楼主 # 2022-11-12 15:38:51
tocurd
已发帖子: 19
求助,v3s使用5.2内核从nano spi启动的时候报错
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Nov 12 2022 - 01:22:45 -0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM:  64 MiB
MMC:   SUNXI SD/MMC: 0
In:    serial@01c28000
Out:   serial@01c28000
Err:   serial@01c28000
DRAM:  64 MiB
In:    serial@01c28000
Net:   No ethernet found.
No controllers found
   Loading Device Tree to 42dfa000, end 42dffbf8 ... OK
prefetch abort
pc : [<6c98190c>]	   lr : [<4100024c>]
sp : 6cd86028  ip : 410006e4	 fp : e0400001
r10: 00000000  r9 : 410fc075	 r8 : 42dfa000
r7 : 00000000  r6 : 2b981840	 r5 : 410000c0  r4 : 40008000
r3 : 00000010  r2 : 000f0000	 r1 : 4100c075  r0 : 6c981908
Flags: nZCv  IRQs off  FIQs off  Mode SVC_32
Resetting CPU ...
resetting ...
用的是nano flash启动,5.2内核
最近编辑记录 tocurd (2022-11-12 23:15:48)
楼主 #1 2022-11-12 23:47:48
tocurd
已发帖子: 19
Re: 求助,v3s使用5.2内核从nano spi启动的时候报错
测试直接写入内存启动可以正常启动到内核
./sunxi-fel.exe -p uboot u-boot-sunxi-with-spl.bin write 0x41000000 zImage write 0x41800000 sun8i-v3s-licheepi-zero.dtb
启动日志
U-Boot 2017.01-rc2-00073-gdd6e8740dc-dirty (Nov 06 2022 - 02:17:41 -0800) Allwinner Technology
DRAM:  64 MiB
In:    serial@01c28000
[    0.000000] Linux version 5.2.0-licheepi-zero+ (root@ubuntu) (gcc version 9.4.0 (Ubuntu 9.4.0-1ubuntu1~20.04.1)) #5 SMP Fri Nov 11 22:41:33 PST 2022
[    0.000000] printk: bootconsole [earlycon0] enabled
[    0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 15883
[    0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,4M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2
[    0.000000] Memory: 53544K/64036K available (6144K kernel code, 302K rwdata, 1716K rodata, 1024K init, 253K bss, 10492K reserved, 0K cma-reserved, 0K highmem)
[    0.000000] rcu: 	RCU event tracing is enabled.
[    0.000000] rcu: 	RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[    0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x498 with crng_init=0
[    0.008001] Switching to timer-based delay loop, resolution 41ns
[    0.014174] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[    0.023585] Console: colour dummy device 80x30
[    0.028076] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[    0.038442] pid_max: default: 32768 minimum: 301
[    0.043208] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.050541] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.059090] CPU: Testing write buffer coherency: ok
[    0.064564] /cpus/cpu@0 missing clock-frequency property
[    0.069890] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.076441] Setting up static identity map for 0x40100000 - 0x40100060
[    0.083194] rcu: Hierarchical SRCU implementation.
[    0.088618] smp: Bringing up secondary CPUs ...
[    0.093161] smp: Brought up 1 node, 1 CPU
[    0.097166] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[    0.103387] CPU: All CPU(s) started in SVC mode.
[    0.109094] devtmpfs: initialized
[    0.115947] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[    0.124001] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.133882] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[    0.140910] pinctrl core: initialized pinctrl subsystem
[    0.147261] NET: Registered protocol family 16
[    0.152339] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.160522] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.168524] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.197858] SCSI subsystem initialized
[    0.201783] usbcore: registered new interface driver usbfs
[    0.207530] usbcore: registered new interface driver hub
[    0.212902] usbcore: registered new device driver usb
[    0.218246] mc: Linux media interface: v0.10
[    0.222567] videodev: Linux video capture interface: v2.00
[    0.228301] Advanced Linux Sound Architecture Driver Initialized.
[    0.236325] clocksource: Switched to clocksource arch_sys_counter
[    0.254317] NET: Registered protocol family 2
[    0.259652] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[    0.268107] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[    0.275772] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[    0.282853] TCP: Hash tables configured (established 1024 bind 1024)
[    0.289377] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.295943] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[    0.303269] NET: Registered protocol family 1
[    0.309620] Initialise system trusted keyrings
[    0.314430] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[    0.328213] jffs2: version 2.2. (NAND) 漏 2001-2006 Red Hat, Inc.
[    0.371492] Key type asymmetric registered
[    0.375601] Asymmetric key parser 'x509' registered
[    0.380670] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[    0.388115] io scheduler mq-deadline registered
[    0.392643] io scheduler kyber registered
[    0.397749] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[    0.407614] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[    0.485240] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[    0.494091] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[    0.505196] printk: console [ttyS0] disabled
[    0.529793] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[    0.538833] printk: console [ttyS0] enabled
[    0.547211] printk: bootconsole [earlycon0] disabled
[    0.583727] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[    0.595259] m25p80 spi0.0: w25q128 (16384 Kbytes)
[    0.601153] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    0.607769] ehci-platform: EHCI generic platform driver
[    0.613312] ehci-platform 1c1a000.usb: EHCI Host Controller
[    0.618989] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[    0.626963] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[    0.656351] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[    0.663609] hub 1-0:1.0: USB hub found
[    0.667574] hub 1-0:1.0: 1 port detected
[    0.672164] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    0.678496] ohci-platform: OHCI generic platform driver
[    0.684092] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[    0.690831] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[    0.698837] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[    0.771439] hub 2-0:1.0: USB hub found
[    0.775286] hub 2-0:1.0: 1 port detected
[    0.780765] usbcore: registered new interface driver usb-storage
[    0.788366] sun6i-rtc 1c20400.rtc: registered as rtc0
[    0.793433] sun6i-rtc 1c20400.rtc: RTC enabled
[    0.798150] i2c /dev entries driver
[    0.803098] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[    0.812804] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[    0.821453] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[    0.857918] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[    0.865405] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[    0.876929] usbcore: registered new interface driver usbhid
[    0.882507] usbhid: USB HID core driver
[    0.889055] Initializing XFRM netlink socket
[    0.893366] NET: Registered protocol family 17
[    0.898537] Registering SWP/SWPB emulation handler
[    0.904461] Loading compiled-in X.509 certificates
[    0.914592] simple-framebuffer 43e89000.framebuffer: framebuffer at 0x43e89000, 0x177000 bytes, mapped to 0x(ptrval)
[    0.925259] simple-framebuffer 43e89000.framebuffer: format=x8r8g8b8, mode=800x480x32, linelength=3200
[    0.941172] Console: switching to colour frame buffer device 100x30
[    0.953295] simple-framebuffer 43e89000.framebuffer: fb0: simplefb registered!
[    0.962097] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    0.973638] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    0.979493] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[    0.988907] hub 3-0:1.0: USB hub found
[    0.992791] hub 3-0:1.0: 1 port detected
[    0.998286] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:02:55 UTC (175)
[    1.006751] vcc3v0: disabling
[    1.009733] vcc5v0: disabling
[    1.012697] ALSA device list:
[    1.015662]   No soundcards found.
[    1.020336] VFS: Cannot open root device "31:03" or unknown-block(31,3): error -19
[    1.028050] Please append a correct "root=" boot option; here are the available partitions:
[    1.036445] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(31,3)
[    1.044795] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero+ #5
[    1.051918] Hardware name: Allwinner sun8i Family
[    1.056652] [<c010eeb8>] (unwind_backtrace) from [<c010b6e0>] (show_stack+0x10/0x14)
[    1.064393] [<c010b6e0>] (show_stack) from [<c06b8bb0>] (dump_stack+0x84/0x98)
[    1.071613] [<c06b8bb0>] (dump_stack) from [<c011ded0>] (panic+0x110/0x2fc)
[    1.078572] [<c011ded0>] (panic) from [<c09013ac>] (mount_block_root+0x250/0x304)
[    1.086049] [<c09013ac>] (mount_block_root) from [<c090163c>] (prepare_namespace+0x154/0x198)
[    1.094568] [<c090163c>] (prepare_namespace) from [<c06cf1e8>] (kernel_init+0x8/0x110)
[    1.102479] [<c06cf1e8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[    1.110037] Exception stack(0xc3833fb0 to 0xc3833ff8)
[    1.115084] 3fa0:                                     00000000 00000000 00000000 00000000
[    1.123252] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    1.131418] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    1.138039] Rebooting in 5 seconds..
楼主 #2 2022-11-12 23:50:59
tocurd
已发帖子: 19
uboot 启动参数配置
#define CONFIG_BOOTCOMMAND   "sf probe 0; "                           \
                             "sf read 0x41800000 0x100000 0x10000; "  \
 #define CONFIG_BOOTARGS      "console=ttyS0,115200 earlyprintk panic=5 rootwait " \
                             "mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,6M(kernel)ro,-(rootfs) root=31:03 rw rootfstype=jffs2"
#3 2022-11-14 13:17:38
4610
已发帖子: 142
时钟太高spi数据错误?uncompress都没过
