楼主 #1 2020-07-27 22:17:48
逸俊晨晖
已发帖子: 151
f1c100s移植littlevGL基于linux fb运行
移植littlevGL版本为7.0 基于linux fb运行
从littlevGL下载基于linux fb运行的littlevGL源码
https://github.com/lvgl/lv_port_linux_frame_buffer
使用cmake构建makefile 安装cmake
apt-get install cmake
在littlevGL目录下编写cmake配置文件CMakeLists.txt
cmake_minimum_required(VERSION 3.5)
project(Ui C)
#set(CMAKE_C_STANDARD 11)
SET(CROSS_COMPILE 1)
set(CMAKE_SYSTEM_NAME Linux)
#设置编译器 用buildroot里面的
set(CMAKE_C_COMPILER "/home/ljh/f1c100s/buildroot-2017.08/output/host/bin/arm-linux-gcc")
SET(TOOLCHAIN_DIR "/usr/bin/")
#SET(CMAKE_FIND_ROOT_PATH  "/usr/arm-linux-gnueabi" "/usr/arm-linux-gnueabi/lib" "/usr/arm-linux-gnueabi/include")
#include_directories(/home/biglion/project/buildroot/rootfs/include)
#link_directories(/home/biglion/project/buildroot/rootfs/lib)
link_directories(/home/ljh/f1c100s/buildroot-2017.08/rootfs/lib)
#引入所有编译用到的源码目录
	/home/ljh/f1c100s/buildroot-2017.08/rootfs/include
	lv_drivers
	lv_examples
	lvgl
	lv_drivers/display
	lv_drivers/indev
	lv_examples/assets
	lv_examples/src/lv_demo_benchmark
	lv_examples/src/lv_demo_keypad_encoder
	lv_examples/src/lv_demo_printer
	lv_examples/src/lv_demo_stress
	lv_examples/src/lv_demo_widgets
	lv_examples/src/lv_ex_get_started
	lv_examples/src/lv_ex_style
	lvgl/porting
	lvgl/src/lv_core
	lvgl/src/lv_draw
	lvgl/src/lv_font
	lvgl/src/lv_gpu
	lvgl/src/lv_hal
	lvgl/src/lv_misc
	lvgl/src/lv_themes
	lvgl/src/lv_widgets
	lvgl/tests/lv_test_core
	lvgl/tests/lv_test_objx
#通过源码目录 引入所有源文件 形成文件变量
aux_source_directory(lv_drivers LV_drivers)
aux_source_directory(lv_examples LV_examples)
aux_source_directory(lvgl LVgl)
aux_source_directory(lv_drivers/display DISPLAY)
aux_source_directory(lv_drivers/indev INDEV)
aux_source_directory(lv_examples/assets ASSETS)
aux_source_directory(lv_examples/src/lv_demo_benchmark BENCHMARK)
aux_source_directory(lv_examples/src/lv_demo_keypad_encoder ENCODER)
aux_source_directory(lv_examples/src/lv_demo_printer PRINTER)
aux_source_directory(lv_examples/src/lv_demo_stress STRESS)
aux_source_directory(lv_examples/src/lv_demo_widgets WIDGET)
aux_source_directory(lv_examples/src/lv_ex_get_started STARTED)
aux_source_directory(lv_examples/src/lv_ex_style STYLE)
aux_source_directory(lvgl/porting PORTING)
aux_source_directory(lvgl/src/lv_core CORE)
aux_source_directory(lvgl/src/lv_draw DRAW)
aux_source_directory(lvgl/src/lv_font FONT)
aux_source_directory(lvgl/src/lv_gpu GPU)
aux_source_directory(lvgl/src/lv_hal HAL)
aux_source_directory(lvgl/src/lv_misc MISC)
aux_source_directory(lvgl/src/lv_themes THEMES)
aux_source_directory(lvgl/src/lv_widgets WIDGETS)
aux_source_directory(lvgl/tests/lv_test_core TEST_CORE)
aux_source_directory(lvgl/tests/lv_test_objx TEST_OBJX)
aux_source_directory(./ CUR)
#引入所有要编译的源文件
add_executable(Ui
	${LV_drivers}
	${LV_examples}
	${LVgl}
	${DISPLAY}
	${ASSETS}
	${BENCHMARK}
	${ENCODER}
	${PRINTER}
	${STRESS}
	${WIDGET}
	${STARTED}
	${STYLE}
	${PORTING}
	${CORE}
	${DRAW}
	${FONT}
	${GPU}
	${HAL}
	${MISC}
	${THEMES}
	${WIDGETS}
	${TEST_CORE}
	${TEST_OBJX}
	${CUR}
注意:每次修改CmakeLists.txt时 最好删除目录下的CMakeCache.txt和CmakeFiles文件
形成Makefile文件
cmake .
编译
make
得到应用程序Ui
发送文件到f1c100s上执行即可看演示效果
发现左上角有闪动的光标 移除方法:
echo 0 > /sys/class/graphics/fbcon/cursor_blink
echo 0 > /sys/class/vtconsole/vtcon1/bind
#2 2022-08-08 13:08:38
达子666
已发帖子: 24
Re: f1c100s移植littlevGL基于linux fb运行
内容写的很丰富,条理清晰,主要还是使用CMake进行编译,简单易懂
#3 2022-08-15 02:50:28
ad0088
这个芯片8M能装得下系统吗
#4 2022-08-25 15:52:44
a358288629
可以显示动态图片 和 播放视频吗?
