配置说明:全志V3S+SPI NAND FLASH W25N01GVZEIG
配置好uboot linux rootfs等打包成flashimg.bin ,烧录到nand flash,第一次上电启动正常进入系统,后面再启动就进不了系统了,这个是uboot配置问题还是linux内核的问题
提示[ 4.371321] Rebooting in 5 seconds..
下面贴出第一次启动的日志 可以进入系统
U-Boot SPL 2022.04 (Dec 08 2022 - 16:43:19 +0800)
DRAM: 64 MiB
Trying to boot from sunxi SPI-NAND
sunxi SPI-NAND: Found Winbond W25N01GVxxIG (efaa21)
sunxi SPI-NAND: Loading u-boot from 0x10000
sunxi SPI-NAND: u-boot hcrc OK!
U-Boot 2022.04 (Dec 08 2022 - 16:43:19 +0800) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
Core: 23 devices, 11 uclasses, devicetree: separate
WDT: Not starting watchdog@1c20ca0
MMC: mmc@1c0f000: 0
Loading Environment from FAT... Card did not respond to voltage select! : -110
In: serial@1c28000
Out: serial@1c28000
Err: serial@1c28000
Net: No ethernet found.
Reading 131072 byte(s) (64 page(s)) at offset 0x00100000
Reading 5242880 byte(s) (2560 page(s)) at offset 0x00120000
Kernel image @ 0x41000000 [ 0x000000 - 0x447038 ]
Loading Device Tree to 42dfa000, end 42dffddf ... OK
[ 0.000000] Linux version 5.2.0-licheepi-zero (root@ymc-virtual-machine) (gcc version 7.5.0 (Linaro GCC 7.5-2019.12)) #1 SMP Wed Dec 7 15:54:41 CST 2022
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 earlyprintk panic=5 rootwait mtdparts=spi0.0:1M(uboot)ro,128k(dtb)ro,5M(kernel)ro,-(rootfs) ubi.mtd=3 root=ubi0:rootfs rw rootfstype=ubifs
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 54004K/65536K available (7168K kernel code, 308K rwdata, 1752K rodata, 1024K init, 257K bss, 11532K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] GIC: GICv2 detected, but range too small and irqchip.gicv2_force_probe not set
[ 0.000000] random: get_random_bytes called from start_kernel+0x2f8/0x484 with crng_init=0
[ 0.000008] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000021] Switching to timer-based delay loop, resolution 41ns
[ 0.000202] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000437] Console: colour dummy device 80x30
[ 0.000492] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000507] pid_max: default: 32768 minimum: 301
[ 0.000665] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000680] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001470] CPU: Testing write buffer coherency: ok
[ 0.001982] /cpus/cpu@0 missing clock-frequency property
[ 0.002010] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002781] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003002] rcu: Hierarchical SRCU implementation.
[ 0.003540] smp: Bringing up secondary CPUs ...
[ 0.003561] smp: Brought up 1 node, 1 CPU
[ 0.003570] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003577] CPU: All CPU(s) started in HYP mode.
[ 0.003582] CPU: Virtualization extensions available.
[ 0.004669] devtmpfs: initialized
[ 0.008060] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008348] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008381] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008641] pinctrl core: initialized pinctrl subsystem
[ 0.009664] NET: Registered protocol family 16
[ 0.010316] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011560] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011577] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.039319] SCSI subsystem initialized
[ 0.039496] usbcore: registered new interface driver usbfs
[ 0.039549] usbcore: registered new interface driver hub
[ 0.039651] usbcore: registered new device driver usb
[ 0.039871] mc: Linux media interface: v0.10
[ 0.039929] videodev: Linux video capture interface: v2.00
[ 0.040289] Advanced Linux Sound Architecture Driver Initialized.
[ 0.042132] clocksource: Switched to clocksource arch_sys_counter
[ 0.053824] NET: Registered protocol family 2
[ 0.054645] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.054689] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054714] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.054736] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.054878] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.054931] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.055221] NET: Registered protocol family 1
[ 0.057072] Initialise system trusted keyrings
[ 0.057438] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.101976] Key type asymmetric registered
[ 0.101997] Asymmetric key parser 'x509' registered
[ 0.102226] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.102243] io scheduler mq-deadline registered
[ 0.102250] io scheduler kyber registered
[ 0.103281] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.106971] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.176995] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.179378] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.180482] printk: console [ttyS0] disabled
[ 0.200785] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[ 0.738352] printk: console [ttyS0] enabled
[ 0.768235] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.779677] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.785081] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.793946] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.800303] Creating 4 MTD partitions on "spi0.0":
[ 0.805185] 0x000000000000-0x000000100000 : "uboot"
[ 0.813053] 0x000000100000-0x000000120000 : "dtb"
[ 0.818812] 0x000000120000-0x000000620000 : "kernel"
[ 0.825338] random: fast init done
[ 0.838767] 0x000000620000-0x000008000000 : "rootfs"
[ 1.013422] random: crng init done
[ 1.099351] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.105958] ehci-platform: EHCI generic platform driver
[ 1.111498] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.117195] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.125186] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 1.152151] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.159336] hub 1-0:1.0: USB hub found
[ 1.163283] hub 1-0:1.0: 1 port detected
[ 1.167870] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.174183] ohci-platform: OHCI generic platform driver
[ 1.179716] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.186431] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.194397] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.267179] hub 2-0:1.0: USB hub found
[ 1.271013] hub 2-0:1.0: 1 port detected
[ 1.278347] usbcore: registered new interface driver usb-storage
[ 1.285948] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 1.291013] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.295722] i2c /dev entries driver
[ 1.300564] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 1.310212] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.318886] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.354759] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.362318] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.373677] usbcore: registered new interface driver usbhid
[ 1.379256] usbhid: USB HID core driver
[ 1.385769] Initializing XFRM netlink socket
[ 1.390080] NET: Registered protocol family 17
[ 1.395213] Registering SWP/SWPB emulation handler
[ 1.401153] Loading compiled-in X.509 certificates
[ 1.415228] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.426742] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.432589] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.441950] hub 3-0:1.0: USB hub found
[ 1.445948] hub 3-0:1.0: 1 port detected
[ 1.451682] ubi0: attaching mtd3
[ 2.069808] ubi0: scanning is finished
[ 2.115618] ubi0: volume 0 ("rootfs") re-sized from 826 to 951 LEBs
[ 2.122831] ubi0: attached mtd3 (name "rootfs", size 121 MiB)
[ 2.128583] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.135516] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.142315] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.149267] ubi0: good PEBs: 975, bad PEBs: 0, corrupted PEBs: 0
[ 2.155278] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.162503] ubi0: max/mean erase counter: 1/0, WL threshold: 4096, image sequence number: 1320759356
[ 2.171621] ubi0: available PEBs: 0, total reserved PEBs: 975, PEBs reserved for bad PEB handling: 20
[ 2.180920] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
[ 2.189097] vcc3v0: disabling
[ 2.192120] vcc3v3: disabling
[ 2.195086] vcc5v0: disabling
[ 2.198051] ALSA device list:
[ 2.201015] No soundcards found.
[ 2.205050] ubi0: background thread "ubi_bgt0d" started, PID 94
[ 2.220640] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 2.229282] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 95
[ 2.427471] UBIFS (ubi0:0): UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[ 2.434954] UBIFS (ubi0:0): LEB size: 126976 bytes (124 KiB), min./max. I/O unit sizes: 2048 bytes/2048 bytes
[ 2.444876] UBIFS (ubi0:0): FS size: 100184064 bytes (95 MiB, 789 LEBs), journal size 9023488 bytes (8 MiB, 72 LEBs)
[ 2.455396] UBIFS (ubi0:0): reserved for root: 0 bytes (0 KiB)
[ 2.461226] UBIFS (ubi0:0): media format: w4/r0 (latest is w5/r0), UUID 84BB4D21-27AF-4A31-B517-8AE1551E1232, small LPT model
[ 2.487579] VFS: Mounted root (ubifs filesystem) on device 0:12.
[ 2.505150] devtmpfs: mounted
[ 2.511044] Freeing unused kernel memory: 1024K
[ 2.519939] Run /sbin/init as init process
[ 3.552712] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 61 bytes from PEB 30:61440, read only 61 bytes, retry
[ 3.567465] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 61 bytes from PEB 30:61440, read only 61 bytes, retry
[ 3.582811] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 61 bytes from PEB 30:61440, read only 61 bytes, retry
[ 3.598049] ubi0 error: ubi_io_read: error -74 (ECC error) while reading 61 bytes from PEB 30:61440, read 61 bytes
[ 3.608446] CPU: 0 PID: 1 Comm: init Not tainted 5.2.0-licheepi-zero #1
[ 3.615050] Hardware name: Allwinner sun8i Family
[ 3.619776] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 3.627516] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 3.634733] [<c07193b8>] (dump_stack) from [<c04e9c54>] (ubi_io_read+0x158/0x348)
[ 3.642215] [<c04e9c54>] (ubi_io_read) from [<c04e7a70>] (ubi_eba_read_leb+0x9c/0x41c)
[ 3.650127] [<c04e7a70>] (ubi_eba_read_leb) from [<c04e6790>] (ubi_leb_read+0x74/0xb4)
[ 3.658043] [<c04e6790>] (ubi_leb_read) from [<c0304c10>] (ubifs_leb_read+0x2c/0x78)
[ 3.665783] [<c0304c10>] (ubifs_leb_read) from [<c0306408>] (ubifs_read_node+0x94/0x248)
[ 3.673870] [<c0306408>] (ubifs_read_node) from [<c0321718>] (ubifs_tnc_read_node+0x48/0xb4)
[ 3.682300] [<c0321718>] (ubifs_tnc_read_node) from [<c0307e24>] (tnc_read_hashed_node+0x6c/0x1bc)
[ 3.691249] [<c0307e24>] (tnc_read_hashed_node) from [<c0309688>] (ubifs_tnc_locate+0x1a0/0x1d8)
[ 3.700024] [<c0309688>] (ubifs_tnc_locate) from [<c0309dd4>] (ubifs_tnc_lookup_nm+0x38/0x138)
[ 3.708626] [<c0309dd4>] (ubifs_tnc_lookup_nm) from [<c02fdfd4>] (ubifs_lookup+0x128/0x30c)
[ 3.716975] [<c02fdfd4>] (ubifs_lookup) from [<c0221348>] (__lookup_slow+0x8c/0x154)
[ 3.724715] [<c0221348>] (__lookup_slow) from [<c0221440>] (lookup_slow+0x30/0x44)
[ 3.732278] [<c0221440>] (lookup_slow) from [<c0223394>] (walk_component+0x1c8/0x300)
[ 3.740100] [<c0223394>] (walk_component) from [<c0223a18>] (path_lookupat+0x70/0x1fc)
[ 3.748008] [<c0223a18>] (path_lookupat) from [<c0225f74>] (filename_lookup+0x9c/0x10c)
[ 3.756006] [<c0225f74>] (filename_lookup) from [<c0212d3c>] (do_faccessat+0xb0/0x220)
[ 3.763917] [<c0212d3c>] (do_faccessat) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[ 3.771735] Exception stack(0xc3833fa8 to 0xc3833ff0)
[ 3.776783] 3fa0: 00000061 00000008 000b1b72 00000006 00000000 00000000
[ 3.784951] 3fc0: 00000061 00000008 00000000 00000021 00000000 00000061 b6f2e000 00000000
[ 3.793116] 3fe0: 000c24a0 bea59ac4 0008e980 b6ea20c6
Starting logging: OK
Starting mdev...
/etc/init.d/S10mdev: line 21: can't create /proc/sys/kernel/hotplug: nonexistent directory
Starting network: OK
Welcome to Lichee Pi
Lichee login: root
第二次启动日志Rebooting in 5 seconds..
DRAM: 64 MiB
DRAM: 64 MiB
MMC: mmc@1c0f000: 0
In: serial@1c28000
Out: serial@1c28000
Err: serial@1c28000
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000201] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000441] Console: colour dummy device 80x30
[ 0.000499] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000516] pid_max: default: 32768 minimum: 301
[ 0.000680] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000696] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001480] CPU: Testing write buffer coherency: ok
[ 0.001991] /cpus/cpu@0 missing clock-frequency property
[ 0.002017] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002806] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003024] rcu: Hierarchical SRCU implementation.
[ 0.003554] smp: Bringing up secondary CPUs ...
[ 0.003576] smp: Brought up 1 node, 1 CPU
[ 0.003585] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003592] CPU: All CPU(s) started in HYP mode.
[ 0.003596] CPU: Virtualization extensions available.
[ 0.004678] devtmpfs: initialized
[ 0.008065] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008361] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008393] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008642] pinctrl core: initialized pinctrl subsystem
[ 0.009653] NET: Registered protocol family 16
[ 0.010301] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011537] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011554] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.039327] SCSI subsystem initialized
[ 0.039511] usbcore: registered new interface driver usbfs
[ 0.039563] usbcore: registered new interface driver hub
[ 0.039665] usbcore: registered new device driver usb
[ 0.039882] mc: Linux media interface: v0.10
[ 0.039936] videodev: Linux video capture interface: v2.00
[ 0.040312] Advanced Linux Sound Architecture Driver Initialized.
[ 0.042155] clocksource: Switched to clocksource arch_sys_counter
[ 0.053818] NET: Registered protocol family 2
[ 0.054687] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.054711] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.054733] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.054877] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.054928] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.055218] NET: Registered protocol family 1
[ 0.057058] Initialise system trusted keyrings
[ 0.057422] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.099929] Key type asymmetric registered
[ 0.099951] Asymmetric key parser 'x509' registered
[ 0.100054] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.100067] io scheduler mq-deadline registered
[ 0.100073] io scheduler kyber registered
[ 0.101057] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.104917] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.175013] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.177380] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.178481] printk: console [ttyS0] disabled
[ 0.198785] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 33, base_baud = 1500000) is a U6_16550A
[ 0.736338] printk: console [ttyS0] enabled
[ 0.766260] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pc not found, using dummy regulator
[ 0.777711] spi-nand spi0.0: Winbond SPI NAND was found.
[ 0.783116] spi-nand spi0.0: 128 MiB, block size: 128 KiB, page size: 2048, OOB size: 64
[ 0.791968] 4 fixed-partitions partitions found on MTD device spi0.0
[ 0.798412] Creating 4 MTD partitions on "spi0.0":
[ 0.803245] 0x000000000000-0x000000100000 : "uboot"
[ 0.811086] 0x000000100000-0x000000120000 : "dtb"
[ 0.816992] 0x000000120000-0x000000620000 : "kernel"
[ 0.823483] random: fast init done
[ 0.836816] 0x000000620000-0x000008000000 : "rootfs"
[ 1.011445] random: crng init done
[ 1.096838] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.103445] ehci-platform: EHCI generic platform driver
[ 1.108984] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.114680] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.122675] ehci-platform 1c1a000.usb: irq 25, io mem 0x01c1a000
[ 1.152171] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.159381] hub 1-0:1.0: USB hub found
[ 1.163337] hub 1-0:1.0: 1 port detected
[ 1.167913] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.174228] ohci-platform: OHCI generic platform driver
[ 1.179764] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.186478] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.194442] ohci-platform 1c1a400.usb: irq 26, io mem 0x01c1a400
[ 1.267192] hub 2-0:1.0: USB hub found
[ 1.271027] hub 2-0:1.0: 1 port detected
[ 1.278364] usbcore: registered new interface driver usb-storage
[ 1.285971] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 1.291035] sun6i-rtc 1c20400.rtc: RTC enabled
[ 1.295744] i2c /dev entries driver
[ 1.300589] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 1.310250] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.318913] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.354782] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.362344] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.373692] usbcore: registered new interface driver usbhid
[ 1.379270] usbhid: USB HID core driver
[ 1.385779] Initializing XFRM netlink socket
[ 1.390093] NET: Registered protocol family 17
[ 1.395224] Registering SWP/SWPB emulation handler
[ 1.401164] Loading compiled-in X.509 certificates
[ 1.415247] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.426762] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.432609] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.441966] hub 3-0:1.0: USB hub found
[ 1.445969] hub 3-0:1.0: 1 port detected
[ 1.451708] ubi0: attaching mtd3
[ 2.596972] ubi0: scanning is finished
[ 2.616268] ubi0: attached mtd3 (name "rootfs", size 121 MiB)
[ 2.622024] ubi0: PEB size: 131072 bytes (128 KiB), LEB size: 126976 bytes
[ 2.628971] ubi0: min./max. I/O unit sizes: 2048/2048, sub-page size 2048
[ 2.635768] ubi0: VID header offset: 2048 (aligned 2048), data offset: 4096
[ 2.642731] ubi0: good PEBs: 975, bad PEBs: 0, corrupted PEBs: 0
[ 2.648729] ubi0: user volume: 1, internal volumes: 1, max. volumes count: 128
[ 2.655952] ubi0: max/mean erase counter: 2/0, WL threshold: 4096, image sequence number: 1320759356
[ 2.665082] ubi0: available PEBs: 0, total reserved PEBs: 975, PEBs reserved for bad PEB handling: 20
[ 2.674368] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:08 UTC (8)
[ 2.682550] vcc3v0: disabling
[ 2.685526] vcc3v3: disabling
[ 2.688490] vcc5v0: disabling
[ 2.691453] ALSA device list:
[ 2.694488] No soundcards found.
[ 2.698462] ubi0: background thread "ubi_bgt0d" started, PID 94
[ 2.706678] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 2.714959] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" started, PID 95
[ 2.756044] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 2.804476] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 2.852835] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 2.901163] ubi0 error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[ 2.912083] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #1
[ 2.919121] Hardware name: Allwinner sun8i Family
[ 2.923846] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 2.931586] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 2.938803] [<c07193b8>] (dump_stack) from [<c04e9c54>] (ubi_io_read+0x158/0x348)
[ 2.946284] [<c04e9c54>] (ubi_io_read) from [<c04e7a70>] (ubi_eba_read_leb+0x9c/0x41c)
[ 2.954196] [<c04e7a70>] (ubi_eba_read_leb) from [<c04e6790>] (ubi_leb_read+0x74/0xb4)
[ 2.962113] [<c04e6790>] (ubi_leb_read) from [<c0304c10>] (ubifs_leb_read+0x2c/0x78)
[ 2.969853] [<c0304c10>] (ubifs_leb_read) from [<c030c180>] (ubifs_start_scan+0x74/0xcc)
[ 2.977935] [<c030c180>] (ubifs_start_scan) from [<c030c400>] (ubifs_scan+0x28/0x2c4)
[ 2.985756] [<c030c400>] (ubifs_scan) from [<c030b628>] (ubifs_read_master+0x40/0x870)
[ 2.993666] [<c030b628>] (ubifs_read_master) from [<c0302dc0>] (ubifs_mount+0xd90/0x159c)
[ 3.001839] [<c0302dc0>] (ubifs_mount) from [<c024949c>] (legacy_get_tree+0x24/0x4c)
[ 3.009578] [<c024949c>] (legacy_get_tree) from [<c0218a3c>] (vfs_get_tree+0x24/0xf0)
[ 3.017407] [<c0218a3c>] (vfs_get_tree) from [<c023a3bc>] (do_mount+0x6b8/0x8dc)
[ 3.024798] [<c023a3bc>] (do_mount) from [<c023a9c0>] (ksys_mount+0x8c/0xb4)
[ 3.031843] [<c023a9c0>] (ksys_mount) from [<c0a0124c>] (mount_block_root+0x118/0x2f4)
[ 3.039753] [<c0a0124c>] (mount_block_root) from [<c0a0154c>] (prepare_namespace+0x9c/0x194)
[ 3.048183] [<c0a0154c>] (prepare_namespace) from [<c072fae8>] (kernel_init+0x8/0x10c)
[ 3.056095] [<c072fae8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 3.063652] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 3.068700] 3fa0: 00000000 00000000 00000000 00000000
[ 3.076867] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.085033] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.091800] UBIFS error (ubi0:0 pid 1): ubifs_scan: bad node
[ 3.133815] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.182096] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.230505] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.278820] ubi0 error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[ 3.289737] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #1
[ 3.296775] Hardware name: Allwinner sun8i Family
[ 3.301498] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 3.309238] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 3.316454] [<c07193b8>] (dump_stack) from [<c04e9c54>] (ubi_io_read+0x158/0x348)
[ 3.323935] [<c04e9c54>] (ubi_io_read) from [<c04e7a70>] (ubi_eba_read_leb+0x9c/0x41c)
[ 3.331847] [<c04e7a70>] (ubi_eba_read_leb) from [<c04e6790>] (ubi_leb_read+0x74/0xb4)
[ 3.339764] [<c04e6790>] (ubi_leb_read) from [<c0304c10>] (ubifs_leb_read+0x2c/0x78)
[ 3.347506] [<c0304c10>] (ubifs_leb_read) from [<c031bbe4>] (get_master_node+0x4c/0x26c)
[ 3.355592] [<c031bbe4>] (get_master_node) from [<c031c100>] (ubifs_recover_master_node+0x54/0x2a0)
[ 3.364630] [<c031c100>] (ubifs_recover_master_node) from [<c030bd38>] (ubifs_read_master+0x750/0x870)
[ 3.373926] [<c030bd38>] (ubifs_read_master) from [<c0302dc0>] (ubifs_mount+0xd90/0x159c)
[ 3.382099] [<c0302dc0>] (ubifs_mount) from [<c024949c>] (legacy_get_tree+0x24/0x4c)
[ 3.389837] [<c024949c>] (legacy_get_tree) from [<c0218a3c>] (vfs_get_tree+0x24/0xf0)
[ 3.397667] [<c0218a3c>] (vfs_get_tree) from [<c023a3bc>] (do_mount+0x6b8/0x8dc)
[ 3.405057] [<c023a3bc>] (do_mount) from [<c023a9c0>] (ksys_mount+0x8c/0xb4)
[ 3.412102] [<c023a9c0>] (ksys_mount) from [<c0a0124c>] (mount_block_root+0x118/0x2f4)
[ 3.420013] [<c0a0124c>] (mount_block_root) from [<c0a0154c>] (prepare_namespace+0x9c/0x194)
[ 3.428444] [<c0a0154c>] (prepare_namespace) from [<c072fae8>] (kernel_init+0x8/0x10c)
[ 3.436355] [<c072fae8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 3.443913] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 3.448961] 3fa0: 00000000 00000000 00000000 00000000
[ 3.457129] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.465294] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.472060] UBIFS error (ubi0:0 pid 1): ubifs_recover_master_node: failed to recover master node
[ 3.480946] UBIFS (ubi0:0): background thread "ubifs_bgt0_0" stops
[ 3.489453] UBIFS (ubi0:0): Mounting in unauthenticated mode
[ 3.531679] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.580225] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.628738] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.677533] ubi0 error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[ 3.688453] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #1
[ 3.695492] Hardware name: Allwinner sun8i Family
[ 3.700208] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 3.707947] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 3.715164] [<c07193b8>] (dump_stack) from [<c04e9c54>] (ubi_io_read+0x158/0x348)
[ 3.722647] [<c04e9c54>] (ubi_io_read) from [<c04e7a70>] (ubi_eba_read_leb+0x9c/0x41c)
[ 3.730559] [<c04e7a70>] (ubi_eba_read_leb) from [<c04e6790>] (ubi_leb_read+0x74/0xb4)
[ 3.738475] [<c04e6790>] (ubi_leb_read) from [<c0304c10>] (ubifs_leb_read+0x2c/0x78)
[ 3.746214] [<c0304c10>] (ubifs_leb_read) from [<c030c180>] (ubifs_start_scan+0x74/0xcc)
[ 3.754289] [<c030c180>] (ubifs_start_scan) from [<c030c400>] (ubifs_scan+0x28/0x2c4)
[ 3.762110] [<c030c400>] (ubifs_scan) from [<c030b628>] (ubifs_read_master+0x40/0x870)
[ 3.770020] [<c030b628>] (ubifs_read_master) from [<c0302dc0>] (ubifs_mount+0xd90/0x159c)
[ 3.778192] [<c0302dc0>] (ubifs_mount) from [<c024949c>] (legacy_get_tree+0x24/0x4c)
[ 3.785931] [<c024949c>] (legacy_get_tree) from [<c0218a3c>] (vfs_get_tree+0x24/0xf0)
[ 3.793758] [<c0218a3c>] (vfs_get_tree) from [<c023a3bc>] (do_mount+0x6b8/0x8dc)
[ 3.801150] [<c023a3bc>] (do_mount) from [<c023a9c0>] (ksys_mount+0x8c/0xb4)
[ 3.808195] [<c023a9c0>] (ksys_mount) from [<c0a0124c>] (mount_block_root+0x118/0x2f4)
[ 3.816105] [<c0a0124c>] (mount_block_root) from [<c0a0154c>] (prepare_namespace+0x9c/0x194)
[ 3.824535] [<c0a0154c>] (prepare_namespace) from [<c072fae8>] (kernel_init+0x8/0x10c)
[ 3.832446] [<c072fae8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 3.840003] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 3.845050] 3fa0: 00000000 00000000 00000000 00000000
[ 3.853218] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 3.861384] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 3.868202] UBIFS error (ubi0:0 pid 1): ubifs_scan: bad node
[ 3.910301] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 3.958758] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 4.007266] ubi0 warning: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read only 126976 bytes, retry
[ 4.055599] ubi0 error: ubi_io_read: error -74 (ECC error) while reading 126976 bytes from PEB 3:4096, read 126976 bytes
[ 4.066512] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #1
[ 4.073550] Hardware name: Allwinner sun8i Family
[ 4.078273] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 4.086013] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 4.093231] [<c07193b8>] (dump_stack) from [<c04e9c54>] (ubi_io_read+0x158/0x348)
[ 4.100712] [<c04e9c54>] (ubi_io_read) from [<c04e7a70>] (ubi_eba_read_leb+0x9c/0x41c)
[ 4.108624] [<c04e7a70>] (ubi_eba_read_leb) from [<c04e6790>] (ubi_leb_read+0x74/0xb4)
[ 4.116540] [<c04e6790>] (ubi_leb_read) from [<c0304c10>] (ubifs_leb_read+0x2c/0x78)
[ 4.124281] [<c0304c10>] (ubifs_leb_read) from [<c031bbe4>] (get_master_node+0x4c/0x26c)
[ 4.132366] [<c031bbe4>] (get_master_node) from [<c031c100>] (ubifs_recover_master_node+0x54/0x2a0)
[ 4.141403] [<c031c100>] (ubifs_recover_master_node) from [<c030bd38>] (ubifs_read_master+0x750/0x870)
[ 4.150700] [<c030bd38>] (ubifs_read_master) from [<c0302dc0>] (ubifs_mount+0xd90/0x159c)
[ 4.158873] [<c0302dc0>] (ubifs_mount) from [<c024949c>] (legacy_get_tree+0x24/0x4c)
[ 4.166612] [<c024949c>] (legacy_get_tree) from [<c0218a3c>] (vfs_get_tree+0x24/0xf0)
[ 4.174440] [<c0218a3c>] (vfs_get_tree) from [<c023a3bc>] (do_mount+0x6b8/0x8dc)
[ 4.181831] [<c023a3bc>] (do_mount) from [<c023a9c0>] (ksys_mount+0x8c/0xb4)
[ 4.188876] [<c023a9c0>] (ksys_mount) from [<c0a0124c>] (mount_block_root+0x118/0x2f4)
[ 4.196786] [<c0a0124c>] (mount_block_root) from [<c0a0154c>] (prepare_namespace+0x9c/0x194)
[ 4.205216] [<c0a0154c>] (prepare_namespace) from [<c072fae8>] (kernel_init+0x8/0x10c)
[ 4.213127] [<c072fae8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 4.220684] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 4.225731] 3fa0: 00000000 00000000 00000000 00000000
[ 4.233898] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.242064] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 4.248833] UBIFS error (ubi0:0 pid 1): ubifs_recover_master_node: failed to recover master node
[ 4.258059] List of all partitions:
[ 4.261555] No filesystem could mount root, tried:
[ 4.261559] ubifs
[ 4.266514]
[ 4.270018] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 4.278274] CPU: 0 PID: 1 Comm: swapper/0 Not tainted 5.2.0-licheepi-zero #1
[ 4.285310] Hardware name: Allwinner sun8i Family
[ 4.290034] [<c010ede4>] (unwind_backtrace) from [<c010b774>] (show_stack+0x10/0x14)
[ 4.297773] [<c010b774>] (show_stack) from [<c07193b8>] (dump_stack+0x88/0x9c)
[ 4.304991] [<c07193b8>] (dump_stack) from [<c011dd64>] (panic+0x110/0x2fc)
[ 4.311949] [<c011dd64>] (panic) from [<c0a013d8>] (mount_block_root+0x2a4/0x2f4)
[ 4.319426] [<c0a013d8>] (mount_block_root) from [<c0a0154c>] (prepare_namespace+0x9c/0x194)
[ 4.327855] [<c0a0154c>] (prepare_namespace) from [<c072fae8>] (kernel_init+0x8/0x10c)
[ 4.335766] [<c072fae8>] (kernel_init) from [<c01010e8>] (ret_from_fork+0x14/0x2c)
[ 4.343323] Exception stack(0xc3833fb0 to 0xc3833ff8)
[ 4.348369] 3fa0: 00000000 00000000 00000000 00000000
[ 4.356537] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 4.364703] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000
ubi烧录问题?记得是不能用dd写入,要保持有的sector是没写状态
感谢解答,打包的脚本文件文件如下方,确实是dd写入,这个应该怎么修改比较好呢,请赐教 感谢
#!/bin/sh
rm -f flashimg.bin
dd if=/dev/zero of=flashimg.bin bs=1M count=16
dd if=u-boot-sunxi-with-spl.bin_split_exp of=flashimg.bin bs=1K conv=notrunc
dd if=sun8i-v3s-licheepi-zero.dtb of=flashimg.bin bs=1K seek=1024 conv=notrunc
dd if=zImage of=flashimg.bin bs=1K seek=1152 conv=notrunc
dd if=ubi.img of=flashimg.bin bs=1K seek=6272 conv=notrunc
参考openwrt的升级
https://github.com/openwrt-mirror/openwrt/blob/master/package/system/procd/files/nand.sh
似乎是用ubiformat写镜像
具体操作已经记不清,只记得ubifs写入有坑…上次用ubifs还是在s3c6410上
最近编辑记录 4610 (2022-12-12 20:55:44)
4610 wrote:
参考openwrt的升级
似乎是用ubiformat写镜像具体操作已经记不清,只记得ubifs写入有坑…上次用ubifs还是在s3c6410上
尝试了还是不行,烧录到nand flash第一次上电可以进入,后面再次进入就ubifs崩溃,是否与linux内核配置有关
@hd_xyz
您好,我这也遇到了这个问题,想请问下您,最后又解决这个问题吗
@hd_xyz
我这解决了这个问题,我这边是因为文件系统打包的问题重新打包之后就ok了,打包命令:
mkfs.ubifs -x lzo -F -m 2048 -e 126976 -c 732 -o rootfs_ubifs.img -d root1
ubinize -o ubi.img -m 2048 -p 131072 -O 2048 -s 2048 ./ubinize.cfg -v
ubinize.cfg:
[rootfs-volume]
mode=ubi
image=rootfs_ubifs.img
vol_id=0
vol_size=92946432
vol_type=dynamic
vol_name=rootfs
vol_flags=autoresize
vol_alignment=1
这是我的镜像,你可以试一下:
最近编辑记录 zj (2023-02-16 08:58:09)
