楼主 # 2022-12-26 15:22:00
hd_xyz
已发帖子: 25
uboot配置全志v3s的LCD显示
目前尝试用uboot2018 --  uboot2022版本均无法使全志v3s点亮lcd ,使用旧版本uboot2017荔枝派的LicheePi_Zero_800x480LCD_defconfig可以显示lcd的logo
从https://github.com/u-boot/u-boot 下载的uboot2022.04版本,
执行make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- LicheePi_Zero_defconfig
再执行make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- menuconfig
进入配置界面后进入> ARM architecture  找不到旧版本uboot2017.01的Enable graphical uboot console on HDMI, LCD or VGA
通过搜索得出
  │ Symbol: VIDEO_HDMI [=n]        │
  │ Type  : bool        │
  │ Prompt: HDMI output support        │
  │   Location:        │
  │ (3) -> ARM architecture        │
  │       -> Enable graphical uboot console on HDMI, LCD or VGA (VIDEO_SUNXI [=n])        │
  │   Defined at arch/arm/mach-sunxi/Kconfig:824        │
  │   Depends on: ARM [=y] && ARCH_SUNXI [=y] && VIDEO_SUNXI [=n] && !MACH_SUN8I [=y] && !MACH_SUNIV [=n]
-> Enable graphical uboot console on HDMI, LCD or VGA (VIDEO_SUNXI [=n]) 该项为n ,不像旧版本的uboot一样直接显示在配置界面可以选y
下方提示的  │   Depends on: ARM [=y] && ARCH_SUNXI [=y] && VIDEO_SUNXI [=n] && !MACH_SUN8I [=y] && !MACH_SUNIV [=n]
尝试把配置界面的
[y] Sunxi SoC Variant (sun8i (Allwinner V3/V3s/S3/S3L))  --->
取消选择v3s为:[ ] Sunxi SoC Variant
则在配置界面下方会自动显示出  -> Enable graphical uboot console on HDMI, LCD or VGA
可以配置为y  也就是打开lcd显示
执行编译
time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log
报错如下
u-boot-2022.04# time make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- 2>&1 | tee build.log
scripts/kconfig/conf  --syncconfig Kconfig
WARNING: unmet direct dependencies detected for SPL_SYS_THUMB_BUILD
  Depends on [n]: ARM [=y] && !ARM64 [=n] && SPL [=n]
  Selected by [y]:
  - ARCH_SUNXI [=y] && <choice> && !ARM64 [=n]
WARNING: unmet direct dependencies detected for SPL_USE_TINY_PRINTF
  Depends on [n]: SPL [=n]
  Selected by [y]:
  Selected by [y]:
  Selected by [y]:
  Selected by [y]:
  Selected by [y]:
  UPD     include/config.h
  CFG     u-boot.cfg
In file included from ./include/common.h:16:0:
include/config.h:4:10: 致命错误: configs/.h:没有那个文件或目录
#include <configs/.h>
编译中断。
make[1]: *** [scripts/Makefile.autoconf:78:u-boot.cfg] 错误 1
  CFGCHK  u-boot.cfg
  OFCHK   .config
make: *** 没有规则可制作目标“include/config/auto.conf”,由“include/config/uboot.release” 需求。 停止。
real    0m0.547s
user    0m0.301s
sys    0m0.266s
结论:此项选中时 [y] Sunxi SoC Variant (sun8i (Allwinner V3/V3s/S3/S3L))  --->
则无法打孔lcd配置Enable graphical uboot console on HDMI, LCD or VGA    ??
请各位大佬指点迷津,是哪一步配置错了,uboot2017是可以显示lcd的   uboot2018-uboot2022就一直配置失败
#1 2022-12-26 16:35:54
shaoxi2010
已发帖子: 382
Re: uboot配置全志v3s的LCD显示
没记错的话,v3s的lcd显示是lichee修改后的,主线框架没有支持这个型号的。
楼主 #2 2022-12-26 18:12:45
hd_xyz
已发帖子: 25
shaoxi2010 说:
对的,用LicheePi修改的uboot2017.01版本可以lcd显示logo,主线没有现成支持lcd的 搞不了,有可以参考的方法或链接嘛 这种情况怎么整呀大佬,主线加上lcd难嘛,我水平很菜 哎
楼主 #3 2022-12-31 15:51:01
hd_xyz
已发帖子: 25
@hd_xyz
顶贴,大佬们  主线uboot怎么支持lcd驱动呀,修改流程是怎么样的 新手不知道怎么入手修改
#4 2023-02-15 23:22:40
senjet
https://github.com/u-boot/u-boot/compare/master...mcerveny:u-boot:simplefb_v3s_v2
请根据上面的差异比较打补丁,实践证明没问题
#5 2023-09-05 23:32:22
sliver_cyh
senjet 说:
这个方法楼上的朋友都试过了吗?
#6 2023-09-17 16:31:01
善思维
楼主改成功了吗?
