楼主 # 2022-12-23 10:36:30
jack821119
已发帖子: 48
buildroot 启动到内核后没反应
[    1.284699] Console: switching to colour frame buffer device 100x30
[    1.324420] sun4i-drm display-engine: fb0:  frame buffer device
[    1.331595] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[    1.340830] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[    1.352902] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[    1.358838] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 1
[    1.369202] hub 1-0:1.0: USB hub found
[    1.373142] hub 1-0:1.0: 1 port detected
[    1.378899] using random self ethernet address
[    1.383438] using random host ethernet address
[    1.389845] usb0: HOST MAC 4e:3f:d1:70:7c:be
[    1.394239] usb0: MAC 46:a5:51:3c:02:89
[    1.398226] g_cdc gadget: CDC Composite Gadget, version: King Kamehameha Day 2008
[    1.405819] g_cdc gadget: g_cdc ready
[    1.410550] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[    1.428306] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[    1.435240] vcc3v3: disabling
[    1.438229] ALSA device list:
[    1.441289]   #0: Loopback 1
[    1.445103] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[    1.453865] cfg80211: failed to load regulatory.db
[    1.562391] random: crng init done
[    2.123660] jffs2: notice: (1) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
[    2.143662] VFS: Mounted root (jffs2 filesystem) on device 31:3.
[    2.152372] devtmpfs: mounted
[    2.162408] Freeing unused kernel memory: 1024K
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: OK
Starting network: OK
Welcome to Buildroot
buildroot login:
请问哪位知道这个 是什么导致的,输入 后一直没有任何反应。
楼主 #1 2022-12-23 10:37:34
jack821119
已发帖子: 48
Re: buildroot 启动到内核后没反应
芯片是F1C100S
#2 2022-12-23 13:27:20
marcus
这不是正常开机么?
串口输出是没问题了,输入也没问题就可以root登录了。
#3 2022-12-23 13:38:35
mysteryli
已发帖子: 493
你这不是已经启动了?
楼主 #4 2022-12-23 14:47:36
jack821119
已发帖子: 48
是启动了,但是我输入账号后完全没任何反应。
楼主 #5 2022-12-23 14:49:05
jack821119
已发帖子: 48
反正就是没有任何反应,感觉就是控制台已经跟板子脱节了一样。
#6 2022-12-23 15:29:04
marcus
那应该是 rx 引脚的问题了吧,检查下线路。
#7 2022-12-23 16:48:58
tianjjff
已发帖子: 129
是不是串口输入有问题?重新插拔下串口助手
楼主 #8 2022-12-23 16:58:23
jack821119
已发帖子: 48
不是串口的问题,重新启动都是一样的现象。每次都是在那个位置
楼主 #9 2022-12-23 17:05:55
jack821119
已发帖子: 48
搞错了,刚才重新检测了串口线,估计是松了。谢谢marcus以及tianjjff。
