楼主 # 2022-09-09 11:48:53
jiuri
pyi接口定义返字典类型,C中该如何实现
在pyi模块中定义了该接口 ,
def get_para(self)->dict:
C中参考了返列表的操作,实现不了,关键代码如下:
        PikaObj* dict = newNormalObj(New_PikaStdData_Dict);
    PikaStdData_Dict___init__(dict);
        Arg* arg = arg_setBytes(NULL, "", para1, 32);
        PikaStdData_Dict_set(dict,"para1", arg);
        arg_deinit(arg);
        arg = arg_setBytes(NULL, "", para2, 32);
        PikaStdData_Dict_set(dict,"para2", arg);
        arg_deinit(arg);
        return dict;
最近编辑记录 jiuri (2022-09-09 11:50:57)
#1 2022-09-09 13:15:39
lyon1998
已发帖子: 146
Re: pyi接口定义返字典类型,C中该如何实现
之前版本有些问题,升级到 v1.10.8,然后参考下面的示例
pyi:
def test_dict() -> dict: ...
C:
PikaObj* Test_test_dict(PikaObj* self) {
    Arg* para1 = arg_newInt(1);
    Arg* para2 = arg_newInt(2);
    PikaStdData_Dict_set(dict, "para1", para1);
    PikaStdData_Dict_set(dict, "para2", para2);
    arg_deinit(para1);
    arg_deinit(para2);
    return dict;
