楼主 # 2022-08-16 11:20:44
titishev
已发帖子: 19
H264 encoder
Hi!
When Cedrus encodes video with size 160x128, the artefacts "pink" are presents in top left corner. Why? Chip V3s.
How to correct it?
If I choose frame size 176x144 - h264 encoder will produse normal video without this artefact/glitch.
你好!
當 Cedrus 對尺寸為 160x128 的視頻進行編碼時,“粉紅色”偽影出現在左上角。 為什麼? 芯片 V3。
如何糾正它?
如果我選擇幀大小 176x144 - h264 編碼器將產生沒有這種偽影/故障的正常視頻。
Pink
#1 2022-08-16 12:03:42
unturned3
已发帖子: 272
Re: H264 encoder
Which "Cedrus" are you using? There's a ton of forks / versions out there afaik.
楼主 #2 2022-08-16 12:35:20
titishev
已发帖子: 19
Re: H264 encoder
I use this source code: https://github.com/jemk/cedrus/tree/master/h264enc
Also I used some variations of this code (ubobrov/mzakharov) and others. Result is same.
320x240 working OK
640x480 working OK
176x144 - OK
but:
480x320 - some atifacts
400x296 - artifacts
160x120 - artifacts
160x128 - artifacts
