U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Nov 12 2022 - 01:22:45 -0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
Hit any key to stop autoboot: 2 1 0
Loading Device Tree to 42dfa000, end 42dffbf8 ... OK
prefetch abort
pc : [<6c98190c>] lr : [<4100024c>]
sp : 6cd86028 ip : 410006e4 fp : e0400001
r10: 00000000 r9 : 410fc075 r8 : 42dfa000
r7 : 00000000 r6 : 2b981840 r5 : 410000c0 r4 : 40008000
r3 : 00000010 r2 : 000f0000 r1 : 4100c075 r0 : 6c981908
Flags: nZCv IRQs off FIQs off Mode SVC_32
Resetting CPU ...
resetting ...
用的是nano flash启动,5.2内核
最近编辑记录 tocurd (2022-11-12 23:15:48)
测试直接写入内存启动可以正常启动到内核
./sunxi-fel.exe -p uboot u-boot-sunxi-with-spl.bin write 0x41000000 zImage write 0x41800000 sun8i-v3s-licheepi-zero.dtb
启动日志
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Nov 06 2022 - 02:17:41 -0800) Allwinner Technology
DRAM: 64 MiB
In: serial@01c28000
[ 0.000000] Linux version 5.2.0-licheepi-zero+ (root@ubuntu) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #5 SMP Fri Nov 11 22:41:33 PST 2022
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] printk: bootconsole [earlycon0] enabled
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 15883
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 53544K/64036K available (6144K kernel code, 302K rwdata, 1716K rodata, 1024K init, 253K bss, 10492K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x498 with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.008001] Switching to timer-based delay loop, resolution 41ns
[ 0.014174] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.023585] Console: colour dummy device 80x30
[ 0.028076] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.038442] pid_max: default: 32768 minimum: 301
[ 0.043208] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050541] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.059090] CPU: Testing write buffer coherency: ok
[ 0.064564] /cpus/cpu@0 missing clock-frequency property
[ 0.069890] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.076441] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.083194] rcu: Hierarchical SRCU implementation.
[ 0.088618] smp: Bringing up secondary CPUs ...
[ 0.093161] smp: Brought up 1 node, 1 CPU
[ 0.097166] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.103387] CPU: All CPU(s) started in SVC mode.
[ 0.109094] devtmpfs: initialized
[ 0.115947] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.124001] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.133882] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.140910] pinctrl core: initialized pinctrl subsystem
[ 0.147261] NET: Registered protocol family 16
[ 0.152339] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.160522] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.168524] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.197858] SCSI subsystem initialized
[ 0.201783] usbcore: registered new interface driver usbfs
[ 0.207530] usbcore: registered new interface driver hub
[ 0.212902] usbcore: registered new device driver usb
[ 0.218246] mc: Linux media interface: v0.10
[ 0.222567] videodev: Linux video capture interface: v2.00
[ 0.228301] Advanced Linux Sound Architecture Driver Initialized.
[ 0.236325] clocksource: Switched to clocksource arch_sys_counter
[ 0.254317] NET: Registered protocol family 2
[ 0.259652] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.268107] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.275772] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.282853] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.289377] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.295943] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.303269] NET: Registered protocol family 1
[ 0.309620] Initialise system trusted keyrings
[ 0.314430] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.328213] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[ 0.371492] Key type asymmetric registered
[ 0.375601] Asymmetric key parser 'x509' registered
[ 0.380670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.388115] io scheduler mq-deadline registered
[ 0.392643] io scheduler kyber registered
[ 0.397749] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.407614] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.485240] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.494091] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.505196] printk: console [ttyS0] disabled
[ 0.529793] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[ 0.538833] printk: console [ttyS0] enabled
[ 0.547211] printk: bootconsole [earlycon0] disabled
[ 0.583727] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.595259] m25p80 spi0.0: w25q128 (16384 Kbytes)
[ 0.601153] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.607769] ehci-platform: EHCI generic platform driver
[ 0.613312] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.618989] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.626963] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 0.656351] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.663609] hub 1-0:1.0: USB hub found
[ 0.667574] hub 1-0:1.0: 1 port detected
[ 0.672164] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.678496] ohci-platform: OHCI generic platform driver
[ 0.684092] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.690831] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.698837] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 0.771439] hub 2-0:1.0: USB hub found
[ 0.775286] hub 2-0:1.0: 1 port detected
[ 0.780765] usbcore: registered new interface driver usb-storage
[ 0.788366] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 0.793433] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.798150] i2c /dev entries driver
[ 0.803098] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 0.812804] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 0.821453] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 0.857918] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 0.865405] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 0.876929] usbcore: registered new interface driver usbhid
[ 0.882507] usbhid: USB HID core driver
[ 0.889055] Initializing XFRM netlink socket
[ 0.893366] NET: Registered protocol family 17
[ 0.898537] Registering SWP/SWPB emulation handler
[ 0.904461] Loading compiled-in X.509 certificates
[ 0.914592] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0x(ptrval)
[ 0.925259] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[ 0.941172] Console: switching to colour frame buffer device 100x30
[ 0.953295] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[ 0.962097] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 0.973638] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 0.979493] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 0.988907] hub 3-0:1.0: USB hub found
[ 0.992791] hub 3-0:1.0: 1 port detected
[ 0.998286] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:02:55 UTC (175)
[ 1.006751] vcc3v0: disabling
[ 1.009733] vcc5v0: disabling
[ 1.012697] ALSA device list:
[ 1.015662] No soundcards found.
[ 1.020336] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[ 1.028050] Please append a correct "root=" boot option; here are the available partitions:
[ 1.036445] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[ 1.044795] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero+ #5
[ 1.051918] Hardware name: Allwinner sun8i Family
[ 1.056652] [<c010eeb8>] (unwind_backtrace) from [<c010b6e0>] (show_stack+0x10/0x14)
[ 1.064393] [<c010b6e0>] (show_stack) from [<c06b8bb0>] (dump_stack+0x84/0x98)
[ 1.071613] [<c06b8bb0>] (dump_stack) from [<c011ded0>] (panic+0x110/0x2fc)
[ 1.078572] [<c011ded0>] (panic) from [<c09013ac>] (mount_block_root+0x250/0x304)
[ 1.086049] [<c09013ac>] (mount_block_root) from [<c090163c>] (prepare_namespace+0x154/0x198)
[ 1.094568] [<c090163c>] (prepare_namespace) from [<c06cf1e8>] (kernel_init+0x8/0x110)
[ 1.102479] [<c06cf1e8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 1.110037] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 1.115084] 3fa0: 00000000 00000000 00000000 00000000
[ 1.123252] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 1.131418] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 1.138039] Rebooting in 5 seconds..
uboot 启动参数配置
#define CONFIG_BOOTCOMMAND "sf probe 0; " \
"sf read 0x41800000 0x100000 0x10000; " \
#define CONFIG_BOOTARGS "console=ttyS0,115200 earlyprintk panic=5 rootwait " \
"mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,6M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2"
时钟太高spi数据错误?uncompress都没过
