楼主 # 2022-09-24 10:27:25
smiletiger
已发帖子: 127
T113超频测试
把CPU频率超频到了1.752GHz   ddr超频到1.164G,老化测试了几个小时很稳定,没任何报错,芯片表面温度为49℃,室温为26℃
- RT -     Thread Operating System
/ | \     4.1.0 build Sep 20 2022 10:33:12
2006 - 2022 Copyright by RT-Thread team
hello rt-thread 10:23:02
msh >CPU_clk=1752MHz
CPU_clk=1752MHz
DDR_clk=1164MHz
msh >core_mark
Benchmark started, please make sure it runs for at least 10s.
2K performance run parameters for coremark.
CoreMark Size    : 666
Total ticks      : 9352
Total time (secs): 9.352000
Iterations/Sec   : 5346.449957
ERROR! Must execute for at least 10 secs for a valid result!
Iterations       : 50000
Compiler version : GCC6.3.1 20170215 (release) [ARM/embedded-6-branch revision 245512]
Compiler flags   :
Memory location  : STACK
seedcrc          : 0xe9f5
[0]crclist       : 0xe714
[0]crcmatrix     : 0x1fd7
[0]crcstate      : 0x8e3a
[0]crcfinal      : 0xa14c
Errors detected
msh >memory_perf 0x46000000 0x100000
MemoryPerf version 1.0.0
Copyright (c) 2022 SummerGift (summergift2019@gmail.com)
Licensed under the MIT License version.
Memory performance testing start...
address: 0x46000000, length: 0x100000, iterations: 200
Data length : 209 MB.
8-bit write speed test begin.
Spend time : 0.165000 s.
8-bit write speed: 1271.001221 M/s.
8-bit read speed test begin.
Spend time : 0.406000 s.
8-bit Read speed: 516.539917 M/s.
16-bit write speed test begin.
Spend time : 0.083000 s.
16-bit write speed: 2526.689209 M/s.
16-bit read speed test begin.
Spend time : 0.234000 s.
16-bit Read speed: 896.218811 M/s.
32-bit write speed test begin.
Spend time : 0.054000 s.
32-bit Write speed: 3883.614746 M/s.
32-bit read speed test begin.
Spend time : 0.133000 s.
32-bit Read speed: 1576.806030 M/s.
Memory performance completed.
最高测试了稳定的频率为 1.8G和1.2G,表面温度为62℃
hello rt-thread 10:33:28
msh >CPU_clk=1800MHz
CPU_clk=1800MHz
DDR_clk=1200MHz
msh >core_mark
CoreMark Size    : 666
Total ticks      : 9147
Total time (secs): 9.147000
Iterations/Sec   : 5466.273095
Iterations       : 50000
Compiler flags   :
seedcrc          : 0xe9f5
[0]crclist       : 0xe714
Errors detected
Spend time : 0.164000 s.
8-bit write speed: 1278.751221 M/s.
Spend time : 0.399000 s.
8-bit Read speed: 525.601990 M/s.
Spend time : 0.229000 s.
16-bit Read speed: 915.786865 M/s.
Spend time : 0.051000 s.
32-bit Write speed: 4112.062500 M/s.
Spend time : 0.147000 s.
32-bit Read speed: 1426.634033 M/s.
msh >
最近编辑记录 smiletiger (2022-09-24 10:39:15)
#3 2022-09-28 12:21:47
明月惊云
Re: T113超频测试
厉害了,为什么其他吧友测试了,cpu最高的只有1.2G左右。现在问题是作为产品出货,最高主频可以到多少合适?
#4 2022-09-29 10:34:16
kakatoo
已发帖子: 88
Re: T113超频测试
牛啊, 好像其他网友测试 只有1G以下能稳定跑。
#5 2022-09-29 14:23:27
明月惊云
Re: T113超频测试
综合考虑,我打算1.2G出货。
#6 2022-09-29 14:45:26
伍零壹
已发帖子: 158
Re: T113超频测试
RT-thread现在支持T113这款芯片?
#7 2023-04-29 17:23:04
vigour1000
已发帖子: 101
Re: T113超频测试
有稳定频率是800M 手册上外设频率固定1.2G
#8 2023-05-01 07:27:04
eric_qiang
Re: T113超频测试
请问如何超频?需要硬件修改核电压供电吗?还是只修改分频寄存器?
