楼主 #1 2021-02-28 18:16:51
马前卒
已发帖子: 60
Linux 应用层 C 代码 POLL 轮询 GPIO 引脚中断 (转)
https://developer.ridgerun.com/wiki/index.php/How_to_use_GPIO_signals
https://developer.ridgerun.com/wiki/index.php?title=Gpio-int-test.c
Gpio-int-test.c:
/* Copyright (c) 2011, RidgeRun
 * All rights reserved.
 * Contributors include:
 *   Todd Fischer
 *   Brad Lu
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions are met:
 * 1. Redistributions of source code must retain the above copyright
 *    notice, this list of conditions and the following disclaimer.
 * 2. Redistributions in binary form must reproduce the above copyright
 *    notice, this list of conditions and the following disclaimer in the
 *    documentation and/or other materials provided with the distribution.
 * 3. All advertising materials mentioning features or use of this software
 *    must display the following acknowledgement:
 *    This product includes software developed by the RidgeRun.
 * 4. Neither the name of the RidgeRun nor the
 *    names of its contributors may be used to endorse or promote products
 *    derived from this software without specific prior written permission.
 * THIS SOFTWARE IS PROVIDED BY RIDGERUN ''AS IS'' AND ANY
 * EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED
 * WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
 * DISCLAIMED. IN NO EVENT SHALL RIDGERUN BE LIABLE FOR ANY
 * DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES
 * (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES;
 * LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND
 * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
 * (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS
 * SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include <errno.h>
#include <unistd.h>
#include <fcntl.h>
#include <poll.h>
 * Constants
#define SYSFS_GPIO_DIR "/sys/class/gpio"
#define POLL_TIMEOUT (3 * 1000) /* 3 seconds */
#define MAX_BUF 64
 * gpio_export
int gpio_export(unsigned int gpio)
	int fd, len;
	char buf[MAX_BUF];
	fd = open(SYSFS_GPIO_DIR "/export", O_WRONLY);
	if (fd < 0) {
		perror("gpio/export");
		return fd;
	len = snprintf(buf, sizeof(buf), "%d", gpio);
	write(fd, buf, len);
	close(fd);
 * gpio_unexport
int gpio_unexport(unsigned int gpio)
	int fd, len;
	char buf[MAX_BUF];
	fd = open(SYSFS_GPIO_DIR "/unexport", O_WRONLY);
	if (fd < 0) {
		return fd;
	close(fd);
 * gpio_set_dir
int gpio_set_dir(unsigned int gpio, unsigned int out_flag)
	int fd, len;
	char buf[MAX_BUF];
	len = snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR  "/gpio%d/direction", gpio);
	fd = open(buf, O_WRONLY);
	if (fd < 0) {
		perror("gpio/direction");
		return fd;
	if (out_flag)
		write(fd, "out", 4);
		write(fd, "in", 3);
	close(fd);
 * gpio_set_value
int gpio_set_value(unsigned int gpio, unsigned int value)
	int fd, len;
	char buf[MAX_BUF];
	len = snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR "/gpio%d/value", gpio);
	if (fd < 0) {
		perror("gpio/set-value");
		return fd;
	if (value)
		write(fd, "1", 2);
		write(fd, "0", 2);
	close(fd);
 * gpio_get_value
int gpio_get_value(unsigned int gpio, unsigned int *value)
	int fd, len;
	char buf[MAX_BUF];
	char ch;
	fd = open(buf, O_RDONLY);
	if (fd < 0) {
		perror("gpio/get-value");
		return fd;
	read(fd, &ch, 1);
	if (ch != '0') {
		*value = 1;
	} else {
		*value = 0;
	close(fd);
 * gpio_set_edge
int gpio_set_edge(unsigned int gpio, char *edge)
	int fd, len;
	char buf[MAX_BUF];
	len = snprintf(buf, sizeof(buf), SYSFS_GPIO_DIR "/gpio%d/edge", gpio);
	if (fd < 0) {
		perror("gpio/set-edge");
		return fd;
	write(fd, edge, strlen(edge) + 1);
	close(fd);
 * gpio_fd_open
int gpio_fd_open(unsigned int gpio)
	int fd, len;
	char buf[MAX_BUF];
	fd = open(buf, O_RDONLY | O_NONBLOCK );
	if (fd < 0) {
		perror("gpio/fd_open");
	return fd;
 * gpio_fd_close
int gpio_fd_close(int fd)
	return close(fd);
 * Main
int main(int argc, char **argv, char **envp)
	struct pollfd fdset[2];
	int nfds = 2;
	int gpio_fd, timeout, rc;
	char *buf[MAX_BUF];
	unsigned int gpio;
	int len;
	if (argc < 2) {
		printf("Usage: gpio-int <gpio-pin>\n\n");
		printf("Waits for a change in the GPIO pin voltage level or input on stdin\n");
		exit(-1);
	gpio = atoi(argv[1]);
	gpio_export(gpio);
	gpio_set_dir(gpio, 0);
	gpio_set_edge(gpio, "rising");
	gpio_fd = gpio_fd_open(gpio);
	timeout = POLL_TIMEOUT;
	while (1) {
		memset((void*)fdset, 0, sizeof(fdset));
		fdset[0].fd = STDIN_FILENO;
		fdset[0].events = POLLIN;
		fdset[1].fd = gpio_fd;
		fdset[1].events = POLLPRI;
		rc = poll(fdset, nfds, timeout);
		if (rc < 0) {
			printf("\npoll() failed!\n");
			return -1;
		if (rc == 0) {
			printf(".");
		if (fdset[1].revents & POLLPRI) {
			lseek(fdset[1].fd, 0, SEEK_SET);
			len = read(fdset[1].fd, buf, MAX_BUF);
			printf("\npoll() GPIO %d interrupt occurred\n", gpio);
		if (fdset[0].revents & POLLIN) {
			(void)read(fdset[0].fd, buf, 1);
			printf("\npoll() stdin read 0x%2.2X\n", (unsigned int) buf[0]);
		fflush(stdout);
	gpio_fd_close(gpio_fd);
楼主 #2 2021-02-28 18:23:15
马前卒
已发帖子: 60
Re: Linux 应用层 C 代码 POLL 轮询 GPIO 引脚中断 (转)
可以设置 上升沿/下降沿/两个都有 触发
可以监控多个GPIO
轮询时间间隔默认3秒,可以自行调整.
#3 2021-03-01 09:52:26
JasonWoo
已发帖子: 84
相当不错,调用用户态的sysfs那就不需要编写额外驱动了。
#4 2021-03-01 13:50:31
yomkk
前段时间需要写一个控制GPIO的程序,原本也是想用这种方式的,后来听说sysfs控制gpio的方式即将被弃用,所以就换用libgpiod了。
最近编辑记录 yomkk (2021-03-01 13:50:58)
#5 2022-03-28 13:41:37
how0723
已发帖子: 65
不错,感谢
#6 2022-10-19 11:01:29
yuess133
yomkk 说:
你好,能否给个libgpiod使用 的例子,我这里提示 #include<gpiod.h>  , 没有gpiod.h这个文件
#7 2022-10-19 14:56:23
海石生风
已发帖子: 571
@yuess133
内核不带gpiod.h这个头文件,要在用户空间安装好libgpiod这个库才能用。
#8 2022-10-20 09:22:31
jxdqwer
挺不错的,要是可以增加epoll方式就更好了,
#9 2022-10-20 10:56:25
海石生风
已发帖子: 571
jxdqwer 说:
其实Linux内核组已经建议不要用sysfs来操作gpio了,建议用libgpiod,它支持异步方式响应gpio中断信号,这种方式就类似于裸机的中断处理了。
