附文档
Quectel_EC200S_Linux_USB_Driver_User_Guide_V1.0.pdf
添加 VID 和 PID
在文件[KERNEL]/drivers/usb/serial/option.c 中添加模块的 VID 和 PID 信息,如下所示:
static const struct usb_device_id option_ids[] = {
#if 1 //Added by Quectel
{ USB_DEVICE(0x2C7C, 0x6002) }, /* Quectel EC200S */
2.添加USB零包
[KERNEL]/drivers/usb/serial/usb_wwan.c.
static struct urb *usb_wwan_setup_urb(struct usb_serial *serial, int endpoint,
int dir, void *ctx, char *buf, int len,void (*callback) (struct urb *))
usb_fill_bulk_urb(urb, serial->dev,
usb_sndbulkpipe(serial->dev, endpoint) | dir,
buf, len, callback, ctx);
#if 1 //Added by Quectel for zero packet
if (dir == USB_DIR_OUT) {
struct usb_device_descriptor *desc = &serial->dev->descriptor;
if (desc->idVendor == cpu_to_le16(0x2C7C))
urb->transfer_flags |= URB_ZERO_PACKET;
return urb;
3.增加复位恢复机制
[KERNEL]/drivers/usb/serial/option.c。
static struct usb_serial_driver option_1port_device = {
#ifdef CONFIG_PM
.suspend = usb_wwan_suspend,
.resume = usb_wwan_resume,
.reset_resume = usb_wwan_resume,
接下来使能一些内核配置项
TODO......
烧录内核成功后
1.烧录完成后使用指令
ls /dev/ttyUSB* 可以看到下面的3个模拟的usb设备
2.之后执行获取到IP地址
ifconfig usb1 up
udhcpc -i usb1
3.使用AT指令使模块拨号
cat /dev/ttyUSB2 &
# 设置为RNDIS模式
echo -e "AT+QCFG=\"usbnet\",3\r\n" > /dev/ttyUSB2
# 查询指令是否生效
echo -e "AT+QCFG=\"usbnet\"\r\n" > /dev/ttyUSB2
# 发送 AT 指令拨号上网指令
echo -e "AT+qnetdevctl=1,1\r\n" > /dev/ttyUSB2
4.执行ping指令测试拨号是否成功
附一些常用的AT指令
echo -e "AT+QCCID\r\n" >/dev/ttyUSB2 //查询SIM卡
echo -e "AT+CFUN=1,1\r\n" >/dev/ttyUSB2 //重启模块
echo -e "AT+QSIMDET=1\r\n" >/dev/ttyUSB2 //开启SIM卡热插拔状态报告
echo -e "AT+QSIMDET=1,1\r\n" >/dev/ttyUSB2 //开启SIM卡检测功能
echo -e "AT+CSQ\r\n" >/dev/ttyUSB2 //查询信号强度
echo -e "AT+QNWINFO\r\n" >/dev/ttyUSB2 //查询网络状态
echo -e "AT+QCFG=\"NWSCANMODE\",3,1\r\n" >/dev/ttyUSB2 //设置4G LTE only
echo -e "AT+QCFG=\"NWSCANMODE\",2,1\r\n" >/dev/ttyUSB2 //设置3G WCDMA only
echo -e "AT+QCFG=\"NWSCANMODE\",1,1\r\n" >/dev/ttyUSB2 //设置2G GSM only
echo -e "AT+QCFG=\"NWSCANMODE\",0,1\r\n" >/dev/ttyUSB2 //设置自动搜索网络
# AT+QSIMDET=1,1或AT+QSIMDET=1,0开启 可以设置高电平 或者低电平有效//SIM卡热拔插,同一个电路 肯定不可以设置两种sim卡检测状态 要么高电平有效 要么低电平有效
# AT+QSIMDET=0 关闭热拔插功能
# 通过AT命令开启SIM卡检查功能
# 举例:
# AT+QSIMSTAT=1 //开启SIM卡热拔插状态报告
# AT+QSIMDET=1,1或AT+QSIMDET=1,0//开启 SIM卡检测功能
# 当SIM卡拔出或者插上的时候,模块会有相应的提示:
# +CPIN:NOT READY
# AT+QSIMSTAT=1,1或AT+QSIMSTAT=1,0
# Call Ready最近编辑记录 tocurd (2022-11-08 13:11:51)
这没坑吧,USB线只要没问题,直接拨号就好了
USB还是串口?
期待顺利填坑
sven1234 wrote:
USB还是串口?
usb
编辑不了了,补一下上面的内核配置
只要移植一下pppd即可。
好像可以强制指定usb serial驱动的vid/pid,不需要重编内核。
