc version 7.4.1 20181213 [linaro-7.4-2019.02 revision 56ec6f6b99cc167ff0c2f8e1a2eed33b1edc85d4] (Linaro GCC 7.4-2019.02)) #11 Fri May 17 23:15:40 EDT 2019
[ 0.000000] random: get_random_bytes called from start_kernel+0x88/0x3ec with crng_init=0
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 8128
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait root=/dev/ram0 rdinit=/linuxrc earlyprintk
[ 0.000000] Memory: 24020K/32768K available (4095K kernel code, 198K rwdata, 920K rodata, 1024K init, 214K bss, 8748K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] vmalloc : 0xc2800000 - 0xff800000 ( 976 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xc2000000 ( 32 MB)
[ 0.000000] .text : 0x(ptrval) - 0x(ptrval) (5088 kB)
[ 0.000000] .init : 0x(ptrval) - 0x(ptrval) (1024 kB)
[ 0.000000] .data : 0x(ptrval) - 0x(ptrval) ( 199 kB)
[ 0.000000] .bss : 0x(ptrval) - 0x(ptrval) ( 215 kB)
[ 0.000048] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[ 0.000117] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000603] Console: colour dummy device 80x30
[ 0.000729] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070252] pid_max: default: 32768 minimum: 301
[ 0.070760] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.070808] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.072055] CPU: Testing write buffer coherency: ok
[ 0.073914] Setting up static identity map for 0x80100000 - 0x8010003c
[ 0.076521] devtmpfs: initialized
[ 0.083173] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.083244] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.083463] pinctrl core: initialized pinctrl subsystem
[ 0.084820] NET: Registered protocol family 16
[ 0.086129] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088065] cpuidle: using governor menu
[ 0.107516] SCSI subsystem initialized
[ 0.107851] usbcore: registered new interface driver usbfs
[ 0.108064] usbcore: registered new interface driver hub
[ 0.108266] usbcore: registered new device driver usb
[ 0.110341] clocksource: Switched to clocksource timer
[ 0.135295] NET: Registered protocol family 2
[ 0.137190] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.137295] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137362] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137415] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.137695] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.137760] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.138247] NET: Registered protocol family 1
[ 0.139095] Unpacking initramfs...
[ 0.662286] Freeing initrd memory: 1800K
[ 0.664263] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.689787] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.690625] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.733946] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.733994] io scheduler noop registered
[ 0.734017] io scheduler deadline registered
[ 0.734751] io scheduler cfq registered (default)
[ 0.734790] io scheduler mq-deadline registered
[ 0.734811] io scheduler kyber registered
[ 0.737563] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.749457] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.906875] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.912970] console [ttyS0] disabled
[ 0.933244] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 1.357947] console [ttyS0] enabled
[ 1.383818] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 24, base_baud = 6250000) is a 16550A
[ 1.408858] loop: module loaded
[ 1.415950] m25p80 spi0.0: found gd25q32, expected w25q128
[ 1.423834] m25p80 spi0.0: gd25q32 (4096 Kbytes)
[ 1.444820] 1 fixed-partitions partitions found on MTD device spi0.0
[ 1.451313] Creating 1 MTD partitions on "spi0.0":
[ 1.456130] 0x000000000000-0x000002000000 : "all"
[ 1.460896] mtd: partition "all" extends beyond the end of device "spi0.0" -- size truncated to 0x400000
[ 1.473468] usbcore: registered new interface driver usb-storage
[ 1.479636] i2c /dev entries driver
[ 1.485459] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.1
[ 1.518853] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.526813] usbcore: registered new interface driver usbhid
[ 1.532503] usbhid: USB HID core driver
[ 1.537604] NET: Registered protocol family 17
[ 1.544479] random: fast init done
[ 1.555937] Freeing unused kernel memory: 1024K
[ 1.560792] Run /linuxrc as init process
can't open /dev/null: No such file or directory
Starting syslogd: OK
Starting klogd: OK
Starting mdev...
/etc/init.d/S10mdev: line 9: can't create /proc/sys/kernel/hotplug: nonexistent directory
[ 1.911337] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.936380] mmc0: new high speed SDHC card at address 21dd
[ 1.944721] mmcblk0: mmc0:21dd APPSD 29.5 GiB
[ 1.971958] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.978842] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.986936] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.993944] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.000907] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.069051] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.075612] print_req_error: I/O error, dev mmcblk0, sector 0
[ 2.081483] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 2.090124] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.097063] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.104012] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.110933] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.117758] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.124709] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 2.131234] print_req_error: I/O error, dev mmcblk0, sector 0
[ 2.136997] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 2.144295] mmcblk0: unable to read partition table
[ 5.536053] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 5.546951] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[ 5.555906] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 5.561842] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 5.574015] hub 1-0:1.0: USB hub found
[ 5.577947] hub 1-0:1.0: 1 port detected
Initializing random number generator... [ 5.667631] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network: OK
[ 5.880725] Mass Storage Function, version: 2009/09/11
[ 5.885904] LUN: removable file: (no medium)
[ 5.890664] LUN: removable file: /dev/mmcblk0
[ 5.895045] Number of LUNs=1
[ 5.900057] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 5.907179] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 5.914311] g_mass_storage gadget: g_mass_storage ready
Welcome to Buildroot
buildroot login: 离线
今天浏览帖子发现了一个usb_id的引脚,就尝试了一下把PE2上拉,这次在fel模式下usb启动linux成功后出现了盘符,但是无法读取,提示请插入磁盘(见下图),后来再次尝试发现取消PE2上拉也可以出现盘符,同样无法读取。更换过sd卡,情况一样。下面附串口输出,不知道有没有遇到过类似情况的大佬
DRAM: 32 MiB
In: serial@1c25000
Out: serial@1c25000
Err: serial@1c25000
Image Name:
[ 0.000118] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000604] Console: colour dummy device 80x30
[ 0.000730] Calibrating delay loop... 203.16 BogoMIPS (lpj=1015808)
[ 0.070253] pid_max: default: 32768 minimum: 301
[ 0.073912] Setting up static identity map for 0x80100000 - 0x8010003c
[ 0.076518] devtmpfs: initialized
[ 0.083168] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.083240] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.083455] pinctrl core: initialized pinctrl subsystem
[ 0.084814] NET: Registered protocol family 16
[ 0.086120] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.088062] cpuidle: using governor menu
[ 0.107471] SCSI subsystem initialized
[ 0.107806] usbcore: registered new interface driver usbfs
[ 0.108011] usbcore: registered new interface driver hub
[ 0.108208] usbcore: registered new device driver usb
[ 0.110312] clocksource: Switched to clocksource timer
[ 0.135002] NET: Registered protocol family 2
[ 0.136875] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes)
[ 0.136973] TCP established hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137039] TCP bind hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.137092] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.137372] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.137438] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.137934] NET: Registered protocol family 1
[ 0.138774] Unpacking initramfs...
[ 0.662030] Freeing initrd memory: 1800K
[ 0.663989] workingset: timestamp_bits=30 max_order=13 bucket_order=0
[ 0.689570] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.690438] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.733784] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 253)
[ 0.733835] io scheduler noop registered
[ 0.733858] io scheduler deadline registered
[ 0.734596] io scheduler cfq registered (default)
[ 0.734638] io scheduler mq-deadline registered
[ 0.734660] io scheduler kyber registered
[ 0.737418] sun4i-usb-phy 1c13400.phy: Couldn't request ID GPIO
[ 0.749360] suniv-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.907024] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.913121] console [ttyS0] disabled
[ 0.933404] 1c25000.serial: ttyS0 at MMIO 0x1c25000 (irq = 23, base_baud = 6250000) is a 16550A
[ 1.358093] console [ttyS0] enabled
[ 1.383959] 1c25400.serial: ttyS1 at MMIO 0x1c25400 (irq = 24, base_baud = 6250000) is a 16550A
[ 1.409064] loop: module loaded
[ 1.416164] m25p80 spi0.0: found gd25q32, expected w25q128
[ 1.424027] m25p80 spi0.0: gd25q32 (4096 Kbytes)
[ 1.445147] 1 fixed-partitions partitions found on MTD device spi0.0
[ 1.451641] Creating 1 MTD partitions on "spi0.0":
[ 1.456453] 0x000000000000-0x000002000000 : "all"
[ 1.461214] mtd: partition "all" extends beyond the end of device "spi0.0" -- size truncated to 0x400000
[ 1.473795] usbcore: registered new interface driver usb-storage
[ 1.479960] i2c /dev entries driver
[ 1.485773] sunxi-mmc 1c0f000.mmc: Linked as a consumer to regulator.1
[ 1.519173] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.527137] usbcore: registered new interface driver usbhid
[ 1.532825] usbhid: USB HID core driver
[ 1.537934] NET: Registered protocol family 17
[ 1.544832] random: fast init done
[ 1.556527] Freeing unused kernel memory: 1024K
[ 1.561371] Run /linuxrc as init process
[ 1.678991] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.701012] mmc0: new high speed SDHC card at address 0007
[ 1.709286] mmcblk0: mmc0:0007 SD32G 29.0 GiB
[ 1.732296] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.739357] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.746479] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.753710] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.760836] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.816433] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.823018] print_req_error: I/O error, dev mmcblk0, sector 0
[ 1.828829] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 1.837191] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.844353] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.851565] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.858600] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.865822] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.873015] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 1.879495] print_req_error: I/O error, dev mmcblk0, sector 0
[ 1.885380] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 1.892667] mmcblk0: unable to read partition table
Starting klogd: OK
Starting mdev...
[ 5.535158] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 5.546056] usb_phy_generic usb_phy_generic.0.auto: Linked as a consumer to regulator.0
[ 5.555027] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 5.560963] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[ 5.573117] hub 1-0:1.0: USB hub found
[ 5.577042] hub 1-0:1.0: 1 port detected
Initializing random number generator... [ 5.667390] random: dd: uninitialized urandom read (512 bytes read)
done.
[ 5.882034] Mass Storage Function, version: 2009/09/11
[ 5.887270] LUN: removable file: (no medium)
[ 5.892067] LUN: removable file: /dev/mmcblk0
[ 5.896446] Number of LUNs=1
[ 5.901617] g_mass_storage gadget: Mass Storage Gadget, version: 2009/09/11
[ 5.908606] g_mass_storage gadget: userspace failed to provide iSerialNumber
[ 5.915826] g_mass_storage gadget: g_mass_storage ready
buildroot login: [ 6.192448] g_mass_storage gadget: high-speed config #1: Linux File-Backed Storage
[ 7.163819] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.171513] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.178568] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.185773] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.192962] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.200023] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.206589] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.215228] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.222323] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.229316] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.236442] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.243592] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.250745] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.257195] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.263065] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 7.393536] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.400581] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.407663] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.414840] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.421993] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.429083] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.435629] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.441480] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 7.682418] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.689449] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.696605] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.703758] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.710942] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.718044] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.724610] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.730474] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 7.739378] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.746588] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.753746] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.760879] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.768009] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.775180] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.781728] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.787495] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 7.912429] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.919423] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.926638] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.933823] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.941104] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.948282] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 7.954848] print_req_error: I/O error, dev mmcblk0, sector 0
[ 7.960705] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 8.149529] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.156625] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.163827] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.171058] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.178167] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.185351] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.191926] print_req_error: I/O error, dev mmcblk0, sector 0
[ 8.197695] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 8.482122] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.489152] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.496367] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.503527] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.510623] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.517788] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.524352] print_req_error: I/O error, dev mmcblk0, sector 0
[ 8.530121] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 8.842150] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.849149] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.856329] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.863487] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.870546] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.877926] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 8.884497] print_req_error: I/O error, dev mmcblk0, sector 0
[ 8.890358] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 9.982199] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 9.989230] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 9.996409] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 10.003550] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 10.010607] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 10.017656] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 10.024204] print_req_error: I/O error, dev mmcblk0, sector 0
[ 10.030008] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 12.612216] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.619213] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.626431] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.633640] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.640836] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.648002] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 12.654571] print_req_error: I/O error, dev mmcblk0, sector 0
[ 12.660431] Buffer I/O error on dev mmcblk0, logical block 0, async page read
[ 13.282088] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.289067] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.296284] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.303486] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.310514] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.317568] sunxi-mmc 1c0f000.mmc: data error, sending stop command
[ 13.324148] print_req_error: I/O error, dev mmcblk0, sector 0离线
后来在https://whycan.com/t_3206.html下载了一个tf卡固件,用读卡器、win32disklmanger烧录到了内存卡,插卡启动。有个情况是我烧录成功后,点击仅校验会报错,如下图。不知道我的用法对不对,最终还是无法启动,下面的是串口输出。
mmc_init: -110, time 21723
spl: mmc init failed with error: -110
SPL: Unsupported Boot Device!
### ERROR ### Please RESET the board ###离线
看来不更换flash我是折腾不了了,等解封买个大点的flash再倒腾。
