最开始按照设备的配置过程配置了,修改了option.c 中的VID 和PID, 硬件电路上,使用的是USB0外接的sl2.1A芯片做为hub,4g网卡连接hub的dp2,dm2.其他没接,在系统启动后,无法加载ttyUSB结点,使用命令 cat /sys/kernel/debug/usb/devices 无输出。下面贴上启动输出,board.dts, sun8iw19p.dtsi, opkg list-installed |grep usb 的输出,希望大家帮忙看看问题所在。
[32]HELLO! BOOT0 is starting!
[35]BOOT0 commit : e3b2a9e
[37]board init start
[39]set pll start
[42]set pll end
[43][pmu]: bus read error
[46][pmu]: bus read error
[48]board init ok
[50]chip id check OK
[52]DRAM BOOT DRIVE INFO: V0.41
[55]DRAM CLK = 528 MHz
[57]DRAM Type = 2 (2:DDR2,3:DDR3)
[61]DRAMC read ODT off.
[63]DRAM ODT off.
[65]DRAM SIZE =64 M
[71]DRAM simple test OK.
[74]rtc standby flag is 0x0, super standby flag is 0x0
[79]dram size =64
[81]card no is 0
[83]sdcard 0 line count 4
[86][mmc]: mmc driver ver 2020-01-08 17:05
[90][mmc]: sdc0 spd mode error, 2
[93][mmc]: set f_max to 50M, set f_max_ddr to 25M
[98][mmc]: mmc 0 bias 0
[105][mmc]: Wrong media type 0x0
[108][mmc]: ***Try SD card 0***
[119][mmc]: HSSDR52/SDR25 4 bit
[122][mmc]: 50000000 Hz
[124][mmc]: 7680 MB
[126][mmc]: ***SD/MMC 0 init OK!!!***
[189]Loading boot-pkg Succeed(index=0).
[193]Entry_name = optee
[196]Entry_name = u-boot
[202]Entry_name = dtb
[206]Jump to second Boot.
MESSAGE: [0x0] TEE-CORE: OP-TEE version: sun8iw19p1_v0.6.0-14-gf6954e7 #1 2019年 11月 21日 星期四 01:34:42 UTC arm
ERROR: [0x0] TEE-CORE:platform_standby_fdt_parse:126: no pmu node
ERROR: [0x0] TEE-CORE:sunxi_twi_parse_from_dt:84: no pmu node
U-Boot 2018.05-00008-g384031a (Jan 16 2020 - 14:12:41 +0800) Allwinner Technology
[00.277]CPU: Allwinner Family
[00.280]Model: sun8iw19
I2C: ready
[00.285]DRAM: 64 MiB
[00.287]Relocation Offset is: f9f46000
[00.309]secure enable bit: 0
[00.311]pmu_axp152_probe pmic_bus_read fail
[00.315]pmu_axp2101_probe pmic_bus_read fail
[00.319]bmu_axp152_probe pmic_bus_read fail
[00.323]bmu_axp2101_probe pmic_bus_read fail
[00.327]CPU=816 MHz,PLL6=600 Mhz,AHB=200 Mhz, APB1=100Mhz MBus=132Mhz
[00.334]gic: sec monitor mode
[00.336]flash init start
[00.338]workmode = 0,storage type = 1
[00.342]MMC: 0
[00.343]get mem for descripter OK !
card_caps:0x3000000a
host_caps:0x3000003f
[00.375]sunxi flash init ok
[00.379]Loading Environment from SUNXI_FLASH... OK
[00.406]update dts
root_partition is rootfs
set root to /dev/mmcblk0p4
[00.436]update part info
[00.462]update bootcmd
[00.464]No ethernet found.
## Booting kernel from Legacy Image at 45000000 ...
Image Name: ARM OpenWrt Linux-4.9.118
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2984256 Bytes = 2.8 MiB
Load Address: 40008000
Entry Point: 40008000
[01.858]Starting kernel ...
[01.860]mmc 2 not find, so not exit
[ 0.000000] Linux version 4.9.118 (tina@ubuntu) (gcc version 6.4.1 (OpenWrt/Linaro GCC 6.4-2017.11 2017-11) ) #24 PREEMPT Sun Nov 20 07:35:55 UTC 2022
[ 0.000000] CPU: ARMv7 Processor [410fc075] revision 5 (ARMv7), cr=50c5387d
[ 0.000000] OF: fdt:Machine model: sun8iw19
[ 0.000000] ion_mem_reserve: err format for ion reserve list!
[ 0.000000] On node 0 totalpages: 16384
[ 0.000000] free_area_init_node: node 0, pgdat c04d8758, node_mem_map c3f79000
[ 0.000000] Normal zone: 128 pages used for memmap
[ 0.000000] Normal zone: 16384 pages, LIFO batch:3
[ 0.000000] psci: PSCIv1.0 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: MIGRATE_INFO_TYPE not supported.
[ 0.000000] psci: SMC Calling Convention v1.0
[ 0.000000] CPU: All CPU(s) started in SVC mode.
[ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
[ 0.000000] pcpu-alloc: [0] 0
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: earlyprintk=sunxi-uart,0x05000000 initcall_debug=0 console=ttyS0,115200 loglevel=8 root=/dev/mmcblk0p4 rootwait init=/pseudo_init rdinit=/sbin/rdinit partitions=boot-res@mmcblk0p1:env@mmcblk0p2:boot@mmcblk0p3:rootfs@mmcblk0p4:UDISK@mmcblk0p5 cma=0 mac_addr= wifi_mac= bt_mac= selinux= specialstr= coherent_pool=16K ion_carveout_list= androidboot.mode=normal androidboot.hardware=sun8iw19p1 boot_type=1 androidboot.boot_type=1 gpt=1 uboot_message=2018.05-00008-g384031a(01/16/2020-14:12:41) mbr_offset=1032192 bootreason=unknow
[ 0.000000] Memory: 59472K/65536K available (3147K kernel code, 236K rwdata, 1244K rodata, 144K init, 129K bss, 6064K reserved, 0K cma-reserved)
[ 0.000000] vmalloc : 0xc4800000 - 0xff800000 ( 944 MB)
[ 0.000000] modules : 0xbf800000 - 0xc0000000 ( 8 MB)
[ 0.000000] .text : 0xc0008000 - 0xc031afb8 (3148 kB)
[ 0.000000] .init : 0xc047a000 - 0xc049e000 ( 144 kB)
[ 0.000000] .data : 0xc049e000 - 0xc04d9358 ( 237 kB)
[ 0.000000] .bss : 0xc04d9358 - 0xc04f9a44 ( 130 kB)
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000000] arm_arch_timer: Architected cp15 timer(s) running at 24.00MHz (phys).
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000158] Console: colour dummy device 80x30
[ 0.000184] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000199] pid_max: default: 32768 minimum: 301
[ 0.000370] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000382] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000975] CPU: Testing write buffer coherency: ok
[ 0.001248] Setting up static identity map for 0x400081c0 - 0x4000820c
[ 0.002697] devtmpfs: initialized
[ 0.030520] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.030861] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.030887] futex hash table entries: 256 (order: -1, 3072 bytes)
[ 0.031047] atomic64_test: passed
[ 0.031058] pinctrl core: initialized pinctrl subsystem
[ 0.031948] NET: Registered protocol family 16
[ 0.032526] DMA: preallocated 16 KiB pool for atomic coherent allocations
[ 0.033972] dump_class_init,857, success
[ 0.035314] sunxi iommu: irq = 23
[ 0.041227] sun8iw19p1-r-pinctrl r_pio: initialized sunXi PIO driver
[ 0.057148] use hosc , set rate 1000000
[ 0.057176] sun8iw19p1-pinctrl pio: initialized sunXi PIO driver
[ 0.059387] iommu: Adding device 1c0e000.ve to group 0
[ 0.061110] iommu: Adding device 2300000.eise to group 0
[ 0.068059] iommu: Adding device 1000000.disp to group 0
[ 0.069831] iommu: Adding device 1480000.g2d to group 0
[ 0.070434] iommu: Adding device 2400000.nna to group 0
[ 0.074136] iommu: Adding device csi0 to group 0
[ 0.075452] iommu: Adding device csi1 to group 0
[ 0.076757] iommu: Adding device 2100000.isp to group 0
[ 0.077357] iommu: Adding device 2104000.scaler to group 0
[ 0.077718] iommu: Adding device 2104400.scaler to group 0
[ 0.078081] iommu: Adding device 2104800.scaler to group 0
[ 0.078559] iommu: Adding device 2104c00.scaler to group 0
[ 0.080075] iommu: Adding device vinc0 to group 0
[ 0.080791] iommu: Adding device vinc1 to group 0
[ 0.131335] pwm module init!
[ 0.135326] SCSI subsystem initialized
[ 0.135723] usbcore: registered new interface driver usbfs
[ 0.135818] usbcore: registered new interface driver hub
[ 0.138499] usbcore: registered new device driver usb
[ 0.138789] sunxi_i2c_adap_init()2754 - init
[ 0.139350] sunxi_i2c_probe()2449 - [i2c1] twi_drv_used = 1
[ 0.139367] sunxi_i2c_probe()2456 - [i2c1] twi_pkt_interval = 0
[ 0.139427] twi_regulator_request()653 - [i2c1] regulator not found(isn't configured in dts)!
[ 0.139438] twi_request_gpio()469 - [i2c1] init name: (null)
[ 0.139868] sunxi_i2c_dma_request()1136 - [i2c1] using dma0chan0 (tx) and dma0chan1 (rx)for DMA transfers
[ 0.139985] sun8iw19p1-pinctrl pio: expect_func as:twi2, but muxsel(5) is func:uart2
[ 0.140005] sun8iw19p1-pinctrl pio: expect_func as:twi2, but muxsel(5) is func:uart2
[ 0.140325] sunxi_i2c_probe()2449 - [i2c2] twi_drv_used = 1
[ 0.140339] sunxi_i2c_probe()2456 - [i2c2] twi_pkt_interval = 0
[ 0.140392] twi_regulator_request()653 - [i2c2] regulator not found(isn't configured in dts)!
[ 0.140403] twi_request_gpio()469 - [i2c2] init name: (null)
[ 0.141525] sunxi_i2c_dma_request()1136 - [i2c2] using dma0chan2 (tx) and dma0chan3 (rx)for DMA transfers
[ 0.141946] media: Linux media interface: v0.10
[ 0.142108] Linux video capture interface: v2.00
[ 0.143339] ion_parse_dt_heap_common: id 0 type 0 name sys_user align 1000
[ 0.143617] ion_parse_dt_heap_common: id 1 type 1 name sys_contig align 1000
[ 0.143837] ion_parse_dt_heap_common: id 4 type 4 name cma align 1000
[ 0.145150] Advanced Linux Sound Architecture Driver Initialized.
[ 0.148587] G2D: rcq version initialized.major:251
[ 0.149635] clocksource: Switched to clocksource arch_sys_counter
[ 0.171997] udc_init,0
[ 0.172175] NET: Registered protocol family 2
[ 0.173144] TCP established hash table entries: 16 (order: -6, 64 bytes)
[ 0.173164] TCP bind hash table entries: 16 (order: -6, 64 bytes)
[ 0.173174] TCP: Hash tables configured (established 16 bind 16)
[ 0.173241] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.173262] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.173438] NET: Registered protocol family 1
[ 0.176423] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.193255] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.193733] jffs2: version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[ 0.196472] NET: Registered protocol family 38
[ 0.196519] io scheduler noop registered
[ 0.196529] io scheduler deadline registered
[ 0.196836] io scheduler cfq registered (default)
[ 0.197792] [DISP]disp_module_init
[ 0.231152] [DISP] Fb_copy_boot_fb,line:1503:
[ 0.231167] no boot_fb0
[ 0.233986] [DISP] disp_sys_pwm_config,line:618:
[ 0.233998] disp_sys_pwm_Config, handle is NULL!
[ 0.234009] [DISP] disp_sys_pwm_set_polarity,line:636:
[ 0.234015] disp_sys_pwm_Set_Polarity, handle is NULL!
[ 0.235397] [DISP]disp_module_init finish
[ 0.237677] uart uart0: get regulator failed
[ 0.237707] uart0 supply uart not found, using dummy regulator
[ 0.237910] uart uart0: uart0 error to get fifo size property
[ 0.237976] uart0: ttyS0 at MMIO 0x5000000 (irq = 294, base_baud = 1500000) is a SUNXI
[ 0.238005] sw_console_setup()1830 - console setup baud 115200 parity n bits 8, flow n
[ 0.365296] [ST7789V LCD INFO] LINE:0208-->LCD_panel_init:
[ 0.365305] [ST7789V LCD INFO] LINE:0225-->lcd_panel_st7789v_init:
[ 0.861872] [DISP] disp_lcd_pwm_enable,line:959:
[ 0.861873] pwm device hdl is NULL
[ 0.861885] [DISP] disp_device_attached_and_enable,line:221:
[ 0.861885] attached ok, mgr0<-->dev0
[ 0.861897] [DISP] disp_device_attached_and_enable,line:224:
[ 0.861897] type:1,mode:0,fmt:rgb,bits:8bits,eotf:4,cs:0 dvi_hdmi:2, range:2 scan:0 ratio:8
[ 1.207648] console [ttyS0] enabled
[ 1.212351] uart uart1: get regulator failed
[ 1.217165] uart1 supply uart not found, using dummy regulator
[ 1.224166] uart uart1: uart1 error to get fifo size property
[ 1.230810] uart1: ttyS1 at MMIO 0x5000400 (irq = 295, base_baud = 1500000) is a SUNXI
[ 1.240824] misc dump reg init
[ 1.246764] libphy: Fixed MDIO Bus: probed
[ 1.252504] sun8iw19p1-pinctrl pio: expect_func as:gmac0, but muxsel(5) is func:ephy
[ 1.261652] sun8iw19p1-pinctrl pio: pin PD1 already requested by soc@03000000:lcd0@01c0c000; cannot claim for 5020000.eth
[ 1.274228] sun8iw19p1-pinctrl pio: pin-97 (5020000.eth) status -22
[ 1.281348] sun8iw19p1-pinctrl pio: could not request pin 97 (PD1) from group PD1 on device pio
[ 1.291293] sunxi-gmac 5020000.eth: Error applying setting, reverse things back
[ 1.299563] sunxi-gmac: probe of 5020000.eth failed with error -22
[ 1.306794] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.314575] get drv_vbus is fail, 84
[ 1.318604] get ehci0-controller, regulator_io is no nocare
[ 1.324984] get ehci0-controller wakeup-source is fail.
[ 1.331081] sunxi ehci0-controller don't init wakeup source
[ 1.337388] [sunxi-ehci0]: probe, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04f3e20, 0x:c48dd000, irq_no:12b
[ 1.349684] sunxi-ehci 5101000.ehci0-controller: SW USB2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.359951] sunxi-ehci 5101000.ehci0-controller: new USB bus registered, assigned bus number 1
[ 1.369839] sunxi-ehci 5101000.ehci0-controller: irq 299, io mem 0xc39fa000
[ 1.399662] sunxi-ehci 5101000.ehci0-controller: USB 0.0 started, EHCI 1.00
[ 1.407505] sunxi-ehci 5101000.ehci0-controller: ehci_irq: highspeed device connect
[ 1.417227] hub 1-0:1.0: USB hub found
[ 1.421727] hub 1-0:1.0: 1 port detected
[ 1.426487] [ehci0-controller]: sunxi_usb_disable_ehci
[ 1.432362] [sunxi-ehci0]: remove, pdev->name: 5101000.ehci0-controller, sunxi_ehci: 0xc04f3e20
[ 1.442216] sunxi-ehci 5101000.ehci0-controller: remove, state 1
[ 1.449005] usb usb1: USB disconnect, device number 1
[ 1.455759] sunxi-ehci 5101000.ehci0-controller: USB bus 1 deregistered
[ 1.463969] ehci-platform: EHCI generic platform driver
[ 1.470523] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.477750] get drv_vbus is fail, 84
[ 1.482026] get ohci0-controller, regulator_io is no nocare
[ 1.488313] get ohci0-controller wakeup-source is fail.
[ 1.494492] sunxi ohci0-controller don't init wakeup source
[ 1.500918] [sunxi-ohci0]: probe, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04f35d0
[ 1.510742] sunxi-ohci 5101000.ohci0-controller: SW USB2.0 'Open' Host Controller (OHCI) Driver
[ 1.520618] sunxi-ohci 5101000.ohci0-controller: new USB bus registered, assigned bus number 1
[ 1.530457] sunxi-ohci 5101000.ohci0-controller: irq 300, io mem 0xc39fa800
[ 1.604719] hub 1-0:1.0: USB hub found
[ 1.609137] hub 1-0:1.0: 1 port detected
[ 1.613970] [ohci0-controller]: sunxi_usb_disable_ohci
[ 1.619802] [sunxi-ohci0]: remove, pdev->name: 5101000.ohci0-controller, sunxi_ohci: 0xc04f35d0
[ 1.629617] sunxi-ohci 5101000.ohci0-controller: remove, state 1
[ 1.636477] usb usb1: USB disconnect, device number 1
[ 1.642955] sunxi-ohci 5101000.ohci0-controller: USB bus 1 deregistered
[ 1.651186] ohci-platform: OHCI generic platform driver
[ 1.657811] usbcore: registered new interface driver cdc_acm
[ 1.664391] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 1.673690] usbcore: registered new interface driver uas
[ 1.680012] usbcore: registered new interface driver usb-storage
[ 1.686987] usbcore: registered new interface driver ums-alauda
[ 1.693892] usbcore: registered new interface driver ums-cypress
[ 1.700918] usbcore: registered new interface driver ums-datafab
[ 1.707931] usbcore: registered new interface driver ums_eneub6250
[ 1.715145] usbcore: registered new interface driver ums-freecom
[ 1.722252] usbcore: registered new interface driver ums-isd200
[ 1.729184] usbcore: registered new interface driver ums-jumpshot
[ 1.736267] usbcore: registered new interface driver ums-karma
[ 1.743121] usbcore: registered new interface driver ums-onetouch
[ 1.750307] usbcore: registered new interface driver ums-realtek
[ 1.757327] usbcore: registered new interface driver ums-sddr09
[ 1.764218] usbcore: registered new interface driver ums-sddr55
[ 1.771168] usbcore: registered new interface driver ums-usbat
[ 1.778146] usbcore: registered new interface driver usbserial
[ 1.785051] usbcore: registered new interface driver usbserial_generic
[ 1.792747] usbserial: USB Serial support registered for generic
[ 1.799841] usbcore: registered new interface driver option
[ 1.806281] usbserial: USB Serial support registered for GSM modem (1-port)
[ 1.814366] usb_serial_number:20080411
[ 1.818944] sunxi_gpadc_init,1831, success
[ 1.824293] sunxi_gpadc_setup: get channel scan data failed
[ 1.831139] input: sunxi-gpadc0 as /devices/virtual/input/input0
[ 1.839279] sunxi-rtc rtc: rtc core: registered sunxi-rtc as rtc0
[ 1.846577] sunxi-rtc rtc: RTC enabled
[ 1.851309] i2c /dev entries driver
[ 1.855951] sunxi cedar version 0.1
[ 1.860288] VE: install start!!!
[ 1.860288]
[ 1.865756] cedar_ve: cedar-ve the get irq is 291
[ 1.871276] VE: line 1811 set the sram data
[ 1.871276]
[ 1.878170] VE: ve_debug_proc_info:c04f6108, data:c3bac000, lock:c04f6190
[ 1.878170]
[ 1.887757] VE: install end!!!
[ 1.887757]
[ 1.893349] google_vp9: sunxi google vp9 version 0.1
[ 1.900199] sunxi-wdt 30090a0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.911241] sunxi-mmc sdc0: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
[ 1.920456] sunxi-mmc sdc0: ***ctl-spec-caps*** 8
[ 1.925801] sunxi-mmc sdc0: No vmmc regulator found
[ 1.931428] sunxi-mmc sdc0: No vqmmc regulator found
[ 1.937031] sunxi-mmc sdc0: No vdmmc regulator found
[ 1.942638] sunxi-mmc sdc0: No vd33sw regulator found
[ 1.948337] sunxi-mmc sdc0: No vd18sw regulator found
[ 1.954099] sunxi-mmc sdc0: No vq33sw regulator found
[ 1.959837] sunxi-mmc sdc0: No vq18sw regulator found
[ 1.965530] sunxi-mmc sdc0: Cann't get uart0 pinstate,check if needed
[ 1.972829] sunxi-mmc sdc0: Cann't get sleep pinstate,check if needed
[ 1.980575] sunxi-mmc sdc0: set host busy
[ 1.985193] mmc:failed to get gpios
[ 1.989134] sunxi-mmc sdc0: min-frequency:100000
[ 1.994647] sunxi-mmc sdc0: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.005125] sunxi-mmc sdc0: no vqmmc,Check if there is regulator
[ 2.039665] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.079664] sunxi-mmc sdc0: detmode:alway in(non removable)
[ 2.079692] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.088085] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.111114] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.122205] sunxi-mmc sdc1: SD/MMC/SDIO Host Controller Driver(v3.37 2019-12-4 9:48)
[ 2.122347] sunxi-mmc sdc1: No vmmc regulator found
[ 2.122353] sunxi-mmc sdc1: No vqmmc regulator found
[ 2.122358] sunxi-mmc sdc1: No vdmmc regulator found
[ 2.122363] sunxi-mmc sdc1: No vd33sw regulator found
[ 2.122369] sunxi-mmc sdc1: No vd18sw regulator found
[ 2.122374] sunxi-mmc sdc1: No vq33sw regulator found
[ 2.122380] sunxi-mmc sdc1: No vq18sw regulator found
[ 2.122396] sunxi-mmc sdc1: Cann't get uart0 pinstate,check if needed
[ 2.122840] sunxi-mmc sdc1: set host busy
[ 2.122904] mmc:failed to get gpios
[ 2.123193] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm UP vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.123224] sunxi-mmc sdc1: no vqmmc,Check if there is regulator
[ 2.154631] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.183663] sunxi-mmc sdc1: detmode:manually by software
[ 2.229241] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.243212] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[ 2.250058] sunxi-mmc sdc1: smc 1 p1 err, cmd 52, RTO !!
[ 2.256107] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 2.267932] usbcore: registered new interface driver usbhid
[ 2.267934] usbhid: USB HID core driver
[ 2.268226] mostcore: init()
[ 2.269234] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.269526] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.269682] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.269827] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.269942] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.269964] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270085] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270114] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270226] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270244] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270350] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270367] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270468] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270483] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270590] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270606] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270714] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270730] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270837] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.270856] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.270966] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.271009] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.271115] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.271130] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.277481] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.277544] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.281937] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.281996] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.285291] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.285323] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.294278] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.294329] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.304101] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.304162] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.304270] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.304311] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.313266] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.313318] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.323081] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.323128] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.332108] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.332150] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.332177] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.341907] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.341940] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.341981] sunxi-mmc sdc0: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.342044] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.342119] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 1 timing SD-HS(SDR25) dt B
[ 2.342253] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.342308] sunxi-mmc sdc0: sdc set ios:clk 50000000Hz bm PP pm ON vdd 21 width 4 timing SD-HS(SDR25) dt B
[ 2.342358] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.342385] mmc0: new high speed SDHC card at address 0001
[ 2.342928] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.351923] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.351983] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.352000] ac108 2-003b: ref_cfg.ref_channel:0x3, set ref_pga_gain:16
[ 2.352107] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.352125] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.352229] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.352331] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.352444] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.352471] mmcblk0: mmc0:0001 ASTC 7.50 GiB
[ 2.352832] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.352949] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.353012] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.353123] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.353315] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.353430] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.353453] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.353561] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.353581] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.363381] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.363492] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.372800] mmcblk0: p1 p2 p3 p4 p5
[ 2.393706] random: fast init done
[ 2.440888] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.440916] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.449862] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.449893] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x3b)
[ 2.449943] ac108 2-003b: i2c probe succeed.
[ 2.459877] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.459910] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.468845] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.468876] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.478594] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.478616] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.487565] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.487592] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.497317] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.497338] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.506284] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.506311] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.516036] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.516057] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.524996] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.525023] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.534754] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.534776] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.543715] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.543741] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.553469] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.553489] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.562430] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.562456] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.572180] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.572200] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.581142] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.581169] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.590891] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.590912] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.599853] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.599879] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.609593] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.609611] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.618558] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.618583] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.628299] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.628320] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.637264] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.637291] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.647005] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.647027] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.655961] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.655987] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.665712] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.665733] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.674673] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.674700] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.684418] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.684440] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.684452] ac108 2-0035: ref_cfg.ref_channel:0x3, set ref_pga_gain:16
[ 2.693490] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.693517] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.702463] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.702485] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.712208] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.712240] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.722937] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.722958] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.731890] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.731918] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.742809] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.742830] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.752558] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.752583] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.763484] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.763504] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.841845] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.841871] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.851602] sunxi_i2c_drv_core_process()1020 - [i2c2] Timeout when sending 9th SCL clk
[ 2.851623] i2c_sunxi_drv_complete()1194 - [i2c2] incomplete xfer(status: 0x1, dev addr: 0x35)
[ 2.851658] ac108 2-0035: i2c probe succeed.
[ 2.852321] --->sunxi_daudio_dev_probe<--- strat.
[ 2.852458] sunxi-daudio daudio0: regulator missing or invalid
[ 2.852591] --->sunxi_daudio_dev_probe<--- end.
[ 2.853206] digital_vol:0, lineout_vol:31, main_gain:23, pa_msleep:160, pa_level:1
[ 2.853217] adcdrc_cfg:0, adchpf_cfg:1, dacdrc_cfg:1, dachpf:0
[ 2.853304] sunxi-internal-codec codec: [sunxi_internal_codec_probe] codec probe finished.
[ 2.855337] NET: Registered protocol family 10
[ 2.866276] NET: Registered protocol family 17
[ 2.866335] NET: Registered protocol family 15
[ 2.867235] Registering SWP/SWPB emulation handler
[ 3.758277] get det_vbus is fail, 84
[ 3.763496] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm PP pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.775539] sunxi-mmc sdc1: smc 1 p1 err, cmd 8, RTO !!
[ 3.781539] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.787466] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.793392] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.799337] sunxi-mmc sdc1: smc 1 p1 err, cmd 5, RTO !!
[ 3.805243] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.811271] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.817286] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.823300] sunxi-mmc sdc1: smc 1 p1 err, cmd 55, RTO !!
[ 3.823336] sunxi-mmc sdc1: sdc set ios:clk 400000Hz bm OD pm ON vdd 21 width 1 timing LEGACY(SDR12) dt B
[ 3.829413] sunxi-mmc sdc1: smc 1 p1 err, cmd 1, RTO !!
[ 3.829437] sunxi-mmc sdc1: sdc set ios:clk 0Hz bm PP pm OFF vdd 0 width 1 timing LEGACY(SDR12) dt B
[ 3.857492] get id is fail, 84
[ 3.861831] sunxi-rtc rtc: setting system clock to 1970-01-01 00:00:14 UTC (14)
[ 3.871232] snddaudio snddaudio0: codec: ac108.2-003b, codec_dai: ac108-pcm0.
[ 3.879863] snddaudio snddaudio0: ac108-pcm0 <-> daudio0 mapping ok
[ 3.888417] ALSA device list:
[ 3.892147] #0: sndac108.2-003b
[ 3.897959] EXT4-fs (mmcblk0p4): couldn't mount as ext3 due to feature incompatibilities
[ 3.917550] EXT4-fs (mmcblk0p4): mounted filesystem without journal. Opts: (null)
[ 3.926300] VFS: Mounted root (ext4 filesystem) readonly on device 179:4.
[ 3.934320] Freeing unused kernel memory: 144K
[ 3.939313] This architecture does not have kernel memory protection.
[ 4.131255] EXT4-fs (mmcblk0p4): warning: mounting unchecked fs, running e2fsck is recommended
[ 4.149331] EXT4-fs error (device mmcblk0p4): ext4_has_uninit_itable:3049: comm mount: Inode table for bg 0 marked as needing zeroing
[ 4.167142] EXT4-fs (mmcblk0p4): Remounting filesystem read-only
[ 4.173953] EXT4-fs (mmcblk0p4): re-mounted. Opts: block_validity,delalloc,barrier,user_xattr
------run rc.preboot file-----
[ 4.380446] EXT4-fs (mmcblk0p5): mounted filesystem with ordered data mode. Opts: (null)
------run rc.modules file-----
------run rc.final file-----
Load mpp modules
[ 4.587991] [sensor_power_err]fetch sensor0_phase from device_tree failed
[ 4.660372] [VIN_ERR]registering sp2305_mipi, No such device!
Initializing random number generator... [ 4.764930] random: dd: uninitialized urandom read (512 bytes read)
done.
Starting network...
[ 5.002227] get wifi_sdc_id failed
[ 5.136274] get wifi_sdc_id failed
insmod: can't insert '/lib/modules/4.9.118/8189fs.ko': Operation not permitted
ifconfig: SIOCGIFFLAGS: No such device
Line 6: Invalid passphrase length 0 (expected: 8..63) '"'.
Line 6: failed to parse psk '""'.
Line 7: failed to parse network block.
Failed to read or parse configuration '/etc/wpa_supplicant.conf'.
udhcpc: SIOCGIFINDEX: No such device
Starting telnetd: OK
enable android usb
[ 7.287701] file system registered
[ 7.299173] Mass Storage Function, version: 2009/09/11
[ 7.305141] LUN: removable file: (no medium)
/etc/init.d/S50usb: line 99: adbd: not found
[ 9.333862] configfs-gadget 5100000.udc-controller: failed to start g1: -19
sh: write error: No such device
generate key
[ 9.372748] random: dropbearkey: uninitialized urandom read (32 bytes read)
[ 9.383051] random: dropbearkey: uninitialized urandom read (32 bytes read)
[ 17.871736] random: dropbearkey: uninitialized urandom read (32 bytes read)
Public key portion is:
ssh-rsa AAAAB3NzaC1yc2EAAAADAQABAAABAQCc05XIzsTw+EDtxmBTRCYwcOducpcsP2davEwD8MfusgVOpBt4e3YDrts56O67rhlMcLJAIbZ3/Khzm+Jg8TnbIBYHoc/2K3Wjv6+ezOqSzX1ClXuwj3ARy8ipycWip0fWDnhvQBpO7YtybC3wWPmCFGQCks7pidmbLwIo3WPo7BfhwH27ayFLFXIpneOqczd9CFzInwy6h4qGMIGwUBMsdk[ 17.903404] random: dropbear: uninitialized urandom read (32 bytes read)
tIJAjnsefmNjeh4w/NcPARE97IvUQTJSd7Qopp9LZC3PLZaoM2jMHl9NyVkhs9Ww0rFAYULEo+bc6BTSfwhRbW4MaPC2VxgvSM1P2R/4We9IYWDa6kunpD0lkokaXf root@YuzukiIRC
Fingerprint: md5 90:a3:29:f0:9f:26:80:8f:d4:da:40:f2:9b:44:18:8b
Start dropbear: OK
Starting ntpd: doneboard.dts
* Allwinner Technology CO., Ltd. sun8iw19p1 soc board.
* soc board support.
/dts-v1/;
#include "sun8iw19p1.dtsi"
dram: dram {
dram_clk = <0x000001e0>;
dram_type = <0x00000003>;
dram_zq = <0x00003bfb>;
dram_odt_en = <0x00000001>;
dram_para1 = <0x004310f2>;
dram_para2 = <0x02000000>;
dram_mr0 = <0x00001c70>;
dram_mr1 = <0x00000000>;
dram_mr2 = <0x00000018>;
dram_mr3 = <0x00000000>;
dram_tpr0 = <0x0046190d>;
dram_tpr1 = <0x0121210a>;
dram_tpr2 = <0x0005403b>;
dram_tpr3 = <0x00002006>;
dram_tpr4 = <0x05040405>;
dram_tpr5 = <0x05050302>;
dram_tpr6 = <0x90006644>;
dram_tpr7 = <0x42c21590>;
dram_tpr8 = <0xd05612c0>;
dram_tpr9 = <0x00083def>;
dram_tpr10 = <0x00000000>;
dram_tpr11 = <0x00210000>;
dram_tpr12 = <0x00000055>;
dram_tpr13 = <0x00006003>;
opp_dvfs_table:opp_dvfs_table {
cluster_num = <1>;
opp_table_count = <1>;
cpu_opp_l_table0: opp_l_table0 {
compatible = "allwinner,opp_l_table0";
opp_count = <2>;
opp-shared;
opp00 {
opp-hz = /bits/ 64 <600000000>;
opp-microvolt = <900000>;
axi-bus-divide-ratio = <3>;
clock-latency-ns = <2000000>;
opp01 {
opp-hz = /bits/ 64 <816000000>;
soc@03000000 {
pinctrl@0300b000 {
twi0_pins_a: twi0@0 {
allwinner,pins = "PI3", "PI4";
allwinner,pname = "twi0_scl", "twi0_sda";
allwinner,function = "twi0";
allwinner,muxsel = <5>;
allwinner,drive = <1>;
allwinner,pull = <0>;
twi0_pins_b: twi0@1 {
allwinner,function = "io_disabled";
allwinner,muxsel = <7>;
twi1_pins_a: twi1@0 {
allwinner,pins = "PI1", "PI2";
allwinner,pname = "twi1_scl", "twi1_sda";
allwinner,function = "twi1";
twi1_pins_b: twi1@1 {
twi2_pins_a: twi2@0 {
allwinner,pins = "PH5", "PH6";
allwinner,pname = "twi2_scl", "twi2_sda";
allwinner,function = "twi2";
twi2_pins_b: twi2@1 {
spi0_pins_a: spi0@0 {
allwinner,pins = "PC0", "PC2", "PC3",
"PC5", "PC4";
allwinner,pname = "spi0_sclk", "spi0_mosi",
"spi0_miso", "spi0_hold", "spi0_wp";
allwinner,function = "spi0";
allwinner,muxsel = <4>;
spi0_pins_b: spi0@1 {
allwinner,pins = "PC1", "PC6";
allwinner,pname = "spi0_cs0", "spi0_cs1";
allwinner,pull = <1>; // only CS should be pulled up
spi0_pins_c: spi0@2 {
allwinner,pins = "PC0", "PC1", "PC2", "PC3",
"PC4", "PC5", "PC6";
spi1_pins_a: spi1@0 {
allwinner,pins = "PH0", "PH1", "PH2";
allwinner,pname = "spi1_sclk", "spi1_mosi",
"spi1_miso";
spi1_pins_b: spi1@1 {
allwinner,pins = "PH3";
allwinner,pname = "spi1_cs0";
spi1_pins_c: spi1@2 {
allwinner,pins = "PH0", "PH1", "PH2", "PH3";
sdc0_pins_a: sdc0@0 {
allwinner,pins = "PF0", "PF1", "PF2", "PF3",
"PF4", "PF5";
allwinner,function = "sdc0";
allwinner,muxsel = <2>;
allwinner,drive = <3>;
sdc0_pins_b: sdc0@1 {
"PF4", "PF5";
sdc1_pins_a: sdc1@0 {
allwinner,pins = "PG0", "PG1", "PG2", "PG3",
"PG4", "PG5";
allwinner,function = "sdc1";
owc0_pins_a: owc0@0 {
allwinner,pins = "PH4";
allwinner,pname = "owc0";
allwinner,function = "owc0";
owc0_pins_b: owc0_sleep@0 {
pwm0_pins_a: pwm0@0 {
allwinner,pins = "PH0";
allwinner,pname = "pwm0_positive";
allwinner,function = "pwm0";
pwm0_pins_b: pwm0@1 {
pwm1_pins_a: pwm1@0 {
allwinner,pins = "PH1";
allwinner,pname = "pwm1_positive";
allwinner,function = "pwm1";
pwm1_pins_b: pwm1@1 {
pwm2_pins_a: pwm2@0 {
allwinner,pins = "PH2";
allwinner,pname = "pwm2_positive";
allwinner,function = "pwm2";
pwm2_pins_b: pwm2@1 {
pwm3_pins_a: pwm3@0 {
allwinner,pname = "pwm3_positive";
allwinner,function = "pwm3";
pwm3_pins_b: pwm3@1 {
pwm4_pins_a: pwm4@0 {
allwinner,pname = "pwm4_positive";
allwinner,function = "pwm4";
pwm4_pins_b: pwm4@1 {
// pwm5_pins_a: pwm5@0 {
// allwinner,pins = "PH5";
// allwinner,pname = "pwm5_positive";
// allwinner,function = "pwm5";
// allwinner,muxsel = <2>;
// allwinner,drive = <1>;
// allwinner,pull = <0>;
// pwm5_pins_b: pwm5@1 {
// allwinner,function = "io_disabled";
// allwinner,muxsel = <7>;
//pwm6_pins_a: pwm6@0 {
// allwinner,pins = "PH6";
// allwinner,pname = "pwm6_positive";
// allwinner,function = "pwm6";
// //pwm6_pins_b: pwm6@1 {
pwm7_pins_a: pwm7@0 {
allwinner,pins = "PH7";
allwinner,pname = "pwm7_positive";
allwinner,function = "pwm7";
pwm7_pins_b: pwm7@1 {
pwm8_pins_a: pwm8@0 {
allwinner,pins = "PH8";
allwinner,pname = "pwm8_positive";
allwinner,function = "pwm8";
pwm8_pins_b: pwm8@1 {
pwm9_pins_a: pwm9@0 {
allwinner,pins = "PH9";
allwinner,pname = "pwm9_positive";
allwinner,function = "pwm9";
pwm9_pins_b: pwm9@1 {
rgb8_pins_a: rgb8@0 {
allwinner,pins = "PD1", "PD2", "PD3", "PD4", "PD5", "PD6",
"PD7", "PD8", "PD18", "PD19", "PD20";
allwinner,pname = "lcdd3", "lcdd4", "lcdd5", "lcdd6", "lcdd7",
"lcdd10", "lcdd11", "lcdd12", "lcdclk", "lcdde",
"lcdhsync";
allwinner,function = "lcd0";
rgb8_pins_b: rgb8@1 {
allwinner,pins = "PD1", "PD2","PD3","PD4","PD5","PD6",
"PD7","PD8","PD18","PD19","PD20";
gpadc:gpadc{
channel_num = <1>;
channel_select = <0x01>;
channel_data_select = <0>;
channel_compare_select = <0x01>;
channel_cld_select = <0x01>;
channel_chd_select = <0x01>;
channel0_compare_lowdata = <1700000>;
channel0_compare_higdata = <1200000>;
key_cnt = <2>;
key0_vol = <0>;
key0_val = <2>; /* KEY_1 */
key1_vol = <160>;
key1_val = <3>; /* KEY_2 */
uart1: uart@05000400 {
compatible = "allwinner,sun8i-uart";
device_type = "uart1";
reg = <0x0 0x05000400 0x0 0x400>;
interrupts = <GIC_SPI 50 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart1>;
pinctrl-0 = <&uart1_pins_a>;
pinctrl-1 = <&uart1_pins_b>;
uart1_port = <1>;
uart1_type = <4>;
// uart3: uart@05000c00 {
// compatible = "allwinner,sun8i-uart";
// device_type = "uart3";
// reg = <0x0 0x05000c00 0x0 0x400>;
// interrupts = <GIC_SPI 52 IRQ_TYPE_LEVEL_HIGH>;
// clocks = <&clk_uart3>;
// pinctrl-names = "default", "sleep";
// pinctrl-0 = <&uart3_pins_a>;
// pinctrl-1 = <&uart3_pins_b>;
// uart3_port = <3>;
// uart3_type = <4>;
// status = "okay";
twi0: twi@0x05002000{
pinctrl-0 = <&twi0_pins_a>;
pinctrl-1 = <&twi0_pins_b>;
twi_drv_used = <1>;
status = "disable";
twi1: twi@0x05002400{
pinctrl-0 = <&twi1_pins_a>;
pinctrl-1 = <&twi1_pins_b>;
clock-frequency = <400000>;
twi2: twi@0x05002800{
pinctrl-0 = <&twi2_pins_a>;
pinctrl-1 = <&twi2_pins_b>;
clock-frequency = <200000>;
ac108@3b{
#sound-dai-cells = <0>;
compatible = "Allwinner,MicArray_0";
reg = <0x3b>;
regulator_used = <0x0>;
power_voltage = <3300000>;
regulator_name = "vcc-3v3";
power_gpio_used = <0x0>;
reset_gpio_used = <0x0>;
twi_bus = <2>;
pga_gain = <0x1F>;
slot_width = <0x20>;
lrck_period = <0x80>;
ref_pga_used = <0x1>;
ref_pga_gain = <0x10>;
ref_channel = <0x3>;
debug_mode = <0x0>;
ac108@35{
compatible = "Allwinner,MicArray_1";
reg = <0x35>;
twi_bus = <2>;
pga_gain = <0x1F>;
debug_mode = <0x0>;
spi@05010000 {
pinctrl-0 = <&spi0_pins_a &spi0_pins_b>;
pinctrl-1 = <&spi0_pins_c>;
status = "disable";
spi_board0 {
device_type = "spi_board0";
compatible = "m25p80";
spi-max-frequency = <0x5f5e100>;
reg = <0x0>;
spi-rx-bus-width = <0x1>;
spi-tx-bus-width = <0x1>;
// spi@05011000 {
// #address-cells = <1>;
// #size-cells = <0>;
// reg = <0x0 0x05011000 0x0 0x1000>;
// interrupts = <GIC_SPI 55 IRQ_TYPE_LEVEL_HIGH>;
// clocks = <&clk_pll_periph0>, <&clk_spi1>;
// clock-frequency = <200000000>;
// pinctrl-0 = <&spi1_pins_b>;
// pinctrl-1 = <&spi1_pins_c>;
// spi1_cs_number = <2>;
// spi1_cs_bitmap = <3>;
// status = "okay";
// spi_board1 {
// device_type = "spi_board1";
// compatible = "spidev";
// spi-max-frequency = <0x5f5e100>;
// reg = <0x0>;
// spi-rx-bus-width = <0x1>;
// spi-tx-bus-width = <0x1>;
vind0:vind@0 {
vind0_clk = <270000000>;
vind0_isp = <200000000>;
actuator0:actuator@0 {
device_type = "actuator0";
actuator0_name = "ad5820_act";
actuator0_slave = <0x18>;
actuator0_af_pwdn = <>;
actuator0_afvdd = "afvcc-csi";
actuator0_afvdd_vol = <2800000>;
status = "disabled";
flash0:flash@0 {
device_type = "flash0";
flash0_type = <2>;
flash0_en = <>;
flash0_mode = <>;
flash0_flvdd = "";
flash0_flvdd_vol = <>;
device_id = <0>;
sensor0:sensor@0 {
device_type = "sensor0";
// sensor0_mname = "ov9732_mipi";
sensor0_mname = "sp2305_mipi";
sensor0_twi_cci_id = <1>;
// sensor0_twi_addr = <0x6c>;
sensor0_twi_addr = <0x78>;
sensor0_mclk_id = <0>;
sensor0_pos = "rear";
sensor0_isp_used = <1>;
sensor0_fmt = <1>;
sensor0_stby_mode = <0>;
sensor0_vflip = <0>;
sensor0_hflip = <0>;
sensor0_iovdd-supply = <>;
sensor0_iovdd_vol = <1800000>;
sensor0_avdd-supply = <>;
sensor0_avdd_vol = <2800000>;
sensor0_dvdd-supply = <>;
sensor0_dvdd_vol = <1200000>;
sensor0_power_en = <>;
/* board error, we can not use the right config. */
sensor0_reset = <&pio PE 16 1 0 1 0>;
sensor0_pwdn = <&pio PE 17 1 0 1 0>;
sensor1:sensor@1 {
device_type = "sensor1";
sensor1_mname = "ov5647";
sensor1_twi_cci_id = <0>;
sensor1_twi_addr = <0x6c>;
sensor1_mclk_id = <1>;
sensor1_pos = "front";
sensor1_isp_used = <0>;
sensor1_fmt = <0>;
sensor1_stby_mode = <0>;
sensor1_vflip = <0>;
sensor1_hflip = <0>;
sensor1_iovdd-supply = <>;
sensor1_iovdd_vol = <2800000>;
sensor1_avdd-supply = <>;
sensor1_avdd_vol = <2800000>;
sensor1_dvdd-supply = <>;
sensor1_dvdd_vol = <1500000>;
sensor1_power_en = <>;
sensor1_reset = <&pio PI 3 1 0 1 0>;
sensor1_pwdn = <&pio PI 4 1 0 1 0>;
vinc0:vinc@0 {
vinc0_csi_sel = <0>;
vinc0_mipi_sel = <0>;
vinc0_isp_sel = <0>;
vinc0_isp_tx_ch = <0>;
vinc0_rear_sensor_sel = <0>;
vinc0_front_sensor_sel = <0>;
vinc0_sensor_list = <0>;
vinc1:vinc@1 {
vinc1_csi_sel = <0>;
vinc1_mipi_sel = <0>;
vinc1_isp_sel = <0>;
vinc1_isp_tx_ch = <0>;
vinc1_rear_sensor_sel = <0>;
vinc1_front_sensor_sel = <0>;
vinc1_sensor_list = <0>;
vinc2:vinc@2 {
vinc2_csi_sel = <0>;
vinc2_mipi_sel = <0>;
vinc2_isp_sel = <0>;
vinc2_isp_tx_ch = <0>;
vinc2_rear_sensor_sel = <0>;
vinc2_front_sensor_sel = <0>;
vinc2_sensor_list = <0>;
vinc3:vinc@3 {
vinc3_csi_sel = <1>;
vinc3_mipi_sel = <0xff>;
vinc3_isp_sel = <1>;
vinc3_isp_tx_ch = <0>;
vinc3_rear_sensor_sel = <1>;
vinc3_front_sensor_sel = <1>;
vinc3_sensor_list = <0>;
// s_owc0: s_owc@07040400 {
// pinctrl-0 = <&owc0_pins_a>;
// pinctrl-1 = <&owc0_pins_b>;
// status = "okay";
sdc0: sdmmc@04020000 {
pinctrl-0 = <&sdc0_pins_a>;
bus-width = <4>;
// cd-gpios = <&pio PF 6 0 1 3 0xffffffff>;
non-removable;
card-pwr-gpios;// = <&pio PC 4 1 1 2 0xffffffff>;
sunxi-power-save-mode;
sunxi-signal-vol-sw-without-pmu;
sd-uhs-sdr50;
sd-uhs-ddr50;
sd-uhs-sdr104;
/*sunxi-dis-signal-vol-sw;*/
max-frequency = <150000000>;
min-frequency = <100000>;
cd-used-24M;
no-sdio;
/*broken-cd;*/
ctl-spec-caps = <0x8>;
card0_boot_para {
device_type = "card0_boot_para";
card_ctrl = <0x0>;
card_high_speed = <0x1>;
card_line = <0x4>;
time_pwroff_ms = <200>;
pinctrl-1 = <&sdc0_pins_b>;
sdc1: sdmmc@04021000 {
pinctrl-0 = <&sdc1_pins_a>;
bus-width = <4>;
/*sunxi-power-save-mode;*/
/*sd-uhs-sdr12*/
/*sd-uhs-sdr25*/
/*sd-uhs-sdr50*/
/*sd-uhs-sdr104*/
cap-sdio-irq;
keep-power-in-suspend;
ignore-pm-notify;
max-frequency = <50000000>;
usbc0:usbc0@0{
usb_port_type = <0x2>;
usb_detect_type = <0x1>;
usb_detect_mode = <0>;
usb_id_gpio;
usb_det_vbus_gpio;
usb_drv_vbus_gpio;
usb_host_init_state = <0>;
disp: disp@01000000 {
disp_init_enable = <1>;
disp_mode = <0>;
screen0_output_type = <1>;
screen0_output_mode = <4>;
disp_rotation_used = <1>;
degree0 = <0>;
fb0_format = <8>;
fb0_width = <240>;
fb0_height = <240>;
// fb0_height = <320>;
lcd0_backlight = <50>;
lcd0_bright = <50>;
lcd0_contrast = <50>;
lcd0_saturation = <57>;
lcd0_hue = <50>;
lcd0: lcd0@01c0c000 {
lcd_used = <1>;
lcd_size = "1.3";
lcd_model_name = "inv";
lcd_driver_name = "st7789v_cpu";
lcd_x = <240>;
lcd_y = <240>;
lcd_width = <108>;
lcd_height = <64>;
lcd_dclk_freq = <10>;
lcd_backlight = <50>;
lcd_pwm_used = <0>;
lcd_pwm_ch = <1>;
lcd_pwm_freq = <50000>;
lcd_pwm_pol = <1>;
lcd_pwm_max_limit = <255>;
lcd_hbp = <60>;
lcd_ht = <298>;
lcd_hspw = <30>;
lcd_vbp = <250>;
lcd_vt = <265>;
lcd_vspw = <2>;
lcd_if = <1>;
lcd_frm = <2>;
lcd_cpu_mode = <1>;
lcd_cpu_te = <0>;
lcd_cpu_if = <14>;
lcd_io_phase = <0x0000>;
lcdgamma4iep = <22>;
lcd_gamma_en = <0>;
lcd_cmap_en = <0>;
lcd_bright_curve_en = <0>;
lcd_rb_swap = <0>;
lcd_gpio_0 = <&pio PH 5 1 0 3 0>; /* rst */
lcd_gpio_1 = <&pio PD 21 1 0 3 0>; /* cs */
pinctrl-0 = <&rgb8_pins_a>;
pinctrl-1 = <&rgb8_pins_b>;
daudio0:daudio@0x05090000 {
mclk_div = <0x1>;
frametype = <0x00>;
tdm_config = <0x00>;
sign_extend = <0x00>;
tx_data_mode = <0x00>;
rx_data_mode = <0x00>;
msb_lsb_first = <0x00>;
pcm_lrck_period = <0x80>;
slot_width_select = <0x20>;
asrc_function_en = <0x00>;
daudio_master = <0x04>;
signal_inversion = <0x01>;
audio_format = <0x01>;
daudio1:daudio@0x05091000 {
mclk_div = <0x01>;
frametype = <0x00>;
tdm_config = <0x01>;
codec:codec@0x05096000 {
pa_level = <0x1>;
main_gain = <0x17>;
adcdrc_cfg = <0x00>;
adchpf_cfg = <0x01>;
dacdrc_cfg = <0x01>;
dachpf_cfg = <0x00>;
digital_vol = <0x00>;
lineout_vol = <0x1f>;
pa_msleep_time = <0xa0>;
/* gpio-spk = <&pio PH 14 1 1 1 1>; */
sndcodec:sound@0 {
snddaudio0:sound@1 {
sunxi,snddaudio-codec = "ac108.2-003b";
sunxi,snddaudio-codec-dai = "ac108-pcm0";
sunxi,cpudai-controller = <&daudio0>;
snddaudio1:sound@2 {
//wlan:wlan {
// compatible = "allwinner,sunxi-wlan";
// clocks = <&clk_losc_out>;
// wlan_busnum = <1>;
// wlan_usbnum = <3>;
// wakeup_source = <0>;
// /* wlan_power-supply = <®_dcdc1>; */
// /* io_regulator-supply = <®_dcdc5>; */
// /* wlan_power_vol = <3300000>; */
// /* io_regulator_vol = <3300000>; */
// /* wlan_en; */
// wlan_regon = <&pio PH 4 1 0 1 0>;
// /* wlan_hostwake = <&pio PG 7 0 0 1 0>; */
// wlan_hostwake;
// status = "okay";
};sun8iw19p.dtsi
* Allwinner Technology CO., Ltd. sun8iw19p1 platform
* modify base on juno.dts
/* kernel used */
/memreserve/ 0x41980000 0x00018000; /* optee:0x41980000~0x41998000,size=96k */
#include <dt-bindings/interrupt-controller/arm-gic.h>
#include "sun8iw19p1-clk.dtsi"
#include "sun8iw19p1-pinctrl.dtsi"
#include <dt-bindings/thermal/thermal.h>
model = "sun8iw19";
compatible = "allwinner,sun8iw19p1";
interrupt-parent = <&wakeupgen>;
#address-cells = <2>;
#size-cells = <2>;
aliases {
serial0 = &uart0;
serial1 = &uart1;
serial2 = &uart2;
serial3 = &uart3;
twi0 = &twi0;
twi1 = &twi1;
twi2 = &twi2;
twi3 = &twi3;
twi4 = &twi4;
spi0 = &spi0;
spi1 = &spi1;
spi2 = &spi2;
gmac0 = &gmac0;
global_timer0 = &soc_timer0;
mmc0 = &sdc0;
mmc2 = &sdc2;
/*nand0 =&nand0;*/
disp = &disp;
lcd0 = &lcd0;
/*hdmi = &hdmi;*/
pwm = &pwm;
pwm0 = &pwm0;
pwm1 = &pwm1;
pwm2 = &pwm2;
pwm3 = &pwm3;
pwm4 = &pwm4;
pwm5 = &pwm5;
pwm6 = &pwm6;
pwm7 = &pwm7;
pwm8 = &pwm8;
pwm9 = &pwm9;
/*tv0 = &tv0;
vdpo0 = &vdpo0;*/
boot_disp = &boot_disp;
chosen {
bootargs = "earlyprintk=sunxi-uart,0x05000000 loglevel=8 initcall_debug=0 console=ttyS0 init=/init";
linux,initrd-start = <0x0 0x0>;
linux,initrd-end = <0x0 0x0>;
cpus {
enable-method = "allwinner,sun8iw19p1";
#size-cells = <0>;
cpu0: cpu@0 {
device_type = "cpu";
compatible = "arm,cortex-a7";
reg = <0x0>;
enable-method = "psci";
clocks = <&clk_pll_cpu>;
clock-frequency = <1008000000>;
clock-latency = <2000000>;
/* if divide bin <&cpu_opp_l_table0 &cpu_opp_l_table1> */
operating-points-v2 = <&cpu_opp_l_table0>;
cpu-idle-states = <&CPU_SLEEP_0 &CLUSTER_SLEEP_0 &SYS_SLEEP_0>;
cooling-min-level = <5>;
cooling-max-level = <0>;
#cooling-cells = <2>; /* min followed by max */
dynamic-power-coefficient = <150>;
idle-states {
entry-method = "arm,psci";
CPU_SLEEP_0: cpu-sleep-0 {
compatible = "arm,idle-state";
arm,psci-suspend-param = <0x0010000>;
entry-latency-us = <45>;
exit-latency-us = <90>;
min-residency-us = <3000>;
local-timer-stop;
CLUSTER_SLEEP_0: cluster-sleep-0 {
arm,psci-suspend-param = <0x1010000>;
entry-latency-us = <55>;
exit-latency-us = <570>;
min-residency-us = <17000>;
local-timer-stop;
SYS_SLEEP_0: sys-sleep-0 {
arm,psci-suspend-param = <0x2010000>;
entry-latency-us = <0xffffffff>;
exit-latency-us = <0xffffffff>;
min-residency-us = <0xffffffff>;
local-timer-stop;
psci {
compatible = "arm,psci-1.0";
method = "smc";
n_brom {
compatible = "allwinner,n-brom";
reg = <0x0 0x0 0x0 0xc000>;
s_brom {
compatible = "allwinner,s-brom";
reg = <0x0 0x0 0x0 0x10000>;
sram_ctrl {
device_type = "sram_ctrl";
compatible = "allwinner,sram_ctrl";
reg = <0x0 0x03000000 0x0 0x100>;
sram_a1 {
compatible = "allwinner,sram_a1";
reg = <0x0 0x00010000 0x0 0x10000>;
sram_a2 {
compatible = "allwinner,sram_a2";
reg = <0x0 0x00040000 0x0 0x14000>;
prcm {
compatible = "allwinner,prcm";
reg = <0x0 0x01f01400 0x0 0x400>;
cpuscfg {
compatible = "allwinner,cpuscfg";
reg = <0x0 0x01f01c00 0x0 0x400>;
ion {
compatible = "allwinner,sunxi-ion";
*types list here:
ION_HEAP_TYPE_SYSTEM = 0,
ION_HEAP_TYPE_SYSTEM_CONTIG = 1,
ION_HEAP_TYPE_CARVEOUT = 2,
ION_HEAP_TYPE_CHUNK = 3,
ION_HEAP_TYPE_DMA = 4,
ION_HEAP_TYPE_SECURE = 6,
heap_sys_user@0{
compatible = "allwinner,sys_user";
heap-name = "sys_user";
heap-id = <0x0>;
heap-base = <0x0>;
heap-size = <0x0>;
heap-type = "ion_system";
heap_sys_contig@0{
compatible = "allwinner,sys_contig";
heap-name = "sys_contig";
heap-id = <0x1>;
heap-base = <0x0>;
heap-size = <0x0>;
heap-type = "ion_contig";
/*heap_carveout@0{
compatible = "allwinner,carveout";
heap-name = "carveout";
heap-id = <0x2>;
heap-base = <0x0>;
heap-size = <0x0>;
heap-type = "ion_carveout";
heap_cma@0{
compatible = "allwinner,cma";
heap-name = "cma";
heap-id = <0x4>;
heap-base = <0x0>;
heap-size = <0x0>;
heap-type = "ion_cma";
dram: dram {
compatible = "allwinner,dram";
device_type = "dram";
clocks = <&clk_pll_ddr0>;
clock-names = "pll_ddr0";
memory@40000000 {
device_type = "memory";
reg = <0x00000000 0x40000000 0x00000000 0x20000000>;
gic: interrupt-controller@03020000 {
compatible = "arm,cortex-a15-gic", "arm,cortex-a9-gic";
#interrupt-cells = <3>;
#address-cells = <0>;
device_type = "gic";
interrupt-controller;
reg = <0x0 0x03021000 0 0x1000>, /* GIC Dist */
<0x0 0x03022000 0 0x2000>, /* GIC CPU */
<0x0 0x03024000 0 0x2000>, /* GIC VCPU Control */
<0x0 0x03026000 0 0x2000>; /* GIC VCPU */
interrupts = <GIC_PPI 9 0xf04>; /* GIC Maintenence IRQ */
interrupt-parent = <&gic>;
nmi_intc: intc-nmi@07010320 {
compatible = "allwinner,sun8i-nmi";
#interrupt-cells = <2>;
reg = <0x0 0x07010320 0 0xc>;
pad-control-v1 = <0x07000208>;
interrupts = <GIC_SPI 104 4>;
wakeupgen: interrupt-controller@0 {
compatible = "allwinner,sunxi-wakeupgen";
sid: sunxi-sid@03006000 {
compatible = "allwinner,sunxi-sid";
device_type = "sid";
reg = <0x0 0x03006000 0 0x200>;
chipid: sunxi-chipid@03006200 {
compatible = "allwinner,sunxi-chipid";
device_type = "chipid";
reg = <0x0 0x03006200 0 0xC0>;
timer {
compatible = "arm,armv7-timer";
interrupts = <GIC_PPI 13 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, /* Secure Phys IRQ */
<GIC_PPI 14 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, /* Non-secure Phys IRQ */
<GIC_PPI 11 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>, /* Virt IRQ */
<GIC_PPI 10 (GIC_CPU_MASK_SIMPLE(2) | IRQ_TYPE_LEVEL_LOW)>; /* Hyp IRQ */
clock-frequency = <24000000>;
arm,cpu-registers-not-fw-configured;
pmu {
compatible = "arm,cortex-a7-pmu";
interrupts = <GIC_SPI 140 4>;
dramfreq {
compatible = "allwinner,sunxi-dramfreq";
reg = <0x0 0x01c62000 0x0 0x1000>,
<0x0 0x01c63000 0x0 0x1000>,
<0x0 0x01c20000 0x0 0x800>;
interrupts = <GIC_SPI 69 0x4>;
/* clocks = <&clk_pll_ddr>, <&clk_pll_periph0>, <&clk_ahb1>; */
uboot: uboot {
mmu_aw: iommu@030f0000 {
compatible = "allwinner,sunxi-iommu";
reg = <0x0 0x030f0000 0x0 0x1000>;
interrupts = <GIC_SPI 95 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "iommu-irq";
clocks = <&clk_iommu>;
clock-names = "iommu";
/*clock-frequency = <24000000>; */
#iommu-cells = <2>;
mbus0:mbus-controller@047FA000 {
compatible = "allwinner,sun8i-mbus";
reg = <0x0 0x04002000 0x0 0x1000>;
#mbus-cells = <1>;
ac200: ac200 {
compatible = "allwinner,sunxi-ac200";
/* clocks = <&clk_tcon0>; */
pinctrl-names = "active","sleep";
ramoops@0x48106000 {
compatible = "ramoops";
reg = <0x0 0x48106000 0x0 0x60000>;
record-size = <0x00020000>;
console-size = <0x00020000>;
pmsg-size = <0x00020000>;
cpucfg@09010000 {
compatible = "allwinner,sunxi-cpucfg";
reg = <0x0 0x09010000 0x0 0xc8>;
soc: soc@03000000 {
compatible = "simple-bus";
#size-cells = <2>;
ranges;
device_type = "soc";
dma0:dma-controller@03002000 {
compatible = "allwinner,sun8i-dma";
reg = <0x0 0x03002000 0x0 0x1000>;
interrupts = <GIC_SPI 10 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_dma>;
#dma-cells = <1>;
soc_timer0: timer@03009000 {
compatible = "allwinner,sun4i-a10-timer";
device_type = "soc_timer";
reg = <0x0 0x03009000 0x0 0x90>;
interrupts = <GIC_SPI 60 IRQ_TYPE_LEVEL_HIGH>;
/* On FPGA, timer can only use the losc.
* On IC, timer should use the hosc.
clocks = <&clk_hosc>, <&clk_losc>;
rtc: rtc@07000000 {
compatible = "allwinner,sun8i-rtc", "allwinner,sunxi-rtc";
device_type = "rtc";
reg = <0x0 0x07000000 0x0 0x400>;
interrupts = <GIC_SPI 105 IRQ_TYPE_LEVEL_HIGH>;
auto_switch;
wakeup-source;
gpr_offset = <0x100>;
gpr_len = <8>;
wdt: watchdog@030090a0 {
compatible = "allwinner,sun50i-wdt";
reg = <0x0 0x030090a0 0x0 0x20>;
interrupts = <GIC_SPI 14 IRQ_TYPE_LEVEL_HIGH>;
ve@01c0e000 {
compatible = "allwinner,sunxi-cedar-ve";
reg = <0x0 0x01c0e000 0x0 0x1000>,
<0x0 0x03000000 0x0 0x10>,
<0x0 0x03001000 0x0 0x800>,
<0x0 0x07010000 0x0 0x300>;
interrupts = <GIC_SPI 25 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_pll_uni>, <&clk_ve>;
iommus = <&mmu_aw 3 1>;
ise: ise@01c10000 {
compatible = "allwinner,sunxi-ise";
reg = <0x0 0x01c10000 0x0 0x1000>,
<0x0 0x03001000 0x0 0x800>;
interrupts = <GIC_SPI 24 4>;
/*clocks = <&clk_pll_ise>, <&clk_ise>;*/
eise: eise@0x02300000 {
compatible = "allwinner,sunxi-eise";
reg = <0x0 0x02300000 0x0 0x1000>,
interrupts = <GIC_SPI 26 4>;
clocks = <&clk_pll_uni>, <&clk_eise>;
iommus = <&mmu_aw 1 1>;
uart0: uart@05000000 {
device_type = "uart0";
reg = <0x0 0x05000000 0x0 0x400>;
interrupts = <GIC_SPI 49 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart0>;
pinctrl-0 = <&uart0_pins_a>;
pinctrl-1 = <&uart0_pins_b>;
uart0_port = <0>;
uart0_type = <2>;
uart1_port = <1>;
uart1_type = <4>;
uart2: uart@05000800 {
device_type = "uart2";
reg = <0x0 0x05000800 0x0 0x400>;
interrupts = <GIC_SPI 51 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_uart2>;
pinctrl-0 = <&uart2_pins_a>;
pinctrl-1 = <&uart2_pins_b>;
uart2_port = <2>;
uart2_type = <4>;
uart3_port = <3>;
uart3_type = <4>;
compatible = "allwinner,sunxi-owc";
device_type = "s_owc0";
reg = <0x0 0x07040400 0x0 0x30>;
interrupts = <GIC_SPI 114 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_hosc>,<&clk_cpurowc>;
#size-cells = <0>;
compatible = "allwinner,sun8i-twi";
device_type = "twi0";
reg = <0x0 0x05002000 0x0 0x400>;
interrupts = <GIC_SPI 41 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_twi0>;
twi_drv_used = <1>;
status = "disable";
#size-cells = <0>;
device_type = "twi1";
reg = <0x0 0x05002400 0x0 0x400>;
interrupts = <GIC_SPI 42 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_twi1>;
twi_drv_used = <1>;
status = "disable";
#size-cells = <0>;
device_type = "twi2";
reg = <0x0 0x05002800 0x0 0x400>;
interrupts = <GIC_SPI 43 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_twi2>;
twi_drv_used = <1>;
status = "disable";
twi3: twi@0x05002c00{
#size-cells = <0>;
device_type = "twi3";
reg = <0x0 0x05002c00 0x0 0x400>;
interrupts = <GIC_SPI 44 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_twi3>;
pinctrl-0 = <&twi3_pins_a>;
pinctrl-1 = <&twi3_pins_b>;
twi_drv_used = <1>;
status = "disable";
twi4: twi@0x07081400{
#size-cells = <0>;
device_type = "twi4";
reg = <0x0 0x07081400 0x0 0x400>;
interrupts = <GIC_SPI 107 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_stwi>;
pinctrl-0 = <&s_twi0_pins_a>;
pinctrl-1 = <&s_twi0_pins_b>;
usbc0:usbc0@0 {
device_type = "usbc0";
compatible = "allwinner,sunxi-otg-manager";
usb_port_type = <2>;
usb_detect_type = <1>;
usb_id_gpio;
usb_det_vbus_gpio;
usb_drv_vbus_gpio;
usb_regulator_io = "nocare";
usb_wakeup_suspend = <0>;
usb_luns = <3>;
usb_serial_unique = <0>;
usb_serial_number = "20080411";
rndis_wceis = <1>;
udc:udc-controller@0x05100000 {
compatible = "allwinner,sunxi-udc";
reg = <0x0 0x05100000 0x0 0x1000>, /*udc base*/
<0x0 0x00000000 0x0 0x100>; /*sram base*/
interrupts = <GIC_SPI 64 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_usbphy0>, <&clk_usbotg>;
ehci0:ehci0-controller@0x05101000 {
compatible = "allwinner,sunxi-ehci0";
reg = <0x0 0x05101000 0x0 0xFFF>, /*hci0 base*/
<0x0 0x00000000 0x0 0x100>, /*sram base*/
<0x0 0x05100000 0x0 0x1000>; /*otg base*/
interrupts = <GIC_SPI 65 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_usbphy0>, <&clk_usbehci0>;
hci_ctrl_no = <0>;
ohci0:ohci0-controller@0x05101400 {
compatible = "allwinner,sunxi-ohci0";
interrupts = <GIC_SPI 66 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_usbphy0>, <&clk_usbohci0>, <&clk_usbohci0_12m>,
<&clk_osc48md4>, <&clk_hosc>, <&clk_losc>;
hci_ctrl_no = <0>;
compatible = "allwinner,sunxi-daudio";
reg = <0x0 0x05090000 0x0 0x7c>;
clocks = <&clk_pll_audio>,<&clk_i2s0>;
pinctrl-0 = <&daudio0_pins_a>;
pinctrl-1 = <&daudio0_pins_b>;
device_type = "daudio0";
tdm_num = <0x00>;
/* pcm platform runtime hwparams config */
rate_max = <0x2ee00>; /* max rate: 192000 */
channels_max = <0x08>; /* max chennels: 8 */
buffer_bytes_max = <0x20000>; /* max buffer size: 1024 * 128 */
period_bytes_max = <0x10000>; /* max period size: 1024 * 64 */
periods_max = <0x08>; /* max count of periods: 8 */
fifo_size = <0x80>; /* fifo size in bytes: 128 */
reg = <0x0 0x05091000 0x0 0x7c>;
clocks = <&clk_pll_audio>,<&clk_i2s1>;
pinctrl-0 = <&daudio1_pins_a>;
pinctrl-1 = <&daudio1_pins_b>;
device_type = "daudio1";
tdm_num = <0x01>;
rate_max = <0x2ee00>; /* 192000 */
channels_max = <0x08>; /* 8 */
buffer_bytes_max = <0x20000>; /* 1024 * 128 */
period_bytes_max = <0x10000>; /* 1024 * 64 */
periods_max = <0x08>; /* 8 */
fifo_size = <0x80>; /* 128 */
compatible = "allwinner,sunxi-internal-codec";
reg = <0x0 0x05096000 0x0 0x320>;
clocks = <&clk_pll_audio>,<&clk_codec_1x>;
device_type = "codec";
sndcodec:sound@0 {
compatible = "allwinner,sunxi-codec-machine";
interrupts = <GIC_SPI 28 IRQ_TYPE_LEVEL_HIGH>;
sunxi,audio-codec = <&codec>;
device_type = "sndcodec";
snddaudio0:sound@1{
compatible = "allwinner,sunxi-daudio0-machine";
sunxi,daudio-controller = <&daudio0>;
device_type = "snddaudio0";
snddaudio1:sound@2{
compatible = "allwinner,sunxi-daudio1-machine";
sunxi,daudio-controller = <&daudio1>;
device_type = "snddaudio1";
spi0: spi@05010000 {
#size-cells = <0>;
compatible = "allwinner,sun8i-spi";
device_type = "spi0";
reg = <0x0 0x05010000 0x0 0x1000>;
interrupts = <GIC_SPI 54 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_pll_periph0>, <&clk_spi0>;
clock-frequency = <300000000>;
spi0_cs_number = <2>;
spi0_cs_bitmap = <3>;
spi1: spi@05011000 {
#size-cells = <0>;
device_type = "spi1";
pinctrl-0 = <&spi1_pins_a &spi1_pins_b>;
spi2: spi@05012000 {
#size-cells = <0>;
device_type = "spi2";
reg = <0x0 0x05012000 0x0 0x1000>;
interrupts = <GIC_SPI 56 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_pll_periph0>, <&clk_spi2>;
pinctrl-0 = <&spi2_pins_a &spi2_pins_b>;
pinctrl-1 = <&spi2_pins_c>;
spi2_cs_number = <1>;
spi2_cs_bitmap = <1>;
spi3: spi@05013000 {
#size-cells = <0>;
compatible = "allwinner,sun50i-spi";
device_type = "spi3";
reg = <0x0 0x05013000 0x0 0x1000>;
interrupts = <GIC_SPI 57 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_pll_periph0>, <&clk_spi3>;
pinctrl-0 = <&spi3_pins_a &spi3_pins_b>;
pinctrl-1 = <&spi3_pins_c>;
spi3_cs_number = <1>;
spi3_cs_bitmap = <1>;
auto_print {
device_type = "auto_print";
sdc2: sdmmc@04022000 {
compatible = "allwinner,sunxi-mmc-v4p5x";
device_type = "sdc2";
reg = <0x0 0x04022000 0x0 0x1000>;
interrupts = <GIC_SPI 48 IRQ_TYPE_LEVEL_HIGH>;
<&clk_pll_unix2>,
<&clk_sdmmc2_mod>,
<&clk_sdmmc2_bus>,
<&clk_sdmmc2_rst>;
clock-names = "osc24m","pll_periph","mmc","ahb","rst";
pinctrl-names = "default","sleep";
pinctrl-0 = <&sdc2_pins_a&sdc2_pins_c>;
pinctrl-1 = <&sdc2_pins_b>;
bus-width = <8>;
/*mmc-ddr-1_8v;*/
/*mmc-hs200-1_8v;*/
/*mmc-hs400-1_8v;*/
cap-sd-highspeed;
cap-mmc-highspeed;
cap-wait-while-busy;
mmc-high-capacity-erase-size;
cap-erase;
/*non-removable;*/
/*max-frequency = <200000000>;*/
/*-- speed mode --*/
/*sm0: DS26_SDR12*/
/*sm1: HSSDR52_SDR25*/
/*sm2: HSDDR52_DDR50*/
/*sm3: HS200_SDR104*/
/*sm4: HS400*/
/*-- frequency point --*/
/*f0: CLK_400K*/
/*f1: CLK_25M*/
/*f2: CLK_50M*/
/*f3: CLK_100M*/
/*f4: CLK_150M*/
/*f5: CLK_200M*/
sdc_tm4_sm0_freq0 = <0>;
sdc_tm4_sm0_freq1 = <0>;
sdc_tm4_sm1_freq0 = <0x00000000>;
sdc_tm4_sm1_freq1 = <0>;
sdc_tm4_sm2_freq0 = <0x00000000>;
sdc_tm4_sm2_freq1 = <0>;
sdc_tm4_sm3_freq0 = <0x05000000>;
sdc_tm4_sm3_freq1 = <0x00000005>;
sdc_tm4_sm4_freq0 = <0x00050000>;
sdc_tm4_sm4_freq1 = <0x00000004>;
/*vmmc-supply = <®_3p3v>;*/
/*vqmc-supply = <®_3p3v>;*/
/*vdmc-supply = <®_3p3v>;*/
/*vmmc = "vcc-card";*/
/*vqmc = "";*/
/*vdmc = "";*/
/*status = "disabled";*/
status = "disable";
compatible = "allwinner,sunxi-mmc-v4p1x";
device_type = "sdc0";
reg = <0x0 0x04020000 0x0 0x1000>;
interrupts = <GIC_SPI 46 IRQ_TYPE_LEVEL_HIGH>;
<&clk_pll_unix2>,
<&clk_sdmmc0_mod>,
<&clk_sdmmc0_bus>,
<&clk_sdmmc0_rst>;
// pinctrl-1 = <&sdc0_pins_b>;
// pinctrl-2 = <&sdc0_pins_c>;
bus-width = <4>;
/*non-removable;*/
/*broken-cd;*/
/*cd-inverted*/
/*cd-gpios = <&pio PF 6 0 1 2 0>;*/
/* vmmc-supply = <®_3p3v>;*/
/* vqmc-supply = <®_3p3v>;*/
/* vdmc-supply = <®_3p3v>;*/
/*vqmc = "";*/
/*vdmc = "";*/
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
cap-sd-highspeed;
cap-mmc-highspeed;
/*cap-sdio-irq;*/
/*keep-power-in-suspend;*/
/*ignore-pm-notify;*/
/*sunxi-dly-400k = <1 0 0 0>; */
/*sunxi-dly-26M = <1 0 0 0>;*/
/*sunxi-dly-52M = <1 0 0 0>;*/
/*sunxi-dly-52M-ddr4 = <1 0 0 0>;*/
/*sunxi-dly-52M-ddr8 = <1 0 0 0>;*/
/*sunxi-dly-104M = <1 0 0 0>;*/
/*sunxi-dly-208M = <1 0 0 0>;*/
/*sunxi-dly-104M-ddr = <1 0 0 0>;*/
/*sunxi-dly-208M-ddr = <1 0 0 0>;*/
status = "disable";
device_type = "sdc1";
reg = <0x0 0x04021000 0x0 0x1000>;
interrupts = <GIC_SPI 47 IRQ_TYPE_LEVEL_HIGH>;
<&clk_pll_unix2>,
<&clk_sdmmc1_mod>,
<&clk_sdmmc1_bus>,
<&clk_sdmmc1_rst>;
pinctrl-1 = <&sdc1_pins_b>;
bus-width = <4>;
/*broken-cd;*/
/*cd-inverted*/
/*cd-gpios = <&pio PG 6 6 1 2 0>;*/
/*vqmc = "";*/
/*vdmc = "";*/
/*sd-uhs-sdr50;*/
/*sd-uhs-ddr50;*/
/*sd-uhs-sdr104;*/
cap-sd-highspeed;
cap-mmc-highspeed;
/*cap-sdio-irq;*/
/*sunxi-dly-400k = <1 0 0 0 0>; */
/*sunxi-dly-26M = <1 0 0 0 0>;*/
/*sunxi-dly-52M = <1 0 0 0 0>;*/
sunxi-dly-52M-ddr4 = <1 0 0 0 2>;
/*sunxi-dly-52M-ddr8 = <1 0 0 0 0>;*/
sunxi-dly-104M = <1 0 0 0 1>;
/*sunxi-dly-208M = <1 1 0 0 0>;*/
sunxi-dly-208M = <1 0 0 0 1>;
/*sunxi-dly-104M-ddr = <1 0 0 0 0>;*/
/*sunxi-dly-208M-ddr = <1 0 0 0 0>;*/
compatible = "allwinner,sunxi-disp";
reg = <0x0 0x01000000 0x0 0x3fffff>,/*de*/
<0x0 0x06510000 0x0 0xfff>,/*disp_if_top*/
<0x0 0x06511000 0x0 0xfff>,/*tcon_lcd0*/
<0x0 0x06504000 0x0 0x2000>;/*dsi0*/
interrupts = <GIC_SPI 62 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 63 IRQ_TYPE_LEVEL_HIGH>,
<GIC_SPI 45 IRQ_TYPE_LEVEL_HIGH>; /*dsi0*/
clocks = <&clk_de>,
<&clk_display_top>,
<&clk_tcon_lcd>,
<&clk_mipi_dphy0>,
<&clk_mipi_host0>;
boot_disp = <0>;
fb_base = <0>;
iommus = <&mmu_aw 0 0>;
compatible = "allwinner,sunxi-lcd0";
hdmi: hdmi@06000000 {
compatible = "allwinner,sunxi-hdmi";
reg = <0x0 0x06000000 0x0 0x100000>;
interrupts = <GIC_SPI 64 IRQ_TYPE_NONE>;
clocks = <&clk_hdmi>,<&clk_hdmi_slow>,<&clk_hdmi_cec>;
pinctrl-names = "ddc_active","ddc_sleep","cec_active", "cec_sleep";
pinctrl-0 = <&hdmi_ddc_pin_a>;
pinctrl-1 = <&hdmi_ddc_pin_b>;
pinctrl-2 = <&hdmi_cec_pin_a>;
pinctrl-3 = <&hdmi_cec_pin_b>;
tv0: tv0@06524000 {
compatible = "allwinner,sunxi-tv";
reg = <0x0 0x06520000 0x0 0x100>,
<0x0 0x06524000 0x0 0x3fc>;
clocks = <&clk_tve_top>,<&clk_tve>;
device_type = "tv0";
vdpo0: vdpo0@06542000 {
compatible = "allwinner,sunxi-vdpo";
reg = <0x0 0x06542000 0x0 0xfff>;
clocks = <&clk_vdpo>;
device_type = "vdpo0";
interrupts = <GIC_SPI 94 IRQ_TYPE_LEVEL_HIGH>;
soc_tr: tr@01000000 {
compatible = "allwinner,sun50i-tr";
reg = <0x0 0x01000000 0x0 0x000200bc>;
interrupts = <GIC_SPI 96 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_de>;
g2d: g2d@01480000 {
compatible = "allwinner,sunxi-g2d";
reg = <0x0 0x01480000 0x0 0xbffff>;
interrupts = <GIC_SPI 21 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_g2d>;
iommus = <&mmu_aw 6 1>;
nna: nna@02400000 {
compatible = "allwinner,sunxi-nna";
reg = <0x0 0x02400000 0x0 0x1ffff>;
interrupts = <GIC_SPI 20 IRQ_TYPE_LEVEL_HIGH>;
clocks = <&clk_nna>, <&clk_nna_rst>;
iommus = <&mmu_aw 2 1>;
pwm: pwm@0300a000 {
compatible = "allwinner,sunxi-pwm";
reg = <0x0 0x0300a000 0x0 0x400>;
clocks = <&clk_pwm>;
pwm-number = <10>;
pwm-base = <0x0>;
pwms = <&pwm0>, <&pwm1>, <&pwm2>, <&pwm3>, <&pwm4>,
<&pwm5>, <&pwm6>, <&pwm7>, <&pwm8>, <&pwm9>;
pwm0: pwm0@0300a000 {
compatible = "allwinner,sunxi-pwm0";
pinctrl-names = "active", "sleep";
pinctrl-0 = <&pwm0_pins_a>;
pinctrl-1 = <&pwm0_pins_b>;
reg_base = <0x0300a000>;
pwm1: pwm1@0300a000 {
compatible = "allwinner,sunxi-pwm1";
pinctrl-0 = <&pwm1_pins_a>;
pinctrl-1 = <&pwm1_pins_b>;
pwm2: pwm2@0300a000 {
compatible = "allwinner,sunxi-pwm2";
pinctrl-0 = <&pwm2_pins_a>;
pinctrl-1 = <&pwm2_pins_b>;
pwm3: pwm3@0300a000 {
compatible = "allwinner,sunxi-pwm3";
pinctrl-0 = <&pwm3_pins_a>;
pinctrl-1 = <&pwm3_pins_b>;
pwm4: pwm4@0300a000 {
compatible = "allwinner,sunxi-pwm4";
pinctrl-0 = <&pwm4_pins_a>;
pinctrl-1 = <&pwm4_pins_b>;
pwm5: pwm5@0300a000 {
compatible = "allwinner,sunxi-pwm5";
pinctrl-0 = <&pwm5_pins_a>;
pinctrl-1 = <&pwm5_pins_b>;
pwm6: pwm6@0300a000 {
compatible = "allwinner,sunxi-pwm6";
pinctrl-0 = <&pwm6_pins_a>;
pinctrl-1 = <&pwm6_pins_b>;
pwm7: pwm7@0300a000 {
compatible = "allwinner,sunxi-pwm7";
pinctrl-0 = <&pwm7_pins_a>;
pinctrl-1 = <&pwm7_pins_b>;
pwm8: pwm8@0300a000 {
compatible = "allwinner,sunxi-pwm8";
pinctrl-0 = <&pwm8_pins_a>;
pinctrl-1 = <&pwm8_pins_b>;
pwm9: pwm9@0300a000 {
compatible = "allwinner,sunxi-pwm9";
pinctrl-0 = <&pwm9_pins_a>;
pinctrl-1 = <&pwm9_pins_b>;
boot_disp: boot_disp {
compatible = "allwinner,boot_disp";
vind0:vind@0 {
compatible = "allwinner,sunxi-vin-media", "simple-bus";
#size-cells = <2>;
ranges;
device_id = <0>;
vind0_clk = <300000000>;
reg = <0x0 0x06600800 0x0 0x200>,
<0x0 0x06600000 0x0 0x800>;
interrupts = <GIC_SPI 92 4>;
clocks = <&clk_csi_top>, <&clk_pll_csi>,
<&clk_csi_master0>, <&clk_hosc>, <&clk_pll_csi>,
<&clk_csi_master1>, <&clk_hosc>, <&clk_pll_csi>,
<&clk_isp>, <&clk_pll_uni>;
pinctrl-names = "mclk0-default","mclk0-sleep","mclk1-default","mclk1-sleep";
pinctrl-0 = <&csi_mclk0_pins_a>;
pinctrl-1 = <&csi_mclk0_pins_b>;
pinctrl-2 = <&csi_mclk1_pins_a>;
pinctrl-3 = <&csi_mclk1_pins_b>;
csi0:csi@0 {
device_type = "csi0";
compatible = "allwinner,sunxi-csi";
reg = <0x0 0x06601000 0x0 0x1000>;
interrupts = <GIC_SPI 78 4>;
device_id = <0>;
iommus = <&mmu_aw 4 1>;
csi1:csi@1 {
device_type = "csi1";
reg = <0x0 0x06602000 0x0 0x1000>;
interrupts = <GIC_SPI 79 4>;
pinctrl-0 = <&csi1_pins_a>;
pinctrl-1 = <&csi1_pins_b>;
device_id = <1>;
mipi0:mipi@0 {
compatible = "allwinner,sunxi-mipi";
reg = <0x0 0x0660C000 0x0 0x1000>;
interrupts = <GIC_SPI 82 4>;
device_id = <0>;
isp0:isp@0 {
compatible = "allwinner,sunxi-isp";
reg = <0x0 0x02100000 0x0 0x800>;
interrupts = <GIC_SPI 33 4>;
device_id = <0>;
iommus = <&mmu_aw 5 1>;
isp1:isp@1 {
device_id = <1>;
scaler0:scaler@0 {
compatible = "allwinner,sunxi-scaler";
reg = <0x0 0x02104000 0x0 0x400>;
device_id = <0>;
scaler1:scaler@1 {
reg = <0x0 0x02104400 0x0 0x400>;
device_id = <1>;
scaler2:scaler@2 {
reg = <0x0 0x02104800 0x0 0x400>;
device_id = <2>;
scaler3:scaler@3 {
reg = <0x0 0x02104C00 0x0 0x400>;
device_id = <3>;
compatible = "allwinner,sunxi-actuator";
flash0:flash@0 {
compatible = "allwinner,sunxi-flash";
flash0_type = <2>;
flash0_en = <>;
flash0_mode = <>;
flash0_flvdd = "";
device_id = <0>;
sensor0:sensor@0 {
compatible = "allwinner,sunxi-sensor";
clocks = <&clk_csi_master0>, <&clk_hosc>, <&clk_pll_csi>;
pinctrl-names = "mclk0-default","mclk0-sleep";
sensor0_mname = "ov5640";
sensor0_twi_cci_id = <0>;
sensor0_mclk_id = <2>;
sensor0_isp_used = <0>;
sensor0_fmt = <0>;
sensor0_reset = <&pio PI 3 1 0 1 0>;
sensor0_pwdn = <&pio PI 4 1 0 1 0>;
flash_handle = <&flash0>;
act_handle = <&actuator0>;
device_id = <0>;
sensor1:sensor@1 {
clocks = <&clk_csi_master1>, <&clk_hosc>, <&clk_pll_csi>;
pinctrl-names = "mclk1-default","mclk1-sleep";
pinctrl-0 = <&csi_mclk1_pins_a>;
pinctrl-1 = <&csi_mclk1_pins_b>;
sensor1_twi_cci_id = <1>;
sensor1_mclk_id = <3>;
sensor1_fmt = <0>;
flash_handle = <>;
act_handle = <>;
device_id = <1>;
vinc0:vinc@0 {
device_type = "vinc0";
compatible = "allwinner,sunxi-vin-core";
reg = <0x0 0x06609000 0x0 0x200>;
interrupts = <GIC_SPI 74 4>;
vinc0_csi_sel = <1>;
vinc0_mipi_sel = <0xff>;
vinc0_isp_sel = <1>;
device_id = <0>;
vinc1:vinc@1 {
device_type = "vinc1";
reg = <0x0 0x06609200 0x0 0x200>;
interrupts = <GIC_SPI 75 4>;
vinc1_csi_sel = <1>;
vinc1_mipi_sel = <0xff>;
vinc1_isp_sel = <1>;
device_id = <1>;
vinc2:vinc@2 {
device_type = "vinc2";
reg = <0x0 0x06609400 0x0 0x200>;
interrupts = <GIC_SPI 76 4>;
vinc2_csi_sel = <3>;
vinc2_mipi_sel = <0xff>;
vinc2_isp_sel = <1>;
vinc2_front_sensor_sel = <1>;
device_id = <2>;
vinc3:vinc@3 {
device_type = "vinc3";
reg = <0x0 0x06609600 0x0 0x200>;
interrupts = <GIC_SPI 77 4>;
vinc3_csi_sel = <3>;
vinc3_rear_sensor_sel = <0>;
device_id = <3>;
Vdevice: vdevice@0 {
compatible = "allwinner,sun8i-vdevice";
device_type = "Vdevice";
interrupt-parent = <&pio>;
interrupts = < PD 3 IRQ_TYPE_LEVEL_HIGH>; /* bank offset type */
pinctrl-names = "default";
pinctrl-0 = <&vdevice_pins_a>;
test-gpios = <&pio PC 3 1 2 2 1>;
cryptoengine: ce@1904000 {
compatible = "allwinner,sunxi-ce";
device_name = "ce";
reg = <0x0 0x01904000 0x0 0xa0>,
<0x0 0x01904800 0x0 0xa0>; /* Unused */
interrupts = <GIC_SPI 35 IRQ_TYPE_EDGE_RISING>,
<GIC_SPI 36 IRQ_TYPE_EDGE_RISING>; /* Unused */
clock-frequency = <300000000>; /* 300MHz */
clocks = <&clk_ce>, <&clk_pll_periph0x2>;
nmi:nmi@0x01f00c00{
#size-cells = <0>;
compatible = "allwinner,sunxi-nmi";
reg = <0x0 0x01f00c00 0x0 0x50>;
nmi_irq_ctrl = <0x0c>;
nmi_irq_en = <0x40>;
nmi_irq_status = <0x10>;
nmi_irq_mask = <0x50>;
nand0:nand0@04011000 {
compatible = "allwinner,sun8iw16-nand";
device_type = "nand0";
reg = <0x0 0x04011000 0x0 0x1000>;
interrupts = <GIC_SPI 29 0x04>;
clocks = <&clk_pll_periph1x2>,<&clk_nand0>,<&clk_nand1>;
pinctrl-0 = <&nand0_pins_a &nand0_pins_b>;
pinctrl-1 = <&nand0_pins_c>;
nand0_regulator1 = "vcc-nand";
nand0_regulator2 = "none";
nand0_cache_level = <0x55aaaa55>;
nand0_flush_cache_num = <0x55aaaa55>;
nand0_capacity_level = <0x55aaaa55>;
nand0_id_number_ctl = <0x55aaaa55>;
nand0_print_level = <0x55aaaa55>;
nand0_p0 = <0x55aaaa55>;
nand0_p1 = <0x55aaaa55>;
nand0_p2 = <0x55aaaa55>;
nand0_p3 = <0x55aaaa55>;
sunxi_thermal_sensor:thermal_sensor{
compatible = "allwinner,thermal_sensor";
reg = <0x0 0x05070400 0x0 0x400>;
interrupts = <GIC_SPI 1 IRQ_TYPE_NONE>;
clocks = <&clk_hosc>,<&clk_ths>;
* sensor 0 in CPU, sensor1 in VE,
* sensor 2 in ISP, sensor 3 in DDR
sensor_num = <4>;
combine_num = <4>;
shut_temp= <115000>;/*millicelsius*/
ths_combine0:ths_combine0{
compatible = "allwinner,ths_combine";
#thermal-sensor-cells = <1>;
combine_sensor_num = <1>;
combine_sensor_type = "CPU";
combine_sensor_temp_type = "max";
combine_sensor_id = <0>;
ths_combine1:ths_combine1{
combine_sensor_type = "VE";
combine_sensor_id = <1>;
ths_combine2:ths_combine2{
combine_sensor_type = "ISP";
combine_sensor_id = <2>;
ths_combine3:ths_combine3{
combine_sensor_type = "DDR";
combine_sensor_id = <3>;
cpu_budget_cooling:cpu_budget_cool{
compatible = "allwinner,budget_cooling";
device_type = "cpu_budget_cooling";
state_cnt = <2>;
cluster_num = <1>;
state0 = <1104000 1>;
state1 = <600000 1>;
thermal-zones{
cpu_thermal_zone{
polling-delay-passive = <1000>;
polling-delay = <1000>;
thermal-sensors = <&ths_combine0 0>;
trips{
cpu_trip0:t0{
temperature = <80000>;/*millicelsius */
type = "passive";
hysteresis = <0>;
crt_trip:t2{
temperature = <115000>;
type = "critical";
hysteresis = <0>;
cooling-maps{
bind0{
contribution = <0>;
trip = <&cpu_trip0>;
cooling-device
= <&cpu_budget_cooling 1 1>;
ve_thermal_zone{
polling-delay = <10000>;
thermal-sensors = <&ths_combine1 1>;
trips{
ve_crt_trip0:t0{
temperature = <115000>;/*millicelsius */
type = "critical";
hysteresis = <0>;
isp_thermal_zone{
thermal-sensors = <&ths_combine2 2>;
trips{
isp_crt_trip0:t0{
type = "critical";
hysteresis = <0>;
ddr_thermal_zone{
thermal-sensors = <&ths_combine3 3>;
trips{
ddr_crt_trip0:t0{
type = "critical";
hysteresis = <0>;
gpadc:gpadc{
compatible = "allwinner,sunxi-gpadc";
reg = <0x0 0x05070000 0x0 0x400>;
interrupts = <GIC_SPI 0 IRQ_TYPE_NONE>;
clocks = <&clk_gpadc>;
status = "disable";
gmac0: eth@05020000 {
compatible = "allwinner,sunxi-gmac";
reg = <0x0 0x05020000 0x0 0xFFFF>,
<0x0 0x03000030 0x0 0x4>;
interrupts = <GIC_SPI 27 IRQ_TYPE_LEVEL_HIGH>;
interrupt-names = "gmacirq";
clocks = <&clk_gmac>, <&clk_ephy_25m>;
clock-names = "gmac", "ephy";
pinctrl-0 = <&gmac_pins_a>;
pinctrl-1 = <&gmac_pins_b>;
phy-mode = "rmii";
use_ephy25m = <1>;
tx-delay = <7>;
rx-delay = <31>;
phy-rst = <&pio PD 19 1 1 1 0>;
gmac-power0;
gmac-power1;
gmac-power2;
};离线
lsusb 报错 :unable to initialize libusb: -99
root@YuzukiIRC:/# opkg list-installed |grep usb
kmod-usb-net - 4.9.118-1
kmod-usb-net-cdc-ether - 4.9.118-1
kmod-usb-net-cdc-mbim - 4.9.118-1
kmod-usb-net-cdc-ncm - 4.9.118-1
kmod-usb-net-cdc-subset - 4.9.118-1
kmod-usb-net-qmi-wwan - 4.9.118-1
kmod-usb-net-rndis - 4.9.118-1
kmod-usb-ohci - 4.9.118-1
kmod-usb-serial - 4.9.118-1
kmod-usb-serial-option - 4.9.118-1
kmod-usb-serial-wwan - 4.9.118-1
kmod-usb-uhci - 4.9.118-1
kmod-usb-wdm - 4.9.118-1
kmod-usb2 - 4.9.118-1
libusb-1.0 - 1.0.19-1
usb-gadget - 1-1
usbutils - 007-1离线
99 EADDRNOTAVAIL Cannot assign requested address
lsusb看看识别到了吗
lsusb看看识别到了吗
lsusb 运行失败,是不是缺库啊?
这是什么意思呀?
tocurd 说:lsusb看看识别到了吗
lsusb 运行失败,是不是缺库啊?
不知道缺了什么库,这是 opkg list-installed |grep usb 的输出
usb-gadget - 1-1
usbutils - 007-1好像少了kmod-usb-core,但是我在menuconfig里已经勾选了,不知道为什么没有
会不会是因为 tina 不支持 usbfs?
看了一下启动脚本,好像在 /etc/init.d/S550usb 中,将USB0 设置成了OTG 模式,不知道怎么取消
rtqq 说:看了一下启动脚本,好像在 /etc/init.d/S550usb 中,将USB0 设置成了OTG 模式,不知道怎么取消
谢谢,问题解决,不过在v831的目录有一点点区别,记录一下,让后来者收益
手动切换到host模式命令:
cat /sys/devices/platform/soc/usbc0/usb_host
