这是晕哥帖子的代码
https://whycan.com/t_1261.html
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/input.h>
#include <linux/input-polldev.h>
#include <linux/i2c.h>
#include <linux/gpio.h>
#include <linux/interrupt.h>
#define GPIO 192 //PG0
#define GPIO_INT_NAME "pg1_int"
#define GPIO_HIGH gpio_get_value(GPIO)
#define GPIO_LOW (gpio_get_value(GPIO) == 0)
short int irq_any_gpio = 0;
int count =0;
enum { falling, rising } type;
static irqreturn_t r_irq_handler(int irq, void *dev_id)
count++;
printk(KERN_DEBUG "interrupt received (irq: %d)\n", irq);
if (irq == gpio_to_irq(GPIO))
type = GPIO_LOW ? falling : rising;
if(type == falling)
printk("gpio pin is low\n");
printk("gpio pin is high\n");
return IRQ_HANDLED;
void r_int_config(void) {
if (gpio_request(GPIO, GPIO_INT_NAME ))
printk("GPIO request failure: %s\n", GPIO_INT_NAME );
return;
if(gpio_direction_input(GPIO) < 0)
printk("can't set greenkey-gpio!\r\n");
if ( (irq_any_gpio = gpio_to_irq(GPIO)) < 0 ) {
printk("GPIO to IRQ mapping failure %s\n",GPIO_INT_NAME );
return;
printk(KERN_NOTICE "Mapped int %d\n", irq_any_gpio);
if (request_irq(irq_any_gpio,(irq_handler_t ) r_irq_handler, IRQF_TRIGGER_FALLING , GPIO_INT_NAME, NULL))
printk("Irq Request failure\n");
return;
return;
void r_int_release(void) {
free_irq(gpio_to_irq(GPIO), NULL);
gpio_free(GPIO);;
return;
int init_module1(void)
printk("<1>Hello World\n");
r_int_config();
module_init(init_module1); // Do some better naming
module_exit(r_int_release);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("whycan");查看也确认中断号申请成功了。
# cat /proc/interrupts
CPU0
19: 1158 GIC-0 27 Level arch_timer
21: 0 GIC-0 50 Level sun4i_timer0
22: 94 GIC-0 92 Level sunxi-mmc
23: 1 GIC-0 103 Level musb-hdrc.1.auto
24: 0 GIC-0 72 Level 1c20400.rtc
30: 403 GIC-0 32 Level ttyS0
33: 6275 GIC-0 114 Level 1c30000.ethernet
67: 0 sunxi_pio_edge 33 Edge pg1_int
IPI0: 0 CPU wakeup interrupts
IPI1: 0 Timer broadcast interrupts
IPI2: 0 Rescheduling interrupts
IPI3: 0 Function call interrupts
IPI4: 0 CPU stop interrupts
IPI5: 0 IRQ work interrupts
IPI6: 0 completion interrupts
Err: 0
#就是不知道为啥进不了中断服务函数.....求各位高手指点...谢谢!
结帖,原因未知,后面采用5.2的linux内核,解决了该问题!
