固件下载: tiny200_rtt_awtk_800x480_w25q128_ns2009.rar
Copy Flash offset 1M to RAM 0x8000000 size:2508352
Copy Flash Ok!
Check Image Crc32:3055548643
Image OK, Goto 0x80000000 ...
- RT - Thread Operating System
/ | \ 4.0.2 build Jan 14 2020
2006 - 2019 Copyright by rt-thread team
[SFUD] Find a Winbond flash chip. Size is 16777216 bytes.
[SFUD] W25Q128 flash device is initialize success.
clk_divider_set_rate 0 198000000 0
[I/I2C] I2C bus [i2c0] registered
periph_get_pll_clk:600000000
cpu_get_clk:408000000
ahb_get_clk:200000000
apb_get_clk:100000000
[D/FAL] (fal_flash_init:61) Flash device | W25Q128 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish.
[I/FAL] ==================== FAL partition table ====================
[I/FAL] | name | flash_dev | offset | length |
[I/FAL] -------------------------------------------------------------
[I/FAL] | Littlefs | W25Q128 | 0x00600000 | 0x00a00000 |
[I/FAL] =============================================================
[I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success.
[I/FAL] The FAL MTD NOR device (Littlefs) created successfully
msh />[E/MMC] [err]:0x00000100, RTO
[E/MMC] mmc cmd 5 err
[I/SDIO] SD card capacity 1931264 KB.
msh />ls
Directory /:
flash <DIR>
mmc <DIR>
usb <DIR>
info.txt 41
msh />
msh />ls /mmc
Directory /mmc:
INFO.TXT 41
bcm.bin 80896
ip.bin 252176
f1c200 <DIR>
msh />ls /flash
Directory /flash:
ts_lib.dat 105
msh />
msh />ps
thread pri status sp stack size max used left tick error
aw_lp 6 suspend 0x00000138 0x00000800 23% 0x00000014 000
awtk 7 suspend 0x00000100 0x00010000 14% 0x00000007 000
tshell 20 running 0x00000210 0x00002000 14% 0x00000002 000
mmcsd_de 22 suspend 0x0000009c 0x00000400 49% 0x00000005 000
tidle0 31 ready 0x00000050 0x00000100 34% 0x00000013 000
msh />free
total memory: 53512944
used memory : 3151892
maximum allocated memory: 3160312
msh />list_device
device type ref count
sd0 Block Device 1
Littlefs MTD Device 1
i2c0 I2C Bus 1
gpio Miscellaneous Device 0
lcd Graphic Device 0
W25Q128 Block Device 0
spi00 SPI Device 0
spi0 SPI Bus 0
uart2 Character Device 0
uart0 Character Device 2
msh />
msh />
上电后先进行屏幕校准,校准完成后自动运行awtk的图表demo, enjoy it !!!
最近编辑记录 haidao (2020-01-14 22:26:45)
补个靓照
坑网有你更精彩!
顶!
感谢分享!
5寸480*272显示不全
不过固件整理挺好 刷机挺方便
楼主能否 描述一下 开发环境的配置,我想了解一下,谢谢!
哇。。。。这是个好东西,,,要是有工程就更好啦。。。。
谢谢分享!
厉害了
真的很棒
您还可以发布源代码吗?
关注
了解一下AWTK,争取抛弃emwin
我触摸是 NS2009 怎么不能校准啊?
自己要移植校准库
要怎么移植啊
最近编辑记录 雷鹏 (2020-04-24 16:03:32)
厉害,关注中,要是有移植参考就好了
点赞, 感谢楼主分享宝贵资源,测试下我新买的Tiny200
感谢楼主分享,新买的Tiny200,正好下载下来测试一下
正在学习全志F1C100S 正有用 谢谢
感谢楼主分享,烧写到Tiny200,可以正常运行
我也正在使用AWTK 整体感觉效果还不错,项目开发文档和测试用例也很丰富
AWTK 整体感觉效果还可以,资料也丰富,有空试一下在100S上
提供源码吧
感谢分享!
界面很漂亮,,感谢分享。有空写到F1C200S 试试
楼主能否分享下固件的的源码,可以上传到git,共同学习下
Copy Flash offset 1M to RAM 0x8000000 size:2508352 Copy Flash Ok! Check Image Crc32:3055548643 Image OK, Goto 0x80000000 ... \ | / - RT - Thread Operating System / | \ 4.0.2 build Jan 14 2020 2006 - 2019 Copyright by rt-thread team [SFUD] Find a Winbond flash chip. Size is 16777216 bytes. [SFUD] W25Q128 flash device is initialize success. clk_divider_set_rate 0 198000000 0 clk_divider_set_rate 0 198000000 0 [I/I2C] I2C bus [i2c0] registered periph_get_pll_clk:600000000 cpu_get_clk:408000000 ahb_get_clk:200000000 apb_get_clk:100000000 [D/FAL] (fal_flash_init:61) Flash device | W25Q128 | addr: 0x00000000 | len: 0x01000000 | blk_size: 0x00001000 |initialized finish. [I/FAL] ==================== FAL partition table ==================== [I/FAL] | name | flash_dev | offset | length | [I/FAL] ------------------------------------------------------------- [I/FAL] | Littlefs | W25Q128 | 0x00600000 | 0x00a00000 | [I/FAL] ============================================================= [I/FAL] RT-Thread Flash Abstraction Layer (V0.4.0) initialize success. [I/FAL] The FAL MTD NOR device (Littlefs) created successfully msh />[E/MMC] [err]:0x00000100, RTO [E/MMC] mmc cmd 5 err [I/SDIO] SD card capacity 1931264 KB. msh />ls Directory /: flash <DIR> mmc <DIR> usb <DIR> info.txt 41 msh /> msh />ls /mmc Directory /mmc: INFO.TXT 41 bcm.bin 80896 ip.bin 252176 f1c200 <DIR> msh />ls /flash Directory /flash: ts_lib.dat 105 msh /> msh />ps thread pri status sp stack size max used left tick error -------- --- ------- ---------- ---------- ------ ---------- --- aw_lp 6 suspend 0x00000138 0x00000800 23% 0x00000014 000 awtk 7 suspend 0x00000100 0x00010000 14% 0x00000007 000 tshell 20 running 0x00000210 0x00002000 14% 0x00000002 000 mmcsd_de 22 suspend 0x0000009c 0x00000400 49% 0x00000005 000 tidle0 31 ready 0x00000050 0x00000100 34% 0x00000013 000 msh />free total memory: 53512944 used memory : 3151892 maximum allocated memory: 3160312 msh />list_device device type ref count -------- -------------------- ---------- sd0 Block Device 1 Littlefs MTD Device 1 i2c0 I2C Bus 1 gpio Miscellaneous Device 0 lcd Graphic Device 0 W25Q128 Block Device 0 spi00 SPI Device 0 spi0 SPI Bus 0 uart2 Character Device 0 uart0 Character Device 2 msh /> msh />
感谢分享!
你好,我移植awtk到f1c+rtthread上,编译的时候没有问题,链接的时候遇见问题
省略n行
CC build\AWTK\awtk-port\lcd_f1cxx.o
CC build\AWTK\awtk-port\main_loop_f1cxx.o
CC build\AWTK\awtk-port\platform.o
LINK rtthread.elf
Error in calling command:arm-none-eabi-g++
Exception: Invalid argument
scons: *** [rtthread.elf] Error 22
scons: building terminated because of errors.
还有个问题awtk-port里面的和f1c显示对接的那几个函数怎么写?
非常不错,不知道有没有人移植touchgfx到f1c100s上
早点看到这个帖子就好了,我的NAND FLASH的问题还没改好
下到我的荔枝派了,触摸好像有问题偏差很大,图形图像显示的挺好的
最近编辑记录 DEQ (2022-10-31 22:16:45)
