楼主 # 2023-02-08 18:11:50
qinhao4832
F1C200s TINA3.5 modules 应该安装到哪个目录
大佬坛友们请帮忙看看:
F1C200s tina3.5 想要启用adb,参考论坛内的帖子操作,运行脚本找不到g_ffs.ko
mount: mounting adb on /dev/usb-ffs/adb failed: No such device
root@billQin:/# -/bin/sh: adbd: not found
请问这个路径填哪里?
make modules_install INSTALL_MOD_PATH=
或是有什么其他方法?有文档资料吗?
楼主 #1 2023-02-08 18:42:15
qinhao4832
Re: F1C200s TINA3.5 modules 应该安装到哪个目录
 _____  _              __     _
|_   _||_| ___  _ _   |  |   |_| ___  _ _  _ _
  | |   _ |   ||   |  |  |__ | ||   || | ||_'_|
  | |  | || | || _ |  |_____||_||_|_||___||_,_|
  |_|  |_||_|_||_|_|  Tina is Based on OpenWrt!
 Tina Linux (Neptune, 5C1C9C53)
===============Hi====================
Usage:
        modprobe module
[1]+  Done(127)                  adbd
root@billQin:/#
root@billQin:/# find -name g_ffs.ko
./lib/modules/3.10.65/kernel/drivers/usb/gadget/g_ffs.ko
./rom/lib/modules/3.10.65/kernel/drivers/usb/gadget/g_ffs.ko
root@billQin:/# ldd ./lib/modules/3.10.65/kernel/drivers/usb/gadget/g_ffs.ko
ldd: ./lib/modules/3.10.65/kernel/drivers/usb/gadget/g_ffs.ko: Not a valid dynamic program
root@billQin:/#
#2 2023-02-08 19:45:46
已发帖子: 3,393
直接编译到内核吧
