root@TinaLinux:/overlay/riscv-qt/examples/widgets/analogclock# ./analogclock -qw
s
[ 535.653672] analogclock invoked oom-killer: gfp_mask=0x100cca(GFP_HIGHUSER_MOVABLE), order=0, oom_score_adj=0
[ 535.735642] CPU: 0 PID: 606 Comm: analogclock Not tainted 5.4.61 #9
[ 535.742633] Call Trace:
[ 535.773553] [<ffffffe0000303ce>] walk_stackframe+0x0/0xa0
[ 535.822020] [<ffffffe0000305b0>] show_stack+0x2a/0x34
[ 535.849855] [<ffffffe000650328>] dump_stack+0x20/0x28
[ 536.016984] [<ffffffe00008c3c8>] dump_header+0x48/0x1a4
[ 536.112921] [<ffffffe00008bc86>] oom_kill_process+0x2d8/0x2da
[ 536.119713] [<ffffffe00008c0f4>] out_of_memory+0x92/0x2c4
[ 536.167666] [<ffffffe0000b7b3c>] __alloc_pages_slowpath+0x6c6/0x79a
[ 536.174712] [<ffffffe0000b7d52>] __alloc_pages_nodemask+0x142/0x174
[ 536.181734] [<ffffffe000088724>] pagecache_get_page+0xd0/0x212
[ 536.347335] [<ffffffe00008909c>] filemap_fault+0x352/0x61c
[ 536.353465] [<ffffffe000143c16>] ext4_filemap_fault+0x28/0x40
[ 536.543747] [<ffffffe0000a522a>] __do_fault+0x26/0xba
[ 536.549387] [<ffffffe0000a838c>] __handle_mm_fault+0x52c/0x91a
[ 536.565250] [<ffffffe0000a87a2>] handle_mm_fault+0x28/0x32
[ 536.629199] [<ffffffe00003183e>] do_page_fault+0xb8/0x2de
[ 536.635347] [<ffffffe00002f018>] ret_from_exception+0x0/0xc
[ 536.643622] Mem-Info:
[ 536.646275] active_anon:246617 inactive_anon:10 isolated_anon:0
[ 536.646275] active_file:108 inactive_file:266 isolated_file:0
[ 536.646275] unevictable:0 dirty:0 writeback:0 unstable:0
[ 536.646275] slab_reclaimable:912 slab_unreclaimable:2821
[ 536.646275] mapped:57 shmem:11 pagetables:612 bounce:0
[ 536.646275] free:1140 free_pcp:76 free_cma:0
[ 536.781031] Node 0 active_anon:986468kB inactive_anon:40kB active_file:512kB inactive_file:516kB unevictable:0kB isolated(anon):0kB isolated(file):0kB mapped:292kB dirty:0kB writeback:0kB shmem:44kB writeback_tmp:0kB unstable:0kB all_unreclaimable? yes
[ 536.963967] DMA32 free:4640kB min:4036kB low:5052kB high:6068kB active_anon:986468kB inactive_anon:40kB active_file:472kB inactive_file:520kB unevictable:0kB writepending:0kB present:1048576kB managed:1021640kB mlocked:0kB kernel_stack:1024kB pagetables:2448kB bounce:0kB free_pcp:700kB local_pcp:700kB free_cma:0kB
[ 537.046957] lowmem_reserve[]: 0 0 0
[ 537.050861] DMA32: 0*4kB 27*8kB (UME) 25*16kB (ME) 8*32kB (UE) 9*64kB (UME) 3*128kB (E) 1*256kB (E) 2*512kB (UM) 1*1024kB (M) 0*2048kB 0*4096kB = 4136kB
[ 537.120014] Free pages count per migrate typeat order: 0 1 2 3 4 5 6 7 8 9 10
[ 537.299830] zone DMA32, type Unmovable 0 1 0 1 3 0 0 1 0 0 0
[ 537.312258] zone DMA32, type Movable 0 32 11 1 1 0 0 1 1 0 0
[ 537.325388] zone DMA32, type Reclaimable 1 11 13 7 5 3 1 0 0 0 0
[ 537.362566] zone DMA32, type CMA 0 0 0 0 0 0 0 0 0 0 0
[ 537.379133] zone DMA32, type HighAtomic 0 0 0 0 0 0 0 0 0 0 0
[ 537.515948] zone DMA32, type Isolate 0 0 0 0 0 0 0 0 0 0 0
[ 537.528385] 475 total pagecache pages
[ 537.532467] 0 pages in swap cache
[ 537.536209] Swap cache stats: add 0, delete 0, find 0/0
[ 537.542033] Free swap = 0kB
[ 537.545279] Total swap = 0kB
[ 537.548507] 262144 pages RAM
[ 537.551713] 0 pages HighMem/MovableOnly
[ 537.556018] 6734 pages reserved
[ 537.559516] 2048 pages cma reserved
[ 537.563398] Tasks state (memory values in pages):
[ 537.569772] [ pid ] uid tgid total_vm rss pgtables_bytes swapents oom_score_adj name
[ 537.661056] [ 125] 0 125 415 40 28672 0 -1000 ubusd
[ 537.670304] [ 137] 0 137 671 41 32768 0 0 ash
[ 537.691685] [ 138] 0 138 406 31 28672 0 0 askfirst
[ 537.811592] [ 238] 0 238 524 51 24576 0 0 dbus-daemon
[ 537.821745] [ 239] 0 239 55716 37 49152 0 0 adbd
[ 537.833362] [ 450] 0 450 465 66 28672 0 -1000 netifd
[ 537.842679] [ 464] 0 464 2462 30 24576 0 0 MtpDaemon
[ 537.854214] [ 503] 0 503 374 23 24576 0 0 swupdate-progre
[ 537.930775] [ 545] 0 545 677 34 32768 0 0 ntpd
[ 538.028849] [ 564] 0 564 21388 131 40960 0 0 tt
[ 538.037731] [ 579] 0 579 773 51 28672 0 -1000 wpa_supplicant
[ 538.047774] [ 606] 0 606 277845 245997 2256896 0 0 analogclock
[ 538.057736] oom-kill:constraint=CONSTRAINT_NONE,nodemask=(null),task=analogclock,pid=606,uid=0
[ 538.067564] Out of memory: Killed process 606 (analogclock) total-vm:1111380kB, anon-rss:983984kB, file-rss:4kB, shmem-rss:0kB, UID:0 pgtables:2204kB oom_score_adj:0
[ 538.615413] oom_reaper: reaped process 606 (analogclock), now anon-rss:0kB, file-rss:0kB, shmem-rss:0kB
Killed环境变量如果不配置全就提示这个。
export QWS_DISPLAY="LinuxFB:mmWidth200:0"
使能了这句就会出现这样的现象。就跑成功过一次,还没记录。
现在在mq上和哪吒上都不行了。
不过qt5是可以起来的。
这是编译配置。
#!/bin/sh
PWD=`pwd`
mkdir riscv-qt
./configure \
-prefix $PWD/riscv-qt \
-opensource \
-release \
-shared \
-Declarative \
-fast \
-no-largefile \
-qt-sql-sqlite \
-qt3support \
-exceptions \
-no-xmlpatterns \
-no-script \
-no-scripttools \
-no-glib \
-no-phonon \
-svg \
-no-webkit \
-qt-zlib \
-qt-libtiff \
-qt-libpng \
-qt-libjpeg \
-make libs \
-nomake tools \
-make examples \
-make docs \
-nomake demos \
-no-nis \
-no-cups \
-no-iconv \
-no-dbus \
-xplatform qws/linux-arm-gnueabi-g++ \
-embedded riscv \
-little-endian \
-qt-freetype \
-depths 16,24,32 \
-qt-gfx-linuxfb \
-qt-gfx-transformed \
-qt-gfx-multiscreen \
-qt-gfx-vnc \
-plugin-gfx-vnc \
-plugin-gfx-linuxfb \
-no-gfx-qvfb \
-qt-kbd-linuxinput \
-qt-kbd-tty \
-no-kbd-qvfb \
-armfpa \
-no-openssl \
-no-opengl \
-no-accessibility \
-optimized-qmake \
-no-mouse-qvfb \
-qt-mouse-linuxtp \
-qt-mouse-tslib \
-pch \
-DQT_QLOCALE_USES_FCVT \
-I/home/d1-nezha/QT/tslib-1.21/riscv-tslib/include \
-L/home/d1-nezha/QT/tslib-1.21/riscv-tslib/lib \
-confirm-license 麻烦大家看看了。
最近编辑记录 liuxingkeji (2022-09-26 21:12:13)
qt4.8.7.tar.xz
编译好的文件如上。
最近编辑记录 liuxingkeji (2022-09-26 21:33:32)
帮顶,看看d1s最终qt跑出来是啥效果~~
我这边想办法跟进处理一下。
嗯嗯,好的,谢谢,感觉像文件系统问题,但是之前的被刷了,没发测了
liuxingkeji 说:哇酷小二 说:我这边想办法跟进处理一下。
64M内存爆了,可能前面处于临界状态,刚好能用.
我这边实测Qt5, 也跑不起来.
我测试时候是QT5能起来,等我回去发下D1S QT跑起来的图片
