问题描述:使用的是友善之臂官网的 2017.11 uboot ,默认配置是 nanopi_h3_defconfig ,然后用内核官网改的 5.15.101,能引导到内核但是加载不了文件系统
日志:
U-Boot SPL 2017.11-g5e8607b-dirty (Mar 16 2023 - 22:27:42)
DRAM: 512 MiB(667MHz)
CPU Freq: 408MHz
memory test: 1
Pattern 55aa Writing...Reading...OK
Trying to boot from MMC1
Boot device: sd
U-Boot 2017.11-g5e8607b-dirty (Mar 16 2023 - 22:27:42 +0800) Allwinner Technology
CPU: Allwinner H3 (SUN8I 1680)
Model: h3_tinyscan
DRAM: 512 MiB
CPU Freq: 1008MHz
MMC: SUNXI SD/MMC: 0, SUNXI SD/MMC: 1
In: serial
Out: serial
Err: serial
Net: phy interface0
eth0: ethernet@1c30000
BOARD: nanopi-m1-plus
USB0: USB EHCI 1.00
USB1: USB OHCI 1.0
USB2: USB EHCI 1.00
USB3: USB OHCI 1.0
USB4: USB EHCI 1.00
USB5: USB OHCI 1.0
scanning bus 0 for devices... 2 USB Device(s) found
scanning bus 2 for devices... 1 USB Device(s) found
scanning bus 4 for devices... 1 USB Device(s) found
reading zImage
4950640 bytes read in 309 ms (15.3 MiB/s)
reading sun8i-h3-nanopi-m1-plus.dtb
23985 bytes read in 30 ms (780.3 KiB/s)
## Flattened Device Tree blob at 40c08000
Booting using the fdt blob at 0x40c08000
Loading Device Tree to 49ff7000, end 49fffdb0 ... OK
[ 0.000000] Linux version 5.15.101 (linxi@linxi1989) (arm-none-linux-gnueabihf-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111, GNU ld (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 2.37.20220122) #3 SMP Thu Mar 16 22:35:07 CST 2023
[ 0.000000] OF: fdt: Machine model: h3_tinyscan
[ 0.000000] cma: Reserved 16 MiB at 0x5ec00000
[ 0.000000] Zone ranges:
[ 0.000000] Normal [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] HighMem empty
[ 0.000000] node 0: [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000040000000-0x000000005fffffff]
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] percpu: Embedded 11 pages/cpu s15372 r8192 d21492 u45056
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 130048
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=3 rootwait root=/dev/mmcblk0p2 earlyprintk rw
[ 0.000000] Unknown kernel command line parameters "earlyprintk", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes, linear)
[ 0.000000] Memory: 490652K/524288K available (7168K kernel code, 912K rwdata, 2016K rodata, 1024K init, 233K bss, 17252K reserved, 16384K cma-reserved, 0K highmem)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000001] sched_clock: 56 bits at 24MHz, resolution 41ns, wraps every 4398046511097ns
[ 0.000019] Switching to timer-based delay loop, resolution 41ns
[ 0.000296] Console: colour dummy device 80x30
[ 0.000349] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000369] pid_max: default: 32768 minimum: 301
[ 0.000548] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000569] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001219] CPU: Testing write buffer coherency: ok
[ 0.001560] /cpus/cpu@0 missing clock-frequency property
[ 0.001603] /cpus/cpu@1 missing clock-frequency property
[ 0.001625] /cpus/cpu@2 missing clock-frequency property
[ 0.001647] /cpus/cpu@3 missing clock-frequency property
[ 0.001663] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002420] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.002565] rcu: Hierarchical SRCU implementation.
[ 0.003150] smp: Bringing up secondary CPUs ...
[ 0.013886] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.024709] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.035465] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.035554] smp: Brought up 1 node, 4 CPUs
[ 0.035584] SMP: Total of 4 processors activated (192.00 BogoMIPS).
[ 0.035595] CPU: All CPU(s) started in HYP mode.
[ 0.035602] CPU: Virtualization extensions available.
[ 0.036176] devtmpfs: initialized
[ 0.041038] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.041260] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.041290] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.042028] pinctrl core: initialized pinctrl subsystem
[ 0.043450] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.044873] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.045888] thermal_sys: Registered thermal governor 'step_wise'
[ 0.046322] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.046346] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.050719] platform 1c0c000.lcd-controller: Fixing up cyclic dependency with 1100000.mixer
[ 0.056315] platform 1ee0000.hdmi: Fixing up cyclic dependency with 1c0c000.lcd-controller
[ 0.060850] platform connector: Fixing up cyclic dependency with 1ee0000.hdmi
[ 0.070687] SCSI subsystem initialized
[ 0.071146] usbcore: registered new interface driver usbfs
[ 0.071201] usbcore: registered new interface driver hub
[ 0.071248] usbcore: registered new device driver usb
[ 0.071440] mc: Linux media interface: v0.10
[ 0.071476] videodev: Linux video capture interface: v2.00
[ 0.071573] pps_core: LinuxPPS API ver. 1 registered
[ 0.071583] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.071605] PTP clock support registered
[ 0.072008] Advanced Linux Sound Architecture Driver Initialized.
[ 0.072875] clocksource: Switched to clocksource arch_sys_counter
[ 0.079517] NET: Registered PF_INET protocol family
[ 0.079755] IP idents hash table entries: 8192 (order: 4, 65536 bytes, linear)
[ 0.080398] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.080437] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.080453] TCP established hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.080496] TCP bind hash table entries: 4096 (order: 3, 32768 bytes, linear)
[ 0.080563] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.080665] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.080707] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.080897] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.081604] RPC: Registered named UNIX socket transport module.
[ 0.081628] RPC: Registered udp transport module.
[ 0.081636] RPC: Registered tcp transport module.
[ 0.081644] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.082775] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 5 counters available
[ 0.084064] workingset: timestamp_bits=30 max_order=17 bucket_order=0
[ 0.089619] NFS: Registering the id_resolver key type
[ 0.089693] Key type id_resolver registered
[ 0.089704] Key type id_legacy registered
[ 0.089828] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.089843] io scheduler mq-deadline registered
[ 0.089853] io scheduler kyber registered
[ 0.094822] sun8i-h3-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.096394] sun8i-h3-r-pinctrl 1f02c00.pinctrl: initialized sunXi PIO driver
[ 0.142994] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.144806] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pa not found, using dummy regulator
[ 0.145649] printk: console [ttyS0] disabled
[ 0.165846] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 51, base_baud = 1500000) is a U6_16550A
[ 0.866317] printk: console [ttyS0] enabled
[ 0.870942] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pg not found, using dummy regulator
[ 0.900170] 1c28400.serial: ttyS1 at MMIO 0x1c28400 (irq = 52, base_baud = 1500000) is a U6_16550A
[ 0.932034] 1c28800.serial: ttyS2 at MMIO 0x1c28800 (irq = 53, base_baud = 1500000) is a U6_16550A
[ 0.963887] 1c28c00.serial: ttyS3 at MMIO 0x1c28c00 (irq = 54, base_baud = 1500000) is a U6_16550A
[ 0.981445] lima 1c40000.gpu: gp - mali400 version major 1 minor 1
[ 0.987720] lima 1c40000.gpu: pp0 - mali400 version major 1 minor 1
[ 0.994044] lima 1c40000.gpu: pp1 - mali400 version major 1 minor 1
[ 1.000340] lima 1c40000.gpu: l2 cache 64K, 4-way, 64byte cache line, 64bit external bus
[ 1.008844] lima 1c40000.gpu: bus rate = 200000000
[ 1.013669] lima 1c40000.gpu: mod rate = 297000000
[ 1.018527] lima 1c40000.gpu: dev_pm_opp_set_regulators: no regulator (mali) found: -19
[ 1.026959] lima 1c40000.gpu: Failed to register cooling device
[ 1.033228] [drm] Initialized lima 1.1.0 20191231 for 1c40000.gpu on minor 0
[ 1.042671] CAN device driver interface
[ 1.047100] dwmac-sun8i 1c30000.ethernet: IRQ eth_wake_irq not found
[ 1.053463] dwmac-sun8i 1c30000.ethernet: IRQ eth_lpi not found
[ 1.059445] dwmac-sun8i 1c30000.ethernet: No regulator found
[ 1.065189] dwmac-sun8i 1c30000.ethernet: PTP uses main clock
[ 1.070958] dwmac-sun8i 1c30000.ethernet: Current syscon value is not the default 148000 (expect 58000)
[ 1.080626] dwmac-sun8i 1c30000.ethernet: No HW DMA feature register supported
[ 1.087879] dwmac-sun8i 1c30000.ethernet: RX Checksum Offload Engine supported
[ 1.095106] dwmac-sun8i 1c30000.ethernet: COE Type 2
[ 1.100069] dwmac-sun8i 1c30000.ethernet: TX Checksum insertion supported
[ 1.106862] dwmac-sun8i 1c30000.ethernet: Normal descriptors
[ 1.112516] dwmac-sun8i 1c30000.ethernet: Chain mode enabled
[ 1.119584] dwmac-sun8i 1c30000.ethernet: Found internal PHY node
[ 1.126115] dwmac-sun8i 1c30000.ethernet: Switch mux to internal PHY
[ 1.132489] dwmac-sun8i 1c30000.ethernet: Powering internal PHY
[ 1.140438] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 1.146994] ehci-platform: EHCI generic platform driver
[ 1.152412] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 1.158019] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 1.166184] ehci-platform 1c1a000.usb: irq 37, io mem 0x01c1a000
[ 1.192892] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 1.199702] hub 1-0:1.0: USB hub found
[ 1.203508] hub 1-0:1.0: 1 port detected
[ 1.207956] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 1.214172] ohci-platform: OHCI generic platform driver
[ 1.219590] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 1.226239] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 1.236481] ohci-platform 1c1a400.usb: irq 38, io mem 0x01c1a400
[ 1.307526] hub 2-0:1.0: USB hub found
[ 1.311312] hub 2-0:1.0: 1 port detected
[ 1.317338] sun6i-rtc 1f00000.rtc: registered as rtc0
[ 1.322420] sun6i-rtc 1f00000.rtc: setting system clock to 1970-01-01T03:59:54 UTC (14394)
[ 1.330705] sun6i-rtc 1f00000.rtc: RTC enabled
[ 1.335455] i2c_dev: i2c /dev entries driver
[ 1.339943] sun8i-h3-r-pinctrl 1f02c00.pinctrl: supply vcc-pl not found, using dummy regulator
[ 1.350041] Registered IR keymap rc-empty
[ 1.354167] rc rc0: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0
[ 1.360904] input: sunxi-ir as /devices/platform/soc/1f02000.ir/rc/rc0/input0
[ 1.368499] sunxi-ir 1f02000.ir: initialized sunXi IR driver
[ 1.375880] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.384745] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pf not found, using dummy regulator
[ 1.385671] sun8i-ce 1c15000.crypto: Set mod clock to 50000000 (50 Mhz) from 24000000 (24 Mhz)
[ 1.394301] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pc not found, using dummy regulator
[ 1.402043] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 1.418027] sunxi-mmc 1c0f000.mmc: Got CD GPIO
[ 1.422890] sunxi-mmc 1c10000.mmc: allocated mmc-pwrseq
[ 1.428599] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 1.436371] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 1.444162] sun8i-ce 1c15000.crypto: will run requests pump with realtime priority
[ 1.447774] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.453490] sunxi-mmc 1c11000.mmc: initialized, max. request size: 16384 KB
[ 1.458724] sunxi-mmc 1c10000.mmc: initialized, max. request size: 16384 KB
[ 1.472890] sun8i-ce 1c15000.crypto: Register cbc(aes)
[ 1.478174] sun8i-ce 1c15000.crypto: Register ecb(aes)
[ 1.483447] sun8i-ce 1c15000.crypto: Register cbc(des3_ede)
[ 1.489133] sun8i-ce 1c15000.crypto: Register ecb(des3_ede)
[ 1.494850] sun8i-ce 1c15000.crypto: CryptoEngine Die ID 1
[ 1.501289] usbcore: registered new interface driver usbhid
[ 1.506895] usbhid: USB HID core driver
[ 1.513274] cedrus 1c0e000.video-codec: Device registered as /dev/video0
[ 1.523687] sun4i-codec 1c22c00.codec: Failed to register our card
[ 1.531291] NET: Registered PF_PACKET protocol family
[ 1.536398] can: controller area network core
[ 1.540860] NET: Registered PF_CAN protocol family
[ 1.545676] can: raw protocol
[ 1.548654] can: broadcast manager protocol
[ 1.552864] can: netlink gateway - max_hops=1
[ 1.557519] Key type dns_resolver registered
[ 1.561900] Registering SWP/SWPB emulation handler
[ 1.566920] mmc1: new high speed SDIO card at address 0001
[ 1.580854] mmc2: new DDR MMC card at address 0001
[ 1.582660] sun8i-h3-pinctrl 1c20800.pinctrl: supply vcc-pd not found, using dummy regulator
[ 1.586620] mmcblk2: mmc2:0001 8GTF4R 7.28 GiB
[ 1.601407] mmcblk2boot0: mmc2:0001 8GTF4R 4.00 MiB
[ 1.605594] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc084d360)
[ 1.608175] mmcblk2boot1: mmc2:0001 8GTF4R 4.00 MiB
[ 1.613728] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0849650)
[ 1.626072] sun8i-dw-hdmi 1ee0000.hdmi: supply hvcc not found, using dummy regulator
[ 1.634955] sun8i-dw-hdmi 1ee0000.hdmi: Detected HDMI TX controller v1.32a with HDCP (sun8i_dw_hdmi_phy)
[ 1.645073] sun8i-dw-hdmi 1ee0000.hdmi: registered DesignWare HDMI I2C bus driver
[ 1.652966] sun4i-drm display-engine: bound 1ee0000.hdmi (ops 0xc084c914)
[ 1.660260] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 1
[ 1.668901] ehci-platform 1c1b000.usb: EHCI Host Controller
[ 1.674532] ehci-platform 1c1b000.usb: new USB bus registered, assigned bus number 3
[ 1.682950] ehci-platform 1c1b000.usb: irq 39, io mem 0x01c1b000
[ 1.712885] ehci-platform 1c1b000.usb: USB 2.0 started, EHCI 1.00
[ 1.719714] hub 3-0:1.0: USB hub found
[ 1.723519] hub 3-0:1.0: 1 port detected
[ 1.728418] ehci-platform 1c1c000.usb: EHCI Host Controller
[ 1.734027] ehci-platform 1c1c000.usb: new USB bus registered, assigned bus number 4
[ 1.742077] ehci-platform 1c1c000.usb: irq 41, io mem 0x01c1c000
[ 1.772879] ehci-platform 1c1c000.usb: USB 2.0 started, EHCI 1.00
[ 1.779632] hub 4-0:1.0: USB hub found
[ 1.783441] hub 4-0:1.0: 1 port detected
[ 1.788284] ehci-platform 1c1d000.usb: EHCI Host Controller
[ 1.793887] ehci-platform 1c1d000.usb: new USB bus registered, assigned bus number 5
[ 1.801915] ehci-platform 1c1d000.usb: irq 43, io mem 0x01c1d000
[ 1.832879] ehci-platform 1c1d000.usb: USB 2.0 started, EHCI 1.00
[ 1.839596] hub 5-0:1.0: USB hub found
[ 1.843398] hub 5-0:1.0: 1 port detected
[ 1.848215] ohci-platform 1c1b400.usb: Generic Platform OHCI controller
[ 1.854862] ohci-platform 1c1b400.usb: new USB bus registered, assigned bus number 6
[ 1.862822] ohci-platform 1c1b400.usb: irq 40, io mem 0x01c1b400
[ 1.937506] hub 6-0:1.0: USB hub found
[ 1.941292] hub 6-0:1.0: 1 port detected
[ 1.946188] ohci-platform 1c1c400.usb: Generic Platform OHCI controller
[ 1.952817] ohci-platform 1c1c400.usb: new USB bus registered, assigned bus number 7
[ 1.960818] ohci-platform 1c1c400.usb: irq 42, io mem 0x01c1c400
[ 2.012884] usb 3-1: new high-speed USB device number 2 using ehci-platform
[ 2.037531] hub 7-0:1.0: USB hub found
[ 2.041313] hub 7-0:1.0: 1 port detected
[ 2.046150] ohci-platform 1c1d400.usb: Generic Platform OHCI controller
[ 2.052778] ohci-platform 1c1d400.usb: new USB bus registered, assigned bus number 8
[ 2.060762] ohci-platform 1c1d400.usb: irq 44, io mem 0x01c1d400
[ 2.137501] hub 8-0:1.0: USB hub found
[ 2.141284] hub 8-0:1.0: 1 port detected
[ 2.146145] usb_phy_generic usb_phy_generic.3.auto: supply vcc not found, using dummy regulator
[ 2.155010] usb_phy_generic usb_phy_generic.3.auto: dummy supplies not allowed for exclusive requests
[ 2.164966] musb-hdrc musb-hdrc.4.auto: MUSB HDRC host driver
[ 2.170731] musb-hdrc musb-hdrc.4.auto: new USB bus registered, assigned bus number 9
[ 2.179372] hub 9-0:1.0: USB hub found
[ 2.183177] hub 9-0:1.0: 1 port detected
[ 2.190424] debugfs: Directory '1c22c00.codec' with parent 'H3 Audio Codec' already present!
[ 2.202463] ALSA device list:
[ 2.205487] #0: H3 Audio Codec
[ 2.209389] Waiting for root device /dev/mmcblk0p2...
[ 2.235379] hub 3-1:1.0: USB hub found
[ 2.239491] hub 3-1:1.0: 4 ports detected
[ 32.482884] vcc3v0: disabling
[ 32.485873] vcc5v0: disablinguboot dts:
/dts-v1/;
#include "sun8i-h3.dtsi"
model = "h3_tinyscan";
compatible = "friendlyarm,nanopi-m1-plus","allwinner,sun8i-h3"; // 使用香橙派和友善之臂的驱动文件
aliases { //设备别名
serial0 = &uart0;
i2c0 = &i2c0;
i2c1 = &i2c1;
i2c2 = &i2c2;
i2c5 = &r_i2c;
ethernet0 = &emac;
ethernet1 = &sdio_wifi;
chosen { // uboot 向 Linux 内核传递数据
leds {
compatible = "gpio-leds";
pinctrl-names = "default";
pinctrl-0 = <&leds_npi>, <&leds_r_npi>;
pwr_led {
label = "h3_tinyscan:blue:status";
gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
status_led {
label = "h3_tinyscan:red:status";
gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>;
default-state = "on";
reg_gmac_3v3: gmac-3v3 {
pinctrl-0 = <&gmac_power_pin_nanopi>;
regulator-name = "gmac-3v3";
startup-delay-us = <100000>;
enable-active-high;
gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>;
wifi_pwrseq: wifi_pwrseq {
compatible = "mmc-pwrseq-simple";
reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */
r_gpio_keys {
compatible = "gpio-keys";
pinctrl-0 = <&sw_r_npi>;
autorepeat; //支持连按
sw1 {
label = "sw1";
linux,code = <BTN_0>; // 百度Linux input_event type值列表和code值列表
gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>;
sw2 {
label = "sw2";
linux,code = <BTN_1>;
gpios = <&r_pio 0 0 GPIO_ACTIVE_LOW>;
sw3 {
label = "sw3";
linux,code = <BTN_2>;
gpios = <&r_pio 0 5 GPIO_ACTIVE_LOW>;
sw4 {
label = "sw4";
linux,code = <BTN_3>;
gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>;
r_i2c: i2c@01f02400 {
compatible = "allwinner,sun6i-a31-i2c";
reg = <0x01f02400 0x400>;
#address-cells = <1>;
#size-cells = <0>;
&ehci1 {
&ehci2 {
&ehci3 {
&ir {
pinctrl-0 = <&ir_pins_a>;
&mmc0 {
bus-width = <4>;
cd-gpios = <&pio 5 6 GPIO_ACTIVE_HIGH>; /* PF6 */
cd-inverted;
pinctrl-0 = <&mmc0_pins_a>, <&mmc0_cd_pin>;
vmmc-supply = <®_vcc3v3>;
&mmc1 {
vqmmc-supply = <®_vcc3v3>;
mmc-pwrseq = <&wifi_pwrseq>;
bus-width = <4>;
non-removable;
sdio_wifi: sdio_wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
interrupt-parent = <&pio>;
interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 / EINT10 */
interrupt-names = "host-wake";
&mmc2 {
pinctrl-0 = <&mmc2_8bit_pins>;
bus-width = <8>;
non-removable;
&ohci1 {
&ohci2 {
&ohci3 {
&pio {
leds_npi: led_pins@0 {
pins = "PA10";
function = "gpio_out";
gmac_power_pin_nanopi: gmac_power_pin@0 {
pins = "PD6";
&emac {
phy = <&phy1>;
phy-mode = "mii";
allwinner,use-internal-phy;
allwinner,leds-active-low;
phy1: ethernet-phy@1 {
reg = <1>;
&r_pio {
leds_r_npi: led_pins@0 {
pins = "PL10";
sw_r_npi: key_pins@0 {
pins = "PL3";
function = "gpio_in";
®_usb0_vbus {
gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */
&uart0 {
pinctrl-0 = <&uart0_pins_a>;
&usbphy {
usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */
usb0_vbus-supply = <®_usb0_vbus>;
/* VBUS on USB host ports are always on */
};uboot defconfig:
CONFIG_ARM=y
CONFIG_ARCH_SUNXI=y
CONFIG_MACH_SUN8I_H3=y
CONFIG_MACH_SUN8I_H3_NANOPI=y
CONFIG_DRAM_CLK=667
CONFIG_DRAM_ZQ=3881979
CONFIG_DRAM_ODT_EN=y
CONFIG_MMC0_CD_PIN="PH13"
CONFIG_MMC_SUNXI_SLOT_EXTRA=2
CONFIG_I2C0_ENABLE=y
CONFIG_I2C1_ENABLE=y
CONFIG_I2C2_ENABLE=y
CONFIG_R_I2C_ENABLE=y
# CONFIG_VIDEO_DE2 is not set
CONFIG_DEFAULT_DEVICE_TREE="sun8i-h3-nanopi-m1-plus"
# CONFIG_SYS_MALLOC_CLEAR_ON_INIT is not set
CONFIG_BOOTCOMMAND="fatload mmc 0:1 ${scriptaddr} boot.scr; source ${scriptaddr}"
CONFIG_CONSOLE_MUX=y
CONFIG_SPL=y
# CONFIG_CMD_BOOTEFI_HELLO_COMPILE is not set
CONFIG_CMD_EEPROM=y
CONFIG_CMD_MEMINFO=y
CONFIG_CMD_MEMTEST=y
# CONFIG_CMD_FLASH is not set
# CONFIG_CMD_FPGA is not set
CONFIG_CMD_OVERLAY=y
# CONFIG_SPL_DOS_PARTITION is not set
# CONFIG_SPL_ISO_PARTITION is not set
# CONFIG_SPL_EFI_PARTITION is not set
CONFIG_ENV_OFFSET=0x200000
CONFIG_DM_I2C_COMPAT=y
CONFIG_I2C_SET_DEFAULT_BUS_NUM=y
CONFIG_I2C_DEFAULT_BUS_NUMBER=0x5
CONFIG_MISC=y
CONFIG_I2C_EEPROM=y
CONFIG_SYS_I2C_EEPROM_ADDR=0x51
CONFIG_SYS_USB_EVENT_POLL_VIA_INT_QUEUE=y
CONFIG_DISPLAY=y
CONFIG_OF_LIBFDT_OVERLAY=y
CONFIG_SUN8I_EMAC=y
CONFIG_USB_EHCI_HCD=ykernel .config:
# Linux/arm 5.15.101 Kernel Configuration
CONFIG_CC_VERSION_TEXT="arm-none-linux-gnueabihf-gcc (GNU Toolchain for the Arm Architecture 11.2-2022.02 (arm-11.14)) 11.2.1 20220111"
CONFIG_CC_IS_GCC=y
CONFIG_GCC_VERSION=110201
CONFIG_CLANG_VERSION=0
CONFIG_AS_IS_GNU=y
CONFIG_AS_VERSION=20243822
CONFIG_LD_IS_BFD=y
CONFIG_LD_VERSION=20243822
CONFIG_LLD_VERSION=0
CONFIG_CC_CAN_LINK=y
CONFIG_CC_CAN_LINK_STATIC=y
CONFIG_CC_HAS_ASM_GOTO=y
CONFIG_CC_HAS_ASM_GOTO_OUTPUT=y
CONFIG_CC_HAS_ASM_GOTO_TIED_OUTPUT=y
CONFIG_CC_HAS_ASM_INLINE=y
CONFIG_CC_HAS_NO_PROFILE_FN_ATTR=y
CONFIG_PAHOLE_VERSION=0
CONFIG_IRQ_WORK=y
CONFIG_BUILDTIME_TABLE_SORT=y
# General setup
CONFIG_INIT_ENV_ARG_LIMIT=32
# CONFIG_COMPILE_TEST is not set
# CONFIG_WERROR is not set
CONFIG_LOCALVERSION=""
CONFIG_LOCALVERSION_AUTO=y
CONFIG_BUILD_SALT=""
CONFIG_HAVE_KERNEL_GZIP=y
CONFIG_HAVE_KERNEL_LZMA=y
CONFIG_HAVE_KERNEL_XZ=y
CONFIG_HAVE_KERNEL_LZO=y
CONFIG_HAVE_KERNEL_LZ4=y
CONFIG_KERNEL_GZIP=y
# CONFIG_KERNEL_LZMA is not set
# CONFIG_KERNEL_XZ is not set
# CONFIG_KERNEL_LZO is not set
# CONFIG_KERNEL_LZ4 is not set
CONFIG_DEFAULT_INIT=""
CONFIG_DEFAULT_HOSTNAME="(none)"
CONFIG_SWAP=y
# CONFIG_SYSVIPC is not set
# CONFIG_POSIX_MQUEUE is not set
# CONFIG_WATCH_QUEUE is not set
CONFIG_CROSS_MEMORY_ATTACH=y
# CONFIG_USELIB is not set
# CONFIG_AUDIT is not set
CONFIG_HAVE_ARCH_AUDITSYSCALL=y
# IRQ subsystem
CONFIG_GENERIC_IRQ_PROBE=y
CONFIG_GENERIC_IRQ_SHOW=y
CONFIG_GENERIC_IRQ_SHOW_LEVEL=y
CONFIG_GENERIC_IRQ_EFFECTIVE_AFF_MASK=y
CONFIG_GENERIC_IRQ_MIGRATION=y
CONFIG_HARDIRQS_SW_RESEND=y
CONFIG_GENERIC_IRQ_CHIP=y
CONFIG_IRQ_DOMAIN=y
CONFIG_IRQ_DOMAIN_HIERARCHY=y
CONFIG_IRQ_FASTEOI_HIERARCHY_HANDLERS=y
CONFIG_GENERIC_IRQ_IPI=y
CONFIG_HANDLE_DOMAIN_IRQ=y
CONFIG_IRQ_FORCED_THREADING=y
CONFIG_SPARSE_IRQ=y
# CONFIG_GENERIC_IRQ_DEBUGFS is not set
# end of IRQ subsystem
CONFIG_GENERIC_IRQ_MULTI_HANDLER=y
CONFIG_GENERIC_TIME_VSYSCALL=y
CONFIG_GENERIC_CLOCKEVENTS=y
CONFIG_ARCH_HAS_TICK_BROADCAST=y
CONFIG_GENERIC_CLOCKEVENTS_BROADCAST=y
# Timers subsystem
CONFIG_TICK_ONESHOT=y
CONFIG_NO_HZ_COMMON=y
# CONFIG_HZ_PERIODIC is not set
CONFIG_NO_HZ_IDLE=y
# CONFIG_NO_HZ_FULL is not set
CONFIG_NO_HZ=y
CONFIG_HIGH_RES_TIMERS=y
# end of Timers subsystem
CONFIG_BPF=y
CONFIG_HAVE_EBPF_JIT=y
# BPF subsystem
# CONFIG_BPF_SYSCALL is not set
# CONFIG_BPF_JIT is not set
# end of BPF subsystem
CONFIG_PREEMPT_NONE=y
# CONFIG_PREEMPT_VOLUNTARY is not set
# CONFIG_PREEMPT is not set
# CPU/Task time and stats accounting
CONFIG_TICK_CPU_ACCOUNTING=y
# CONFIG_VIRT_CPU_ACCOUNTING_GEN is not set
# CONFIG_IRQ_TIME_ACCOUNTING is not set
CONFIG_SCHED_THERMAL_PRESSURE=y
# CONFIG_BSD_PROCESS_ACCT is not set
# CONFIG_TASKSTATS is not set
# CONFIG_PSI is not set
# end of CPU/Task time and stats accounting
CONFIG_CPU_ISOLATION=y
# RCU Subsystem
CONFIG_TREE_RCU=y
# CONFIG_RCU_EXPERT is not set
CONFIG_SRCU=y
CONFIG_TREE_SRCU=y
CONFIG_RCU_STALL_COMMON=y
CONFIG_RCU_NEED_SEGCBLIST=y
# end of RCU Subsystem
# CONFIG_IKCONFIG is not set
# CONFIG_IKHEADERS is not set
CONFIG_LOG_BUF_SHIFT=17
CONFIG_LOG_CPU_MAX_BUF_SHIFT=12
CONFIG_PRINTK_SAFE_LOG_BUF_SHIFT=13
# CONFIG_PRINTK_INDEX is not set
CONFIG_GENERIC_SCHED_CLOCK=y
# Scheduler features
# CONFIG_UCLAMP_TASK is not set
# end of Scheduler features
CONFIG_CGROUPS=y
# CONFIG_MEMCG is not set
# CONFIG_BLK_CGROUP is not set
# CONFIG_CGROUP_SCHED is not set
# CONFIG_CGROUP_PIDS is not set
# CONFIG_CGROUP_RDMA is not set
# CONFIG_CGROUP_FREEZER is not set
# CONFIG_CPUSETS is not set
# CONFIG_CGROUP_DEVICE is not set
# CONFIG_CGROUP_CPUACCT is not set
# CONFIG_CGROUP_PERF is not set
# CONFIG_CGROUP_MISC is not set
CONFIG_NAMESPACES=y
CONFIG_UTS_NS=y
# CONFIG_USER_NS is not set
CONFIG_PID_NS=y
CONFIG_NET_NS=y
# CONFIG_CHECKPOINT_RESTORE is not set
# CONFIG_SCHED_AUTOGROUP is not set
# CONFIG_SYSFS_DEPRECATED is not set
# CONFIG_RELAY is not set
CONFIG_BLK_DEV_INITRD=y
CONFIG_INITRAMFS_SOURCE=""
CONFIG_RD_GZIP=y
CONFIG_RD_BZIP2=y
CONFIG_RD_LZMA=y
CONFIG_RD_XZ=y
CONFIG_RD_LZO=y
CONFIG_RD_LZ4=y
CONFIG_RD_ZSTD=y
# CONFIG_BOOT_CONFIG is not set
CONFIG_CC_OPTIMIZE_FOR_PERFORMANCE=y
# CONFIG_CC_OPTIMIZE_FOR_SIZE is not set
CONFIG_LD_ORPHAN_WARN=y
CONFIG_SYSCTL=y
CONFIG_HAVE_UID16=y
# CONFIG_EXPERT is not set
CONFIG_UID16=y
CONFIG_MULTIUSER=y
CONFIG_SYSFS_SYSCALL=y
CONFIG_FHANDLE=y
CONFIG_POSIX_TIMERS=y
CONFIG_PRINTK=y
CONFIG_BUG=y
CONFIG_ELF_CORE=y
CONFIG_BASE_FULL=y
CONFIG_FUTEX=y
CONFIG_FUTEX_PI=y
CONFIG_HAVE_FUTEX_CMPXCHG=y
CONFIG_EPOLL=y
CONFIG_SIGNALFD=y
CONFIG_TIMERFD=y
CONFIG_EVENTFD=y
CONFIG_SHMEM=y
CONFIG_AIO=y
CONFIG_IO_URING=y
CONFIG_ADVISE_SYSCALLS=y
CONFIG_MEMBARRIER=y
CONFIG_KALLSYMS=y
CONFIG_KALLSYMS_BASE_RELATIVE=y
# CONFIG_USERFAULTFD is not set
CONFIG_ARCH_HAS_MEMBARRIER_SYNC_CORE=y
CONFIG_KCMP=y
CONFIG_RSEQ=y
# CONFIG_EMBEDDED is not set
CONFIG_HAVE_PERF_EVENTS=y
CONFIG_PERF_USE_VMALLOC=y
# Kernel Performance Events And Counters
CONFIG_PERF_EVENTS=y
# end of Kernel Performance Events And Counters
CONFIG_VM_EVENT_COUNTERS=y
CONFIG_SLUB_DEBUG=y
CONFIG_COMPAT_BRK=y
# CONFIG_SLAB is not set
CONFIG_SLUB=y
CONFIG_SLAB_MERGE_DEFAULT=y
# CONFIG_SLAB_FREELIST_RANDOM is not set
# CONFIG_SLAB_FREELIST_HARDENED is not set
# CONFIG_SHUFFLE_PAGE_ALLOCATOR is not set
CONFIG_SLUB_CPU_PARTIAL=y
# CONFIG_PROFILING is not set
# end of General setup
CONFIG_ARM=y
CONFIG_ARM_HAS_SG_CHAIN=y
CONFIG_SYS_SUPPORTS_APM_EMULATION=y
CONFIG_HAVE_PROC_CPU=y
CONFIG_STACKTRACE_SUPPORT=y
CONFIG_LOCKDEP_SUPPORT=y
CONFIG_FIX_EARLYCON_MEM=y
CONFIG_GENERIC_HWEIGHT=y
CONFIG_GENERIC_CALIBRATE_DELAY=y
CONFIG_ARCH_SUPPORTS_UPROBES=y
CONFIG_ARM_PATCH_PHYS_VIRT=y
CONFIG_GENERIC_BUG=y
CONFIG_PGTABLE_LEVELS=2
# System Type
CONFIG_MMU=y
CONFIG_ARCH_MMAP_RND_BITS_MIN=8
CONFIG_ARCH_MMAP_RND_BITS_MAX=16
CONFIG_ARCH_MULTIPLATFORM=y
# CONFIG_ARCH_EP93XX is not set
# CONFIG_ARCH_FOOTBRIDGE is not set
# CONFIG_ARCH_IOP32X is not set
# CONFIG_ARCH_IXP4XX is not set
# CONFIG_ARCH_DOVE is not set
# CONFIG_ARCH_PXA is not set
# CONFIG_ARCH_RPC is not set
# CONFIG_ARCH_SA1100 is not set
# CONFIG_ARCH_S3C24XX is not set
# CONFIG_ARCH_OMAP1 is not set
# Multiple platform selection
# CPU Core family selection
# CONFIG_ARCH_MULTI_V6 is not set
CONFIG_ARCH_MULTI_V7=y
CONFIG_ARCH_MULTI_V6_V7=y
# end of Multiple platform selection
# CONFIG_ARCH_VIRT is not set
# CONFIG_ARCH_ACTIONS is not set
# CONFIG_ARCH_ALPINE is not set
# CONFIG_ARCH_ARTPEC is not set
# CONFIG_ARCH_ASPEED is not set
# CONFIG_ARCH_AT91 is not set
# CONFIG_ARCH_BCM is not set
# CONFIG_ARCH_BERLIN is not set
# CONFIG_ARCH_DIGICOLOR is not set
# CONFIG_ARCH_EXYNOS is not set
# CONFIG_ARCH_HIGHBANK is not set
# CONFIG_ARCH_HISI is not set
# CONFIG_ARCH_MXC is not set
# CONFIG_ARCH_KEYSTONE is not set
# CONFIG_ARCH_MEDIATEK is not set
# CONFIG_ARCH_MESON is not set
# CONFIG_ARCH_MILBEAUT is not set
# CONFIG_ARCH_MMP is not set
# CONFIG_ARCH_MSTARV7 is not set
# CONFIG_ARCH_MVEBU is not set
# CONFIG_ARCH_NPCM is not set
# TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_OMAP3 is not set
# CONFIG_ARCH_OMAP4 is not set
# CONFIG_SOC_OMAP5 is not set
# CONFIG_SOC_AM33XX is not set
# CONFIG_SOC_AM43XX is not set
# CONFIG_SOC_DRA7XX is not set
# end of TI OMAP/AM/DM/DRA Family
# CONFIG_ARCH_QCOM is not set
# CONFIG_ARCH_RDA is not set
# CONFIG_ARCH_REALTEK is not set
# CONFIG_ARCH_REALVIEW is not set
# CONFIG_ARCH_ROCKCHIP is not set
# CONFIG_ARCH_S5PV210 is not set
# CONFIG_ARCH_RENESAS is not set
# CONFIG_ARCH_INTEL_SOCFPGA is not set
# CONFIG_PLAT_SPEAR is not set
# CONFIG_ARCH_STI is not set
# CONFIG_ARCH_STM32 is not set
CONFIG_ARCH_SUNXI=y
CONFIG_MACH_SUN4I=y
CONFIG_MACH_SUN5I=y
CONFIG_MACH_SUN6I=y
CONFIG_MACH_SUN7I=y
CONFIG_MACH_SUN8I=y
CONFIG_MACH_SUN9I=y
CONFIG_ARCH_SUNXI_MC_SMP=y
# CONFIG_ARCH_TEGRA is not set
# CONFIG_ARCH_UNIPHIER is not set
# CONFIG_ARCH_U8500 is not set
# CONFIG_ARCH_VEXPRESS is not set
# CONFIG_ARCH_WM8850 is not set
# CONFIG_ARCH_ZYNQ is not set
# Processor Type
CONFIG_CPU_V7=y
CONFIG_CPU_THUMB_CAPABLE=y
CONFIG_CPU_32v6K=y
CONFIG_CPU_32v7=y
CONFIG_CPU_ABRT_EV7=y
CONFIG_CPU_PABRT_V7=y
CONFIG_CPU_CACHE_V7=y
CONFIG_CPU_CACHE_VIPT=y
CONFIG_CPU_COPY_V6=y
CONFIG_CPU_TLB_V7=y
CONFIG_CPU_HAS_ASID=y
CONFIG_CPU_CP15=y
CONFIG_CPU_CP15_MMU=y
# Processor Features
# CONFIG_ARM_LPAE is not set
CONFIG_ARM_THUMB=y
# CONFIG_ARM_THUMBEE is not set
CONFIG_ARM_VIRT_EXT=y
CONFIG_SWP_EMULATE=y
# CONFIG_CPU_BIG_ENDIAN is not set
# CONFIG_CPU_ICACHE_DISABLE is not set
# CONFIG_CPU_ICACHE_MISMATCH_WORKAROUND is not set
# CONFIG_CPU_BPREDICT_DISABLE is not set
CONFIG_CPU_SPECTRE=y
CONFIG_HARDEN_BRANCH_PREDICTOR=y
CONFIG_HARDEN_BRANCH_HISTORY=y
CONFIG_KUSER_HELPERS=y
CONFIG_VDSO=y
CONFIG_OUTER_CACHE=y
CONFIG_OUTER_CACHE_SYNC=y
CONFIG_MIGHT_HAVE_CACHE_L2X0=y
CONFIG_CACHE_L2X0=y
# CONFIG_CACHE_L2X0_PMU is not set
# CONFIG_PL310_ERRATA_588369 is not set
# CONFIG_PL310_ERRATA_727915 is not set
# CONFIG_PL310_ERRATA_753970 is not set
# CONFIG_PL310_ERRATA_769419 is not set
CONFIG_ARM_L1_CACHE_SHIFT_6=y
CONFIG_ARM_L1_CACHE_SHIFT=6
CONFIG_ARM_DMA_MEM_BUFFERABLE=y
CONFIG_ARM_HEAVY_MB=y
CONFIG_ARCH_SUPPORTS_BIG_ENDIAN=y
CONFIG_DEBUG_ALIGN_RODATA=y
# CONFIG_ARM_ERRATA_430973 is not set
CONFIG_ARM_ERRATA_643719=y
# CONFIG_ARM_ERRATA_720789 is not set
# CONFIG_ARM_ERRATA_754322 is not set
# CONFIG_ARM_ERRATA_754327 is not set
# CONFIG_ARM_ERRATA_764369 is not set
# CONFIG_ARM_ERRATA_775420 is not set
# CONFIG_ARM_ERRATA_798181 is not set
# CONFIG_ARM_ERRATA_773022 is not set
# CONFIG_ARM_ERRATA_818325_852422 is not set
# CONFIG_ARM_ERRATA_821420 is not set
# CONFIG_ARM_ERRATA_825619 is not set
# CONFIG_ARM_ERRATA_857271 is not set
# CONFIG_ARM_ERRATA_852421 is not set
# CONFIG_ARM_ERRATA_852423 is not set
# CONFIG_ARM_ERRATA_857272 is not set
# end of System Type
# Bus support
# CONFIG_ARM_ERRATA_814220 is not set
# end of Bus support
# Kernel Features
CONFIG_HAVE_SMP=y
CONFIG_SMP=y
CONFIG_SMP_ON_UP=y
CONFIG_ARM_CPU_TOPOLOGY=y
# CONFIG_SCHED_MC is not set
# CONFIG_SCHED_SMT is not set
CONFIG_HAVE_ARM_ARCH_TIMER=y
# CONFIG_MCPM is not set
# CONFIG_BIG_LITTLE is not set
CONFIG_VMSPLIT_3G=y
# CONFIG_VMSPLIT_3G_OPT is not set
# CONFIG_VMSPLIT_2G is not set
# CONFIG_VMSPLIT_1G is not set
CONFIG_PAGE_OFFSET=0xC0000000
CONFIG_NR_CPUS=8
CONFIG_HOTPLUG_CPU=y
CONFIG_ARM_PSCI=y
CONFIG_ARCH_NR_GPIO=416
CONFIG_HZ_FIXED=0
CONFIG_HZ_100=y
# CONFIG_HZ_200 is not set
# CONFIG_HZ_250 is not set
# CONFIG_HZ_300 is not set
# CONFIG_HZ_500 is not set
# CONFIG_HZ_1000 is not set
CONFIG_HZ=100
CONFIG_SCHED_HRTICK=y
# CONFIG_THUMB2_KERNEL is not set
CONFIG_ARM_PATCH_IDIV=y
CONFIG_AEABI=y
# CONFIG_OABI_COMPAT is not set
CONFIG_ARCH_SELECT_MEMORY_MODEL=y
CONFIG_ARCH_FLATMEM_ENABLE=y
CONFIG_ARCH_SPARSEMEM_ENABLE=y
CONFIG_HIGHMEM=y
CONFIG_HIGHPTE=y
CONFIG_CPU_SW_DOMAIN_PAN=y
CONFIG_HW_PERF_EVENTS=y
CONFIG_ARCH_WANT_GENERAL_HUGETLB=y
CONFIG_ARM_MODULE_PLTS=y
CONFIG_FORCE_MAX_ZONEORDER=11
CONFIG_ALIGNMENT_TRAP=y
# CONFIG_UACCESS_WITH_MEMCPY is not set
# CONFIG_PARAVIRT is not set
# CONFIG_PARAVIRT_TIME_ACCOUNTING is not set
# CONFIG_XEN is not set
CONFIG_STACKPROTECTOR_PER_TASK=y
# end of Kernel Features
# Boot options
CONFIG_USE_OF=y
CONFIG_ATAGS=y
# CONFIG_DEPRECATED_PARAM_STRUCT is not set
CONFIG_ZBOOT_ROM_TEXT=0x0
CONFIG_ZBOOT_ROM_BSS=0x0
CONFIG_ARM_APPENDED_DTB=y
CONFIG_ARM_ATAG_DTB_COMPAT=y
CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_FROM_BOOTLOADER=y
# CONFIG_ARM_ATAG_DTB_COMPAT_CMDLINE_EXTEND is not set
CONFIG_CMDLINE=""
# CONFIG_KEXEC is not set
# CONFIG_CRASH_DUMP is not set
CONFIG_AUTO_ZRELADDR=y
# CONFIG_EFI is not set
# end of Boot options
# CPU Power Management
# CPU Frequency scaling
CONFIG_CPU_FREQ=y
CONFIG_CPU_FREQ_GOV_ATTR_SET=y
# CONFIG_CPU_FREQ_STAT is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_PERFORMANCE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_DEFAULT_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_DEFAULT_GOV_SCHEDUTIL=y
CONFIG_CPU_FREQ_GOV_PERFORMANCE=y
# CONFIG_CPU_FREQ_GOV_POWERSAVE is not set
# CONFIG_CPU_FREQ_GOV_USERSPACE is not set
# CONFIG_CPU_FREQ_GOV_ONDEMAND is not set
# CONFIG_CPU_FREQ_GOV_CONSERVATIVE is not set
CONFIG_CPU_FREQ_GOV_SCHEDUTIL=y
# CPU frequency scaling drivers
CONFIG_CPUFREQ_DT=y
CONFIG_CPUFREQ_DT_PLATDEV=y
# CONFIG_ARM_ALLWINNER_SUN50I_CPUFREQ_NVMEM is not set
# end of CPU Frequency scaling
# CPU Idle
# CONFIG_CPU_IDLE is not set
# end of CPU Idle
# end of CPU Power Management
# Floating point emulation
# At least one emulation must be selected
CONFIG_VFP=y
CONFIG_VFPv3=y
CONFIG_NEON=y
# CONFIG_KERNEL_MODE_NEON is not set
# end of Floating point emulation
# Power management options
CONFIG_SUSPEND=y
CONFIG_SUSPEND_FREEZER=y
# CONFIG_HIBERNATION is not set
CONFIG_PM_SLEEP=y
CONFIG_PM_SLEEP_SMP=y
# CONFIG_PM_AUTOSLEEP is not set
# CONFIG_PM_WAKELOCKS is not set
CONFIG_PM=y
# CONFIG_PM_DEBUG is not set
# CONFIG_APM_EMULATION is not set
CONFIG_PM_CLK=y
# CONFIG_WQ_POWER_EFFICIENT_DEFAULT is not set
CONFIG_CPU_PM=y
# CONFIG_ENERGY_MODEL is not set
CONFIG_ARCH_SUSPEND_POSSIBLE=y
CONFIG_ARM_CPU_SUSPEND=y
CONFIG_ARCH_HIBERNATION_POSSIBLE=y
# end of Power management options
# CONFIG_ARM_CRYPTO is not set
CONFIG_AS_VFP_VMRS_FPINST=y
# General architecture-dependent options
# CONFIG_KPROBES is not set
# CONFIG_JUMP_LABEL is not set
CONFIG_HAVE_EFFICIENT_UNALIGNED_ACCESS=y
CONFIG_ARCH_USE_BUILTIN_BSWAP=y
CONFIG_HAVE_KPROBES=y
CONFIG_HAVE_KRETPROBES=y
CONFIG_HAVE_OPTPROBES=y
CONFIG_HAVE_NMI=y
CONFIG_TRACE_IRQFLAGS_SUPPORT=y
CONFIG_HAVE_ARCH_TRACEHOOK=y
CONFIG_HAVE_DMA_CONTIGUOUS=y
CONFIG_GENERIC_SMP_IDLE_THREAD=y
CONFIG_GENERIC_IDLE_POLL_SETUP=y
CONFIG_ARCH_HAS_FORTIFY_SOURCE=y
CONFIG_ARCH_HAS_KEEPINITRD=y
CONFIG_ARCH_HAS_SET_MEMORY=y
CONFIG_HAVE_ARCH_THREAD_STRUCT_WHITELIST=y
CONFIG_ARCH_32BIT_OFF_T=y
CONFIG_HAVE_REGS_AND_STACK_ACCESS_API=y
CONFIG_HAVE_RSEQ=y
CONFIG_HAVE_HW_BREAKPOINT=y
CONFIG_HAVE_PERF_REGS=y
CONFIG_HAVE_PERF_USER_STACK_DUMP=y
CONFIG_HAVE_ARCH_JUMP_LABEL=y
CONFIG_ARCH_HAVE_NMI_SAFE_CMPXCHG=y
CONFIG_ARCH_WANT_IPC_PARSE_VERSION=y
CONFIG_HAVE_ARCH_SECCOMP=y
CONFIG_HAVE_ARCH_SECCOMP_FILTER=y
CONFIG_SECCOMP=y
CONFIG_SECCOMP_FILTER=y
# CONFIG_SECCOMP_CACHE_DEBUG is not set
CONFIG_HAVE_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR=y
CONFIG_STACKPROTECTOR_STRONG=y
CONFIG_LTO_NONE=y
CONFIG_HAVE_CONTEXT_TRACKING=y
CONFIG_HAVE_VIRT_CPU_ACCOUNTING_GEN=y
CONFIG_HAVE_IRQ_TIME_ACCOUNTING=y
CONFIG_HAVE_MOD_ARCH_SPECIFIC=y
CONFIG_MODULES_USE_ELF_REL=y
CONFIG_ARCH_HAS_ELF_RANDOMIZE=y
CONFIG_HAVE_ARCH_MMAP_RND_BITS=y
CONFIG_HAVE_EXIT_THREAD=y
CONFIG_ARCH_MMAP_RND_BITS=8
CONFIG_ARCH_WANT_DEFAULT_TOPDOWN_MMAP_LAYOUT=y
CONFIG_CLONE_BACKWARDS=y
CONFIG_OLD_SIGSUSPEND3=y
CONFIG_OLD_SIGACTION=y
CONFIG_COMPAT_32BIT_TIME=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX=y
CONFIG_ARCH_OPTIONAL_KERNEL_RWX_DEFAULT=y
CONFIG_ARCH_HAS_STRICT_KERNEL_RWX=y
CONFIG_STRICT_KERNEL_RWX=y
CONFIG_ARCH_HAS_STRICT_MODULE_RWX=y
CONFIG_STRICT_MODULE_RWX=y
CONFIG_ARCH_HAS_PHYS_TO_DMA=y
# CONFIG_LOCK_EVENT_COUNTS is not set
CONFIG_ARCH_WANT_LD_ORPHAN_WARN=y
CONFIG_HAVE_ARCH_PFN_VALID=y
# GCOV-based kernel profiling
# CONFIG_GCOV_KERNEL is not set
CONFIG_ARCH_HAS_GCOV_PROFILE_ALL=y
# end of GCOV-based kernel profiling
CONFIG_HAVE_GCC_PLUGINS=y
CONFIG_GCC_PLUGINS=y
# CONFIG_GCC_PLUGIN_LATENT_ENTROPY is not set
# CONFIG_GCC_PLUGIN_RANDSTRUCT is not set
CONFIG_GCC_PLUGIN_ARM_SSP_PER_TASK=y
# end of General architecture-dependent options
CONFIG_RT_MUTEXES=y
CONFIG_BASE_SMALL=0
CONFIG_MODULES=y
# CONFIG_MODULE_FORCE_LOAD is not set
CONFIG_MODULE_UNLOAD=y
# CONFIG_MODULE_FORCE_UNLOAD is not set
# CONFIG_MODVERSIONS is not set
# CONFIG_MODULE_SRCVERSION_ALL is not set
# CONFIG_MODULE_SIG is not set
CONFIG_MODULE_COMPRESS_NONE=y
# CONFIG_MODULE_COMPRESS_GZIP is not set
# CONFIG_MODULE_COMPRESS_XZ is not set
# CONFIG_MODULE_COMPRESS_ZSTD is not set
# CONFIG_MODULE_ALLOW_MISSING_NAMESPACE_IMPORTS is not set
CONFIG_MODPROBE_PATH="/sbin/modprobe"
CONFIG_MODULES_TREE_LOOKUP=y
CONFIG_BLOCK=y
CONFIG_BLK_DEV_BSG_COMMON=y
# CONFIG_BLK_DEV_BSGLIB is not set
# CONFIG_BLK_DEV_INTEGRITY is not set
# CONFIG_BLK_DEV_ZONED is not set
# CONFIG_BLK_WBT is not set
CONFIG_BLK_DEBUG_FS=y
# CONFIG_BLK_SED_OPAL is not set
# CONFIG_BLK_INLINE_ENCRYPTION is not set
# Partition Types
# CONFIG_PARTITION_ADVANCED is not set
CONFIG_MSDOS_PARTITION=y
CONFIG_EFI_PARTITION=y
# end of Partition Types
CONFIG_BLK_PM=y
# IO Schedulers
CONFIG_MQ_IOSCHED_DEADLINE=y
CONFIG_MQ_IOSCHED_KYBER=y
# CONFIG_IOSCHED_BFQ is not set
# end of IO Schedulers
CONFIG_INLINE_SPIN_UNLOCK_IRQ=y
CONFIG_INLINE_READ_UNLOCK=y
CONFIG_INLINE_READ_UNLOCK_IRQ=y
CONFIG_INLINE_WRITE_UNLOCK=y
CONFIG_INLINE_WRITE_UNLOCK_IRQ=y
CONFIG_ARCH_SUPPORTS_ATOMIC_RMW=y
CONFIG_MUTEX_SPIN_ON_OWNER=y
CONFIG_RWSEM_SPIN_ON_OWNER=y
CONFIG_LOCK_SPIN_ON_OWNER=y
CONFIG_ARCH_HAS_NON_OVERLAPPING_ADDRESS_SPACE=y
CONFIG_FREEZER=y
# Executable file formats
CONFIG_BINFMT_ELF=y
# CONFIG_BINFMT_ELF_FDPIC is not set
CONFIG_ELFCORE=y
CONFIG_CORE_DUMP_DEFAULT_ELF_HEADERS=y
CONFIG_BINFMT_SCRIPT=y
CONFIG_ARCH_HAS_BINFMT_FLAT=y
# CONFIG_BINFMT_FLAT is not set
CONFIG_BINFMT_FLAT_ARGVP_ENVP_ON_STACK=y
# CONFIG_BINFMT_MISC is not set
CONFIG_COREDUMP=y
# end of Executable file formats
# Memory Management options
CONFIG_SELECT_MEMORY_MODEL=y
CONFIG_FLATMEM_MANUAL=y
# CONFIG_SPARSEMEM_MANUAL is not set
CONFIG_FLATMEM=y
CONFIG_ARCH_KEEP_MEMBLOCK=y
CONFIG_MEMORY_ISOLATION=y
CONFIG_SPLIT_PTLOCK_CPUS=4
CONFIG_COMPACTION=y
# CONFIG_PAGE_REPORTING is not set
CONFIG_MIGRATION=y
CONFIG_CONTIG_ALLOC=y
CONFIG_BOUNCE=y
# CONFIG_KSM is not set
CONFIG_DEFAULT_MMAP_MIN_ADDR=4096
# CONFIG_CLEANCACHE is not set
# CONFIG_FRONTSWAP is not set
CONFIG_CMA=y
# CONFIG_CMA_DEBUGFS is not set
# CONFIG_CMA_SYSFS is not set
CONFIG_CMA_AREAS=7
# CONFIG_ZPOOL is not set
# CONFIG_ZSMALLOC is not set
CONFIG_GENERIC_EARLY_IOREMAP=y
# CONFIG_IDLE_PAGE_TRACKING is not set
# CONFIG_PERCPU_STATS is not set
# CONFIG_GUP_TEST is not set
CONFIG_KMAP_LOCAL=y
CONFIG_KMAP_LOCAL_NON_LINEAR_PTE_ARRAY=y
# Data Access Monitoring
# CONFIG_DAMON is not set
# end of Data Access Monitoring
# end of Memory Management options
CONFIG_NET=y
# Networking options
CONFIG_PACKET=y
# CONFIG_PACKET_DIAG is not set
CONFIG_UNIX=y
CONFIG_UNIX_SCM=y
CONFIG_AF_UNIX_OOB=y
# CONFIG_UNIX_DIAG is not set
# CONFIG_TLS is not set
# CONFIG_XFRM_USER is not set
# CONFIG_NET_KEY is not set
CONFIG_INET=y
# CONFIG_IP_MULTICAST is not set
# CONFIG_IP_ADVANCED_ROUTER is not set
CONFIG_IP_PNP=y
CONFIG_IP_PNP_DHCP=y
CONFIG_IP_PNP_BOOTP=y
# CONFIG_IP_PNP_RARP is not set
# CONFIG_NET_IPIP is not set
# CONFIG_NET_IPGRE_DEMUX is not set
# CONFIG_SYN_COOKIES is not set
# CONFIG_NET_IPVTI is not set
# CONFIG_NET_FOU is not set
# CONFIG_INET_AH is not set
# CONFIG_INET_ESP is not set
# CONFIG_INET_IPCOMP is not set
CONFIG_INET_TABLE_PERTURB_ORDER=16
# CONFIG_INET_DIAG is not set
# CONFIG_TCP_CONG_ADVANCED is not set
CONFIG_TCP_CONG_CUBIC=y
CONFIG_DEFAULT_TCP_CONG="cubic"
# CONFIG_TCP_MD5SIG is not set
# CONFIG_IPV6 is not set
# CONFIG_MPTCP is not set
# CONFIG_NETWORK_SECMARK is not set
CONFIG_NET_PTP_CLASSIFY=y
# CONFIG_NETWORK_PHY_TIMESTAMPING is not set
# CONFIG_NETFILTER is not set
# CONFIG_BPFILTER is not set
# CONFIG_IP_DCCP is not set
# CONFIG_IP_SCTP is not set
# CONFIG_RDS is not set
# CONFIG_TIPC is not set
# CONFIG_ATM is not set
# CONFIG_L2TP is not set
# CONFIG_BRIDGE is not set
# CONFIG_NET_DSA is not set
# CONFIG_VLAN_8021Q is not set
# CONFIG_DECNET is not set
# CONFIG_LLC2 is not set
# CONFIG_ATALK is not set
# CONFIG_X25 is not set
# CONFIG_LAPB is not set
# CONFIG_PHONET is not set
# CONFIG_IEEE802154 is not set
# CONFIG_NET_SCHED is not set
# CONFIG_DCB is not set
CONFIG_DNS_RESOLVER=y
# CONFIG_BATMAN_ADV is not set
# CONFIG_OPENVSWITCH is not set
# CONFIG_VSOCKETS is not set
# CONFIG_NETLINK_DIAG is not set
# CONFIG_MPLS is not set
# CONFIG_NET_NSH is not set
# CONFIG_HSR is not set
# CONFIG_NET_SWITCHDEV is not set
# CONFIG_NET_L3_MASTER_DEV is not set
# CONFIG_QRTR is not set
# CONFIG_NET_NCSI is not set
CONFIG_PCPU_DEV_REFCNT=y
CONFIG_RPS=y
CONFIG_RFS_ACCEL=y
CONFIG_SOCK_RX_QUEUE_MAPPING=y
CONFIG_XPS=y
# CONFIG_CGROUP_NET_PRIO is not set
# CONFIG_CGROUP_NET_CLASSID is not set
CONFIG_NET_RX_BUSY_POLL=y
CONFIG_BQL=y
CONFIG_NET_FLOW_LIMIT=y
# Network testing
# CONFIG_NET_PKTGEN is not set
# end of Network testing
# end of Networking options
# CONFIG_HAMRADIO is not set
CONFIG_CAN=y
CONFIG_CAN_RAW=y
CONFIG_CAN_BCM=y
CONFIG_CAN_GW=y
# CONFIG_CAN_J1939 is not set
# CONFIG_CAN_ISOTP is not set
# CAN Device Drivers
# CONFIG_CAN_VCAN is not set
# CONFIG_CAN_VXCAN is not set
# CONFIG_CAN_SLCAN is not set
CONFIG_CAN_DEV=y
CONFIG_CAN_CALC_BITTIMING=y
# CONFIG_CAN_FLEXCAN is not set
# CONFIG_CAN_GRCAN is not set
CONFIG_CAN_SUN4I=y
# CONFIG_CAN_TI_HECC is not set
# CONFIG_CAN_C_CAN is not set
# CONFIG_CAN_CC770 is not set
# CONFIG_CAN_IFI_CANFD is not set
# CONFIG_CAN_M_CAN is not set
# CONFIG_CAN_RCAR is not set
# CONFIG_CAN_RCAR_CANFD is not set
# CONFIG_CAN_SJA1000 is not set
# CONFIG_CAN_SOFTING is not set
# CAN SPI interfaces
# CONFIG_CAN_HI311X is not set
# CONFIG_CAN_MCP251X is not set
# CONFIG_CAN_MCP251XFD is not set
# end of CAN SPI interfaces
# CAN USB interfaces
# CONFIG_CAN_8DEV_USB is not set
# CONFIG_CAN_EMS_USB is not set
# CONFIG_CAN_ESD_USB2 is not set
# CONFIG_CAN_ETAS_ES58X is not set
# CONFIG_CAN_GS_USB is not set
# CONFIG_CAN_KVASER_USB is not set
# CONFIG_CAN_MCBA_USB is not set
# CONFIG_CAN_PEAK_USB is not set
# CONFIG_CAN_UCAN is not set
# end of CAN USB interfaces
# CONFIG_CAN_DEBUG_DEVICES is not set
# end of CAN Device Drivers
# CONFIG_BT is not set
# CONFIG_AF_RXRPC is not set
# CONFIG_AF_KCM is not set
# CONFIG_MCTP is not set
# CONFIG_WIRELESS is not set
# CONFIG_RFKILL is not set
# CONFIG_NET_9P is not set
# CONFIG_CAIF is not set
# CONFIG_CEPH_LIB is not set
# CONFIG_NFC is not set
# CONFIG_PSAMPLE is not set
# CONFIG_NET_IFE is not set
# CONFIG_LWTUNNEL is not set
CONFIG_NET_SELFTESTS=y
CONFIG_PAGE_POOL=y
# CONFIG_FAILOVER is not set
CONFIG_ETHTOOL_NETLINK=y
# Device Drivers
CONFIG_HAVE_PCI=y
# CONFIG_PCI is not set
# CONFIG_PCCARD is not set
# Generic Driver Options
# CONFIG_UEVENT_HELPER is not set
CONFIG_DEVTMPFS=y
CONFIG_DEVTMPFS_MOUNT=y
CONFIG_STANDALONE=y
CONFIG_PREVENT_FIRMWARE_BUILD=y
# Firmware loader
CONFIG_FW_LOADER=y
CONFIG_EXTRA_FIRMWARE=""
# CONFIG_FW_LOADER_USER_HELPER is not set
# CONFIG_FW_LOADER_COMPRESS is not set
CONFIG_FW_CACHE=y
# end of Firmware loader
CONFIG_ALLOW_DEV_COREDUMP=y
# CONFIG_TEST_ASYNC_DRIVER_PROBE is not set
CONFIG_GENERIC_CPU_AUTOPROBE=y
CONFIG_GENERIC_CPU_VULNERABILITIES=y
CONFIG_SOC_BUS=y
CONFIG_REGMAP=y
CONFIG_REGMAP_I2C=y
CONFIG_REGMAP_SPI=y
CONFIG_REGMAP_MMIO=y
CONFIG_REGMAP_IRQ=y
CONFIG_DMA_SHARED_BUFFER=y
# CONFIG_DMA_FENCE_TRACE is not set
CONFIG_GENERIC_ARCH_TOPOLOGY=y
# end of Generic Driver Options
# Bus devices
CONFIG_ARM_CCI=y
CONFIG_ARM_CCI400_COMMON=y
CONFIG_ARM_CCI400_PORT_CTRL=y
# CONFIG_BRCMSTB_GISB_ARB is not set
# CONFIG_MOXTET is not set
# CONFIG_SUN50I_DE2_BUS is not set
CONFIG_SUNXI_RSB=y
# CONFIG_VEXPRESS_CONFIG is not set
# CONFIG_MHI_BUS is not set
# end of Bus devices
# CONFIG_CONNECTOR is not set
# Firmware Drivers
# ARM System Control and Management Interface Protocol
# CONFIG_ARM_SCMI_PROTOCOL is not set
# end of ARM System Control and Management Interface Protocol
# CONFIG_ARM_SCPI_PROTOCOL is not set
# CONFIG_FW_CFG_SYSFS is not set
# CONFIG_TRUSTED_FOUNDATIONS is not set
# CONFIG_GOOGLE_FIRMWARE is not set
CONFIG_ARM_PSCI_FW=y
CONFIG_HAVE_ARM_SMCCC=y
CONFIG_HAVE_ARM_SMCCC_DISCOVERY=y
CONFIG_ARM_SMCCC_SOC_ID=y
# Tegra firmware driver
# end of Tegra firmware driver
# end of Firmware Drivers
# CONFIG_GNSS is not set
CONFIG_MTD=y
# CONFIG_MTD_TESTS is not set
# Partition parsers
# CONFIG_MTD_AR7_PARTS is not set
# CONFIG_MTD_CMDLINE_PARTS is not set
CONFIG_MTD_OF_PARTS=y
# CONFIG_MTD_AFS_PARTS is not set
# CONFIG_MTD_REDBOOT_PARTS is not set
# end of Partition parsers
# User Modules And Translation Layers
# CONFIG_MTD_BLOCK is not set
# CONFIG_MTD_BLOCK_RO is not set
# CONFIG_FTL is not set
# CONFIG_NFTL is not set
# CONFIG_INFTL is not set
# CONFIG_RFD_FTL is not set
# CONFIG_SSFDC is not set
# CONFIG_SM_FTL is not set
# CONFIG_MTD_OOPS is not set
# CONFIG_MTD_SWAP is not set
# CONFIG_MTD_PARTITIONED_MASTER is not set
# RAM/ROM/Flash chip drivers
# CONFIG_MTD_CFI is not set
# CONFIG_MTD_JEDECPROBE is not set
CONFIG_MTD_MAP_BANK_WIDTH_1=y
CONFIG_MTD_MAP_BANK_WIDTH_2=y
CONFIG_MTD_MAP_BANK_WIDTH_4=y
CONFIG_MTD_CFI_I1=y
CONFIG_MTD_CFI_I2=y
# CONFIG_MTD_RAM is not set
# CONFIG_MTD_ROM is not set
# CONFIG_MTD_ABSENT is not set
# end of RAM/ROM/Flash chip drivers
# Mapping drivers for chip access
# CONFIG_MTD_COMPLEX_MAPPINGS is not set
# CONFIG_MTD_PLATRAM is not set
# end of Mapping drivers for chip access
# Self-contained MTD device drivers
# CONFIG_MTD_DATAFLASH is not set
# CONFIG_MTD_MCHP23K256 is not set
# CONFIG_MTD_MCHP48L640 is not set
# CONFIG_MTD_SST25L is not set
# CONFIG_MTD_SLRAM is not set
# CONFIG_MTD_PHRAM is not set
# CONFIG_MTD_MTDRAM is not set
# CONFIG_MTD_BLOCK2MTD is not set
# Disk-On-Chip Device Drivers
# CONFIG_MTD_DOCG3 is not set
# end of Self-contained MTD device drivers
# NAND
# CONFIG_MTD_ONENAND is not set
# CONFIG_MTD_RAW_NAND is not set
# CONFIG_MTD_SPI_NAND is not set
# ECC engine support
# CONFIG_MTD_NAND_ECC_SW_HAMMING is not set
# CONFIG_MTD_NAND_ECC_SW_BCH is not set
# end of ECC engine support
# end of NAND
# LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_LPDDR is not set
# CONFIG_MTD_LPDDR2_NVM is not set
# end of LPDDR & LPDDR2 PCM memory drivers
# CONFIG_MTD_SPI_NOR is not set
# CONFIG_MTD_UBI is not set
# CONFIG_MTD_HYPERBUS is not set
CONFIG_DTC=y
CONFIG_OF=y
# CONFIG_OF_UNITTEST is not set
CONFIG_OF_FLATTREE=y
CONFIG_OF_EARLY_FLATTREE=y
CONFIG_OF_KOBJ=y
CONFIG_OF_ADDRESS=y
CONFIG_OF_IRQ=y
CONFIG_OF_RESERVED_MEM=y
# CONFIG_OF_OVERLAY is not set
CONFIG_ARCH_MIGHT_HAVE_PC_PARPORT=y
# CONFIG_PARPORT is not set
CONFIG_BLK_DEV=y
# CONFIG_BLK_DEV_NULL_BLK is not set
# CONFIG_BLK_DEV_LOOP is not set
# CONFIG_BLK_DEV_DRBD is not set
# CONFIG_BLK_DEV_NBD is not set
# CONFIG_BLK_DEV_RAM is not set
# CONFIG_CDROM_PKTCDVD is not set
# CONFIG_ATA_OVER_ETH is not set
# CONFIG_BLK_DEV_RBD is not set
# NVME Support
# CONFIG_NVME_FC is not set
# CONFIG_NVME_TCP is not set
# end of NVME Support
# Misc devices
# CONFIG_AD525X_DPOT is not set
# CONFIG_DUMMY_IRQ is not set
# CONFIG_ICS932S401 is not set
# CONFIG_ENCLOSURE_SERVICES is not set
# CONFIG_APDS9802ALS is not set
# CONFIG_ISL29003 is not set
# CONFIG_ISL29020 is not set
# CONFIG_SENSORS_TSL2550 is not set
# CONFIG_SENSORS_BH1770 is not set
# CONFIG_SENSORS_APDS990X is not set
# CONFIG_HMC6352 is not set
# CONFIG_DS1682 is not set
# CONFIG_LATTICE_ECP3_CONFIG is not set
# CONFIG_SRAM is not set
# CONFIG_XILINX_SDFEC is not set
# CONFIG_C2PORT is not set
# EEPROM support
# CONFIG_EEPROM_AT24 is not set
# CONFIG_EEPROM_AT25 is not set
# CONFIG_EEPROM_LEGACY is not set
# CONFIG_EEPROM_MAX6875 is not set
# CONFIG_EEPROM_93CX6 is not set
# CONFIG_EEPROM_93XX46 is not set
# CONFIG_EEPROM_IDT_89HPESX is not set
# CONFIG_EEPROM_EE1004 is not set
# end of EEPROM support
# Texas Instruments shared transport line discipline
# CONFIG_TI_ST is not set
# end of Texas Instruments shared transport line discipline
# CONFIG_SENSORS_LIS3_SPI is not set
# CONFIG_SENSORS_LIS3_I2C is not set
# CONFIG_ALTERA_STAPL is not set
# CONFIG_ECHO is not set
# CONFIG_MISC_RTSX_USB is not set
# CONFIG_PVPANIC is not set
# end of Misc devices
# SCSI device support
CONFIG_SCSI_MOD=y
# CONFIG_RAID_ATTRS is not set
CONFIG_SCSI_COMMON=y
CONFIG_SCSI=y
CONFIG_SCSI_DMA=y
CONFIG_SCSI_PROC_FS=y
# SCSI support type (disk, tape, CD-ROM)
CONFIG_BLK_DEV_SD=y
# CONFIG_CHR_DEV_ST is not set
# CONFIG_BLK_DEV_SR is not set
# CONFIG_CHR_DEV_SG is not set
CONFIG_BLK_DEV_BSG=y
# CONFIG_CHR_DEV_SCH is not set
# CONFIG_SCSI_CONSTANTS is not set
# CONFIG_SCSI_LOGGING is not set
# CONFIG_SCSI_SCAN_ASYNC is not set
# SCSI Transports
# CONFIG_SCSI_SPI_ATTRS is not set
# CONFIG_SCSI_FC_ATTRS is not set
# CONFIG_SCSI_ISCSI_ATTRS is not set
# CONFIG_SCSI_SAS_ATTRS is not set
# CONFIG_SCSI_SAS_LIBSAS is not set
# CONFIG_SCSI_SRP_ATTRS is not set
# end of SCSI Transports
CONFIG_SCSI_LOWLEVEL=y
# CONFIG_ISCSI_TCP is not set
# CONFIG_ISCSI_BOOT_SYSFS is not set
# CONFIG_SCSI_UFSHCD is not set
# CONFIG_SCSI_DEBUG is not set
# CONFIG_SCSI_DH is not set
# end of SCSI device support
CONFIG_ATA=y
CONFIG_SATA_HOST=y
CONFIG_ATA_VERBOSE_ERROR=y
CONFIG_ATA_FORCE=y
CONFIG_SATA_PMP=y
# Controllers with non-SFF native interface
# CONFIG_SATA_AHCI_PLATFORM is not set
# CONFIG_AHCI_CEVA is not set
CONFIG_AHCI_SUNXI=y
# CONFIG_AHCI_QORIQ is not set
CONFIG_ATA_SFF=y
# SFF controllers with custom DMA interface
CONFIG_ATA_BMDMA=y
# SATA SFF controllers with BMDMA
# CONFIG_SATA_DWC is not set
# PATA SFF controllers with BMDMA
# PIO-only SFF controllers
# Generic fallback / legacy drivers
# CONFIG_MD is not set
# CONFIG_TARGET_CORE is not set
CONFIG_NETDEVICES=y
CONFIG_MII=y
CONFIG_NET_CORE=y
# CONFIG_BONDING is not set
# CONFIG_DUMMY is not set
# CONFIG_WIREGUARD is not set
# CONFIG_EQUALIZER is not set
# CONFIG_NET_TEAM is not set
# CONFIG_MACVLAN is not set
# CONFIG_IPVLAN is not set
# CONFIG_VXLAN is not set
# CONFIG_GENEVE is not set
# CONFIG_BAREUDP is not set
# CONFIG_GTP is not set
# CONFIG_MACSEC is not set
# CONFIG_NETCONSOLE is not set
# CONFIG_TUN is not set
# CONFIG_TUN_VNET_CROSS_LE is not set
# CONFIG_VETH is not set
# CONFIG_NLMON is not set
CONFIG_ETHERNET=y
CONFIG_NET_VENDOR_ALACRITECH=y
CONFIG_NET_VENDOR_ALLWINNER=y
CONFIG_SUN4I_EMAC=y
# CONFIG_ALTERA_TSE is not set
CONFIG_NET_VENDOR_AMAZON=y
CONFIG_NET_VENDOR_AQUANTIA=y
# CONFIG_NET_VENDOR_ARC is not set
# CONFIG_NET_VENDOR_BROADCOM is not set
CONFIG_NET_VENDOR_CADENCE=y
# CONFIG_MACB is not set
CONFIG_NET_VENDOR_CAVIUM=y
# CONFIG_NET_VENDOR_CIRRUS is not set
CONFIG_NET_VENDOR_CORTINA=y
# CONFIG_GEMINI_ETHERNET is not set
# CONFIG_DM9000 is not set
# CONFIG_DNET is not set
CONFIG_NET_VENDOR_EZCHIP=y
# CONFIG_EZCHIP_NPS_MANAGEMENT_ENET is not set
# CONFIG_NET_VENDOR_FARADAY is not set
CONFIG_NET_VENDOR_GOOGLE=y
CONFIG_NET_VENDOR_HISILICON=y
# CONFIG_HIX5HD2_GMAC is not set
# CONFIG_HISI_FEMAC is not set
# CONFIG_HIP04_ETH is not set
# CONFIG_HNS_DSAF is not set
# CONFIG_HNS_ENET is not set
CONFIG_NET_VENDOR_HUAWEI=y
# CONFIG_NET_VENDOR_INTEL is not set
CONFIG_NET_VENDOR_LITEX=y
# CONFIG_LITEX_LITEETH is not set
# CONFIG_NET_VENDOR_MARVELL is not set
CONFIG_NET_VENDOR_MELLANOX=y
# CONFIG_MLXSW_CORE is not set
# CONFIG_MLXFW is not set
# CONFIG_NET_VENDOR_MICREL is not set
# CONFIG_NET_VENDOR_MICROCHIP is not set
CONFIG_NET_VENDOR_MICROSEMI=y
CONFIG_NET_VENDOR_MICROSOFT=y
CONFIG_NET_VENDOR_NI=y
# CONFIG_NI_XGE_MANAGEMENT_ENET is not set
# CONFIG_NET_VENDOR_NATSEMI is not set
CONFIG_NET_VENDOR_NETRONOME=y
# CONFIG_ETHOC is not set
CONFIG_NET_VENDOR_PENSANDO=y
CONFIG_NET_VENDOR_QUALCOMM=y
# CONFIG_QCA7000_SPI is not set
# CONFIG_QCOM_EMAC is not set
# CONFIG_RMNET is not set
CONFIG_NET_VENDOR_RENESAS=y
CONFIG_NET_VENDOR_ROCKER=y
# CONFIG_NET_VENDOR_SAMSUNG is not set
# CONFIG_NET_VENDOR_SEEQ is not set
CONFIG_NET_VENDOR_SOLARFLARE=y
# CONFIG_NET_VENDOR_SMSC is not set
CONFIG_NET_VENDOR_SOCIONEXT=y
CONFIG_NET_VENDOR_STMICRO=y
CONFIG_STMMAC_ETH=y
# CONFIG_STMMAC_SELFTESTS is not set
CONFIG_STMMAC_PLATFORM=y
# CONFIG_DWMAC_DWC_QOS_ETH is not set
CONFIG_DWMAC_GENERIC=y
CONFIG_DWMAC_SUNXI=y
CONFIG_DWMAC_SUN8I=y
# CONFIG_DWMAC_INTEL_PLAT is not set
CONFIG_NET_VENDOR_SYNOPSYS=y
# CONFIG_DWC_XLGMAC is not set
# CONFIG_NET_VENDOR_VIA is not set
# CONFIG_NET_VENDOR_WIZNET is not set
CONFIG_NET_VENDOR_XILINX=y
# CONFIG_XILINX_EMACLITE is not set
# CONFIG_XILINX_AXI_EMAC is not set
# CONFIG_XILINX_LL_TEMAC is not set
CONFIG_PHYLINK=y
CONFIG_PHYLIB=y
CONFIG_SWPHY=y
# CONFIG_LED_TRIGGER_PHY is not set
CONFIG_FIXED_PHY=y
# CONFIG_SFP is not set
# MII PHY device drivers
# CONFIG_AMD_PHY is not set
# CONFIG_ADIN_PHY is not set
# CONFIG_AQUANTIA_PHY is not set
# CONFIG_AX88796B_PHY is not set
# CONFIG_BROADCOM_PHY is not set
# CONFIG_BCM54140_PHY is not set
# CONFIG_BCM7XXX_PHY is not set
# CONFIG_BCM84881_PHY is not set
# CONFIG_BCM87XX_PHY is not set
# CONFIG_CICADA_PHY is not set
# CONFIG_CORTINA_PHY is not set
# CONFIG_DAVICOM_PHY is not set
# CONFIG_ICPLUS_PHY is not set
# CONFIG_LXT_PHY is not set
# CONFIG_INTEL_XWAY_PHY is not set
# CONFIG_LSI_ET1011C_PHY is not set
# CONFIG_MARVELL_PHY is not set
# CONFIG_MARVELL_10G_PHY is not set
# CONFIG_MARVELL_88X2222_PHY is not set
# CONFIG_MAXLINEAR_GPHY is not set
# CONFIG_MEDIATEK_GE_PHY is not set
CONFIG_MICREL_PHY=y
# CONFIG_MICROCHIP_PHY is not set
# CONFIG_MICROCHIP_T1_PHY is not set
# CONFIG_MICROSEMI_PHY is not set
# CONFIG_MOTORCOMM_PHY is not set
# CONFIG_NATIONAL_PHY is not set
# CONFIG_NXP_C45_TJA11XX_PHY is not set
# CONFIG_NXP_TJA11XX_PHY is not set
# CONFIG_AT803X_PHY is not set
# CONFIG_QSEMI_PHY is not set
CONFIG_REALTEK_PHY=y
# CONFIG_RENESAS_PHY is not set
# CONFIG_ROCKCHIP_PHY is not set
# CONFIG_SMSC_PHY is not set
# CONFIG_STE10XP is not set
# CONFIG_TERANETICS_PHY is not set
# CONFIG_DP83822_PHY is not set
# CONFIG_DP83TC811_PHY is not set
# CONFIG_DP83848_PHY is not set
# CONFIG_DP83867_PHY is not set
# CONFIG_DP83869_PHY is not set
# CONFIG_VITESSE_PHY is not set
# CONFIG_XILINX_GMII2RGMII is not set
# CONFIG_MICREL_KS8995MA is not set
CONFIG_MDIO_DEVICE=y
CONFIG_MDIO_BUS=y
CONFIG_FWNODE_MDIO=y
CONFIG_OF_MDIO=y
CONFIG_MDIO_DEVRES=y
CONFIG_MDIO_SUN4I=y
# CONFIG_MDIO_BITBANG is not set
# CONFIG_MDIO_BCM_UNIMAC is not set
# CONFIG_MDIO_HISI_FEMAC is not set
# CONFIG_MDIO_MVUSB is not set
# CONFIG_MDIO_MSCC_MIIM is not set
# CONFIG_MDIO_IPQ4019 is not set
# CONFIG_MDIO_IPQ8064 is not set
# MDIO Multiplexers
CONFIG_MDIO_BUS_MUX=y
# CONFIG_MDIO_BUS_MUX_GPIO is not set
# CONFIG_MDIO_BUS_MUX_MULTIPLEXER is not set
# CONFIG_MDIO_BUS_MUX_MMIOREG is not set
# PCS device drivers
CONFIG_PCS_XPCS=y
# end of PCS device drivers
# CONFIG_PPP is not set
# CONFIG_SLIP is not set
CONFIG_USB_NET_DRIVERS=y
# CONFIG_USB_CATC is not set
# CONFIG_USB_KAWETH is not set
# CONFIG_USB_PEGASUS is not set
# CONFIG_USB_RTL8150 is not set
# CONFIG_USB_RTL8152 is not set
# CONFIG_USB_LAN78XX is not set
# CONFIG_USB_USBNET is not set
# CONFIG_USB_IPHETH is not set
# CONFIG_WLAN is not set
# CONFIG_WAN is not set
# Wireless WAN
# CONFIG_WWAN is not set
# end of Wireless WAN
# CONFIG_NETDEVSIM is not set
# CONFIG_NET_FAILOVER is not set
# CONFIG_ISDN is not set
# Input device support
CONFIG_INPUT=y
CONFIG_INPUT_LEDS=y
CONFIG_INPUT_FF_MEMLESS=y
# CONFIG_INPUT_SPARSEKMAP is not set
# CONFIG_INPUT_MATRIXKMAP is not set
# Userland interfaces
# CONFIG_INPUT_MOUSEDEV is not set
# CONFIG_INPUT_JOYDEV is not set
CONFIG_INPUT_EVDEV=y
# CONFIG_INPUT_EVBUG is not set
# Input Device Drivers
CONFIG_INPUT_KEYBOARD=y
# CONFIG_KEYBOARD_ADC is not set
# CONFIG_KEYBOARD_ADP5588 is not set
# CONFIG_KEYBOARD_ADP5589 is not set
CONFIG_KEYBOARD_ATKBD=y
# CONFIG_KEYBOARD_QT1050 is not set
# CONFIG_KEYBOARD_QT1070 is not set
# CONFIG_KEYBOARD_QT2160 is not set
# CONFIG_KEYBOARD_DLINK_DIR685 is not set
# CONFIG_KEYBOARD_LKKBD is not set
# CONFIG_KEYBOARD_GPIO is not set
# CONFIG_KEYBOARD_GPIO_POLLED is not set
# CONFIG_KEYBOARD_TCA6416 is not set
# CONFIG_KEYBOARD_TCA8418 is not set
# CONFIG_KEYBOARD_MATRIX is not set
# CONFIG_KEYBOARD_LM8323 is not set
# CONFIG_KEYBOARD_LM8333 is not set
# CONFIG_KEYBOARD_MAX7359 is not set
# CONFIG_KEYBOARD_MCS is not set
# CONFIG_KEYBOARD_MPR121 is not set
# CONFIG_KEYBOARD_NEWTON is not set
# CONFIG_KEYBOARD_OPENCORES is not set
# CONFIG_KEYBOARD_SAMSUNG is not set
# CONFIG_KEYBOARD_STOWAWAY is not set
# CONFIG_KEYBOARD_SUNKBD is not set
CONFIG_KEYBOARD_SUN4I_LRADC=y
# CONFIG_KEYBOARD_OMAP4 is not set
# CONFIG_KEYBOARD_TM2_TOUCHKEY is not set
# CONFIG_KEYBOARD_XTKBD is not set
# CONFIG_KEYBOARD_CAP11XX is not set
# CONFIG_KEYBOARD_BCM is not set
# CONFIG_INPUT_MOUSE is not set
# CONFIG_INPUT_JOYSTICK is not set
# CONFIG_INPUT_TABLET is not set
CONFIG_INPUT_TOUCHSCREEN=y
# CONFIG_TOUCHSCREEN_ADS7846 is not set
# CONFIG_TOUCHSCREEN_AD7877 is not set
# CONFIG_TOUCHSCREEN_AD7879 is not set
# CONFIG_TOUCHSCREEN_ADC is not set
# CONFIG_TOUCHSCREEN_AR1021_I2C is not set
# CONFIG_TOUCHSCREEN_ATMEL_MXT is not set
# CONFIG_TOUCHSCREEN_AUO_PIXCIR is not set
# CONFIG_TOUCHSCREEN_BU21013 is not set
# CONFIG_TOUCHSCREEN_BU21029 is not set
# CONFIG_TOUCHSCREEN_CHIPONE_ICN8318 is not set
# CONFIG_TOUCHSCREEN_CY8CTMA140 is not set
# CONFIG_TOUCHSCREEN_CY8CTMG110 is not set
# CONFIG_TOUCHSCREEN_CYTTSP_CORE is not set
# CONFIG_TOUCHSCREEN_CYTTSP4_CORE is not set
# CONFIG_TOUCHSCREEN_DYNAPRO is not set
# CONFIG_TOUCHSCREEN_HAMPSHIRE is not set
# CONFIG_TOUCHSCREEN_EETI is not set
# CONFIG_TOUCHSCREEN_EGALAX is not set
# CONFIG_TOUCHSCREEN_EGALAX_SERIAL is not set
# CONFIG_TOUCHSCREEN_EXC3000 is not set
# CONFIG_TOUCHSCREEN_FUJITSU is not set
# CONFIG_TOUCHSCREEN_GOODIX is not set
# CONFIG_TOUCHSCREEN_HIDEEP is not set
# CONFIG_TOUCHSCREEN_HYCON_HY46XX is not set
# CONFIG_TOUCHSCREEN_ILI210X is not set
# CONFIG_TOUCHSCREEN_ILITEK is not set
# CONFIG_TOUCHSCREEN_S6SY761 is not set
# CONFIG_TOUCHSCREEN_GUNZE is not set
# CONFIG_TOUCHSCREEN_EKTF2127 is not set
# CONFIG_TOUCHSCREEN_ELAN is not set
# CONFIG_TOUCHSCREEN_ELO is not set
# CONFIG_TOUCHSCREEN_WACOM_W8001 is not set
# CONFIG_TOUCHSCREEN_WACOM_I2C is not set
# CONFIG_TOUCHSCREEN_MAX11801 is not set
# CONFIG_TOUCHSCREEN_MCS5000 is not set
# CONFIG_TOUCHSCREEN_MMS114 is not set
# CONFIG_TOUCHSCREEN_MELFAS_MIP4 is not set
# CONFIG_TOUCHSCREEN_MSG2638 is not set
# CONFIG_TOUCHSCREEN_MTOUCH is not set
# CONFIG_TOUCHSCREEN_IMX6UL_TSC is not set
# CONFIG_TOUCHSCREEN_INEXIO is not set
# CONFIG_TOUCHSCREEN_MK712 is not set
# CONFIG_TOUCHSCREEN_PENMOUNT is not set
# CONFIG_TOUCHSCREEN_EDT_FT5X06 is not set
# CONFIG_TOUCHSCREEN_TOUCHRIGHT is not set
# CONFIG_TOUCHSCREEN_TOUCHWIN is not set
# CONFIG_TOUCHSCREEN_PIXCIR is not set
# CONFIG_TOUCHSCREEN_WDT87XX_I2C is not set
# CONFIG_TOUCHSCREEN_USB_COMPOSITE is not set
# CONFIG_TOUCHSCREEN_TOUCHIT213 is not set
# CONFIG_TOUCHSCREEN_TSC_SERIO is not set
# CONFIG_TOUCHSCREEN_TSC2004 is not set
# CONFIG_TOUCHSCREEN_TSC2005 is not set
# CONFIG_TOUCHSCREEN_TSC2007 is not set
# CONFIG_TOUCHSCREEN_RM_TS is not set
# CONFIG_TOUCHSCREEN_SILEAD is not set
# CONFIG_TOUCHSCREEN_SIS_I2C is not set
# CONFIG_TOUCHSCREEN_ST1232 is not set
# CONFIG_TOUCHSCREEN_STMFTS is not set
CONFIG_TOUCHSCREEN_SUN4I=y
# CONFIG_TOUCHSCREEN_SURFACE3_SPI is not set
# CONFIG_TOUCHSCREEN_SX8654 is not set
# CONFIG_TOUCHSCREEN_TPS6507X is not set
# CONFIG_TOUCHSCREEN_ZET6223 is not set
# CONFIG_TOUCHSCREEN_ZFORCE is not set
# CONFIG_TOUCHSCREEN_ROHM_BU21023 is not set
# CONFIG_TOUCHSCREEN_IQS5XX is not set
# CONFIG_TOUCHSCREEN_ZINITIX is not set
CONFIG_INPUT_MISC=y
# CONFIG_INPUT_AD714X is not set
# CONFIG_INPUT_ATMEL_CAPTOUCH is not set
# CONFIG_INPUT_BMA150 is not set
# CONFIG_INPUT_E3X0_BUTTON is not set
# CONFIG_INPUT_MMA8450 is not set
# CONFIG_INPUT_GPIO_BEEPER is not set
# CONFIG_INPUT_GPIO_DECODER is not set
# CONFIG_INPUT_GPIO_VIBRA is not set
# CONFIG_INPUT_ATI_REMOTE2 is not set
# CONFIG_INPUT_KEYSPAN_REMOTE is not set
# CONFIG_INPUT_KXTJ9 is not set
# CONFIG_INPUT_POWERMATE is not set
# CONFIG_INPUT_YEALINK is not set
# CONFIG_INPUT_CM109 is not set
# CONFIG_INPUT_REGULATOR_HAPTIC is not set
CONFIG_INPUT_AXP20X_PEK=y
# CONFIG_INPUT_UINPUT is not set
# CONFIG_INPUT_PCF8574 is not set
# CONFIG_INPUT_PWM_BEEPER is not set
# CONFIG_INPUT_PWM_VIBRA is not set
# CONFIG_INPUT_GPIO_ROTARY_ENCODER is not set
# CONFIG_INPUT_DA7280_HAPTICS is not set
# CONFIG_INPUT_ADXL34X is not set
# CONFIG_INPUT_IMS_PCU is not set
# CONFIG_INPUT_IQS269A is not set
# CONFIG_INPUT_IQS626A is not set
# CONFIG_INPUT_CMA3000 is not set
# CONFIG_INPUT_DRV260X_HAPTICS is not set
# CONFIG_INPUT_DRV2665_HAPTICS is not set
# CONFIG_INPUT_DRV2667_HAPTICS is not set
# CONFIG_RMI4_CORE is not set
# Hardware I/O ports
CONFIG_SERIO=y
CONFIG_SERIO_SERPORT=y
CONFIG_SERIO_LIBPS2=y
# CONFIG_SERIO_RAW is not set
# CONFIG_SERIO_ALTERA_PS2 is not set
# CONFIG_SERIO_PS2MULT is not set
# CONFIG_SERIO_ARC_PS2 is not set
# CONFIG_SERIO_APBPS2 is not set
CONFIG_SERIO_SUN4I_PS2=y
# CONFIG_SERIO_GPIO_PS2 is not set
# CONFIG_USERIO is not set
# CONFIG_GAMEPORT is not set
# end of Hardware I/O ports
# end of Input device support
# Character devices
CONFIG_TTY=y
CONFIG_VT=y
CONFIG_CONSOLE_TRANSLATIONS=y
CONFIG_VT_CONSOLE=y
CONFIG_VT_CONSOLE_SLEEP=y
CONFIG_HW_CONSOLE=y
# CONFIG_VT_HW_CONSOLE_BINDING is not set
CONFIG_UNIX98_PTYS=y
CONFIG_LEGACY_PTYS=y
CONFIG_LEGACY_PTY_COUNT=256
CONFIG_LDISC_AUTOLOAD=y
# Serial drivers
CONFIG_SERIAL_EARLYCON=y
CONFIG_SERIAL_8250=y
CONFIG_SERIAL_8250_DEPRECATED_OPTIONS=y
CONFIG_SERIAL_8250_16550A_VARIANTS=y
# CONFIG_SERIAL_8250_FINTEK is not set
CONFIG_SERIAL_8250_CONSOLE=y
CONFIG_SERIAL_8250_DMA=y
CONFIG_SERIAL_8250_NR_UARTS=8
CONFIG_SERIAL_8250_RUNTIME_UARTS=8
# CONFIG_SERIAL_8250_EXTENDED is not set
# CONFIG_SERIAL_8250_ASPEED_VUART is not set
CONFIG_SERIAL_8250_DWLIB=y
CONFIG_SERIAL_8250_FSL=y
CONFIG_SERIAL_8250_DW=y
# CONFIG_SERIAL_8250_EM is not set
# CONFIG_SERIAL_8250_RT288X is not set
CONFIG_SERIAL_OF_PLATFORM=y
# Non-8250 serial port support
# CONFIG_SERIAL_EARLYCON_ARM_SEMIHOST is not set
# CONFIG_SERIAL_MAX3100 is not set
# CONFIG_SERIAL_MAX310X is not set
# CONFIG_SERIAL_UARTLITE is not set
CONFIG_SERIAL_CORE=y
CONFIG_SERIAL_CORE_CONSOLE=y
# CONFIG_SERIAL_SIFIVE is not set
# CONFIG_SERIAL_SCCNXP is not set
# CONFIG_SERIAL_SC16IS7XX is not set
# CONFIG_SERIAL_BCM63XX is not set
# CONFIG_SERIAL_ALTERA_JTAGUART is not set
# CONFIG_SERIAL_ALTERA_UART is not set
# CONFIG_SERIAL_XILINX_PS_UART is not set
# CONFIG_SERIAL_ARC is not set
# CONFIG_SERIAL_FSL_LPUART is not set
# CONFIG_SERIAL_FSL_LINFLEXUART is not set
# CONFIG_SERIAL_CONEXANT_DIGICOLOR is not set
# CONFIG_SERIAL_ST_ASC is not set
# CONFIG_SERIAL_SPRD is not set
# end of Serial drivers
CONFIG_SERIAL_MCTRL_GPIO=y
# CONFIG_SERIAL_NONSTANDARD is not set
# CONFIG_N_GSM is not set
# CONFIG_NULL_TTY is not set
# CONFIG_HVC_DCC is not set
# CONFIG_SERIAL_DEV_BUS is not set
# CONFIG_VIRTIO_CONSOLE is not set
# CONFIG_IPMI_HANDLER is not set
# CONFIG_HW_RANDOM is not set
CONFIG_DEVMEM=y
# CONFIG_TCG_TPM is not set
# CONFIG_XILLYBUS is not set
# CONFIG_XILLYUSB is not set
CONFIG_RANDOM_TRUST_BOOTLOADER=y
# end of Character devices
# I2C support
CONFIG_I2C=y
CONFIG_I2C_BOARDINFO=y
CONFIG_I2C_COMPAT=y
CONFIG_I2C_CHARDEV=y
CONFIG_I2C_MUX=y
# Multiplexer I2C Chip support
# CONFIG_I2C_ARB_GPIO_CHALLENGE is not set
# CONFIG_I2C_MUX_GPIO is not set
# CONFIG_I2C_MUX_GPMUX is not set
# CONFIG_I2C_MUX_LTC4306 is not set
# CONFIG_I2C_MUX_PCA9541 is not set
# CONFIG_I2C_MUX_PCA954x is not set
# CONFIG_I2C_MUX_PINCTRL is not set
# CONFIG_I2C_MUX_REG is not set
# CONFIG_I2C_DEMUX_PINCTRL is not set
# CONFIG_I2C_MUX_MLXCPLD is not set
# end of Multiplexer I2C Chip support
CONFIG_I2C_HELPER_AUTO=y
CONFIG_I2C_ALGOBIT=y
# I2C Hardware Bus support
# I2C system bus drivers (mostly embedded / system-on-chip)
# CONFIG_I2C_CBUS_GPIO is not set
# CONFIG_I2C_DESIGNWARE_PLATFORM is not set
# CONFIG_I2C_EMEV2 is not set
# CONFIG_I2C_GPIO is not set
CONFIG_I2C_MV64XXX=y
# CONFIG_I2C_OCORES is not set
# CONFIG_I2C_PCA_PLATFORM is not set
# CONFIG_I2C_RK3X is not set
# CONFIG_I2C_SIMTEC is not set
CONFIG_I2C_SUN6I_P2WI=y
# CONFIG_I2C_XILINX is not set
# External I2C/SMBus adapter drivers
# CONFIG_I2C_DIOLAN_U2C is not set
# CONFIG_I2C_CP2615 is not set
# CONFIG_I2C_ROBOTFUZZ_OSIF is not set
# CONFIG_I2C_TAOS_EVM is not set
# CONFIG_I2C_TINY_USB is not set
# Other I2C/SMBus bus drivers
# CONFIG_I2C_VIRTIO is not set
# end of I2C Hardware Bus support
# CONFIG_I2C_STUB is not set
# CONFIG_I2C_SLAVE is not set
# CONFIG_I2C_DEBUG_CORE is not set
# CONFIG_I2C_DEBUG_ALGO is not set
# CONFIG_I2C_DEBUG_BUS is not set
# end of I2C support
# CONFIG_I3C is not set
CONFIG_SPI=y
CONFIG_SPI_MASTER=y
# CONFIG_SPI_MEM is not set
# SPI Master Controller Drivers
# CONFIG_SPI_ALTERA is not set
# CONFIG_SPI_AXI_SPI_ENGINE is not set
# CONFIG_SPI_BITBANG is not set
# CONFIG_SPI_CADENCE is not set
# CONFIG_SPI_CADENCE_QUADSPI is not set
# CONFIG_SPI_DESIGNWARE is not set
# CONFIG_SPI_NXP_FLEXSPI is not set
# CONFIG_SPI_GPIO is not set
# CONFIG_SPI_FSL_SPI is not set
# CONFIG_SPI_OC_TINY is not set
# CONFIG_SPI_ROCKCHIP is not set
# CONFIG_SPI_SC18IS602 is not set
# CONFIG_SPI_SIFIVE is not set
CONFIG_SPI_SUN4I=y
CONFIG_SPI_SUN6I=y
# CONFIG_SPI_MXIC is not set
# CONFIG_SPI_XCOMM is not set
# CONFIG_SPI_XILINX is not set
# CONFIG_SPI_ZYNQMP_GQSPI is not set
# CONFIG_SPI_AMD is not set
# SPI Multiplexer support
# CONFIG_SPI_MUX is not set
# SPI Protocol Masters
# CONFIG_SPI_SPIDEV is not set
# CONFIG_SPI_LOOPBACK_TEST is not set
# CONFIG_SPI_TLE62X0 is not set
# CONFIG_SPI_SLAVE is not set
# CONFIG_SPMI is not set
# CONFIG_HSI is not set
CONFIG_PPS=y
# CONFIG_PPS_DEBUG is not set
# PPS clients support
# CONFIG_PPS_CLIENT_KTIMER is not set
# CONFIG_PPS_CLIENT_LDISC is not set
# CONFIG_PPS_CLIENT_GPIO is not set
# PPS generators support
# PTP clock support
CONFIG_PTP_1588_CLOCK=y
CONFIG_PTP_1588_CLOCK_OPTIONAL=y
# Enable PHYLIB and NETWORK_PHY_TIMESTAMPING to see the additional clocks.
CONFIG_PTP_1588_CLOCK_KVM=y
# CONFIG_PTP_1588_CLOCK_IDT82P33 is not set
# CONFIG_PTP_1588_CLOCK_IDTCM is not set
# end of PTP clock support
CONFIG_PINCTRL=y
CONFIG_PINMUX=y
CONFIG_PINCONF=y
CONFIG_GENERIC_PINCONF=y
# CONFIG_PINCTRL_AXP209 is not set
# CONFIG_PINCTRL_MCP23S08 is not set
# CONFIG_PINCTRL_SINGLE is not set
# CONFIG_PINCTRL_SX150X is not set
# CONFIG_PINCTRL_STMFX is not set
# CONFIG_PINCTRL_OCELOT is not set
# CONFIG_PINCTRL_MICROCHIP_SGPIO is not set
# Renesas pinctrl drivers
# end of Renesas pinctrl drivers
CONFIG_PINCTRL_SUNXI=y
CONFIG_PINCTRL_SUN4I_A10=y
CONFIG_PINCTRL_SUN5I=y
CONFIG_PINCTRL_SUN6I_A31=y
CONFIG_PINCTRL_SUN6I_A31_R=y
CONFIG_PINCTRL_SUN8I_A23=y
CONFIG_PINCTRL_SUN8I_A33=y
CONFIG_PINCTRL_SUN8I_A83T=y
CONFIG_PINCTRL_SUN8I_A83T_R=y
CONFIG_PINCTRL_SUN8I_A23_R=y
CONFIG_PINCTRL_SUN8I_H3=y
CONFIG_PINCTRL_SUN8I_H3_R=y
CONFIG_PINCTRL_SUN8I_V3S=y
CONFIG_PINCTRL_SUN9I_A80=y
CONFIG_PINCTRL_SUN9I_A80_R=y
# CONFIG_PINCTRL_SUN50I_A64 is not set
# CONFIG_PINCTRL_SUN50I_A64_R is not set
# CONFIG_PINCTRL_SUN50I_A100 is not set
# CONFIG_PINCTRL_SUN50I_A100_R is not set
# CONFIG_PINCTRL_SUN50I_H5 is not set
# CONFIG_PINCTRL_SUN50I_H6 is not set
# CONFIG_PINCTRL_SUN50I_H6_R is not set
# CONFIG_PINCTRL_SUN50I_H616 is not set
# CONFIG_PINCTRL_SUN50I_H616_R is not set
CONFIG_ARCH_HAVE_CUSTOM_GPIO_H=y
CONFIG_GPIOLIB=y
CONFIG_GPIOLIB_FASTPATH_LIMIT=512
CONFIG_OF_GPIO=y
CONFIG_GPIO_CDEV=y
CONFIG_GPIO_CDEV_V1=y
# Memory mapped GPIO drivers
# CONFIG_GPIO_74XX_MMIO is not set
# CONFIG_GPIO_ALTERA is not set
# CONFIG_GPIO_CADENCE is not set
# CONFIG_GPIO_DWAPB is not set
# CONFIG_GPIO_FTGPIO010 is not set
# CONFIG_GPIO_GENERIC_PLATFORM is not set
# CONFIG_GPIO_GRGPIO is not set
# CONFIG_GPIO_HLWD is not set
# CONFIG_GPIO_LOGICVC is not set
# CONFIG_GPIO_MB86S7X is not set
# CONFIG_GPIO_MPC8XXX is not set
# CONFIG_GPIO_SAMA5D2_PIOBU is not set
# CONFIG_GPIO_SIFIVE is not set
# CONFIG_GPIO_SYSCON is not set
# CONFIG_GPIO_XILINX is not set
# CONFIG_GPIO_ZEVIO is not set
# CONFIG_GPIO_AMD_FCH is not set
# end of Memory mapped GPIO drivers
# I2C GPIO expanders
# CONFIG_GPIO_ADP5588 is not set
# CONFIG_GPIO_ADNP is not set
# CONFIG_GPIO_GW_PLD is not set
# CONFIG_GPIO_MAX7300 is not set
# CONFIG_GPIO_MAX732X is not set
# CONFIG_GPIO_PCA953X is not set
# CONFIG_GPIO_PCA9570 is not set
# CONFIG_GPIO_PCF857X is not set
# CONFIG_GPIO_TPIC2810 is not set
# end of I2C GPIO expanders
# MFD GPIO expanders
# CONFIG_HTC_EGPIO is not set
# end of MFD GPIO expanders
# SPI GPIO expanders
# CONFIG_GPIO_74X164 is not set
# CONFIG_GPIO_MAX3191X is not set
# CONFIG_GPIO_MAX7301 is not set
# CONFIG_GPIO_MC33880 is not set
# CONFIG_GPIO_PISOSR is not set
# CONFIG_GPIO_XRA1403 is not set
# end of SPI GPIO expanders
# USB GPIO expanders
# end of USB GPIO expanders
# Virtual GPIO drivers
# CONFIG_GPIO_AGGREGATOR is not set
# CONFIG_GPIO_MOCKUP is not set
# end of Virtual GPIO drivers
# CONFIG_W1 is not set
# CONFIG_POWER_RESET is not set
CONFIG_POWER_SUPPLY=y
# CONFIG_POWER_SUPPLY_DEBUG is not set
CONFIG_POWER_SUPPLY_HWMON=y
# CONFIG_PDA_POWER is not set
# CONFIG_GENERIC_ADC_BATTERY is not set
# CONFIG_TEST_POWER is not set
# CONFIG_CHARGER_ADP5061 is not set
# CONFIG_BATTERY_CW2015 is not set
# CONFIG_BATTERY_DS2780 is not set
# CONFIG_BATTERY_DS2781 is not set
# CONFIG_BATTERY_DS2782 is not set
# CONFIG_BATTERY_SBS is not set
# CONFIG_CHARGER_SBS is not set
# CONFIG_MANAGER_SBS is not set
# CONFIG_BATTERY_BQ27XXX is not set
CONFIG_CHARGER_AXP20X=y
CONFIG_BATTERY_AXP20X=y
CONFIG_AXP20X_POWER=y
# CONFIG_BATTERY_MAX17040 is not set
# CONFIG_BATTERY_MAX17042 is not set
# CONFIG_CHARGER_ISP1704 is not set
# CONFIG_CHARGER_MAX8903 is not set
# CONFIG_CHARGER_LP8727 is not set
# CONFIG_CHARGER_GPIO is not set
# CONFIG_CHARGER_MANAGER is not set
# CONFIG_CHARGER_LT3651 is not set
# CONFIG_CHARGER_LTC4162L is not set
# CONFIG_CHARGER_DETECTOR_MAX14656 is not set
# CONFIG_CHARGER_BQ2415X is not set
# CONFIG_CHARGER_BQ24190 is not set
# CONFIG_CHARGER_BQ24257 is not set
# CONFIG_CHARGER_BQ24735 is not set
# CONFIG_CHARGER_BQ2515X is not set
# CONFIG_CHARGER_BQ25890 is not set
# CONFIG_CHARGER_BQ25980 is not set
# CONFIG_CHARGER_BQ256XX is not set
# CONFIG_CHARGER_SMB347 is not set
# CONFIG_BATTERY_GAUGE_LTC2941 is not set
# CONFIG_BATTERY_GOLDFISH is not set
# CONFIG_BATTERY_RT5033 is not set
# CONFIG_CHARGER_RT9455 is not set
# CONFIG_CHARGER_UCS1002 is not set
# CONFIG_CHARGER_BD99954 is not set
CONFIG_HWMON=y
# CONFIG_HWMON_DEBUG_CHIP is not set
# Native drivers
# CONFIG_SENSORS_AD7314 is not set
# CONFIG_SENSORS_AD7414 is not set
# CONFIG_SENSORS_AD7418 is not set
# CONFIG_SENSORS_ADM1021 is not set
# CONFIG_SENSORS_ADM1025 is not set
# CONFIG_SENSORS_ADM1026 is not set
# CONFIG_SENSORS_ADM1029 is not set
# CONFIG_SENSORS_ADM1031 is not set
# CONFIG_SENSORS_ADM1177 is not set
# CONFIG_SENSORS_ADM9240 is not set
# CONFIG_SENSORS_ADT7310 is not set
# CONFIG_SENSORS_ADT7410 is not set
# CONFIG_SENSORS_ADT7411 is not set
# CONFIG_SENSORS_ADT7462 is not set
# CONFIG_SENSORS_ADT7470 is not set
# CONFIG_SENSORS_ADT7475 is not set
# CONFIG_SENSORS_AHT10 is not set
# CONFIG_SENSORS_AQUACOMPUTER_D5NEXT is not set
# CONFIG_SENSORS_AS370 is not set
# CONFIG_SENSORS_ASC7621 is not set
# CONFIG_SENSORS_AXI_FAN_CONTROL is not set
# CONFIG_SENSORS_ASPEED is not set
# CONFIG_SENSORS_ATXP1 is not set
# CONFIG_SENSORS_CORSAIR_CPRO is not set
# CONFIG_SENSORS_CORSAIR_PSU is not set
# CONFIG_SENSORS_DRIVETEMP is not set
# CONFIG_SENSORS_DS620 is not set
# CONFIG_SENSORS_DS1621 is not set
# CONFIG_SENSORS_F71805F is not set
# CONFIG_SENSORS_F71882FG is not set
# CONFIG_SENSORS_F75375S is not set
# CONFIG_SENSORS_FTSTEUTATES is not set
# CONFIG_SENSORS_GL518SM is not set
# CONFIG_SENSORS_GL520SM is not set
# CONFIG_SENSORS_G760A is not set
# CONFIG_SENSORS_G762 is not set
# CONFIG_SENSORS_GPIO_FAN is not set
# CONFIG_SENSORS_HIH6130 is not set
# CONFIG_SENSORS_IIO_HWMON is not set
# CONFIG_SENSORS_IT87 is not set
# CONFIG_SENSORS_JC42 is not set
# CONFIG_SENSORS_POWR1220 is not set
# CONFIG_SENSORS_LINEAGE is not set
# CONFIG_SENSORS_LTC2945 is not set
# CONFIG_SENSORS_LTC2947_I2C is not set
# CONFIG_SENSORS_LTC2947_SPI is not set
# CONFIG_SENSORS_LTC2990 is not set
# CONFIG_SENSORS_LTC2992 is not set
# CONFIG_SENSORS_LTC4151 is not set
# CONFIG_SENSORS_LTC4215 is not set
# CONFIG_SENSORS_LTC4222 is not set
# CONFIG_SENSORS_LTC4245 is not set
# CONFIG_SENSORS_LTC4260 is not set
# CONFIG_SENSORS_LTC4261 is not set
# CONFIG_SENSORS_MAX1111 is not set
# CONFIG_SENSORS_MAX127 is not set
# CONFIG_SENSORS_MAX16065 is not set
# CONFIG_SENSORS_MAX1619 is not set
# CONFIG_SENSORS_MAX1668 is not set
# CONFIG_SENSORS_MAX197 is not set
# CONFIG_SENSORS_MAX31722 is not set
# CONFIG_SENSORS_MAX31730 is not set
# CONFIG_SENSORS_MAX6621 is not set
# CONFIG_SENSORS_MAX6639 is not set
# CONFIG_SENSORS_MAX6642 is not set
# CONFIG_SENSORS_MAX6650 is not set
# CONFIG_SENSORS_MAX6697 is not set
# CONFIG_SENSORS_MAX31790 is not set
# CONFIG_SENSORS_MCP3021 is not set
# CONFIG_SENSORS_TC654 is not set
# CONFIG_SENSORS_TPS23861 is not set
# CONFIG_SENSORS_MR75203 is not set
# CONFIG_SENSORS_ADCXX is not set
# CONFIG_SENSORS_LM63 is not set
# CONFIG_SENSORS_LM70 is not set
# CONFIG_SENSORS_LM73 is not set
# CONFIG_SENSORS_LM75 is not set
# CONFIG_SENSORS_LM77 is not set
# CONFIG_SENSORS_LM78 is not set
# CONFIG_SENSORS_LM80 is not set
# CONFIG_SENSORS_LM83 is not set
# CONFIG_SENSORS_LM85 is not set
# CONFIG_SENSORS_LM87 is not set
# CONFIG_SENSORS_LM90 is not set
# CONFIG_SENSORS_LM92 is not set
# CONFIG_SENSORS_LM93 is not set
# CONFIG_SENSORS_LM95234 is not set
# CONFIG_SENSORS_LM95241 is not set
# CONFIG_SENSORS_LM95245 is not set
# CONFIG_SENSORS_PC87360 is not set
# CONFIG_SENSORS_PC87427 is not set
# CONFIG_SENSORS_NTC_THERMISTOR is not set
# CONFIG_SENSORS_NCT6683 is not set
# CONFIG_SENSORS_NCT6775 is not set
# CONFIG_SENSORS_NCT7802 is not set
# CONFIG_SENSORS_NCT7904 is not set
# CONFIG_SENSORS_NPCM7XX is not set
# CONFIG_SENSORS_NZXT_KRAKEN2 is not set
# CONFIG_SENSORS_OCC_P8_I2C is not set
# CONFIG_SENSORS_PCF8591 is not set
# CONFIG_PMBUS is not set
# CONFIG_SENSORS_PWM_FAN is not set
# CONFIG_SENSORS_SBTSI is not set
# CONFIG_SENSORS_SBRMI is not set
# CONFIG_SENSORS_SHT15 is not set
# CONFIG_SENSORS_SHT21 is not set
# CONFIG_SENSORS_SHT3x is not set
# CONFIG_SENSORS_SHT4x is not set
# CONFIG_SENSORS_SHTC1 is not set
# CONFIG_SENSORS_DME1737 is not set
# CONFIG_SENSORS_EMC1403 is not set
# CONFIG_SENSORS_EMC2103 is not set
# CONFIG_SENSORS_EMC6W201 is not set
# CONFIG_SENSORS_SMSC47M1 is not set
# CONFIG_SENSORS_SMSC47M192 is not set
# CONFIG_SENSORS_SMSC47B397 is not set
# CONFIG_SENSORS_SCH5627 is not set
# CONFIG_SENSORS_SCH5636 is not set
# CONFIG_SENSORS_STTS751 is not set
# CONFIG_SENSORS_SMM665 is not set
# CONFIG_SENSORS_ADC128D818 is not set
# CONFIG_SENSORS_ADS7828 is not set
# CONFIG_SENSORS_ADS7871 is not set
# CONFIG_SENSORS_AMC6821 is not set
# CONFIG_SENSORS_INA209 is not set
# CONFIG_SENSORS_INA2XX is not set
# CONFIG_SENSORS_INA3221 is not set
# CONFIG_SENSORS_TC74 is not set
# CONFIG_SENSORS_THMC50 is not set
# CONFIG_SENSORS_TMP102 is not set
# CONFIG_SENSORS_TMP103 is not set
# CONFIG_SENSORS_TMP108 is not set
# CONFIG_SENSORS_TMP401 is not set
# CONFIG_SENSORS_TMP421 is not set
# CONFIG_SENSORS_TMP513 is not set
# CONFIG_SENSORS_VT1211 is not set
# CONFIG_SENSORS_W83773G is not set
# CONFIG_SENSORS_W83781D is not set
# CONFIG_SENSORS_W83791D is not set
# CONFIG_SENSORS_W83792D is not set
# CONFIG_SENSORS_W83793 is not set
# CONFIG_SENSORS_W83795 is not set
# CONFIG_SENSORS_W83L785TS is not set
# CONFIG_SENSORS_W83L786NG is not set
# CONFIG_SENSORS_W83627HF is not set
# CONFIG_SENSORS_W83627EHF is not set
CONFIG_THERMAL=y
# CONFIG_THERMAL_NETLINK is not set
# CONFIG_THERMAL_STATISTICS is not set
CONFIG_THERMAL_EMERGENCY_POWEROFF_DELAY_MS=0
CONFIG_THERMAL_HWMON=y
CONFIG_THERMAL_OF=y
# CONFIG_THERMAL_WRITABLE_TRIPS is not set
CONFIG_THERMAL_DEFAULT_GOV_STEP_WISE=y
# CONFIG_THERMAL_DEFAULT_GOV_FAIR_SHARE is not set
# CONFIG_THERMAL_DEFAULT_GOV_USER_SPACE is not set
# CONFIG_THERMAL_GOV_FAIR_SHARE is not set
CONFIG_THERMAL_GOV_STEP_WISE=y
# CONFIG_THERMAL_GOV_BANG_BANG is not set
# CONFIG_THERMAL_GOV_USER_SPACE is not set
CONFIG_CPU_THERMAL=y
CONFIG_CPU_FREQ_THERMAL=y
# CONFIG_DEVFREQ_THERMAL is not set
# CONFIG_THERMAL_EMULATION is not set
# CONFIG_THERMAL_MMIO is not set
CONFIG_SUN8I_THERMAL=y
# CONFIG_GENERIC_ADC_THERMAL is not set
CONFIG_WATCHDOG=y
CONFIG_WATCHDOG_CORE=y
# CONFIG_WATCHDOG_NOWAYOUT is not set
CONFIG_WATCHDOG_HANDLE_BOOT_ENABLED=y
CONFIG_WATCHDOG_OPEN_TIMEOUT=0
# CONFIG_WATCHDOG_SYSFS is not set
# CONFIG_WATCHDOG_HRTIMER_PRETIMEOUT is not set
# Watchdog Pretimeout Governors
# CONFIG_WATCHDOG_PRETIMEOUT_GOV is not set
# Watchdog Device Drivers
# CONFIG_SOFT_WATCHDOG is not set
# CONFIG_GPIO_WATCHDOG is not set
# CONFIG_XILINX_WATCHDOG is not set
# CONFIG_ZIIRAVE_WATCHDOG is not set
# CONFIG_CADENCE_WATCHDOG is not set
# CONFIG_FTWDT010_WATCHDOG is not set
# CONFIG_DW_WATCHDOG is not set
CONFIG_SUNXI_WATCHDOG=y
# CONFIG_MAX63XX_WATCHDOG is not set
# CONFIG_ARM_SMC_WATCHDOG is not set
# CONFIG_MEN_A21_WDT is not set
# USB-based Watchdog Cards
# CONFIG_USBPCWATCHDOG is not set
CONFIG_SSB_POSSIBLE=y
# CONFIG_SSB is not set
CONFIG_BCMA_POSSIBLE=y
# CONFIG_BCMA is not set
# Multifunction device drivers
CONFIG_MFD_CORE=y
# CONFIG_MFD_ACT8945A is not set
# CONFIG_MFD_AS3711 is not set
# CONFIG_MFD_AS3722 is not set
# CONFIG_PMIC_ADP5520 is not set
# CONFIG_MFD_AAT2870_CORE is not set
# CONFIG_MFD_ATMEL_FLEXCOM is not set
# CONFIG_MFD_ATMEL_HLCDC is not set
# CONFIG_MFD_BCM590XX is not set
# CONFIG_MFD_BD9571MWV is not set
CONFIG_MFD_AC100=y
CONFIG_MFD_AXP20X=y
CONFIG_MFD_AXP20X_I2C=y
CONFIG_MFD_AXP20X_RSB=y
# CONFIG_MFD_MADERA is not set
# CONFIG_MFD_ASIC3 is not set
# CONFIG_PMIC_DA903X is not set
# CONFIG_MFD_DA9052_SPI is not set
# CONFIG_MFD_DA9052_I2C is not set
# CONFIG_MFD_DA9055 is not set
# CONFIG_MFD_DA9062 is not set
# CONFIG_MFD_DA9063 is not set
# CONFIG_MFD_DA9150 is not set
# CONFIG_MFD_DLN2 is not set
# CONFIG_MFD_GATEWORKS_GSC is not set
# CONFIG_MFD_MC13XXX_SPI is not set
# CONFIG_MFD_MC13XXX_I2C is not set
# CONFIG_MFD_MP2629 is not set
# CONFIG_MFD_HI6421_PMIC is not set
# CONFIG_HTC_PASIC3 is not set
# CONFIG_HTC_I2CPLD is not set
# CONFIG_MFD_IQS62X is not set
# CONFIG_MFD_KEMPLD is not set
# CONFIG_MFD_88PM800 is not set
# CONFIG_MFD_88PM805 is not set
# CONFIG_MFD_88PM860X is not set
# CONFIG_MFD_MAX14577 is not set
# CONFIG_MFD_MAX77620 is not set
# CONFIG_MFD_MAX77650 is not set
# CONFIG_MFD_MAX77686 is not set
# CONFIG_MFD_MAX77693 is not set
# CONFIG_MFD_MAX77843 is not set
# CONFIG_MFD_MAX8907 is not set
# CONFIG_MFD_MAX8925 is not set
# CONFIG_MFD_MAX8997 is not set
# CONFIG_MFD_MAX8998 is not set
# CONFIG_MFD_MT6360 is not set
# CONFIG_MFD_MT6397 is not set
# CONFIG_MFD_MENF21BMC is not set
# CONFIG_EZX_PCAP is not set
# CONFIG_MFD_CPCAP is not set
# CONFIG_MFD_VIPERBOARD is not set
# CONFIG_MFD_NTXEC is not set
# CONFIG_MFD_RETU is not set
# CONFIG_MFD_PCF50633 is not set
# CONFIG_MFD_PM8XXX is not set
# CONFIG_MFD_RT4831 is not set
# CONFIG_MFD_RT5033 is not set
# CONFIG_MFD_RC5T583 is not set
# CONFIG_MFD_RK808 is not set
# CONFIG_MFD_RN5T618 is not set
# CONFIG_MFD_SEC_CORE is not set
# CONFIG_MFD_SI476X_CORE is not set
# CONFIG_MFD_SM501 is not set
# CONFIG_MFD_SKY81452 is not set
# CONFIG_MFD_STMPE is not set
CONFIG_MFD_SUN6I_PRCM=y
CONFIG_MFD_SYSCON=y
# CONFIG_MFD_TI_AM335X_TSCADC is not set
# CONFIG_MFD_LP3943 is not set
# CONFIG_MFD_LP8788 is not set
# CONFIG_MFD_TI_LMU is not set
# CONFIG_MFD_PALMAS is not set
# CONFIG_TPS6105X is not set
# CONFIG_TPS65010 is not set
# CONFIG_TPS6507X is not set
# CONFIG_MFD_TPS65086 is not set
# CONFIG_MFD_TPS65090 is not set
# CONFIG_MFD_TPS65217 is not set
# CONFIG_MFD_TI_LP873X is not set
# CONFIG_MFD_TI_LP87565 is not set
# CONFIG_MFD_TPS65218 is not set
# CONFIG_MFD_TPS6586X is not set
# CONFIG_MFD_TPS65910 is not set
# CONFIG_MFD_TPS65912_I2C is not set
# CONFIG_MFD_TPS65912_SPI is not set
# CONFIG_MFD_TPS80031 is not set
# CONFIG_TWL4030_CORE is not set
# CONFIG_TWL6040_CORE is not set
# CONFIG_MFD_WL1273_CORE is not set
# CONFIG_MFD_LM3533 is not set
# CONFIG_MFD_TC3589X is not set
# CONFIG_MFD_T7L66XB is not set
# CONFIG_MFD_TC6387XB is not set
# CONFIG_MFD_TC6393XB is not set
# CONFIG_MFD_TQMX86 is not set
# CONFIG_MFD_LOCHNAGAR is not set
# CONFIG_MFD_ARIZONA_I2C is not set
# CONFIG_MFD_ARIZONA_SPI is not set
# CONFIG_MFD_WM8400 is not set
# CONFIG_MFD_WM831X_I2C is not set
# CONFIG_MFD_WM831X_SPI is not set
# CONFIG_MFD_WM8350_I2C is not set
# CONFIG_MFD_WM8994 is not set
# CONFIG_MFD_ROHM_BD718XX is not set
# CONFIG_MFD_ROHM_BD70528 is not set
# CONFIG_MFD_ROHM_BD71828 is not set
# CONFIG_MFD_ROHM_BD957XMUF is not set
# CONFIG_MFD_STPMIC1 is not set
# CONFIG_MFD_STMFX is not set
# CONFIG_MFD_ATC260X_I2C is not set
# CONFIG_MFD_QCOM_PM8008 is not set
# CONFIG_MFD_INTEL_M10_BMC is not set
# CONFIG_MFD_RSMU_I2C is not set
# CONFIG_MFD_RSMU_SPI is not set
# end of Multifunction device drivers
CONFIG_REGULATOR=y
# CONFIG_REGULATOR_DEBUG is not set
CONFIG_REGULATOR_FIXED_VOLTAGE=y
# CONFIG_REGULATOR_VIRTUAL_CONSUMER is not set
# CONFIG_REGULATOR_USERSPACE_CONSUMER is not set
# CONFIG_REGULATOR_88PG86X is not set
# CONFIG_REGULATOR_ACT8865 is not set
# CONFIG_REGULATOR_AD5398 is not set
CONFIG_REGULATOR_AXP20X=y
# CONFIG_REGULATOR_DA9121 is not set
# CONFIG_REGULATOR_DA9210 is not set
# CONFIG_REGULATOR_DA9211 is not set
# CONFIG_REGULATOR_FAN53555 is not set
# CONFIG_REGULATOR_FAN53880 is not set
CONFIG_REGULATOR_GPIO=y
# CONFIG_REGULATOR_ISL9305 is not set
# CONFIG_REGULATOR_ISL6271A is not set
# CONFIG_REGULATOR_LP3971 is not set
# CONFIG_REGULATOR_LP3972 is not set
# CONFIG_REGULATOR_LP872X is not set
# CONFIG_REGULATOR_LP8755 is not set
# CONFIG_REGULATOR_LTC3589 is not set
# CONFIG_REGULATOR_LTC3676 is not set
# CONFIG_REGULATOR_MAX1586 is not set
# CONFIG_REGULATOR_MAX8649 is not set
# CONFIG_REGULATOR_MAX8660 is not set
# CONFIG_REGULATOR_MAX8893 is not set
# CONFIG_REGULATOR_MAX8952 is not set
# CONFIG_REGULATOR_MAX8973 is not set
# CONFIG_REGULATOR_MAX77826 is not set
# CONFIG_REGULATOR_MCP16502 is not set
# CONFIG_REGULATOR_MP5416 is not set
# CONFIG_REGULATOR_MP8859 is not set
# CONFIG_REGULATOR_MP886X is not set
# CONFIG_REGULATOR_MPQ7920 is not set
# CONFIG_REGULATOR_MT6311 is not set
# CONFIG_REGULATOR_PCA9450 is not set
# CONFIG_REGULATOR_PF8X00 is not set
# CONFIG_REGULATOR_PFUZE100 is not set
# CONFIG_REGULATOR_PV88060 is not set
# CONFIG_REGULATOR_PV88080 is not set
# CONFIG_REGULATOR_PV88090 is not set
# CONFIG_REGULATOR_PWM is not set
# CONFIG_REGULATOR_RASPBERRYPI_TOUCHSCREEN_ATTINY is not set
# CONFIG_REGULATOR_RT4801 is not set
# CONFIG_REGULATOR_RT6160 is not set
# CONFIG_REGULATOR_RT6245 is not set
# CONFIG_REGULATOR_RTQ2134 is not set
# CONFIG_REGULATOR_RTMV20 is not set
# CONFIG_REGULATOR_RTQ6752 is not set
# CONFIG_REGULATOR_SLG51000 is not set
# CONFIG_REGULATOR_SY8106A is not set
# CONFIG_REGULATOR_SY8824X is not set
# CONFIG_REGULATOR_SY8827N is not set
# CONFIG_REGULATOR_TPS51632 is not set
# CONFIG_REGULATOR_TPS62360 is not set
# CONFIG_REGULATOR_TPS65023 is not set
# CONFIG_REGULATOR_TPS6507X is not set
# CONFIG_REGULATOR_TPS65132 is not set
# CONFIG_REGULATOR_TPS6524X is not set
# CONFIG_REGULATOR_VCTRL is not set
CONFIG_RC_CORE=y
CONFIG_RC_MAP=y
# CONFIG_LIRC is not set
# CONFIG_RC_DECODERS is not set
CONFIG_RC_DEVICES=y
# CONFIG_RC_ATI_REMOTE is not set
# CONFIG_IR_HIX5HD2 is not set
# CONFIG_IR_IMON is not set
# CONFIG_IR_IMON_RAW is not set
# CONFIG_IR_MCEUSB is not set
# CONFIG_IR_REDRAT3 is not set
# CONFIG_IR_STREAMZAP is not set
# CONFIG_IR_IGORPLUGUSB is not set
# CONFIG_IR_IGUANA is not set
# CONFIG_IR_TTUSBIR is not set
# CONFIG_RC_LOOPBACK is not set
# CONFIG_IR_GPIO_CIR is not set
CONFIG_IR_SUNXI=y
# CONFIG_IR_SERIAL is not set
# CONFIG_IR_SIR is not set
# CONFIG_RC_XBOX_DVD is not set
# CONFIG_IR_TOY is not set
CONFIG_CEC_CORE=y
CONFIG_CEC_PIN=y
# CONFIG_MEDIA_CEC_RC is not set
# CONFIG_CEC_PIN_ERROR_INJ is not set
# CONFIG_MEDIA_CEC_SUPPORT is not set
CONFIG_MEDIA_SUPPORT=y
CONFIG_MEDIA_SUPPORT_FILTER=y
CONFIG_MEDIA_SUBDRV_AUTOSELECT=y
# Media device types
# CONFIG_MEDIA_CAMERA_SUPPORT is not set
# CONFIG_MEDIA_ANALOG_TV_SUPPORT is not set
# CONFIG_MEDIA_DIGITAL_TV_SUPPORT is not set
# CONFIG_MEDIA_RADIO_SUPPORT is not set
# CONFIG_MEDIA_SDR_SUPPORT is not set
CONFIG_MEDIA_PLATFORM_SUPPORT=y
# CONFIG_MEDIA_TEST_SUPPORT is not set
# end of Media device types
CONFIG_VIDEO_DEV=y
CONFIG_MEDIA_CONTROLLER=y
# Video4Linux options
CONFIG_VIDEO_V4L2=y
CONFIG_VIDEO_V4L2_I2C=y
CONFIG_VIDEO_V4L2_SUBDEV_API=y
# CONFIG_VIDEO_ADV_DEBUG is not set
# CONFIG_VIDEO_FIXED_MINOR_RANGES is not set
CONFIG_V4L2_MEM2MEM_DEV=y
CONFIG_V4L2_FWNODE=y
CONFIG_V4L2_ASYNC=y
# end of Video4Linux options
# Media controller options
CONFIG_MEDIA_CONTROLLER_REQUEST_API=y
# Please notice that the enabled Media controller Request API is EXPERIMENTAL
# end of Media controller options
# Media drivers
# Drivers filtered as selected at 'Filter media drivers'
# CONFIG_MEDIA_USB_SUPPORT is not set
CONFIG_VIDEOBUF2_CORE=y
CONFIG_VIDEOBUF2_V4L2=y
CONFIG_VIDEOBUF2_MEMOPS=y
CONFIG_VIDEOBUF2_DMA_CONTIG=y
CONFIG_V4L_PLATFORM_DRIVERS=y
# CONFIG_VIDEO_CADENCE is not set
# CONFIG_VIDEO_ASPEED is not set
# CONFIG_VIDEO_MUX is not set
# CONFIG_VIDEO_XILINX is not set
CONFIG_VIDEO_SUN4I_CSI=y
CONFIG_VIDEO_SUN6I_CSI=y
CONFIG_V4L_MEM2MEM_DRIVERS=y
# CONFIG_VIDEO_MEM2MEM_DEINTERLACE is not set
CONFIG_VIDEO_SUN8I_DEINTERLACE=y
CONFIG_VIDEO_SUN8I_ROTATE=y
# end of Media drivers
CONFIG_MEDIA_HIDE_ANCILLARY_SUBDRV=y
# Media ancillary drivers
# IR I2C driver auto-selected by 'Autoselect ancillary drivers'
CONFIG_VIDEO_IR_I2C=y
# audio, video and radio I2C drivers auto-selected by 'Autoselect ancillary drivers'
# Video and audio decoders
# SPI I2C drivers auto-selected by 'Autoselect ancillary drivers'
# Media SPI Adapters
# end of Media SPI Adapters
# end of Media ancillary drivers
# Graphics support
# CONFIG_IMX_IPUV3_CORE is not set
CONFIG_DRM=y
CONFIG_DRM_MIPI_DSI=y
CONFIG_DRM_DP_AUX_BUS=y
# CONFIG_DRM_DP_AUX_CHARDEV is not set
# CONFIG_DRM_DEBUG_MM is not set
CONFIG_DRM_KMS_HELPER=y
# CONFIG_DRM_LOAD_EDID_FIRMWARE is not set
# CONFIG_DRM_DP_CEC is not set
CONFIG_DRM_GEM_CMA_HELPER=y
CONFIG_DRM_KMS_CMA_HELPER=y
CONFIG_DRM_GEM_SHMEM_HELPER=y
CONFIG_DRM_SCHED=y
# I2C encoder or helper chips
# CONFIG_DRM_I2C_CH7006 is not set
# CONFIG_DRM_I2C_SIL164 is not set
# CONFIG_DRM_I2C_NXP_TDA998X is not set
# CONFIG_DRM_I2C_NXP_TDA9950 is not set
# end of I2C encoder or helper chips
# ARM devices
# CONFIG_DRM_HDLCD is not set
# CONFIG_DRM_MALI_DISPLAY is not set
# CONFIG_DRM_KOMEDA is not set
# end of ARM devices
# CONFIG_DRM_VGEM is not set
# CONFIG_DRM_VKMS is not set
# CONFIG_DRM_EXYNOS is not set
# CONFIG_DRM_UDL is not set
# CONFIG_DRM_ARMADA is not set
# CONFIG_DRM_RCAR_DW_HDMI is not set
# CONFIG_DRM_RCAR_LVDS is not set
CONFIG_DRM_SUN4I=y
CONFIG_DRM_SUN4I_HDMI=y
CONFIG_DRM_SUN4I_HDMI_CEC=y
CONFIG_DRM_SUN4I_BACKEND=y
CONFIG_DRM_SUN6I_DSI=y
CONFIG_DRM_SUN8I_DW_HDMI=y
CONFIG_DRM_SUN8I_MIXER=y
CONFIG_DRM_SUN8I_TCON_TOP=y
# CONFIG_DRM_OMAP is not set
# CONFIG_DRM_TILCDC is not set
# CONFIG_DRM_VIRTIO_GPU is not set
# CONFIG_DRM_FSL_DCU is not set
# CONFIG_DRM_STM is not set
CONFIG_DRM_PANEL=y
# Display Panels
# CONFIG_DRM_PANEL_ABT_Y030XX067A is not set
# CONFIG_DRM_PANEL_ARM_VERSATILE is not set
# CONFIG_DRM_PANEL_ASUS_Z00T_TM5P5_NT35596 is not set
# CONFIG_DRM_PANEL_BOE_HIMAX8279D is not set
# CONFIG_DRM_PANEL_BOE_TV101WUM_NL6 is not set
# CONFIG_DRM_PANEL_DSI_CM is not set
CONFIG_DRM_PANEL_LVDS=y
CONFIG_DRM_PANEL_SIMPLE=y
# CONFIG_DRM_PANEL_ELIDA_KD35T133 is not set
# CONFIG_DRM_PANEL_FEIXIN_K101_IM2BA02 is not set
# CONFIG_DRM_PANEL_FEIYANG_FY07024DI26A30D is not set
# CONFIG_DRM_PANEL_ILITEK_IL9322 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9341 is not set
# CONFIG_DRM_PANEL_ILITEK_ILI9881C is not set
# CONFIG_DRM_PANEL_INNOLUX_EJ030NA is not set
# CONFIG_DRM_PANEL_INNOLUX_P079ZCA is not set
# CONFIG_DRM_PANEL_JDI_LT070ME05000 is not set
# CONFIG_DRM_PANEL_KHADAS_TS050 is not set
# CONFIG_DRM_PANEL_KINGDISPLAY_KD097D04 is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK050H3146W is not set
# CONFIG_DRM_PANEL_LEADTEK_LTK500HD1829 is not set
# CONFIG_DRM_PANEL_SAMSUNG_LD9040 is not set
# CONFIG_DRM_PANEL_LG_LB035Q02 is not set
# CONFIG_DRM_PANEL_LG_LG4573 is not set
# CONFIG_DRM_PANEL_NEC_NL8048HL11 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT35510 is not set
# CONFIG_DRM_PANEL_NOVATEK_NT36672A is not set
# CONFIG_DRM_PANEL_NOVATEK_NT39016 is not set
# CONFIG_DRM_PANEL_MANTIX_MLAF057WE51 is not set
# CONFIG_DRM_PANEL_OLIMEX_LCD_OLINUXINO is not set
# CONFIG_DRM_PANEL_ORISETECH_OTM8009A is not set
# CONFIG_DRM_PANEL_OSD_OSD101T2587_53TS is not set
# CONFIG_DRM_PANEL_PANASONIC_VVX10F034N00 is not set
# CONFIG_DRM_PANEL_RASPBERRYPI_TOUCHSCREEN is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM67191 is not set
# CONFIG_DRM_PANEL_RAYDIUM_RM68200 is not set
# CONFIG_DRM_PANEL_RONBO_RB070D30 is not set
# CONFIG_DRM_PANEL_SAMSUNG_ATNA33XC20 is not set
# CONFIG_DRM_PANEL_SAMSUNG_DB7430 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6D16D0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E3HA2 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63J0X03 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E63M0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E88A0_AMS452EF01 is not set
# CONFIG_DRM_PANEL_SAMSUNG_S6E8AA0 is not set
# CONFIG_DRM_PANEL_SAMSUNG_SOFEF00 is not set
# CONFIG_DRM_PANEL_SEIKO_43WVF1G is not set
# CONFIG_DRM_PANEL_SHARP_LQ101R1SX01 is not set
# CONFIG_DRM_PANEL_SHARP_LS037V7DW01 is not set
# CONFIG_DRM_PANEL_SHARP_LS043T1LE01 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7701 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7703 is not set
# CONFIG_DRM_PANEL_SITRONIX_ST7789V is not set
# CONFIG_DRM_PANEL_SONY_ACX424AKP is not set
# CONFIG_DRM_PANEL_SONY_ACX565AKM is not set
# CONFIG_DRM_PANEL_TDO_TL070WSH30 is not set
# CONFIG_DRM_PANEL_TPO_TD028TTEC1 is not set
# CONFIG_DRM_PANEL_TPO_TD043MTEA1 is not set
# CONFIG_DRM_PANEL_TPO_TPG110 is not set
# CONFIG_DRM_PANEL_TRULY_NT35597_WQXGA is not set
# CONFIG_DRM_PANEL_VISIONOX_RM69299 is not set
# CONFIG_DRM_PANEL_WIDECHIPS_WS2401 is not set
# CONFIG_DRM_PANEL_XINPENG_XPP055C272 is not set
# end of Display Panels
CONFIG_DRM_BRIDGE=y
CONFIG_DRM_PANEL_BRIDGE=y
# Display Interface Bridges
# CONFIG_DRM_CDNS_DSI is not set
# CONFIG_DRM_CHIPONE_ICN6211 is not set
# CONFIG_DRM_CHRONTEL_CH7033 is not set
# CONFIG_DRM_DISPLAY_CONNECTOR is not set
# CONFIG_DRM_LONTIUM_LT8912B is not set
# CONFIG_DRM_LONTIUM_LT9611 is not set
# CONFIG_DRM_LONTIUM_LT9611UXC is not set
# CONFIG_DRM_ITE_IT66121 is not set
# CONFIG_DRM_LVDS_CODEC is not set
# CONFIG_DRM_MEGACHIPS_STDPXXXX_GE_B850V3_FW is not set
# CONFIG_DRM_NWL_MIPI_DSI is not set
# CONFIG_DRM_NXP_PTN3460 is not set
# CONFIG_DRM_PARADE_PS8622 is not set
# CONFIG_DRM_PARADE_PS8640 is not set
# CONFIG_DRM_SIL_SII8620 is not set
# CONFIG_DRM_SII902X is not set
# CONFIG_DRM_SII9234 is not set
CONFIG_DRM_SIMPLE_BRIDGE=y
# CONFIG_DRM_THINE_THC63LVD1024 is not set
# CONFIG_DRM_TOSHIBA_TC358762 is not set
# CONFIG_DRM_TOSHIBA_TC358764 is not set
# CONFIG_DRM_TOSHIBA_TC358767 is not set
# CONFIG_DRM_TOSHIBA_TC358768 is not set
# CONFIG_DRM_TOSHIBA_TC358775 is not set
# CONFIG_DRM_TI_TFP410 is not set
# CONFIG_DRM_TI_SN65DSI83 is not set
# CONFIG_DRM_TI_SN65DSI86 is not set
# CONFIG_DRM_TI_TPD12S015 is not set
# CONFIG_DRM_ANALOGIX_ANX6345 is not set
# CONFIG_DRM_ANALOGIX_ANX78XX is not set
# CONFIG_DRM_ANALOGIX_ANX7625 is not set
# CONFIG_DRM_I2C_ADV7511 is not set
# CONFIG_DRM_CDNS_MHDP8546 is not set
CONFIG_DRM_DW_HDMI=y
# CONFIG_DRM_DW_HDMI_AHB_AUDIO is not set
# CONFIG_DRM_DW_HDMI_I2S_AUDIO is not set
# CONFIG_DRM_DW_HDMI_CEC is not set
# end of Display Interface Bridges
# CONFIG_DRM_STI is not set
# CONFIG_DRM_ETNAVIV is not set
# CONFIG_DRM_ARCPGU is not set
# CONFIG_DRM_GM12U320 is not set
# CONFIG_DRM_SIMPLEDRM is not set
# CONFIG_TINYDRM_HX8357D is not set
# CONFIG_TINYDRM_ILI9225 is not set
# CONFIG_TINYDRM_ILI9341 is not set
# CONFIG_TINYDRM_ILI9486 is not set
# CONFIG_TINYDRM_MI0283QT is not set
# CONFIG_TINYDRM_REPAPER is not set
# CONFIG_TINYDRM_ST7586 is not set
# CONFIG_TINYDRM_ST7735R is not set
# CONFIG_DRM_PL111 is not set
# CONFIG_DRM_TVE200 is not set
CONFIG_DRM_LIMA=y
# CONFIG_DRM_PANFROST is not set
# CONFIG_DRM_MCDE is not set
# CONFIG_DRM_TIDSS is not set
# CONFIG_DRM_GUD is not set
# CONFIG_DRM_LEGACY is not set
CONFIG_DRM_PANEL_ORIENTATION_QUIRKS=y
# Frame buffer Devices
CONFIG_FB_CMDLINE=y
# CONFIG_FB is not set
# end of Frame buffer Devices
# Backlight & LCD device support
# CONFIG_LCD_CLASS_DEVICE is not set
CONFIG_BACKLIGHT_CLASS_DEVICE=y
# CONFIG_BACKLIGHT_KTD253 is not set
CONFIG_BACKLIGHT_PWM=y
# CONFIG_BACKLIGHT_QCOM_WLED is not set
# CONFIG_BACKLIGHT_ADP8860 is not set
# CONFIG_BACKLIGHT_ADP8870 is not set
# CONFIG_BACKLIGHT_LM3630A is not set
# CONFIG_BACKLIGHT_LM3639 is not set
# CONFIG_BACKLIGHT_LP855X is not set
# CONFIG_BACKLIGHT_GPIO is not set
# CONFIG_BACKLIGHT_LV5207LP is not set
# CONFIG_BACKLIGHT_BD6107 is not set
# CONFIG_BACKLIGHT_ARCXCNN is not set
# CONFIG_BACKLIGHT_LED is not set
# end of Backlight & LCD device support
CONFIG_VIDEOMODE_HELPERS=y
CONFIG_HDMI=y
# Console display driver support
CONFIG_DUMMY_CONSOLE=y
# end of Console display driver support
# end of Graphics support
CONFIG_SOUND=y
CONFIG_SND=y
CONFIG_SND_TIMER=y
CONFIG_SND_PCM=y
CONFIG_SND_DMAENGINE_PCM=y
CONFIG_SND_JACK=y
CONFIG_SND_JACK_INPUT_DEV=y
# CONFIG_SND_OSSEMUL is not set
CONFIG_SND_PCM_TIMER=y
# CONFIG_SND_HRTIMER is not set
# CONFIG_SND_DYNAMIC_MINORS is not set
CONFIG_SND_SUPPORT_OLD_API=y
CONFIG_SND_PROC_FS=y
CONFIG_SND_VERBOSE_PROCFS=y
# CONFIG_SND_VERBOSE_PRINTK is not set
# CONFIG_SND_DEBUG is not set
# CONFIG_SND_SEQUENCER is not set
CONFIG_SND_DRIVERS=y
# CONFIG_SND_DUMMY is not set
# CONFIG_SND_ALOOP is not set
# CONFIG_SND_MTPAV is not set
# CONFIG_SND_SERIAL_U16550 is not set
# CONFIG_SND_MPU401 is not set
# HD-Audio
# end of HD-Audio
CONFIG_SND_HDA_PREALLOC_SIZE=64
CONFIG_SND_ARM=y
CONFIG_SND_SPI=y
CONFIG_SND_USB=y
# CONFIG_SND_USB_AUDIO is not set
# CONFIG_SND_USB_UA101 is not set
# CONFIG_SND_USB_CAIAQ is not set
# CONFIG_SND_USB_6FIRE is not set
# CONFIG_SND_USB_HIFACE is not set
# CONFIG_SND_BCD2000 is not set
# CONFIG_SND_USB_POD is not set
# CONFIG_SND_USB_PODHD is not set
# CONFIG_SND_USB_TONEPORT is not set
# CONFIG_SND_USB_VARIAX is not set
CONFIG_SND_SOC=y
CONFIG_SND_SOC_GENERIC_DMAENGINE_PCM=y
# CONFIG_SND_SOC_ADI is not set
# CONFIG_SND_SOC_AMD_ACP is not set
# CONFIG_SND_ATMEL_SOC is not set
# CONFIG_SND_BCM63XX_I2S_WHISTLER is not set
# CONFIG_SND_DESIGNWARE_I2S is not set
# SoC Audio for Freescale CPUs
# Common SoC Audio options for Freescale CPUs:
# CONFIG_SND_SOC_FSL_ASRC is not set
# CONFIG_SND_SOC_FSL_SAI is not set
# CONFIG_SND_SOC_FSL_AUDMIX is not set
# CONFIG_SND_SOC_FSL_SSI is not set
# CONFIG_SND_SOC_FSL_SPDIF is not set
# CONFIG_SND_SOC_FSL_ESAI is not set
# CONFIG_SND_SOC_FSL_MICFIL is not set
# CONFIG_SND_SOC_FSL_XCVR is not set
# CONFIG_SND_SOC_IMX_AUDMUX is not set
# end of SoC Audio for Freescale CPUs
# CONFIG_SND_I2S_HI6210_I2S is not set
# CONFIG_SND_SOC_IMG is not set
# CONFIG_SND_SOC_MTK_BTCVSD is not set
# CONFIG_SND_SOC_SOF_TOPLEVEL is not set
# STMicroelectronics STM32 SOC audio support
# end of STMicroelectronics STM32 SOC audio support
# Allwinner SoC Audio support
CONFIG_SND_SUN4I_CODEC=y
CONFIG_SND_SUN8I_CODEC=y
CONFIG_SND_SUN8I_CODEC_ANALOG=y
CONFIG_SND_SUN4I_I2S=y
CONFIG_SND_SUN4I_SPDIF=y
CONFIG_SND_SUN8I_ADDA_PR_REGMAP=y
# end of Allwinner SoC Audio support
# CONFIG_SND_SOC_XILINX_I2S is not set
# CONFIG_SND_SOC_XILINX_AUDIO_FORMATTER is not set
# CONFIG_SND_SOC_XILINX_SPDIF is not set
# CONFIG_SND_SOC_XTFPGA_I2S is not set
CONFIG_SND_SOC_I2C_AND_SPI=y
# CODEC drivers
# CONFIG_SND_SOC_AC97_CODEC is not set
# CONFIG_SND_SOC_ADAU1372_I2C is not set
# CONFIG_SND_SOC_ADAU1372_SPI is not set
# CONFIG_SND_SOC_ADAU1701 is not set
# CONFIG_SND_SOC_ADAU1761_I2C is not set
# CONFIG_SND_SOC_ADAU1761_SPI is not set
# CONFIG_SND_SOC_ADAU7002 is not set
# CONFIG_SND_SOC_ADAU7118_HW is not set
# CONFIG_SND_SOC_ADAU7118_I2C is not set
# CONFIG_SND_SOC_AK4104 is not set
# CONFIG_SND_SOC_AK4118 is not set
# CONFIG_SND_SOC_AK4458 is not set
# CONFIG_SND_SOC_AK4554 is not set
# CONFIG_SND_SOC_AK4613 is not set
# CONFIG_SND_SOC_AK4642 is not set
# CONFIG_SND_SOC_AK5386 is not set
# CONFIG_SND_SOC_AK5558 is not set
# CONFIG_SND_SOC_ALC5623 is not set
# CONFIG_SND_SOC_BD28623 is not set
# CONFIG_SND_SOC_BT_SCO is not set
# CONFIG_SND_SOC_CS35L32 is not set
# CONFIG_SND_SOC_CS35L33 is not set
# CONFIG_SND_SOC_CS35L34 is not set
# CONFIG_SND_SOC_CS35L35 is not set
# CONFIG_SND_SOC_CS35L36 is not set
# CONFIG_SND_SOC_CS42L42 is not set
# CONFIG_SND_SOC_CS42L51_I2C is not set
# CONFIG_SND_SOC_CS42L52 is not set
# CONFIG_SND_SOC_CS42L56 is not set
# CONFIG_SND_SOC_CS42L73 is not set
# CONFIG_SND_SOC_CS4234 is not set
# CONFIG_SND_SOC_CS4265 is not set
# CONFIG_SND_SOC_CS4270 is not set
# CONFIG_SND_SOC_CS4271_I2C is not set
# CONFIG_SND_SOC_CS4271_SPI is not set
# CONFIG_SND_SOC_CS42XX8_I2C is not set
# CONFIG_SND_SOC_CS43130 is not set
# CONFIG_SND_SOC_CS4341 is not set
# CONFIG_SND_SOC_CS4349 is not set
# CONFIG_SND_SOC_CS53L30 is not set
# CONFIG_SND_SOC_CX2072X is not set
# CONFIG_SND_SOC_DA7213 is not set
# CONFIG_SND_SOC_DMIC is not set
# CONFIG_SND_SOC_ES7134 is not set
# CONFIG_SND_SOC_ES7241 is not set
# CONFIG_SND_SOC_ES8316 is not set
# CONFIG_SND_SOC_ES8328_I2C is not set
# CONFIG_SND_SOC_ES8328_SPI is not set
# CONFIG_SND_SOC_GTM601 is not set
# CONFIG_SND_SOC_ICS43432 is not set
# CONFIG_SND_SOC_INNO_RK3036 is not set
# CONFIG_SND_SOC_MAX98088 is not set
# CONFIG_SND_SOC_MAX98357A is not set
# CONFIG_SND_SOC_MAX98504 is not set
# CONFIG_SND_SOC_MAX9867 is not set
# CONFIG_SND_SOC_MAX98927 is not set
# CONFIG_SND_SOC_MAX98373_I2C is not set
# CONFIG_SND_SOC_MAX98390 is not set
# CONFIG_SND_SOC_MAX9860 is not set
# CONFIG_SND_SOC_MSM8916_WCD_DIGITAL is not set
# CONFIG_SND_SOC_PCM1681 is not set
# CONFIG_SND_SOC_PCM1789_I2C is not set
# CONFIG_SND_SOC_PCM179X_I2C is not set
# CONFIG_SND_SOC_PCM179X_SPI is not set
# CONFIG_SND_SOC_PCM186X_I2C is not set
# CONFIG_SND_SOC_PCM186X_SPI is not set
# CONFIG_SND_SOC_PCM3060_I2C is not set
# CONFIG_SND_SOC_PCM3060_SPI is not set
# CONFIG_SND_SOC_PCM3168A_I2C is not set
# CONFIG_SND_SOC_PCM3168A_SPI is not set
# CONFIG_SND_SOC_PCM5102A is not set
# CONFIG_SND_SOC_PCM512x_I2C is not set
# CONFIG_SND_SOC_PCM512x_SPI is not set
# CONFIG_SND_SOC_RK3328 is not set
# CONFIG_SND_SOC_RT5616 is not set
# CONFIG_SND_SOC_RT5631 is not set
# CONFIG_SND_SOC_RT5640 is not set
# CONFIG_SND_SOC_RT5659 is not set
# CONFIG_SND_SOC_SGTL5000 is not set
# CONFIG_SND_SOC_SIMPLE_AMPLIFIER is not set
# CONFIG_SND_SOC_SIMPLE_MUX is not set
# CONFIG_SND_SOC_SPDIF is not set
# CONFIG_SND_SOC_SSM2305 is not set
# CONFIG_SND_SOC_SSM2518 is not set
# CONFIG_SND_SOC_SSM2602_SPI is not set
# CONFIG_SND_SOC_SSM2602_I2C is not set
# CONFIG_SND_SOC_SSM4567 is not set
# CONFIG_SND_SOC_STA32X is not set
# CONFIG_SND_SOC_STA350 is not set
# CONFIG_SND_SOC_STI_SAS is not set
# CONFIG_SND_SOC_TAS2552 is not set
# CONFIG_SND_SOC_TAS2562 is not set
# CONFIG_SND_SOC_TAS2764 is not set
# CONFIG_SND_SOC_TAS2770 is not set
# CONFIG_SND_SOC_TAS5086 is not set
# CONFIG_SND_SOC_TAS571X is not set
# CONFIG_SND_SOC_TAS5720 is not set
# CONFIG_SND_SOC_TAS6424 is not set
# CONFIG_SND_SOC_TDA7419 is not set
# CONFIG_SND_SOC_TFA9879 is not set
# CONFIG_SND_SOC_TFA989X is not set
# CONFIG_SND_SOC_TLV320AIC23_I2C is not set
# CONFIG_SND_SOC_TLV320AIC23_SPI is not set
# CONFIG_SND_SOC_TLV320AIC31XX is not set
# CONFIG_SND_SOC_TLV320AIC32X4_I2C is not set
# CONFIG_SND_SOC_TLV320AIC32X4_SPI is not set
# CONFIG_SND_SOC_TLV320AIC3X_I2C is not set
# CONFIG_SND_SOC_TLV320AIC3X_SPI is not set
# CONFIG_SND_SOC_TLV320ADCX140 is not set
# CONFIG_SND_SOC_TS3A227E is not set
# CONFIG_SND_SOC_TSCS42XX is not set
# CONFIG_SND_SOC_TSCS454 is not set
# CONFIG_SND_SOC_UDA1334 is not set
# CONFIG_SND_SOC_WM8510 is not set
# CONFIG_SND_SOC_WM8523 is not set
# CONFIG_SND_SOC_WM8524 is not set
# CONFIG_SND_SOC_WM8580 is not set
# CONFIG_SND_SOC_WM8711 is not set
# CONFIG_SND_SOC_WM8728 is not set
# CONFIG_SND_SOC_WM8731 is not set
# CONFIG_SND_SOC_WM8737 is not set
# CONFIG_SND_SOC_WM8741 is not set
# CONFIG_SND_SOC_WM8750 is not set
# CONFIG_SND_SOC_WM8753 is not set
# CONFIG_SND_SOC_WM8770 is not set
# CONFIG_SND_SOC_WM8776 is not set
# CONFIG_SND_SOC_WM8782 is not set
# CONFIG_SND_SOC_WM8804_I2C is not set
# CONFIG_SND_SOC_WM8804_SPI is not set
# CONFIG_SND_SOC_WM8903 is not set
# CONFIG_SND_SOC_WM8904 is not set
# CONFIG_SND_SOC_WM8960 is not set
# CONFIG_SND_SOC_WM8962 is not set
# CONFIG_SND_SOC_WM8974 is not set
# CONFIG_SND_SOC_WM8978 is not set
# CONFIG_SND_SOC_WM8985 is not set
# CONFIG_SND_SOC_ZL38060 is not set
# CONFIG_SND_SOC_MAX9759 is not set
# CONFIG_SND_SOC_MT6351 is not set
# CONFIG_SND_SOC_MT6358 is not set
# CONFIG_SND_SOC_MT6660 is not set
# CONFIG_SND_SOC_NAU8315 is not set
# CONFIG_SND_SOC_NAU8540 is not set
# CONFIG_SND_SOC_NAU8810 is not set
# CONFIG_SND_SOC_NAU8822 is not set
# CONFIG_SND_SOC_NAU8824 is not set
# CONFIG_SND_SOC_TPA6130A2 is not set
# CONFIG_SND_SOC_LPASS_WSA_MACRO is not set
# CONFIG_SND_SOC_LPASS_VA_MACRO is not set
# CONFIG_SND_SOC_LPASS_RX_MACRO is not set
# CONFIG_SND_SOC_LPASS_TX_MACRO is not set
# end of CODEC drivers
# CONFIG_SND_SIMPLE_CARD is not set
# CONFIG_SND_AUDIO_GRAPH_CARD is not set
# HID support
CONFIG_HID=y
# CONFIG_HID_BATTERY_STRENGTH is not set
# CONFIG_HIDRAW is not set
# CONFIG_UHID is not set
CONFIG_HID_GENERIC=y
# Special HID drivers
CONFIG_HID_A4TECH=y
# CONFIG_HID_ACCUTOUCH is not set
# CONFIG_HID_ACRUX is not set
CONFIG_HID_APPLE=y
# CONFIG_HID_APPLEIR is not set
# CONFIG_HID_ASUS is not set
# CONFIG_HID_AUREAL is not set
CONFIG_HID_BELKIN=y
# CONFIG_HID_BETOP_FF is not set
# CONFIG_HID_BIGBEN_FF is not set
CONFIG_HID_CHERRY=y
CONFIG_HID_CHICONY=y
# CONFIG_HID_CORSAIR is not set
# CONFIG_HID_COUGAR is not set
# CONFIG_HID_MACALLY is not set
# CONFIG_HID_PRODIKEYS is not set
# CONFIG_HID_CMEDIA is not set
# CONFIG_HID_CREATIVE_SB0540 is not set
CONFIG_HID_CYPRESS=y
# CONFIG_HID_DRAGONRISE is not set
# CONFIG_HID_EMS_FF is not set
# CONFIG_HID_ELAN is not set
# CONFIG_HID_ELECOM is not set
# CONFIG_HID_ELO is not set
CONFIG_HID_EZKEY=y
# CONFIG_HID_GEMBIRD is not set
# CONFIG_HID_GFRM is not set
# CONFIG_HID_GLORIOUS is not set
# CONFIG_HID_HOLTEK is not set
# CONFIG_HID_VIVALDI is not set
# CONFIG_HID_GT683R is not set
# CONFIG_HID_KEYTOUCH is not set
# CONFIG_HID_KYE is not set
# CONFIG_HID_UCLOGIC is not set
# CONFIG_HID_WALTOP is not set
# CONFIG_HID_VIEWSONIC is not set
# CONFIG_HID_GYRATION is not set
# CONFIG_HID_ICADE is not set
CONFIG_HID_ITE=y
# CONFIG_HID_JABRA is not set
# CONFIG_HID_TWINHAN is not set
CONFIG_HID_KENSINGTON=y
# CONFIG_HID_LCPOWER is not set
# CONFIG_HID_LED is not set
# CONFIG_HID_LENOVO is not set
CONFIG_HID_LOGITECH=y
# CONFIG_HID_LOGITECH_HIDPP is not set
# CONFIG_LOGITECH_FF is not set
# CONFIG_LOGIRUMBLEPAD2_FF is not set
# CONFIG_LOGIG940_FF is not set
# CONFIG_LOGIWHEELS_FF is not set
# CONFIG_HID_MAGICMOUSE is not set
# CONFIG_HID_MALTRON is not set
# CONFIG_HID_MAYFLASH is not set
CONFIG_HID_REDRAGON=y
CONFIG_HID_MICROSOFT=y
CONFIG_HID_MONTEREY=y
# CONFIG_HID_MULTITOUCH is not set
# CONFIG_HID_NTI is not set
# CONFIG_HID_NTRIG is not set
# CONFIG_HID_ORTEK is not set
# CONFIG_HID_PANTHERLORD is not set
# CONFIG_HID_PENMOUNT is not set
# CONFIG_HID_PETALYNX is not set
# CONFIG_HID_PICOLCD is not set
# CONFIG_HID_PLANTRONICS is not set
# CONFIG_HID_PLAYSTATION is not set
# CONFIG_HID_PRIMAX is not set
# CONFIG_HID_RETRODE is not set
# CONFIG_HID_ROCCAT is not set
# CONFIG_HID_SAITEK is not set
# CONFIG_HID_SAMSUNG is not set
# CONFIG_HID_SEMITEK is not set
# CONFIG_HID_SONY is not set
# CONFIG_HID_SPEEDLINK is not set
# CONFIG_HID_STEAM is not set
# CONFIG_HID_STEELSERIES is not set
# CONFIG_HID_SUNPLUS is not set
# CONFIG_HID_RMI is not set
# CONFIG_HID_GREENASIA is not set
# CONFIG_HID_SMARTJOYPLUS is not set
# CONFIG_HID_TIVO is not set
# CONFIG_HID_TOPSEED is not set
# CONFIG_HID_THINGM is not set
# CONFIG_HID_THRUSTMASTER is not set
# CONFIG_HID_UDRAW_PS3 is not set
# CONFIG_HID_WACOM is not set
# CONFIG_HID_WIIMOTE is not set
# CONFIG_HID_XINMO is not set
# CONFIG_HID_ZEROPLUS is not set
# CONFIG_HID_ZYDACRON is not set
# CONFIG_HID_SENSOR_HUB is not set
# CONFIG_HID_ALPS is not set
# CONFIG_HID_MCP2221 is not set
# end of Special HID drivers
# USB HID support
CONFIG_USB_HID=y
# CONFIG_HID_PID is not set
# CONFIG_USB_HIDDEV is not set
# end of USB HID support
# I2C HID support
# CONFIG_I2C_HID_OF is not set
# CONFIG_I2C_HID_OF_GOODIX is not set
# end of I2C HID support
# end of HID support
CONFIG_USB_OHCI_LITTLE_ENDIAN=y
CONFIG_USB_SUPPORT=y
CONFIG_USB_COMMON=y
# CONFIG_USB_LED_TRIG is not set
# CONFIG_USB_ULPI_BUS is not set
# CONFIG_USB_CONN_GPIO is not set
CONFIG_USB_ARCH_HAS_HCD=y
CONFIG_USB=y
# CONFIG_USB_ANNOUNCE_NEW_DEVICES is not set
# Miscellaneous USB options
CONFIG_USB_DEFAULT_PERSIST=y
# CONFIG_USB_FEW_INIT_RETRIES is not set
# CONFIG_USB_DYNAMIC_MINORS is not set
# CONFIG_USB_OTG is not set
# CONFIG_USB_OTG_PRODUCTLIST is not set
# CONFIG_USB_LEDS_TRIGGER_USBPORT is not set
CONFIG_USB_AUTOSUSPEND_DELAY=2
# CONFIG_USB_MON is not set
# USB Host Controller Drivers
# CONFIG_USB_C67X00_HCD is not set
# CONFIG_USB_XHCI_HCD is not set
CONFIG_USB_EHCI_HCD=y
# CONFIG_USB_EHCI_ROOT_HUB_TT is not set
CONFIG_USB_EHCI_TT_NEWSCHED=y
# CONFIG_USB_EHCI_FSL is not set
CONFIG_USB_EHCI_HCD_PLATFORM=y
# CONFIG_USB_OXU210HP_HCD is not set
# CONFIG_USB_ISP116X_HCD is not set
# CONFIG_USB_FOTG210_HCD is not set
# CONFIG_USB_MAX3421_HCD is not set
CONFIG_USB_OHCI_HCD=y
CONFIG_USB_OHCI_HCD_PLATFORM=y
# CONFIG_USB_SL811_HCD is not set
# CONFIG_USB_R8A66597_HCD is not set
# CONFIG_USB_HCD_TEST_MODE is not set
# USB Device Class drivers
# CONFIG_USB_ACM is not set
# CONFIG_USB_PRINTER is not set
# CONFIG_USB_WDM is not set
# CONFIG_USB_TMC is not set
# NOTE: USB_STORAGE depends on SCSI but BLK_DEV_SD may
# also be needed; see USB_STORAGE Help for more info
# CONFIG_USB_STORAGE is not set
# USB Imaging devices
# CONFIG_USB_MDC800 is not set
# CONFIG_USB_MICROTEK is not set
# CONFIG_USBIP_CORE is not set
# CONFIG_USB_CDNS_SUPPORT is not set
CONFIG_USB_MUSB_HDRC=y
# CONFIG_USB_MUSB_HOST is not set
# CONFIG_USB_MUSB_GADGET is not set
CONFIG_USB_MUSB_DUAL_ROLE=y
# Platform Glue Layer
CONFIG_USB_MUSB_SUNXI=y
# MUSB DMA mode
# CONFIG_MUSB_PIO_ONLY is not set
# CONFIG_USB_DWC3 is not set
# CONFIG_USB_DWC2 is not set
# CONFIG_USB_CHIPIDEA is not set
# CONFIG_USB_ISP1760 is not set
# USB port drivers
# CONFIG_USB_SERIAL is not set
# USB Miscellaneous drivers
# CONFIG_USB_EMI62 is not set
# CONFIG_USB_EMI26 is not set
# CONFIG_USB_ADUTUX is not set
# CONFIG_USB_SEVSEG is not set
# CONFIG_USB_LEGOTOWER is not set
# CONFIG_USB_LCD is not set
# CONFIG_USB_CYPRESS_CY7C63 is not set
# CONFIG_USB_CYTHERM is not set
# CONFIG_USB_IDMOUSE is not set
# CONFIG_USB_FTDI_ELAN is not set
# CONFIG_USB_APPLEDISPLAY is not set
# CONFIG_APPLE_MFI_FASTCHARGE is not set
# CONFIG_USB_SISUSBVGA is not set
# CONFIG_USB_LD is not set
# CONFIG_USB_TRANCEVIBRATOR is not set
# CONFIG_USB_IOWARRIOR is not set
# CONFIG_USB_TEST is not set
# CONFIG_USB_EHSET_TEST_FIXTURE is not set
# CONFIG_USB_ISIGHTFW is not set
# CONFIG_USB_YUREX is not set
# CONFIG_USB_EZUSB_FX2 is not set
# CONFIG_USB_HUB_USB251XB is not set
# CONFIG_USB_HSIC_USB3503 is not set
# CONFIG_USB_HSIC_USB4604 is not set
# CONFIG_USB_LINK_LAYER_TEST is not set
# USB Physical Layer drivers
CONFIG_USB_PHY=y
CONFIG_NOP_USB_XCEIV=y
# CONFIG_AM335X_PHY_USB is not set
# CONFIG_USB_GPIO_VBUS is not set
# CONFIG_USB_ISP1301 is not set
# CONFIG_USB_ULPI is not set
# end of USB Physical Layer drivers
CONFIG_USB_GADGET=y
# CONFIG_USB_GADGET_DEBUG_FILES is not set
# CONFIG_USB_GADGET_DEBUG_FS is not set
CONFIG_USB_GADGET_VBUS_DRAW=2
CONFIG_USB_GADGET_STORAGE_NUM_BUFFERS=2
# USB Peripheral Controller
# CONFIG_USB_FUSB300 is not set
# CONFIG_USB_FOTG210_UDC is not set
# CONFIG_USB_GR_UDC is not set
# CONFIG_USB_R8A66597 is not set
# CONFIG_USB_PXA27X is not set
# CONFIG_USB_MV_UDC is not set
# CONFIG_USB_MV_U3D is not set
# CONFIG_USB_SNP_UDC_PLAT is not set
# CONFIG_USB_M66592 is not set
# CONFIG_USB_BDC_UDC is not set
# CONFIG_USB_NET2272 is not set
# CONFIG_USB_GADGET_XILINX is not set
# CONFIG_USB_MAX3420_UDC is not set
# CONFIG_USB_DUMMY_HCD is not set
# end of USB Peripheral Controller
# CONFIG_USB_CONFIGFS is not set
# USB Gadget precomposed configurations
# CONFIG_USB_ZERO is not set
# CONFIG_USB_AUDIO is not set
# CONFIG_USB_ETH is not set
# CONFIG_USB_G_NCM is not set
# CONFIG_USB_GADGETFS is not set
# CONFIG_USB_FUNCTIONFS is not set
# CONFIG_USB_MASS_STORAGE is not set
# CONFIG_USB_G_SERIAL is not set
# CONFIG_USB_MIDI_GADGET is not set
# CONFIG_USB_G_PRINTER is not set
# CONFIG_USB_CDC_COMPOSITE is not set
# CONFIG_USB_G_ACM_MS is not set
# CONFIG_USB_G_MULTI is not set
# CONFIG_USB_G_HID is not set
# CONFIG_USB_G_DBGP is not set
# CONFIG_USB_G_WEBCAM is not set
# CONFIG_USB_RAW_GADGET is not set
# end of USB Gadget precomposed configurations
# CONFIG_TYPEC is not set
# CONFIG_USB_ROLE_SWITCH is not set
CONFIG_MMC=y
CONFIG_PWRSEQ_EMMC=y
CONFIG_PWRSEQ_SIMPLE=y
CONFIG_MMC_BLOCK=y
CONFIG_MMC_BLOCK_MINORS=8
# CONFIG_SDIO_UART is not set
# CONFIG_MMC_TEST is not set
# MMC/SD/SDIO Host Controller Drivers
# CONFIG_MMC_DEBUG is not set
# CONFIG_MMC_SDHCI is not set
# CONFIG_MMC_SPI is not set
# CONFIG_MMC_DW is not set
# CONFIG_MMC_VUB300 is not set
# CONFIG_MMC_USHC is not set
# CONFIG_MMC_USDHI6ROL0 is not set
CONFIG_MMC_SUNXI=y
# CONFIG_MMC_CQHCI is not set
# CONFIG_MMC_HSQ is not set
# CONFIG_MMC_MTK is not set
# CONFIG_MEMSTICK is not set
CONFIG_NEW_LEDS=y
CONFIG_LEDS_CLASS=y
# CONFIG_LEDS_CLASS_FLASH is not set
# CONFIG_LEDS_CLASS_MULTICOLOR is not set
# CONFIG_LEDS_BRIGHTNESS_HW_CHANGED is not set
# LED drivers
# CONFIG_LEDS_AN30259A is not set
# CONFIG_LEDS_AW2013 is not set
# CONFIG_LEDS_BCM6328 is not set
# CONFIG_LEDS_BCM6358 is not set
# CONFIG_LEDS_CR0014114 is not set
# CONFIG_LEDS_EL15203000 is not set
# CONFIG_LEDS_LM3530 is not set
# CONFIG_LEDS_LM3532 is not set
# CONFIG_LEDS_LM3642 is not set
# CONFIG_LEDS_LM3692X is not set
# CONFIG_LEDS_PCA9532 is not set
CONFIG_LEDS_GPIO=y
# CONFIG_LEDS_LP3944 is not set
# CONFIG_LEDS_LP3952 is not set
# CONFIG_LEDS_LP50XX is not set
# CONFIG_LEDS_LP55XX_COMMON is not set
# CONFIG_LEDS_LP8860 is not set
# CONFIG_LEDS_PCA955X is not set
# CONFIG_LEDS_PCA963X is not set
# CONFIG_LEDS_DAC124S085 is not set
# CONFIG_LEDS_PWM is not set
# CONFIG_LEDS_REGULATOR is not set
# CONFIG_LEDS_BD2802 is not set
# CONFIG_LEDS_LT3593 is not set
# CONFIG_LEDS_TCA6507 is not set
# CONFIG_LEDS_TLC591XX is not set
# CONFIG_LEDS_LM355x is not set
# CONFIG_LEDS_IS31FL319X is not set
# CONFIG_LEDS_IS31FL32XX is not set
# LED driver for blink(1) USB RGB LED is under Special HID drivers (HID_THINGM)
# CONFIG_LEDS_BLINKM is not set
# CONFIG_LEDS_SYSCON is not set
# CONFIG_LEDS_MLXREG is not set
# CONFIG_LEDS_USER is not set
# CONFIG_LEDS_SPI_BYTE is not set
# CONFIG_LEDS_TI_LMU_COMMON is not set
# Flash and Torch LED drivers
# LED Triggers
CONFIG_LEDS_TRIGGERS=y
# CONFIG_LEDS_TRIGGER_TIMER is not set
# CONFIG_LEDS_TRIGGER_ONESHOT is not set
# CONFIG_LEDS_TRIGGER_DISK is not set
# CONFIG_LEDS_TRIGGER_MTD is not set
CONFIG_LEDS_TRIGGER_HEARTBEAT=y
# CONFIG_LEDS_TRIGGER_BACKLIGHT is not set
# CONFIG_LEDS_TRIGGER_CPU is not set
# CONFIG_LEDS_TRIGGER_ACTIVITY is not set
# CONFIG_LEDS_TRIGGER_GPIO is not set
CONFIG_LEDS_TRIGGER_DEFAULT_ON=y
# iptables trigger is under Netfilter config (LED target)
# CONFIG_LEDS_TRIGGER_TRANSIENT is not set
# CONFIG_LEDS_TRIGGER_CAMERA is not set
# CONFIG_LEDS_TRIGGER_PANIC is not set
# CONFIG_LEDS_TRIGGER_NETDEV is not set
# CONFIG_LEDS_TRIGGER_PATTERN is not set
# CONFIG_LEDS_TRIGGER_AUDIO is not set
# CONFIG_LEDS_TRIGGER_TTY is not set
# CONFIG_ACCESSIBILITY is not set
# CONFIG_INFINIBAND is not set
CONFIG_EDAC_ATOMIC_SCRUB=y
CONFIG_EDAC_SUPPORT=y
CONFIG_RTC_LIB=y
CONFIG_RTC_CLASS=y
CONFIG_RTC_HCTOSYS=y
CONFIG_RTC_HCTOSYS_DEVICE="rtc0"
CONFIG_RTC_SYSTOHC=y
CONFIG_RTC_SYSTOHC_DEVICE="rtc0"
# CONFIG_RTC_DEBUG is not set
CONFIG_RTC_NVMEM=y
# RTC interfaces
# CONFIG_RTC_INTF_SYSFS is not set
# CONFIG_RTC_INTF_PROC is not set
CONFIG_RTC_INTF_DEV=y
# CONFIG_RTC_INTF_DEV_UIE_EMUL is not set
# CONFIG_RTC_DRV_TEST is not set
# I2C RTC drivers
# CONFIG_RTC_DRV_ABB5ZES3 is not set
# CONFIG_RTC_DRV_ABEOZ9 is not set
# CONFIG_RTC_DRV_ABX80X is not set
CONFIG_RTC_DRV_AC100=y
# CONFIG_RTC_DRV_DS1307 is not set
# CONFIG_RTC_DRV_DS1374 is not set
# CONFIG_RTC_DRV_DS1672 is not set
# CONFIG_RTC_DRV_HYM8563 is not set
# CONFIG_RTC_DRV_MAX6900 is not set
# CONFIG_RTC_DRV_RS5C372 is not set
# CONFIG_RTC_DRV_ISL1208 is not set
# CONFIG_RTC_DRV_ISL12022 is not set
# CONFIG_RTC_DRV_ISL12026 is not set
# CONFIG_RTC_DRV_X1205 is not set
# CONFIG_RTC_DRV_PCF8523 is not set
# CONFIG_RTC_DRV_PCF85063 is not set
# CONFIG_RTC_DRV_PCF85363 is not set
# CONFIG_RTC_DRV_PCF8563 is not set
# CONFIG_RTC_DRV_PCF8583 is not set
# CONFIG_RTC_DRV_M41T80 is not set
# CONFIG_RTC_DRV_BQ32K is not set
# CONFIG_RTC_DRV_S35390A is not set
# CONFIG_RTC_DRV_FM3130 is not set
# CONFIG_RTC_DRV_RX8010 is not set
# CONFIG_RTC_DRV_RX8581 is not set
# CONFIG_RTC_DRV_RX8025 is not set
# CONFIG_RTC_DRV_EM3027 is not set
# CONFIG_RTC_DRV_RV3028 is not set
# CONFIG_RTC_DRV_RV3032 is not set
# CONFIG_RTC_DRV_RV8803 is not set
# CONFIG_RTC_DRV_SD3078 is not set
# SPI RTC drivers
# CONFIG_RTC_DRV_M41T93 is not set
# CONFIG_RTC_DRV_M41T94 is not set
# CONFIG_RTC_DRV_DS1302 is not set
# CONFIG_RTC_DRV_DS1305 is not set
# CONFIG_RTC_DRV_DS1343 is not set
# CONFIG_RTC_DRV_DS1347 is not set
# CONFIG_RTC_DRV_DS1390 is not set
# CONFIG_RTC_DRV_MAX6916 is not set
# CONFIG_RTC_DRV_R9701 is not set
# CONFIG_RTC_DRV_RX4581 is not set
# CONFIG_RTC_DRV_RS5C348 is not set
# CONFIG_RTC_DRV_MAX6902 is not set
# CONFIG_RTC_DRV_PCF2123 is not set
# CONFIG_RTC_DRV_MCP795 is not set
CONFIG_RTC_I2C_AND_SPI=y
# SPI and I2C RTC drivers
# CONFIG_RTC_DRV_DS3232 is not set
# CONFIG_RTC_DRV_PCF2127 is not set
# CONFIG_RTC_DRV_RV3029C2 is not set
# CONFIG_RTC_DRV_RX6110 is not set
# Platform RTC drivers
# CONFIG_RTC_DRV_CMOS is not set
# CONFIG_RTC_DRV_DS1286 is not set
# CONFIG_RTC_DRV_DS1511 is not set
# CONFIG_RTC_DRV_DS1553 is not set
# CONFIG_RTC_DRV_DS1685_FAMILY is not set
# CONFIG_RTC_DRV_DS1742 is not set
# CONFIG_RTC_DRV_DS2404 is not set
# CONFIG_RTC_DRV_STK17TA8 is not set
# CONFIG_RTC_DRV_M48T86 is not set
# CONFIG_RTC_DRV_M48T35 is not set
# CONFIG_RTC_DRV_M48T59 is not set
# CONFIG_RTC_DRV_MSM6242 is not set
# CONFIG_RTC_DRV_BQ4802 is not set
# CONFIG_RTC_DRV_RP5C01 is not set
# CONFIG_RTC_DRV_V3020 is not set
# CONFIG_RTC_DRV_ZYNQMP is not set
# on-CPU RTC drivers
CONFIG_RTC_DRV_SUN6I=y
CONFIG_RTC_DRV_SUNXI=y
# CONFIG_RTC_DRV_CADENCE is not set
# CONFIG_RTC_DRV_FTRTC010 is not set
# CONFIG_RTC_DRV_R7301 is not set
# HID Sensor RTC drivers
# CONFIG_RTC_DRV_GOLDFISH is not set
CONFIG_DMADEVICES=y
# CONFIG_DMADEVICES_DEBUG is not set
# DMA Devices
CONFIG_DMA_ENGINE=y
CONFIG_DMA_VIRTUAL_CHANNELS=y
CONFIG_DMA_OF=y
# CONFIG_ALTERA_MSGDMA is not set
CONFIG_DMA_SUN4I=y
CONFIG_DMA_SUN6I=y
# CONFIG_DW_AXI_DMAC is not set
# CONFIG_FSL_EDMA is not set
# CONFIG_FSL_QDMA is not set
# CONFIG_INTEL_IDMA64 is not set
# CONFIG_NBPFAXI_DMA is not set
# CONFIG_XILINX_ZYNQMP_DPDMA is not set
# CONFIG_QCOM_HIDMA_MGMT is not set
# CONFIG_QCOM_HIDMA is not set
# CONFIG_DW_DMAC is not set
# CONFIG_SF_PDMA is not set
# DMA Clients
# CONFIG_ASYNC_TX_DMA is not set
# CONFIG_DMATEST is not set
# DMABUF options
CONFIG_SYNC_FILE=y
# CONFIG_SW_SYNC is not set
# CONFIG_UDMABUF is not set
# CONFIG_DMABUF_MOVE_NOTIFY is not set
# CONFIG_DMABUF_DEBUG is not set
# CONFIG_DMABUF_SELFTESTS is not set
# CONFIG_DMABUF_HEAPS is not set
# CONFIG_DMABUF_SYSFS_STATS is not set
# end of DMABUF options
# CONFIG_AUXDISPLAY is not set
# CONFIG_UIO is not set
# CONFIG_VFIO is not set
# CONFIG_VIRT_DRIVERS is not set
CONFIG_VIRTIO_MENU=y
# CONFIG_VIRTIO_MMIO is not set
# CONFIG_VDPA is not set
CONFIG_VHOST_MENU=y
# CONFIG_VHOST_NET is not set
# CONFIG_VHOST_CROSS_ENDIAN_LEGACY is not set
# Microsoft Hyper-V guest support
# end of Microsoft Hyper-V guest support
# CONFIG_GREYBUS is not set
# CONFIG_COMEDI is not set
CONFIG_STAGING=y
# IIO staging drivers
# Accelerometers
# CONFIG_ADIS16203 is not set
# CONFIG_ADIS16240 is not set
# end of Accelerometers
# Analog to digital converters
# CONFIG_AD7816 is not set
# CONFIG_AD7280 is not set
# end of Analog to digital converters
# Analog digital bi-direction converters
# CONFIG_ADT7316 is not set
# end of Analog digital bi-direction converters
# Capacitance to digital converters
# CONFIG_AD7746 is not set
# end of Capacitance to digital converters
# Direct Digital Synthesis
# CONFIG_AD9832 is not set
# CONFIG_AD9834 is not set
# end of Direct Digital Synthesis
# Network Analyzer, Impedance Converters
# CONFIG_AD5933 is not set
# end of Network Analyzer, Impedance Converters
# Active energy metering IC
# CONFIG_ADE7854 is not set
# end of Active energy metering IC
# Resolver to digital converters
# CONFIG_AD2S1210 is not set
# end of Resolver to digital converters
# end of IIO staging drivers
CONFIG_STAGING_MEDIA=y
CONFIG_VIDEO_SUNXI=y
CONFIG_VIDEO_SUNXI_CEDRUS=y
# Android
# end of Android
# CONFIG_STAGING_BOARD is not set
# CONFIG_LTE_GDM724X is not set
# CONFIG_GS_FPGABOOT is not set
# CONFIG_UNISYSSPAR is not set
# CONFIG_COMMON_CLK_XLNX_CLKWZRD is not set
# CONFIG_PI433 is not set
# CONFIG_XIL_AXIS_FIFO is not set
# CONFIG_FIELDBUS_DEV is not set
# CONFIG_GOLDFISH is not set
# CONFIG_CHROME_PLATFORMS is not set
# CONFIG_MELLANOX_PLATFORM is not set
CONFIG_HAVE_CLK=y
CONFIG_HAVE_CLK_PREPARE=y
CONFIG_COMMON_CLK=y
# Clock driver for ARM Reference designs
# CONFIG_ICST is not set
# CONFIG_CLK_SP810 is not set
# end of Clock driver for ARM Reference designs
# CONFIG_LMK04832 is not set
# CONFIG_COMMON_CLK_MAX9485 is not set
# CONFIG_COMMON_CLK_SI5341 is not set
# CONFIG_COMMON_CLK_SI5351 is not set
# CONFIG_COMMON_CLK_SI514 is not set
# CONFIG_COMMON_CLK_SI544 is not set
# CONFIG_COMMON_CLK_SI570 is not set
# CONFIG_COMMON_CLK_CDCE706 is not set
# CONFIG_COMMON_CLK_CDCE925 is not set
# CONFIG_COMMON_CLK_CS2000_CP is not set
# CONFIG_COMMON_CLK_AXI_CLKGEN is not set
# CONFIG_COMMON_CLK_PWM is not set
# CONFIG_COMMON_CLK_VC5 is not set
# CONFIG_COMMON_CLK_FIXED_MMIO is not set
CONFIG_CLK_SUNXI=y
CONFIG_CLK_SUNXI_CLOCKS=y
CONFIG_CLK_SUNXI_PRCM_SUN6I=y
CONFIG_CLK_SUNXI_PRCM_SUN8I=y
CONFIG_CLK_SUNXI_PRCM_SUN9I=y
CONFIG_SUNXI_CCU=y
CONFIG_SUN4I_A10_CCU=y
CONFIG_SUN5I_CCU=y
CONFIG_SUN6I_A31_CCU=y
CONFIG_SUN8I_A23_CCU=y
CONFIG_SUN8I_A33_CCU=y
CONFIG_SUN8I_A83T_CCU=y
CONFIG_SUN8I_H3_CCU=y
CONFIG_SUN8I_V3S_CCU=y
CONFIG_SUN8I_DE2_CCU=y
CONFIG_SUN8I_R40_CCU=y
CONFIG_SUN9I_A80_CCU=y
CONFIG_SUN8I_R_CCU=y
# CONFIG_XILINX_VCU is not set
# CONFIG_HWSPINLOCK is not set
# Clock Source drivers
CONFIG_TIMER_OF=y
CONFIG_TIMER_PROBE=y
CONFIG_CLKSRC_MMIO=y
CONFIG_SUN4I_TIMER=y
CONFIG_SUN5I_HSTIMER=y
CONFIG_ARM_ARCH_TIMER=y
CONFIG_ARM_ARCH_TIMER_EVTSTREAM=y
# CONFIG_MICROCHIP_PIT64B is not set
# end of Clock Source drivers
CONFIG_MAILBOX=y
# CONFIG_PLATFORM_MHU is not set
# CONFIG_ALTERA_MBOX is not set
# CONFIG_MAILBOX_TEST is not set
CONFIG_SUN6I_MSGBOX=y
# CONFIG_IOMMU_SUPPORT is not set
# Remoteproc drivers
# CONFIG_REMOTEPROC is not set
# end of Remoteproc drivers
# Rpmsg drivers
# CONFIG_RPMSG_QCOM_GLINK_RPM is not set
# CONFIG_RPMSG_VIRTIO is not set
# end of Rpmsg drivers
# CONFIG_SOUNDWIRE is not set
# SOC (System On Chip) specific Drivers
# Amlogic SoC drivers
# end of Amlogic SoC drivers
# Broadcom SoC drivers
# CONFIG_SOC_BRCMSTB is not set
# end of Broadcom SoC drivers
# NXP/Freescale QorIQ SoC drivers
# CONFIG_QUICC_ENGINE is not set
# CONFIG_FSL_RCPM is not set
# end of NXP/Freescale QorIQ SoC drivers
# i.MX SoC drivers
# end of i.MX SoC drivers
# Enable LiteX SoC Builder specific drivers
# CONFIG_LITEX_SOC_CONTROLLER is not set
# end of Enable LiteX SoC Builder specific drivers
# Qualcomm SoC drivers
# end of Qualcomm SoC drivers
CONFIG_SUNXI_MBUS=y
CONFIG_SUNXI_SRAM=y
# CONFIG_SOC_TI is not set
# Xilinx SoC drivers
# end of Xilinx SoC drivers
# end of SOC (System On Chip) specific Drivers
CONFIG_PM_DEVFREQ=y
# DEVFREQ Governors
CONFIG_DEVFREQ_GOV_SIMPLE_ONDEMAND=y
# CONFIG_DEVFREQ_GOV_PERFORMANCE is not set
# CONFIG_DEVFREQ_GOV_POWERSAVE is not set
# CONFIG_DEVFREQ_GOV_USERSPACE is not set
# CONFIG_DEVFREQ_GOV_PASSIVE is not set
# DEVFREQ Drivers
# CONFIG_PM_DEVFREQ_EVENT is not set
CONFIG_EXTCON=y
# Extcon Device Drivers
# CONFIG_EXTCON_ADC_JACK is not set
# CONFIG_EXTCON_FSA9480 is not set
# CONFIG_EXTCON_GPIO is not set
# CONFIG_EXTCON_MAX3355 is not set
# CONFIG_EXTCON_PTN5150 is not set
# CONFIG_EXTCON_RT8973A is not set
# CONFIG_EXTCON_SM5502 is not set
# CONFIG_EXTCON_USB_GPIO is not set
# CONFIG_MEMORY is not set
CONFIG_IIO=y
# CONFIG_IIO_BUFFER is not set
# CONFIG_IIO_CONFIGFS is not set
# CONFIG_IIO_TRIGGER is not set
# CONFIG_IIO_SW_DEVICE is not set
# CONFIG_IIO_SW_TRIGGER is not set
# CONFIG_IIO_TRIGGERED_EVENT is not set
# Accelerometers
# CONFIG_ADIS16201 is not set
# CONFIG_ADIS16209 is not set
# CONFIG_ADXL345_I2C is not set
# CONFIG_ADXL345_SPI is not set
# CONFIG_ADXL372_SPI is not set
# CONFIG_ADXL372_I2C is not set
# CONFIG_BMA180 is not set
# CONFIG_BMA220 is not set
# CONFIG_BMA400 is not set
# CONFIG_BMC150_ACCEL is not set
# CONFIG_BMI088_ACCEL is not set
# CONFIG_DA280 is not set
# CONFIG_DA311 is not set
# CONFIG_DMARD06 is not set
# CONFIG_DMARD09 is not set
# CONFIG_DMARD10 is not set
# CONFIG_FXLS8962AF_I2C is not set
# CONFIG_FXLS8962AF_SPI is not set
# CONFIG_IIO_ST_ACCEL_3AXIS is not set
# CONFIG_KXSD9 is not set
# CONFIG_KXCJK1013 is not set
# CONFIG_MC3230 is not set
# CONFIG_MMA7455_I2C is not set
# CONFIG_MMA7455_SPI is not set
# CONFIG_MMA7660 is not set
# CONFIG_MMA8452 is not set
# CONFIG_MMA9551 is not set
# CONFIG_MMA9553 is not set
# CONFIG_MXC4005 is not set
# CONFIG_MXC6255 is not set
# CONFIG_SCA3000 is not set
# CONFIG_SCA3300 is not set
# CONFIG_STK8312 is not set
# CONFIG_STK8BA50 is not set
# CONFIG_AD7091R5 is not set
# CONFIG_AD7124 is not set
# CONFIG_AD7192 is not set
# CONFIG_AD7266 is not set
# CONFIG_AD7291 is not set
# CONFIG_AD7292 is not set
# CONFIG_AD7298 is not set
# CONFIG_AD7476 is not set
# CONFIG_AD7606_IFACE_PARALLEL is not set
# CONFIG_AD7606_IFACE_SPI is not set
# CONFIG_AD7766 is not set
# CONFIG_AD7768_1 is not set
# CONFIG_AD7780 is not set
# CONFIG_AD7791 is not set
# CONFIG_AD7793 is not set
# CONFIG_AD7887 is not set
# CONFIG_AD7923 is not set
# CONFIG_AD7949 is not set
# CONFIG_AD799X is not set
# CONFIG_ADI_AXI_ADC is not set
CONFIG_AXP20X_ADC=y
# CONFIG_AXP288_ADC is not set
# CONFIG_CC10001_ADC is not set
# CONFIG_ENVELOPE_DETECTOR is not set
# CONFIG_HI8435 is not set
# CONFIG_HX711 is not set
# CONFIG_INA2XX_ADC is not set
# CONFIG_LTC2471 is not set
# CONFIG_LTC2485 is not set
# CONFIG_LTC2496 is not set
# CONFIG_LTC2497 is not set
# CONFIG_MAX1027 is not set
# CONFIG_MAX11100 is not set
# CONFIG_MAX1118 is not set
# CONFIG_MAX1241 is not set
# CONFIG_MAX1363 is not set
# CONFIG_MAX9611 is not set
# CONFIG_MCP320X is not set
# CONFIG_MCP3422 is not set
# CONFIG_MCP3911 is not set
# CONFIG_NAU7802 is not set
# CONFIG_SD_ADC_MODULATOR is not set
# CONFIG_SUN4I_GPADC is not set
# CONFIG_TI_ADC081C is not set
# CONFIG_TI_ADC0832 is not set
# CONFIG_TI_ADC084S021 is not set
# CONFIG_TI_ADC12138 is not set
# CONFIG_TI_ADC108S102 is not set
# CONFIG_TI_ADC128S052 is not set
# CONFIG_TI_ADC161S626 is not set
# CONFIG_TI_ADS1015 is not set
# CONFIG_TI_ADS7950 is not set
# CONFIG_TI_ADS8344 is not set
# CONFIG_TI_ADS8688 is not set
# CONFIG_TI_ADS124S08 is not set
# CONFIG_TI_ADS131E08 is not set
# CONFIG_TI_TLC4541 is not set
# CONFIG_TI_TSC2046 is not set
# CONFIG_VF610_ADC is not set
# CONFIG_XILINX_XADC is not set
# Analog Front Ends
# CONFIG_IIO_RESCALE is not set
# end of Analog Front Ends
# Amplifiers
# CONFIG_AD8366 is not set
# CONFIG_HMC425 is not set
# end of Amplifiers
# CONFIG_AD7150 is not set
# Chemical Sensors
# CONFIG_ATLAS_PH_SENSOR is not set
# CONFIG_ATLAS_EZO_SENSOR is not set
# CONFIG_BME680 is not set
# CONFIG_CCS811 is not set
# CONFIG_IAQCORE is not set
# CONFIG_SCD30_CORE is not set
# CONFIG_SENSIRION_SGP30 is not set
# CONFIG_SENSIRION_SGP40 is not set
# CONFIG_SPS30_I2C is not set
# CONFIG_VZ89X is not set
# end of Chemical Sensors
# Hid Sensor IIO Common
# end of Hid Sensor IIO Common
# IIO SCMI Sensors
# end of IIO SCMI Sensors
# SSP Sensor Common
# CONFIG_IIO_SSP_SENSORHUB is not set
# end of SSP Sensor Common
# Digital to analog converters
# CONFIG_AD5064 is not set
# CONFIG_AD5360 is not set
# CONFIG_AD5380 is not set
# CONFIG_AD5421 is not set
# CONFIG_AD5446 is not set
# CONFIG_AD5449 is not set
# CONFIG_AD5592R is not set
# CONFIG_AD5593R is not set
# CONFIG_AD5504 is not set
# CONFIG_AD5624R_SPI is not set
# CONFIG_AD5686_SPI is not set
# CONFIG_AD5696_I2C is not set
# CONFIG_AD5755 is not set
# CONFIG_AD5758 is not set
# CONFIG_AD5761 is not set
# CONFIG_AD5764 is not set
# CONFIG_AD5766 is not set
# CONFIG_AD5770R is not set
# CONFIG_AD5791 is not set
# CONFIG_AD7303 is not set
# CONFIG_AD8801 is not set
# CONFIG_DPOT_DAC is not set
# CONFIG_DS4424 is not set
# CONFIG_LTC1660 is not set
# CONFIG_LTC2632 is not set
# CONFIG_M62332 is not set
# CONFIG_MAX517 is not set
# CONFIG_MAX5821 is not set
# CONFIG_MCP4725 is not set
# CONFIG_MCP4922 is not set
# CONFIG_TI_DAC082S085 is not set
# CONFIG_TI_DAC5571 is not set
# CONFIG_TI_DAC7311 is not set
# CONFIG_TI_DAC7612 is not set
# CONFIG_VF610_DAC is not set
# end of Digital to analog converters
# IIO dummy driver
# end of IIO dummy driver
# Frequency Synthesizers DDS/PLL
# Clock Generator/Distribution
# CONFIG_AD9523 is not set
# end of Clock Generator/Distribution
# Phase-Locked Loop (PLL) frequency synthesizers
# CONFIG_ADF4350 is not set
# CONFIG_ADF4371 is not set
# end of Phase-Locked Loop (PLL) frequency synthesizers
# end of Frequency Synthesizers DDS/PLL
# Digital gyroscope sensors
# CONFIG_ADIS16080 is not set
# CONFIG_ADIS16130 is not set
# CONFIG_ADIS16136 is not set
# CONFIG_ADIS16260 is not set
# CONFIG_ADXRS290 is not set
# CONFIG_ADXRS450 is not set
# CONFIG_BMG160 is not set
# CONFIG_FXAS21002C is not set
# CONFIG_MPU3050_I2C is not set
# CONFIG_IIO_ST_GYRO_3AXIS is not set
# CONFIG_ITG3200 is not set
# end of Digital gyroscope sensors
# Health Sensors
# Heart Rate Monitors
# CONFIG_AFE4403 is not set
# CONFIG_AFE4404 is not set
# CONFIG_MAX30100 is not set
# CONFIG_MAX30102 is not set
# end of Heart Rate Monitors
# end of Health Sensors
# Humidity sensors
# CONFIG_AM2315 is not set
# CONFIG_DHT11 is not set
# CONFIG_HDC100X is not set
# CONFIG_HDC2010 is not set
# CONFIG_HTS221 is not set
# CONFIG_HTU21 is not set
# CONFIG_SI7005 is not set
# CONFIG_SI7020 is not set
# end of Humidity sensors
# Inertial measurement units
# CONFIG_ADIS16400 is not set
# CONFIG_ADIS16460 is not set
# CONFIG_ADIS16475 is not set
# CONFIG_ADIS16480 is not set
# CONFIG_BMI160_I2C is not set
# CONFIG_BMI160_SPI is not set
# CONFIG_FXOS8700_I2C is not set
# CONFIG_FXOS8700_SPI is not set
# CONFIG_KMX61 is not set
# CONFIG_INV_ICM42600_I2C is not set
# CONFIG_INV_ICM42600_SPI is not set
# CONFIG_INV_MPU6050_I2C is not set
# CONFIG_INV_MPU6050_SPI is not set
# CONFIG_IIO_ST_LSM6DSX is not set
# CONFIG_IIO_ST_LSM9DS0 is not set
# end of Inertial measurement units
# Light sensors
# CONFIG_ADJD_S311 is not set
# CONFIG_ADUX1020 is not set
# CONFIG_AL3010 is not set
# CONFIG_AL3320A is not set
# CONFIG_APDS9300 is not set
# CONFIG_APDS9960 is not set
# CONFIG_AS73211 is not set
# CONFIG_BH1750 is not set
# CONFIG_BH1780 is not set
# CONFIG_CM32181 is not set
# CONFIG_CM3232 is not set
# CONFIG_CM3323 is not set
# CONFIG_CM3605 is not set
# CONFIG_CM36651 is not set
# CONFIG_GP2AP002 is not set
# CONFIG_GP2AP020A00F is not set
# CONFIG_SENSORS_ISL29018 is not set
# CONFIG_SENSORS_ISL29028 is not set
# CONFIG_ISL29125 is not set
# CONFIG_JSA1212 is not set
# CONFIG_RPR0521 is not set
# CONFIG_LTR501 is not set
# CONFIG_LV0104CS is not set
# CONFIG_MAX44000 is not set
# CONFIG_MAX44009 is not set
# CONFIG_NOA1305 is not set
# CONFIG_OPT3001 is not set
# CONFIG_PA12203001 is not set
# CONFIG_SI1133 is not set
# CONFIG_SI1145 is not set
# CONFIG_STK3310 is not set
# CONFIG_ST_UVIS25 is not set
# CONFIG_TCS3414 is not set
# CONFIG_TCS3472 is not set
# CONFIG_SENSORS_TSL2563 is not set
# CONFIG_TSL2583 is not set
# CONFIG_TSL2591 is not set
# CONFIG_TSL2772 is not set
# CONFIG_TSL4531 is not set
# CONFIG_US5182D is not set
# CONFIG_VCNL4000 is not set
# CONFIG_VCNL4035 is not set
# CONFIG_VEML6030 is not set
# CONFIG_VEML6070 is not set
# CONFIG_VL6180 is not set
# CONFIG_ZOPT2201 is not set
# end of Light sensors
# Magnetometer sensors
# CONFIG_AK8974 is not set
# CONFIG_AK8975 is not set
# CONFIG_AK09911 is not set
# CONFIG_BMC150_MAGN_I2C is not set
# CONFIG_BMC150_MAGN_SPI is not set
# CONFIG_MAG3110 is not set
# CONFIG_MMC35240 is not set
# CONFIG_IIO_ST_MAGN_3AXIS is not set
# CONFIG_SENSORS_HMC5843_I2C is not set
# CONFIG_SENSORS_HMC5843_SPI is not set
# CONFIG_SENSORS_RM3100_I2C is not set
# CONFIG_SENSORS_RM3100_SPI is not set
# CONFIG_YAMAHA_YAS530 is not set
# end of Magnetometer sensors
# Multiplexers
# CONFIG_IIO_MUX is not set
# end of Multiplexers
# Inclinometer sensors
# end of Inclinometer sensors
# Linear and angular position sensors
# end of Linear and angular position sensors
# Digital potentiometers
# CONFIG_AD5110 is not set
# CONFIG_AD5272 is not set
# CONFIG_DS1803 is not set
# CONFIG_MAX5432 is not set
# CONFIG_MAX5481 is not set
# CONFIG_MAX5487 is not set
# CONFIG_MCP4018 is not set
# CONFIG_MCP4131 is not set
# CONFIG_MCP4531 is not set
# CONFIG_MCP41010 is not set
# CONFIG_TPL0102 is not set
# end of Digital potentiometers
# Digital potentiostats
# CONFIG_LMP91000 is not set
# end of Digital potentiostats
# Pressure sensors
# CONFIG_ABP060MG is not set
# CONFIG_BMP280 is not set
# CONFIG_DLHL60D is not set
# CONFIG_DPS310 is not set
# CONFIG_HP03 is not set
# CONFIG_ICP10100 is not set
# CONFIG_MPL115_I2C is not set
# CONFIG_MPL115_SPI is not set
# CONFIG_MPL3115 is not set
# CONFIG_MS5611 is not set
# CONFIG_MS5637 is not set
# CONFIG_IIO_ST_PRESS is not set
# CONFIG_T5403 is not set
# CONFIG_HP206C is not set
# CONFIG_ZPA2326 is not set
# end of Pressure sensors
# Lightning sensors
# CONFIG_AS3935 is not set
# end of Lightning sensors
# Proximity and distance sensors
# CONFIG_ISL29501 is not set
# CONFIG_LIDAR_LITE_V2 is not set
# CONFIG_MB1232 is not set
# CONFIG_PING is not set
# CONFIG_RFD77402 is not set
# CONFIG_SRF04 is not set
# CONFIG_SX9310 is not set
# CONFIG_SX9500 is not set
# CONFIG_SRF08 is not set
# CONFIG_VCNL3020 is not set
# CONFIG_VL53L0X_I2C is not set
# end of Proximity and distance sensors
# CONFIG_AD2S90 is not set
# CONFIG_AD2S1200 is not set
# Temperature sensors
# CONFIG_LTC2983 is not set
# CONFIG_MAXIM_THERMOCOUPLE is not set
# CONFIG_MLX90614 is not set
# CONFIG_MLX90632 is not set
# CONFIG_TMP006 is not set
# CONFIG_TMP007 is not set
# CONFIG_TMP117 is not set
# CONFIG_TSYS01 is not set
# CONFIG_TSYS02D is not set
# CONFIG_MAX31856 is not set
# end of Temperature sensors
CONFIG_PWM=y
CONFIG_PWM_SYSFS=y
# CONFIG_PWM_ATMEL_TCB is not set
# CONFIG_PWM_FSL_FTM is not set
# CONFIG_PWM_PCA9685 is not set
CONFIG_PWM_SUN4I=y
# IRQ chip support
CONFIG_IRQCHIP=y
CONFIG_ARM_GIC=y
CONFIG_ARM_GIC_MAX_NR=1
# CONFIG_AL_FIC is not set
# end of IRQ chip support
# CONFIG_IPACK_BUS is not set
CONFIG_ARCH_HAS_RESET_CONTROLLER=y
CONFIG_RESET_CONTROLLER=y
CONFIG_RESET_SIMPLE=y
CONFIG_RESET_SUNXI=y
# CONFIG_RESET_TI_SYSCON is not set
# PHY Subsystem
CONFIG_GENERIC_PHY=y
CONFIG_GENERIC_PHY_MIPI_DPHY=y
# CONFIG_PHY_CAN_TRANSCEIVER is not set
CONFIG_PHY_SUN4I_USB=y
CONFIG_PHY_SUN6I_MIPI_DPHY=y
CONFIG_PHY_SUN9I_USB=y
# CONFIG_PHY_SUN50I_USB3 is not set
# CONFIG_BCM_KONA_USB2_PHY is not set
# CONFIG_PHY_CADENCE_TORRENT is not set
# CONFIG_PHY_CADENCE_DPHY is not set
# CONFIG_PHY_CADENCE_SIERRA is not set
# CONFIG_PHY_CADENCE_SALVO is not set
# CONFIG_PHY_FSL_IMX8MQ_USB is not set
# CONFIG_PHY_MIXEL_MIPI_DPHY is not set
# CONFIG_PHY_PXA_28NM_HSIC is not set
# CONFIG_PHY_PXA_28NM_USB2 is not set
# CONFIG_PHY_CPCAP_USB is not set
# CONFIG_PHY_MAPPHONE_MDM6600 is not set
# CONFIG_PHY_OCELOT_SERDES is not set
# end of PHY Subsystem
# CONFIG_POWERCAP is not set
# CONFIG_MCB is not set
# Performance monitor support
# CONFIG_ARM_CCI_PMU is not set
# CONFIG_ARM_CCN is not set
CONFIG_ARM_PMU=y
# end of Performance monitor support
# CONFIG_RAS is not set
# Android
# CONFIG_ANDROID is not set
# end of Android
# CONFIG_DAX is not set
CONFIG_NVMEM=y
CONFIG_NVMEM_SYSFS=y
CONFIG_NVMEM_SUNXI_SID=y
# CONFIG_NVMEM_RMEM is not set
# HW tracing support
# CONFIG_STM is not set
# CONFIG_INTEL_TH is not set
# end of HW tracing support
# CONFIG_FPGA is not set
# CONFIG_FSI is not set
# CONFIG_TEE is not set
CONFIG_PM_OPP=y
# CONFIG_SIOX is not set
# CONFIG_SLIMBUS is not set
# CONFIG_INTERCONNECT is not set
# CONFIG_COUNTER is not set
# end of Device Drivers
# File systems
CONFIG_DCACHE_WORD_ACCESS=y
# CONFIG_VALIDATE_FS_PARSER is not set
CONFIG_FS_IOMAP=y
# CONFIG_EXT2_FS is not set
# CONFIG_EXT3_FS is not set
CONFIG_EXT4_FS=y
CONFIG_EXT4_USE_FOR_EXT2=y
# CONFIG_EXT4_FS_POSIX_ACL is not set
# CONFIG_EXT4_FS_SECURITY is not set
# CONFIG_EXT4_DEBUG is not set
CONFIG_JBD2=y
# CONFIG_JBD2_DEBUG is not set
CONFIG_FS_MBCACHE=y
# CONFIG_REISERFS_FS is not set
# CONFIG_JFS_FS is not set
# CONFIG_XFS_FS is not set
# CONFIG_GFS2_FS is not set
# CONFIG_BTRFS_FS is not set
# CONFIG_NILFS2_FS is not set
# CONFIG_F2FS_FS is not set
CONFIG_FS_POSIX_ACL=y
CONFIG_EXPORTFS=y
# CONFIG_EXPORTFS_BLOCK_OPS is not set
CONFIG_FILE_LOCKING=y
# CONFIG_FS_ENCRYPTION is not set
# CONFIG_FS_VERITY is not set
CONFIG_FSNOTIFY=y
CONFIG_DNOTIFY=y
CONFIG_INOTIFY_USER=y
# CONFIG_FANOTIFY is not set
# CONFIG_QUOTA is not set
# CONFIG_AUTOFS4_FS is not set
# CONFIG_AUTOFS_FS is not set
# CONFIG_FUSE_FS is not set
# CONFIG_OVERLAY_FS is not set
# Caches
# CONFIG_FSCACHE is not set
# end of Caches
# CD-ROM/DVD Filesystems
# CONFIG_ISO9660_FS is not set
# CONFIG_UDF_FS is not set
# end of CD-ROM/DVD Filesystems
# DOS/FAT/EXFAT/NT Filesystems
CONFIG_FAT_FS=y
# CONFIG_MSDOS_FS is not set
CONFIG_VFAT_FS=y
CONFIG_FAT_DEFAULT_CODEPAGE=437
CONFIG_FAT_DEFAULT_IOCHARSET="iso8859-1"
# CONFIG_FAT_DEFAULT_UTF8 is not set
# CONFIG_EXFAT_FS is not set
# CONFIG_NTFS_FS is not set
# CONFIG_NTFS3_FS is not set
# end of DOS/FAT/EXFAT/NT Filesystems
# Pseudo filesystems
CONFIG_PROC_FS=y
CONFIG_PROC_SYSCTL=y
CONFIG_PROC_PAGE_MONITOR=y
# CONFIG_PROC_CHILDREN is not set
CONFIG_KERNFS=y
CONFIG_SYSFS=y
CONFIG_TMPFS=y
# CONFIG_TMPFS_POSIX_ACL is not set
# CONFIG_TMPFS_XATTR is not set
CONFIG_MEMFD_CREATE=y
# CONFIG_CONFIGFS_FS is not set
# end of Pseudo filesystems
CONFIG_MISC_FILESYSTEMS=y
# CONFIG_ORANGEFS_FS is not set
# CONFIG_ADFS_FS is not set
# CONFIG_AFFS_FS is not set
# CONFIG_ECRYPT_FS is not set
# CONFIG_HFS_FS is not set
# CONFIG_HFSPLUS_FS is not set
# CONFIG_BEFS_FS is not set
# CONFIG_BFS_FS is not set
# CONFIG_EFS_FS is not set
# CONFIG_JFFS2_FS is not set
# CONFIG_CRAMFS is not set
# CONFIG_SQUASHFS is not set
# CONFIG_VXFS_FS is not set
# CONFIG_MINIX_FS is not set
# CONFIG_OMFS_FS is not set
# CONFIG_HPFS_FS is not set
# CONFIG_QNX4FS_FS is not set
# CONFIG_QNX6FS_FS is not set
# CONFIG_ROMFS_FS is not set
# CONFIG_PSTORE is not set
# CONFIG_SYSV_FS is not set
# CONFIG_UFS_FS is not set
# CONFIG_EROFS_FS is not set
CONFIG_NETWORK_FILESYSTEMS=y
CONFIG_NFS_FS=y
CONFIG_NFS_V2=y
CONFIG_NFS_V3=y
CONFIG_NFS_V3_ACL=y
CONFIG_NFS_V4=y
# CONFIG_NFS_SWAP is not set
# CONFIG_NFS_V4_1 is not set
CONFIG_ROOT_NFS=y
# CONFIG_NFS_USE_LEGACY_DNS is not set
CONFIG_NFS_USE_KERNEL_DNS=y
CONFIG_NFS_DISABLE_UDP_SUPPORT=y
# CONFIG_NFSD is not set
CONFIG_GRACE_PERIOD=y
CONFIG_LOCKD=y
CONFIG_LOCKD_V4=y
CONFIG_NFS_ACL_SUPPORT=y
CONFIG_NFS_COMMON=y
CONFIG_SUNRPC=y
CONFIG_SUNRPC_GSS=y
# CONFIG_SUNRPC_DEBUG is not set
# CONFIG_CEPH_FS is not set
# CONFIG_CIFS is not set
# CONFIG_SMB_SERVER is not set
# CONFIG_CODA_FS is not set
# CONFIG_AFS_FS is not set
CONFIG_NLS=y
CONFIG_NLS_DEFAULT="iso8859-1"
CONFIG_NLS_CODEPAGE_437=y
# CONFIG_NLS_CODEPAGE_737 is not set
# CONFIG_NLS_CODEPAGE_775 is not set
# CONFIG_NLS_CODEPAGE_850 is not set
# CONFIG_NLS_CODEPAGE_852 is not set
# CONFIG_NLS_CODEPAGE_855 is not set
# CONFIG_NLS_CODEPAGE_857 is not set
# CONFIG_NLS_CODEPAGE_860 is not set
# CONFIG_NLS_CODEPAGE_861 is not set
# CONFIG_NLS_CODEPAGE_862 is not set
# CONFIG_NLS_CODEPAGE_863 is not set
# CONFIG_NLS_CODEPAGE_864 is not set
# CONFIG_NLS_CODEPAGE_865 is not set
# CONFIG_NLS_CODEPAGE_866 is not set
# CONFIG_NLS_CODEPAGE_869 is not set
# CONFIG_NLS_CODEPAGE_936 is not set
# CONFIG_NLS_CODEPAGE_950 is not set
# CONFIG_NLS_CODEPAGE_932 is not set
# CONFIG_NLS_CODEPAGE_949 is not set
# CONFIG_NLS_CODEPAGE_874 is not set
# CONFIG_NLS_ISO8859_8 is not set
# CONFIG_NLS_CODEPAGE_1250 is not set
# CONFIG_NLS_CODEPAGE_1251 is not set
# CONFIG_NLS_ASCII is not set
CONFIG_NLS_ISO8859_1=y
# CONFIG_NLS_ISO8859_2 is not set
# CONFIG_NLS_ISO8859_3 is not set
# CONFIG_NLS_ISO8859_4 is not set
# CONFIG_NLS_ISO8859_5 is not set
# CONFIG_NLS_ISO8859_6 is not set
# CONFIG_NLS_ISO8859_7 is not set
# CONFIG_NLS_ISO8859_9 is not set
# CONFIG_NLS_ISO8859_13 is not set
# CONFIG_NLS_ISO8859_14 is not set
# CONFIG_NLS_ISO8859_15 is not set
# CONFIG_NLS_KOI8_R is not set
# CONFIG_NLS_KOI8_U is not set
# CONFIG_NLS_MAC_ROMAN is not set
# CONFIG_NLS_MAC_CELTIC is not set
# CONFIG_NLS_MAC_CENTEURO is not set
# CONFIG_NLS_MAC_CROATIAN is not set
# CONFIG_NLS_MAC_CYRILLIC is not set
# CONFIG_NLS_MAC_GAELIC is not set
# CONFIG_NLS_MAC_GREEK is not set
# CONFIG_NLS_MAC_ICELAND is not set
# CONFIG_NLS_MAC_INUIT is not set
# CONFIG_NLS_MAC_ROMANIAN is not set
# CONFIG_NLS_MAC_TURKISH is not set
# CONFIG_NLS_UTF8 is not set
# CONFIG_UNICODE is not set
CONFIG_IO_WQ=y
# end of File systems
# Security options
CONFIG_KEYS=y
# CONFIG_KEYS_REQUEST_CACHE is not set
# CONFIG_PERSISTENT_KEYRINGS is not set
# CONFIG_ENCRYPTED_KEYS is not set
# CONFIG_KEY_DH_OPERATIONS is not set
# CONFIG_SECURITY_DMESG_RESTRICT is not set
# CONFIG_SECURITY is not set
# CONFIG_SECURITYFS is not set
CONFIG_HAVE_HARDENED_USERCOPY_ALLOCATOR=y
# CONFIG_HARDENED_USERCOPY is not set
# CONFIG_FORTIFY_SOURCE is not set
# CONFIG_STATIC_USERMODEHELPER is not set
CONFIG_DEFAULT_SECURITY_DAC=y
CONFIG_LSM="landlock,lockdown,yama,loadpin,safesetid,integrity,bpf"
# Kernel hardening options
# Memory initialization
CONFIG_INIT_STACK_NONE=y
# CONFIG_GCC_PLUGIN_STRUCTLEAK_USER is not set
# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF is not set
# CONFIG_GCC_PLUGIN_STRUCTLEAK_BYREF_ALL is not set
# CONFIG_INIT_ON_ALLOC_DEFAULT_ON is not set
# CONFIG_INIT_ON_FREE_DEFAULT_ON is not set
CONFIG_CC_HAS_ZERO_CALL_USED_REGS=y
# CONFIG_ZERO_CALL_USED_REGS is not set
# end of Memory initialization
# end of Kernel hardening options
# end of Security options
CONFIG_CRYPTO=y
# Crypto core or helper
CONFIG_CRYPTO_ALGAPI=y
CONFIG_CRYPTO_ALGAPI2=y
CONFIG_CRYPTO_AEAD2=y
CONFIG_CRYPTO_SKCIPHER=y
CONFIG_CRYPTO_SKCIPHER2=y
CONFIG_CRYPTO_HASH=y
CONFIG_CRYPTO_HASH2=y
CONFIG_CRYPTO_RNG=y
CONFIG_CRYPTO_RNG2=y
CONFIG_CRYPTO_AKCIPHER2=y
CONFIG_CRYPTO_KPP2=y
CONFIG_CRYPTO_ACOMP2=y
CONFIG_CRYPTO_MANAGER=y
CONFIG_CRYPTO_MANAGER2=y
# CONFIG_CRYPTO_USER is not set
CONFIG_CRYPTO_MANAGER_DISABLE_TESTS=y
# CONFIG_CRYPTO_NULL is not set
CONFIG_CRYPTO_NULL2=y
# CONFIG_CRYPTO_PCRYPT is not set
# CONFIG_CRYPTO_CRYPTD is not set
# CONFIG_CRYPTO_AUTHENC is not set
# CONFIG_CRYPTO_TEST is not set
CONFIG_CRYPTO_ENGINE=y
# Public-key cryptography
# CONFIG_CRYPTO_RSA is not set
# CONFIG_CRYPTO_DH is not set
# CONFIG_CRYPTO_ECDH is not set
# CONFIG_CRYPTO_ECDSA is not set
# CONFIG_CRYPTO_ECRDSA is not set
# CONFIG_CRYPTO_SM2 is not set
# CONFIG_CRYPTO_CURVE25519 is not set
# Authenticated Encryption with Associated Data
# CONFIG_CRYPTO_CCM is not set
# CONFIG_CRYPTO_GCM is not set
# CONFIG_CRYPTO_CHACHA20POLY1305 is not set
# CONFIG_CRYPTO_AEGIS128 is not set
# CONFIG_CRYPTO_SEQIV is not set
# CONFIG_CRYPTO_ECHAINIV is not set
# Block modes
CONFIG_CRYPTO_CBC=y
# CONFIG_CRYPTO_CFB is not set
# CONFIG_CRYPTO_CTR is not set
# CONFIG_CRYPTO_CTS is not set
CONFIG_CRYPTO_ECB=y
# CONFIG_CRYPTO_LRW is not set
# CONFIG_CRYPTO_OFB is not set
# CONFIG_CRYPTO_PCBC is not set
# CONFIG_CRYPTO_XTS is not set
# CONFIG_CRYPTO_KEYWRAP is not set
# CONFIG_CRYPTO_ADIANTUM is not set
# CONFIG_CRYPTO_ESSIV is not set
# Hash modes
# CONFIG_CRYPTO_CMAC is not set
# CONFIG_CRYPTO_HMAC is not set
# CONFIG_CRYPTO_XCBC is not set
# CONFIG_CRYPTO_VMAC is not set
# Digest
CONFIG_CRYPTO_CRC32C=y
# CONFIG_CRYPTO_CRC32 is not set
# CONFIG_CRYPTO_XXHASH is not set
# CONFIG_CRYPTO_BLAKE2B is not set
# CONFIG_CRYPTO_CRCT10DIF is not set
# CONFIG_CRYPTO_GHASH is not set
# CONFIG_CRYPTO_POLY1305 is not set
# CONFIG_CRYPTO_MD4 is not set
CONFIG_CRYPTO_MD5=y
# CONFIG_CRYPTO_MICHAEL_MIC is not set
# CONFIG_CRYPTO_RMD160 is not set
CONFIG_CRYPTO_SHA1=y
# CONFIG_CRYPTO_SHA256 is not set
# CONFIG_CRYPTO_SHA512 is not set
# CONFIG_CRYPTO_SHA3 is not set
# CONFIG_CRYPTO_SM3 is not set
# CONFIG_CRYPTO_STREEBOG is not set
# CONFIG_CRYPTO_WP512 is not set
# Ciphers
CONFIG_CRYPTO_AES=y
# CONFIG_CRYPTO_AES_TI is not set
# CONFIG_CRYPTO_BLOWFISH is not set
# CONFIG_CRYPTO_CAMELLIA is not set
# CONFIG_CRYPTO_CAST5 is not set
# CONFIG_CRYPTO_CAST6 is not set
CONFIG_CRYPTO_DES=y
# CONFIG_CRYPTO_FCRYPT is not set
# CONFIG_CRYPTO_CHACHA20 is not set
# CONFIG_CRYPTO_SERPENT is not set
# CONFIG_CRYPTO_SM4 is not set
# CONFIG_CRYPTO_TWOFISH is not set
# Compression
# CONFIG_CRYPTO_DEFLATE is not set
# CONFIG_CRYPTO_LZO is not set
# CONFIG_CRYPTO_842 is not set
# CONFIG_CRYPTO_LZ4 is not set
# CONFIG_CRYPTO_LZ4HC is not set
# CONFIG_CRYPTO_ZSTD is not set
# Random Number Generation
# CONFIG_CRYPTO_ANSI_CPRNG is not set
# CONFIG_CRYPTO_DRBG_MENU is not set
# CONFIG_CRYPTO_JITTERENTROPY is not set
# CONFIG_CRYPTO_USER_API_HASH is not set
# CONFIG_CRYPTO_USER_API_SKCIPHER is not set
# CONFIG_CRYPTO_USER_API_RNG is not set
# CONFIG_CRYPTO_USER_API_AEAD is not set
CONFIG_CRYPTO_HW=y
CONFIG_CRYPTO_DEV_ALLWINNER=y
CONFIG_CRYPTO_DEV_SUN4I_SS=y
CONFIG_CRYPTO_DEV_SUN4I_SS_PRNG=y
# CONFIG_CRYPTO_DEV_SUN4I_SS_DEBUG is not set
CONFIG_CRYPTO_DEV_SUN8I_CE=y
# CONFIG_CRYPTO_DEV_SUN8I_CE_DEBUG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_HASH is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN8I_CE_TRNG is not set
CONFIG_CRYPTO_DEV_SUN8I_SS=y
# CONFIG_CRYPTO_DEV_SUN8I_SS_DEBUG is not set
# CONFIG_CRYPTO_DEV_SUN8I_SS_PRNG is not set
# CONFIG_CRYPTO_DEV_SUN8I_SS_HASH is not set
# CONFIG_CRYPTO_DEV_ATMEL_ECC is not set
# CONFIG_CRYPTO_DEV_ATMEL_SHA204A is not set
# CONFIG_CRYPTO_DEV_SAFEXCEL is not set
# CONFIG_CRYPTO_DEV_CCREE is not set
# CONFIG_CRYPTO_DEV_AMLOGIC_GXL is not set
# CONFIG_ASYMMETRIC_KEY_TYPE is not set
# Certificates for signature checking
# CONFIG_SYSTEM_BLACKLIST_KEYRING is not set
# end of Certificates for signature checking
# Library routines
CONFIG_LINEAR_RANGES=y
# CONFIG_PACKING is not set
CONFIG_BITREVERSE=y
CONFIG_HAVE_ARCH_BITREVERSE=y
CONFIG_GENERIC_STRNCPY_FROM_USER=y
CONFIG_GENERIC_STRNLEN_USER=y
CONFIG_GENERIC_NET_UTILS=y
# CONFIG_CORDIC is not set
# CONFIG_PRIME_NUMBERS is not set
CONFIG_RATIONAL=y
CONFIG_GENERIC_PCI_IOMAP=y
CONFIG_ARCH_USE_CMPXCHG_LOCKREF=y
# Crypto library routines
CONFIG_CRYPTO_LIB_AES=y
CONFIG_CRYPTO_LIB_BLAKE2S_GENERIC=y
# CONFIG_CRYPTO_LIB_CHACHA is not set
# CONFIG_CRYPTO_LIB_CURVE25519 is not set
CONFIG_CRYPTO_LIB_DES=y
CONFIG_CRYPTO_LIB_POLY1305_RSIZE=9
# CONFIG_CRYPTO_LIB_POLY1305 is not set
# CONFIG_CRYPTO_LIB_CHACHA20POLY1305 is not set
# end of Crypto library routines
CONFIG_LIB_MEMNEQ=y
CONFIG_CRC_CCITT=y
CONFIG_CRC16=y
# CONFIG_CRC_T10DIF is not set
# CONFIG_CRC_ITU_T is not set
CONFIG_CRC32=y
# CONFIG_CRC32_SELFTEST is not set
CONFIG_CRC32_SLICEBY8=y
# CONFIG_CRC32_SLICEBY4 is not set
# CONFIG_CRC32_SARWATE is not set
# CONFIG_CRC32_BIT is not set
# CONFIG_CRC64 is not set
# CONFIG_CRC4 is not set
# CONFIG_CRC7 is not set
# CONFIG_LIBCRC32C is not set
# CONFIG_CRC8 is not set
CONFIG_XXHASH=y
# CONFIG_RANDOM32_SELFTEST is not set
CONFIG_ZLIB_INFLATE=y
CONFIG_LZO_DECOMPRESS=y
CONFIG_LZ4_DECOMPRESS=y
CONFIG_ZSTD_DECOMPRESS=y
CONFIG_XZ_DEC=y
CONFIG_XZ_DEC_X86=y
CONFIG_XZ_DEC_POWERPC=y
CONFIG_XZ_DEC_IA64=y
CONFIG_XZ_DEC_ARM=y
CONFIG_XZ_DEC_ARMTHUMB=y
CONFIG_XZ_DEC_SPARC=y
CONFIG_XZ_DEC_BCJ=y
# CONFIG_XZ_DEC_TEST is not set
CONFIG_DECOMPRESS_GZIP=y
CONFIG_DECOMPRESS_BZIP2=y
CONFIG_DECOMPRESS_LZMA=y
CONFIG_DECOMPRESS_XZ=y
CONFIG_DECOMPRESS_LZO=y
CONFIG_DECOMPRESS_LZ4=y
CONFIG_DECOMPRESS_ZSTD=y
CONFIG_GENERIC_ALLOCATOR=y
CONFIG_ASSOCIATIVE_ARRAY=y
CONFIG_HAS_IOMEM=y
CONFIG_HAS_IOPORT_MAP=y
CONFIG_HAS_DMA=y
CONFIG_DMA_OPS=y
CONFIG_NEED_DMA_MAP_STATE=y
CONFIG_DMA_DECLARE_COHERENT=y
CONFIG_ARCH_HAS_SETUP_DMA_OPS=y
CONFIG_ARCH_HAS_TEARDOWN_DMA_OPS=y
CONFIG_DMA_NONCOHERENT_MMAP=y
CONFIG_DMA_REMAP=y
CONFIG_DMA_CMA=y
# CONFIG_DMA_PERNUMA_CMA is not set
# Default contiguous memory area size:
CONFIG_CMA_SIZE_MBYTES=16
CONFIG_CMA_SIZE_SEL_MBYTES=y
# CONFIG_CMA_SIZE_SEL_PERCENTAGE is not set
# CONFIG_CMA_SIZE_SEL_MIN is not set
# CONFIG_CMA_SIZE_SEL_MAX is not set
CONFIG_CMA_ALIGNMENT=8
# CONFIG_DMA_API_DEBUG is not set
# CONFIG_DMA_MAP_BENCHMARK is not set
CONFIG_SGL_ALLOC=y
CONFIG_CPU_RMAP=y
CONFIG_DQL=y
CONFIG_GLOB=y
# CONFIG_GLOB_SELFTEST is not set
CONFIG_NLATTR=y
# CONFIG_IRQ_POLL is not set
CONFIG_LIBFDT=y
CONFIG_OID_REGISTRY=y
CONFIG_HAVE_GENERIC_VDSO=y
CONFIG_GENERIC_GETTIMEOFDAY=y
CONFIG_GENERIC_VDSO_32=y
CONFIG_SG_POOL=y
CONFIG_SBITMAP=y
# end of Library routines
CONFIG_GENERIC_LIB_DEVMEM_IS_ALLOWED=y
# Kernel hacking
# printk and dmesg options
CONFIG_PRINTK_TIME=y
# CONFIG_PRINTK_CALLER is not set
# CONFIG_STACKTRACE_BUILD_ID is not set
CONFIG_CONSOLE_LOGLEVEL_DEFAULT=7
CONFIG_CONSOLE_LOGLEVEL_QUIET=4
CONFIG_MESSAGE_LOGLEVEL_DEFAULT=4
# CONFIG_DYNAMIC_DEBUG is not set
# CONFIG_DYNAMIC_DEBUG_CORE is not set
CONFIG_SYMBOLIC_ERRNAME=y
CONFIG_DEBUG_BUGVERBOSE=y
# end of printk and dmesg options
CONFIG_AS_HAS_NON_CONST_LEB128=y
# Compile-time checks and compiler options
CONFIG_FRAME_WARN=1024
# CONFIG_STRIP_ASM_SYMS is not set
# CONFIG_HEADERS_INSTALL is not set
# CONFIG_DEBUG_SECTION_MISMATCH is not set
CONFIG_SECTION_MISMATCH_WARN_ONLY=y
# end of Compile-time checks and compiler options
# Generic Kernel Debugging Instruments
# CONFIG_MAGIC_SYSRQ is not set
CONFIG_DEBUG_FS=y
CONFIG_DEBUG_FS_ALLOW_ALL=y
# CONFIG_DEBUG_FS_DISALLOW_MOUNT is not set
# CONFIG_DEBUG_FS_ALLOW_NONE is not set
CONFIG_HAVE_ARCH_KGDB=y
# CONFIG_UBSAN is not set
CONFIG_HAVE_KCSAN_COMPILER=y
# end of Generic Kernel Debugging Instruments
# CONFIG_DEBUG_KERNEL is not set
# Memory Debugging
# CONFIG_PAGE_EXTENSION is not set
# CONFIG_PAGE_POISONING is not set
# CONFIG_DEBUG_RODATA_TEST is not set
# CONFIG_DEBUG_WX is not set
# CONFIG_SLUB_DEBUG_ON is not set
# CONFIG_SLUB_STATS is not set
CONFIG_HAVE_DEBUG_KMEMLEAK=y
CONFIG_ARCH_HAS_DEBUG_VIRTUAL=y
CONFIG_DEBUG_MEMORY_INIT=y
CONFIG_HAVE_ARCH_KASAN=y
CONFIG_CC_HAS_KASAN_GENERIC=y
CONFIG_CC_HAS_WORKING_NOSANITIZE_ADDRESS=y
# CONFIG_KASAN is not set
# end of Memory Debugging
# Debug Oops, Lockups and Hangs
# CONFIG_PANIC_ON_OOPS is not set
CONFIG_PANIC_ON_OOPS_VALUE=0
CONFIG_PANIC_TIMEOUT=0
# CONFIG_TEST_LOCKUP is not set
# end of Debug Oops, Lockups and Hangs
# Scheduler Debugging
# end of Scheduler Debugging
# CONFIG_DEBUG_TIMEKEEPING is not set
# Lock Debugging (spinlocks, mutexes, etc...)
CONFIG_LOCK_DEBUGGING_SUPPORT=y
# CONFIG_WW_MUTEX_SELFTEST is not set
# end of Lock Debugging (spinlocks, mutexes, etc...)
# CONFIG_DEBUG_IRQFLAGS is not set
# CONFIG_STACKTRACE is not set
# CONFIG_WARN_ALL_UNSEEDED_RANDOM is not set
# Debug kernel data structures
# CONFIG_BUG_ON_DATA_CORRUPTION is not set
# end of Debug kernel data structures
# RCU Debugging
CONFIG_RCU_CPU_STALL_TIMEOUT=21
# end of RCU Debugging
CONFIG_HAVE_FUNCTION_TRACER=y
CONFIG_HAVE_FUNCTION_GRAPH_TRACER=y
CONFIG_HAVE_DYNAMIC_FTRACE=y
CONFIG_HAVE_DYNAMIC_FTRACE_WITH_REGS=y
CONFIG_HAVE_FTRACE_MCOUNT_RECORD=y
CONFIG_HAVE_SYSCALL_TRACEPOINTS=y
CONFIG_HAVE_C_RECORDMCOUNT=y
CONFIG_TRACING_SUPPORT=y
# CONFIG_FTRACE is not set
# CONFIG_SAMPLES is not set
# CONFIG_STRICT_DEVMEM is not set
# arm Debugging
# CONFIG_UNWINDER_FRAME_POINTER is not set
CONFIG_UNWINDER_ARM=y
CONFIG_ARM_UNWIND=y
# CONFIG_DEBUG_USER is not set
CONFIG_DEBUG_LL_INCLUDE="mach/debug-macro.S"
CONFIG_UNCOMPRESS_INCLUDE="debug/uncompress.h"
# CONFIG_PID_IN_CONTEXTIDR is not set
# CONFIG_CORESIGHT is not set
# end of arm Debugging
# Kernel Testing and Coverage
# CONFIG_KUNIT is not set
CONFIG_ARCH_HAS_KCOV=y
CONFIG_CC_HAS_SANCOV_TRACE_PC=y
# CONFIG_KCOV is not set
CONFIG_RUNTIME_TESTING_MENU=y
# CONFIG_LKDTM is not set
# CONFIG_TEST_MIN_HEAP is not set
# CONFIG_TEST_DIV64 is not set
# CONFIG_REED_SOLOMON_TEST is not set
# CONFIG_ATOMIC64_SELFTEST is not set
# CONFIG_TEST_HEXDUMP is not set
# CONFIG_STRING_SELFTEST is not set
# CONFIG_TEST_STRING_HELPERS is not set
# CONFIG_TEST_STRSCPY is not set
# CONFIG_TEST_KSTRTOX is not set
# CONFIG_TEST_PRINTF is not set
# CONFIG_TEST_SCANF is not set
# CONFIG_TEST_BITMAP is not set
# CONFIG_TEST_UUID is not set
# CONFIG_TEST_XARRAY is not set
# CONFIG_TEST_OVERFLOW is not set
# CONFIG_TEST_RHASHTABLE is not set
# CONFIG_TEST_HASH is not set
# CONFIG_TEST_IDA is not set
# CONFIG_TEST_LKM is not set
# CONFIG_TEST_BITOPS is not set
# CONFIG_TEST_VMALLOC is not set
# CONFIG_TEST_USER_COPY is not set
# CONFIG_TEST_BPF is not set
# CONFIG_TEST_BLACKHOLE_DEV is not set
# CONFIG_FIND_BIT_BENCHMARK is not set
# CONFIG_TEST_FIRMWARE is not set
# CONFIG_TEST_SYSCTL is not set
# CONFIG_TEST_UDELAY is not set
# CONFIG_TEST_STATIC_KEYS is not set
# CONFIG_TEST_KMOD is not set
# CONFIG_TEST_MEMCAT_P is not set
# CONFIG_TEST_STACKINIT is not set
# CONFIG_TEST_MEMINIT is not set
# CONFIG_TEST_FREE_PAGES is not set
CONFIG_ARCH_USE_MEMTEST=y
# CONFIG_MEMTEST is not set
# end of Kernel Testing and Coverage
# end of Kernel hackingkernel .dts:
/dts-v1/;
#include "sun8i-h3.dtsi"
model = "h3_tinyscan";
compatible = "friendlyarm,nanopi-m1-plus","allwinner,sun8i-h3"; // 使用香橙派和友善之臂的驱动文件
aliases { //设备别名
serial1 = &uart3;
ethernet0 = &emac;
ethernet1 = &sdio_wifi;
chosen { // uboot 向 Linux 内核传递数据
leds {
compatible = "gpio-leds";
pwr_led {
label = "h3_tinyscan:blue:status";
gpios = <&pio 0 10 GPIO_ACTIVE_HIGH>;
linux,default-trigger = "heartbeat";
status_led {
label = "h3_tinyscan:red:status";
gpios = <&r_pio 0 10 GPIO_ACTIVE_HIGH>;
default-state = "on";
reg_gmac_3v3: gmac-3v3 {
regulator-name = "gmac-3v3";
startup-delay-us = <100000>;
enable-active-high;
gpio = <&pio 3 6 GPIO_ACTIVE_HIGH>;
wifi_pwrseq: wifi_pwrseq {
compatible = "mmc-pwrseq-simple";
reset-gpios = <&r_pio 0 7 GPIO_ACTIVE_LOW>; /* PL7 */
connector {
compatible = "hdmi-connector";
type = "a";
port {
hdmi_con_in: endpoint {
remote-endpoint = <&hdmi_out_con>;
r_gpio_keys {
compatible = "gpio-keys";
autorepeat; //支持连按
//input-name = "sw1";
sw1 {
label = "sw1";
linux,code = <BTN_0>; // 百度Linux input_event type值列表和code值列表
gpios = <&r_pio 0 2 GPIO_ACTIVE_LOW>;
sw2 {
label = "sw2";
linux,code = <BTN_1>;
gpios = <&r_pio 0 0 GPIO_ACTIVE_LOW>;
sw3 {
label = "sw3";
linux,code = <BTN_2>;
gpios = <&r_pio 0 5 GPIO_ACTIVE_LOW>;
sw4 {
label = "sw4";
linux,code = <BTN_3>;
gpios = <&r_pio 0 3 GPIO_ACTIVE_LOW>;
&codec {
allwinner,audio-routing =
"Line Out", "LINEOUT",
"MIC1", "Mic",
"Mic", "MBIAS";
&de {
&cpu0 {
cpu-supply = <®_vdd_cpux>;
&ehci0 {
&ehci1 {
&ehci2 {
&emac {
pinctrl-names = "default";
phy-handle = <&int_mii_phy>;
phy-mode = "mii";
allwinner,leds-active-low;
&ehci3 {
&hdmi {
&hdmi_out {
hdmi_out_con: endpoint {
remote-endpoint = <&hdmi_con_in>;
&ir {
pinctrl-0 = <&r_ir_rx_pin>;
&mmc0 {
vmmc-supply = <®_vcc3v3>;
bus-width = <4>;
cd-gpios = <&pio 5 6 GPIO_ACTIVE_LOW>; /* PF6 */
&mmc1 {
vqmmc-supply = <®_vcc3v3>;
mmc-pwrseq = <&wifi_pwrseq>;
bus-width = <4>;
non-removable;
sdio_wifi: sdio_wifi@1 {
reg = <1>;
compatible = "brcm,bcm4329-fmac";
interrupt-parent = <&pio>;
interrupts = <6 10 IRQ_TYPE_LEVEL_LOW>; /* PG10 / EINT10 */
interrupt-names = "host-wake";
&mmc2 {
pinctrl-0 = <&mmc2_8bit_pins>;
bus-width = <8>;
non-removable;
&ohci0 {
&ohci1 {
&ohci2 {
&ohci3 {
&r_i2c {
reg_vdd_cpux: regulator@65 {
compatible = "silergy,sy8106a";
reg = <0x65>;
regulator-name = "vdd-cpux";
silergy,fixed-microvolt = <1200000>;
* The datasheet uses 1.1V as the minimum value of VDD-CPUX,
* however both the Armbian DVFS table and the official one
* have operating points with voltage under 1.1V, and both
* DVFS table are known to work properly at the lowest
* operating point.
* Use 1.0V as the minimum voltage instead.
regulator-min-microvolt = <1000000>;
regulator-max-microvolt = <1300000>;
regulator-boot-on;
regulator-always-on;
®_usb0_vbus {
gpio = <&r_pio 0 2 GPIO_ACTIVE_HIGH>; /* PL2 */
&uart0 {
pinctrl-0 = <&uart0_pa_pins>;
&uart1 {
pinctrl-0 = <&uart1_pins>;
&uart2 {
pinctrl-0 = <&uart2_pins>;
&uart3 {
pinctrl-0 = <&uart3_pins>, <&uart3_rts_cts_pins>;
&usb_otg {
dr_mode = "otg";
&usbphy {
usb0_id_det-gpios = <&pio 6 12 GPIO_ACTIVE_HIGH>; /* PG12 */
usb0_vbus-supply = <®_usb0_vbus>;
/* VBUS on USB host ports are always on */
};离线
今天补充的问题,分区文件是可以读到的,SD卡也有输出信息:
=>ls mmc 0:1
4953024 zImage
23387 sun8i-h3-nanopi-m1-plus.dtb
2 file(s), 0 dir(s)
=> ls mmc 0:2
<DIR> 4096 .
<DIR> 4096 ..
<DIR> 16384 lost+found
<DIR> 12288 bin
<DIR> 4096 boot
<DIR> 4096 dev
<DIR> 12288 etc
<DIR> 4096 home
<DIR> 4096 lib
<DIR> 4096 media
<DIR> 4096 mnt
<DIR> 4096 opt
<DIR> 4096 proc
<DIR> 4096 root
<DIR> 4096 run
<DIR> 12288 sbin
<DIR> 4096 srv
<DIR> 4096 sys
<DIR> 4096 tmp
<DIR> 4096 usr
<DIR> 4096 .Trash-0
<DIR> 4096 var
9641984 core
=>mmc part
Partition Map for MMC device 0 -- Partition Type: DOS
Part Start Sector Num Sectors UUID Type
1 40960 102400 000c279b-01 0b
2 143360 11350177 000c279b-02 83
=> mmc info
Device: SUNXI SD/MMC
Manufacturer ID: 3
OEM: 5344
Tran Speed: 50000000
Rd Block Len: 512
SD version 3.0
High Capacity: Yes
Capacity: 29.7 GiB
Bus Width: 4-bit
Erase Group Size: 512 Bytes离线
问题解决,是缺少了很多配置选项,不能直接使用官方内核
