主板原来采用RTL8723BS,已正常使用。现在改用AP6212时,无法使用。
RTL8723SB开机log
[ 1.627824] cfg80211: failed to load regulatory.db
[ 1.633295] Waiting for root device /dev/mmcblk0p2...
[ 1.648679] mmc1: new high speed SDIO card at address 0001
[ 1.662748] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.674076] mmc0: new high speed SDXC card at address aaaa
[ 1.681056] mmcblk0: mmc0:aaaa SD64G 59.5 GiB
[ 1.689557] mmcblk0: p1 p2
AP6212开机log
[ 1.660763] cfg80211: failed to load regulatory.db
[ 1.666089] Waiting for root device /dev/mmcblk0p2...
[ 1.698405] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.709719] mmc0: new high speed SDXC card at address aaaa
[ 1.716776] mmcblk0: mmc0:aaaa SD128 119 GiB
[ 1.725166] mmcblk0: p1 p2
可以看到AP6212开机少了一个mmc1。
已经确定硬件问题。改板后再后续
