楼主 # 2022-10-27 19:58:28
已发帖子: 856
博流智能将要推出杀手级芯片bl808(可以跑linux)
这价格如果在10元左右,f1c100s可以退休了
https://www.cnx-software.com/2022/10/10/pine64-ox64-sbc-bl808-risc-v-multi-protocol-wisoc-64mb-ram/
SoC – Bouffalo Lab BL808 with:
CPU
Alibaba T-head C906 64-bit RISC-V core @ 480MHz
Alibaba T-head E907 32-bit RISC-V core @ 320MHz
Memory – 64MB embedded DRAM
AI accelerator – NPU BLAI-100 (Bouffalo Lab AI engine) for video/audio detection/recognition
Wireless
2.4 GHz 802.11 b/g/n Wi-Fi  4
Bluetooth 5.x dual mode (classic + BLE)
IEEE 802.15.4 for Zigbee
Display
Up to 4-lane MIPI DSI
Up to 8-bit MIPI DBI
16-bit MIPI DPI
QSPI
Audio Codec – 2x ADC, 1x DAC, sample rate: 8 to 192KHz, 24-bit
Camera
2-lane MIPI CSI and DVP interfaces
MJPEG and H.264 encoder up to 1920×1080 @ 30fps + 640×480 @ 30fps
Package – 88-pin QFN
Storage
16Mbit (2MB) or 128Mbit (16MB) XSPI NOR flash
MicroSD socket with support for SDHC and SDXC
Camera & audio – 2-lane MIPI CSI co-located with USB-C port for camera module including microphone and speaker
Antenna – 2.4GHz chip antenna soldered on board, footprint for u.FL connector
USB – 1x USB 2.0 OTG Type-C port with MIPI CSI “alternative” mode
Expansion – 2x 20-pin headers with castellated holes with GPIO, SPI, I2C, and UART, possible I2S and GMII expansion
Debugging – 5-pin JTAG header
Misc – BOOT button, red power LED
Power Supply – 5V/0.5A via USB Type-C port or micro USB port
Dimensions – 51 x 21 x 19mm
最近编辑记录 kekemuyu (2022-10-27 19:59:11)
#1 2022-10-27 20:19:03
hameyou
已发帖子: 240
Re: 博流智能将要推出杀手级芯片bl808(可以跑linux)
看这资源,如果不能跑linux真是可惜了
#2 2022-10-27 20:30:28
xfdr0805
已发帖子: 348
这板子哪里能买到?
[Update: We have received information about pricing and availability:
The model with 16Mbit flash and no microSD socket will sell for $6, and the model with 128Mbit flash and microSD socket will go for $8. Mass production is scheduled for mid-November]
#3 2022-10-27 20:38:24
xfdr0805
已发帖子: 348
#4 2022-10-27 20:59:45
XIVN1987
已发帖子: 267
用 USB Type-C 连接 MIPI CSI 摄像头??
还有这种东西??这是什么标准定义的还是博流自己发明的??
#5 2022-10-27 21:59:18
4610
已发帖子: 141
XIVN1987 说:
原理图链接里有
楼主 #6 2022-10-27 22:06:59
已发帖子: 856
BL808_RM_zhBL808_RM_zh.pdf
BL808_DS_zhBL808_DS_zh.pdf
楼主 #7 2022-10-27 22:14:07
已发帖子: 856
#8 2022-10-27 23:51:22
metro
已发帖子: 445
BL808定位和V831比较类似(CPU性能差点,编码器不支持H.265,优势是自带无线),所以感觉价格上不太可能太低,盲猜20块钱吧。
不过,博流还有BL616/618还没亮相,这个性价比应该会更高,可以等一等。
#9 2022-10-28 07:53:39
le062
已发帖子: 75
还是要看价格,15以下就是神仙芯片。
25以上就一般般
#10 2022-10-28 09:01:35
junyee
已发帖子: 38
参照BL702 6元的价格,
这个配置10元绝无可能。
#11 2022-10-28 10:27:24
hong54
盲猜测25+
#12 2022-10-28 21:22:52
Q969785651
已发帖子: 30
看这规格绝对25+
主要关心下MIPI CSI标准品吗
#13 2022-11-02 06:32:57
dven
所在地: 中国广州
已发帖子: 43
感觉像是对标D1S
#14 2022-11-02 09:53:09
lignin
已发帖子: 133
20元以下有玩一玩的想法
#15 2022-11-02 16:08:34
海石生风
已发帖子: 776
XIVN1987 说:
应该只是借助USB Type-C的线路跑MIPI的同时解决供电问题,即接口标准还是MIPI。Type-C接口有3对差分线满足MIPI 2-lane需求,而CC跟SUB脚还可以跑I2C
最近编辑记录 海石生风 (2022-11-02 16:09:38)
#16 2022-11-02 18:02:46
dgtg
已发帖子: 271
这配置比C100强多了,如果是10元无敌了
#17 2022-11-02 20:17:50
midnight
已发帖子: 26
想想这个是怎么用吧
芯片分成了两块,M0/D0,一MCU,一MPU。MCU是e907,MPU是c906。
最大的问题是,一些常见外设是在MCU那边的,例如emac,usb,这些中断是路由到了e907,wifi/bt/zigbee肯定也在e907,sd card还不知道,或者用轮询模式使用sd card/emmc?c906更类似一个多媒体的协处理器。c906跑起来,要访问这些外设都通过某种模式穿越到e907?
楼主 #18 2022-11-02 22:25:02
已发帖子: 856
cpu间通过ipc通信
#19 2022-11-02 23:05:51
lfs911
已发帖子: 38
就算是上面说的25+,这个配置也基本无敌了吧这个价位,而且技术支持肯定也比f1c好,不过这个现在似乎没有零售,淘宝找了下都没得买
#20 2022-11-03 00:31:06
DEQ
已发帖子: 30
可能又是个坑,想爬出来没准又要掉不少头发
#21 2022-11-03 10:16:28
XIVN1987
已发帖子: 267
kekemuyu 说:
cpu间通过ipc通信
当时看到这张图我就很疑惑,,这图的意思难道是说以太网、SD、USB这些高级外设都是单片机外设,跑linux的D0不能访问??
那这些外设还能用linux驱动程序驱动吗??
如果不能,,那这设计也太鸡肋了!!
如果能,,那这框图画的也太误导了!!
#22 2022-11-03 14:48:04
海石生风
已发帖子: 776
@XIVN1987
整个系统有三条总线,每条总线都挂有特定处设,但所有外设的寄存器都映射到同一个物理地址空间,而中断源则分成两组,两组间的中断源并不相同,CPU_M0和CPU_LP管理其中一组,CPU_D0管理另一组。
不同于ARM的AMP——如STM32MP15x的中断由GIC统一管理,不同核心可以共享同一个外设中断;BL808的中断处理比较简单,各个核心只能固定使用不同的外设中断。
如果要跨核心使用外设中断话,就要使用核间中断来进行中断转换了。
#23 2022-11-03 14:55:03
Blueskull
已发帖子: 458
@XIVN1987
我感觉两条总线之间有桥,可以无CPU参与直接互相访问。EMAC做到MCU上可能是为了减小控制延迟,比如一些工业以太网应用。
另外,ESP32才240M主频,一样轻松干百兆以太网,这又不是什么千兆万兆,这点带宽走总线桥就好了。
所以高带宽走桥,低延迟走MCU,我觉得是科学的。
#24 2022-11-03 16:53:43
midnight
已发帖子: 26
应该是不同的核都能访问外设,但中断源从手册上看应该是完全不行。也就是c906可以通过emac收发IP包,但是中断?ok,没有的,在e907那边。或者另外一种,通过ipc把e907的emac封成一个网卡。
这个还只是emac,毕竟wifi肯定是在e907那边的。存储这块则不清楚的了,走sd card/emmc,也许轮询模式也可以。
#25 2022-11-03 21:19:32
TimeWalker
sipeed已经上架了
#26 2022-11-03 21:52:56
jony5
这主频,跑wifi都快不起来把,看不懂
#27 2022-11-03 22:17:20
david
已发帖子: 395
有链接吗 没找到
#28 2022-11-03 22:20:29
tango_zhu
已发帖子: 128
价格好像是68 带摄像头
#29 2022-11-04 09:50:54
marcus
最近杀手级的芯片太多了,哪有那么多韭菜可杀?
#30 2022-11-04 10:29:43
lignin
已发帖子: 133
价格70的一个开发板也还能接受,就是sdk资料哪里能搞到,linux好像也还在开发中
#31 2022-11-04 10:35:03
lignin
已发帖子: 133
#32 2023-01-03 14:40:56
wujique
已发帖子: 178
sipeed上面有个表格,这芯片价格6美金。
楼主 #33 2023-01-03 15:12:15
已发帖子: 856
@wujique
6美元时模组价格
#34 2023-01-06 09:45:41
astankvai
已发帖子: 74
这个板子哪里有得买?
#35 2023-01-06 10:40:38
海石生风
已发帖子: 776
astankvai 说:
这个板子哪里有得买?
Sipeed淘宝店M1s
#36 2023-02-01 14:08:58
weiyongwill
已发帖子: 65
海石生风 说:
astankvai 说:
这个板子哪里有得买?
Sipeed淘宝店M1s
没有单独的芯片卖,模块太贵了
#37 2023-02-01 15:30:07
看了下Linux SDK,好像外设没几个有驱动呀,怎么玩
#38 2023-05-25 11:18:36
zhenfanhei
已发帖子: 311
博流网页上都没得BL808,估计是验证用的片子,有老外论坛上说想用它的MIPI-DSI买芯片都买不到
#39 2023-05-25 21:52:00
yelong98
已发帖子: 97
洗洗睡吧,已经没音讯了
#40 2023-05-26 09:09:21
海石生风
已发帖子: 776
官方的github、gitee都有提及BL808,BBS上有人回复芯片购买还需等待。应该是SDK还没搞完。
#41 2023-05-26 16:49:19
netwp
已发帖子: 31
等R128和ESP32-P4出来,BL808就没优势了
#42 2024-04-09 15:22:40
jxfengzi
BL808淘宝上看不到,只看到sipeed的开发板。
