楼主 # 2022-09-02 14:05:03
pwwzlxz
NS2009触摸屏没有ABS_X EVENT
使用荔枝派NANO开发板,编译配置触摸屏是可以的。但是放到LVGL上触摸屏总是不能用。
使用evtest测试发现只有ABS_Y坐标,不知道是那里设置的不对。
Event: time 42.000343, type 343 (?), code 0 (?), value 931748
Event: time 73401.000003, type 3 (EV_ABS), code 1 (ABS_Y), value 667
Event: time 21.000343, type 343 (?), code 0 (?), value 971768
Event: time 21.000344, type 344 (?), code 0 (?), value 10689
Event: time 42.000344, type 344 (?), code 0 (?), value 651737
Event: time 73401.000003, type 3 (EV_ABS), code 1 (ABS_Y), value 765
Event: time 32.000344, type 344 (?), code 0 (?), value 691819
Event: time 73401.065539, -------------- SYN_REPORT ------------
Event: time 21.000344, type 344 (?), code 0 (?), value 730688
Event: time 42.000345, type 345 (?), code 0 (?), value 131739
Event: time 73401.000003, type 3 (EV_ABS), code 1 (ABS_Y), value 3361
Event: time 21.000345, type 345 (?), code 0 (?), value 171766
Event: time 21.000345, type 345 (?), code 0 (?), value 210700
Event: time 42.000345, type 345 (?), code 0 (?), value 891726
Event: time 73401.000003, type 3 (EV_ABS), code 1 (ABS_Y), value 3603
Event: time 21.000345, type 345 (?), code 0 (?), value 930679
Event: time 42.000348, type 348 (?), code 0 (?), value 931752
Event: time 73401.000003, type 3 (EV_ABS), code 1 (ABS_Y), value 3823
Event: time 21.000348, type 348 (?), code 0 (?), value 970686
#1 2022-09-02 14:54:00
已发帖子: 3,393
Re: NS2009触摸屏没有ABS_X EVENT
你这个是adc数据,并不是坐标,用关键字右上角搜搜:
ts_uinput
或者: https://cn.bing.com/search?q=ts_uinput+site%3Adebugdump.com
楼主 #2 2022-09-02 21:06:30
pwwzlxz
内核编译选上: User level driver support
build root选上:> Target packages > Libraries > Hardware handling -tslib
进入系统运行:TSLIB_TSDEVICE=/dev/input/event0 ts_calibrate
在图上点完第一个校准点后程序就退出来了。显示:ts_read_raw:NO such file or directory
请帮忙看看是怎么回事。
#3 2022-09-02 21:24:14
已发帖子: 3,393
/dev/input/event0 确认是 ns2009 生成的吗?
楼主 #4 2022-09-02 21:38:59
pwwzlxz
是的,用ts2007也是这个节点。cat 可以有数据
#5 2022-09-02 22:04:04
已发帖子: 3,393
有没有使用中断呢?
楼主 #6 2022-09-02 22:11:00
pwwzlxz
使用中断了。不过设备树里没有配置。现在配置为NS2009
#7 2022-09-02 22:19:55
已发帖子: 3,393
没有碰到这么奇怪的问题,试一试TSC2007驱动。
楼主 #8 2022-09-02 22:59:19
pwwzlxz
已经试过了,一样的情况。我用musl编译的根文件系统,有关系吗?
楼主 #9 2022-09-02 23:53:26
pwwzlxz
用musl编译编译的根文件系统不行。用uclib-ng是可以的
