我需要利用T5的usb0输出视频图像,脚本参考run_otg,应用层demo来自uvc-gadget,应用层启动指令为./uvc-gadget -i /root/images.jpg -f 1 -s 1 -r 1。
在设备树中CONFIG_USB_F_UVC和CONFIG_USB_LIBCOMPOSITE都已经打开,接入Ubuntu之后也能识别出video设备,但是无法通过VLC或者cheese打开,想问下大佬们这是什么问题导致的,是应用层还是脚本的问题。几个打印信息的报错都找过,没能找到解决方法。。。
相关信息如下
在ubuntu中使用v4l-utils查看打印信息如下
❯ v4l2-ctl -d /dev/video0 --all
Driver Info (not using libv4l2):
Driver name : uvcvideo
Card type : UVC Camera (1f3a:100d): UVC Cam
Bus info : usb-0000:02:03.0-1
Driver version: 5.4.218
Capabilities : 0x84A00001
Video Capture
Metadata Capture
Streaming
Extended Pix Format
Device Capabilities
Device Caps : 0x04200001
Video Capture
Streaming
Extended Pix Format
Priority: 2
Video input : 0 (Camera 1: ok)
Format Video Capture:
Width/Height : 1280/720
Pixel Format : 'MJPG'
Field : None
Bytes per Line : 0
Size Image : 460800
Colorspace : sRGB
Transfer Function : Default (maps to sRGB)
YCbCr/HSV Encoding: Default (maps to ITU-R 601)
Quantization : Default (maps to Full Range)
Flags :
Crop Capability Video Capture:
Bounds : Left 0, Top 0, Width 1280, Height 720
Default : Left 0, Top 0, Width 1280, Height 720
Pixel Aspect: 1/1
Selection: crop_default, Left 0, Top 0, Width 1280, Height 720
Selection: crop_bounds, Left 0, Top 0, Width 1280, Height 720
Streaming Parameters Video Capture:
Capabilities : timeperframe
Frames per second: 15.000 (15/1)
Read buffers : 0
brightness 0x00980900 (int) : min=0 max=255 step=1 default=127 value=0
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=0 value=0VLC 报错日志
main debug: looking for art finder module matching "any": 2 candidates
v4l2 debug: opening device '/dev/video0'
v4l2 error: cannot open device '/dev/video0': Operation not permitted
main debug: no access_demux modules matched
main debug: creating access: v4l2:///dev/video0
main debug: (path: /dev/video0)
main debug: looking for access module matching "v4l2": 29 candidates
main debug: no access modules matchedUbuntu的dmesg信息
[18491.358318] usb 1-1: new high-speed USB device number 23 using ehci-pci
[18491.710832] usb 1-1: New USB device found, idVendor=1f3a, idProduct=100d, bcdDevice= 4.09
[18491.710834] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[18491.710834] usb 1-1: Product: 123
[18491.710835] usb 1-1: Manufacturer: Test
[18491.710835] usb 1-1: SerialNumber: 20080411
[18491.754885] uvcvideo: Found UVC 1.00 device 123 (1f3a:100d)
[18496.942618] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 1: -110 (exp. 1).
[18497.056143] uvcvideo: Failed to query (GET_INFO) UVC control 2 on unit 2: -32 (exp. 1).
[18502.318681] uvcvideo: UVC non compliance - GET_DEF(PROBE) not supported. Enabling workaround.
[18507.439217] uvcvideo: Failed to query (129) UVC probe control : -110 (exp. 26).
[18507.439221] uvcvideo: Failed to initialize the device (-5).lsusb的输出为
❯ sudo lsusb -v -d 1f3a:100d
Bus 001 Device 023: ID 1f3a:100d Onda (unverified)
Device Descriptor:
bLength 18
bDescriptorType 1
bcdUSB 2.00
bDeviceClass 0 (Defined at Interface level)
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
idVendor 0x1f3a Onda (unverified)
idProduct 0x100d
bcdDevice 4.09
iManufacturer 1 Test
iProduct 2 123
iSerial 3 20080411
bNumConfigurations 1
Configuration Descriptor:
bLength 9
bDescriptorType 2
wTotalLength 175
bNumInterfaces 2
bConfigurationValue 1
iConfiguration 4
bmAttributes 0xc0
Self Powered
MaxPower 500mA
Interface Association:
bLength 8
bDescriptorType 11
bFirstInterface 0
bInterfaceCount 2
bFunctionClass 14 Video
bFunctionSubClass 3 Video Interface Collection
bFunctionProtocol 0
iFunction 5 UVC Camera
Interface Descriptor:
bLength 9
bDescriptorType 4
bInterfaceNumber 0
bAlternateSetting 0
bNumEndpoints 1
bInterfaceClass 14 Video
bInterfaceSubClass 1 Video Control
bInterfaceProtocol 0
iInterface 5 UVC Camera
VideoControl Interface Descriptor:
bLength 13
bDescriptorType 36
bDescriptorSubtype 1 (HEADER)
bcdUVC 1.00
wTotalLength 51
dwClockFrequency 48.000000MHz
bInCollection 1
baInterfaceNr( 0) 1
bLength 18
bDescriptorType 36
bDescriptorSubtype 2 (INPUT_TERMINAL)
bTerminalID 1
wTerminalType 0x0201 Camera Sensor
bAssocTerminal 0
iTerminal 0
wObjectiveFocalLengthMin 0
wObjectiveFocalLengthMax 0
wOcularFocalLength 0
bControlSize 3
bmControls 0x00000002
Auto-Exposure Mode
bLength 11
bDescriptorType 36
bDescriptorSubtype 5 (PROCESSING_UNIT)
Warning: Descriptor too short
bUnitID 2
bSourceID 1
wMaxMultiplier 16384
bControlSize 2
bmControls 0x00000001
Brightness
iProcessing 0
bmVideoStandards 0x 9
None
SECAM - 625/50
bLength 9
bDescriptorType 36
bDescriptorSubtype 3 (OUTPUT_TERMINAL)
bTerminalID 3
wTerminalType 0x0101 USB Streaming
bAssocTerminal 0
bSourceID 2
iTerminal 0
Endpoint Descriptor:
bLength 7
bDescriptorType 5
bEndpointAddress 0x84 EP 4 IN
bmAttributes 3
Transfer Type Interrupt
Synch Type None
Usage Type Data
wMaxPacketSize 0x0010 1x 16 bytes
bInterval 8
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 0
bNumEndpoints 0
bInterfaceSubClass 2 Video Streaming
iInterface 6 Video Streaming
VideoStreaming Interface Descriptor:
bLength 14
bDescriptorType 36
bDescriptorSubtype 1 (INPUT_HEADER)
bNumFormats 1
wTotalLength 61
bEndPointAddress 131
bmInfo 0
bTerminalLink 3
bStillCaptureMethod 0
bTriggerSupport 0
bTriggerUsage 0
bControlSize 1
bmaControls( 0) 11
bLength 11
bDescriptorType 36
bDescriptorSubtype 6 (FORMAT_MJPEG)
bFormatIndex 1
bNumFrameDescriptors 1
bFlags 0
Fixed-size samples: No
bDefaultFrameIndex 1
bAspectRatioX 0
bAspectRatioY 0
bmInterlaceFlags 0x00
Interlaced stream or variable: No
Fields per frame: 1 fields
Field 1 first: No
Field pattern: Field 1 only
bCopyProtect 0
bLength 30
bDescriptorType 36
bDescriptorSubtype 7 (FRAME_MJPEG)
bFrameIndex 1
bmCapabilities 0x00
Still image unsupported
wWidth 1280
wHeight 720
dwMinBitRate 442368000
dwMaxBitRate 442368000
dwMaxVideoFrameBufferSize 1843200
dwDefaultFrameInterval 333333
bFrameIntervalType 1
dwFrameInterval( 0) 333333
bLength 6
bDescriptorType 36
bDescriptorSubtype 13 (COLORFORMAT)
bColorPrimaries 1 (BT.709,sRGB)
bTransferCharacteristics 1 (BT.709)
bMatrixCoefficients 4 (SMPTE 170M (BT.601))
bLength 9
bDescriptorType 4
bInterfaceNumber 1
bAlternateSetting 1
bNumEndpoints 1
bLength 7
bDescriptorType 5
bEndpointAddress 0x83 EP 3 IN
bmAttributes 5
Transfer Type Isochronous
Synch Type Asynchronous
Usage Type Data
wMaxPacketSize 0x0400 1x 1024 bytes
bInterval 1
Device Qualifier (for other device speed):
bLength 10
bDescriptorType 6
bcdUSB 2.00
bDeviceSubClass 0
bDeviceProtocol 0
bMaxPacketSize0 64
Device Status: 0x0001
Self Powered在尝试使用g_webcam.ko之后也是不成功
最近编辑记录 Flork (2023-04-17 19:21:46)
脚本如下
#!/bin/sh
# now using this scripts
# MODULES_DIR="/lib/modules/`uname -r`"
#insmod $MODULES_DIR/sunxi_usb_udc.ko
#insmod $MODULES_DIR/sunxi_usbc.ko
mount -t configfs none /sys/kernel/config
mkdir /sys/kernel/config/usb_gadget/g1
echo "0x1f3a" > /sys/kernel/config/usb_gadget/g1/idVendor
echo "0x100f" > /sys/kernel/config/usb_gadget/g1/idProduct
mkdir /sys/kernel/config/usb_gadget/g1/strings/0x409
echo "20080411" > /sys/kernel/config/usb_gadget/g1/strings/0x409/serialnumber
echo "Test" > /sys/kernel/config/usb_gadget/g1/strings/0x409/manufacturer
mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0
mkdir -p /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p
echo 1280 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/wWidth
echo 720 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/wHeight
echo 333333 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/dwFrameInterval
echo 333333 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/dwDefaultFrameInterval
echo 442368000 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/dwMinBitRate
echo 442368000 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/dwMaxBitRate
echo 1843200 > /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/480p/dwMaxVideoFrameBufferSize
mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/mjpeg/m/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/fs
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/streaming/class/hs
mkdir /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/fs/
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/header/h/ /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/control/class/ss/
mkdir /sys/kernel/config/usb_gadget/g1/functions/ffs.adb
mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1
echo 0xc0 > /sys/kernel/config/usb_gadget/g1/configs/c.1/bmAttributes
echo 500 > /sys/kernel/config/usb_gadget/g1/configs/c.1/MaxPower
mkdir /sys/kernel/config/usb_gadget/g1/configs/c.1/strings/0x409
mkdir /sys/kernel/config/usb_gadget/g1/functions/mass_storage.usb0
ln -s /sys/kernel/config/usb_gadget/g1/functions/mass_storage.usb0/ /sys/kernel/config/usb_gadget/g1/configs/c.1/mass_storage.usb0
mkdir /dev/usb-ffs
mkdir /dev/usb-ffs/adb
mount -o uid=2000,gid=2000 -t functionfs adb /dev/usb-ffs/adb/
udc=`ls /sys/class/udc`
isudc=0
start(){
while [ 1 ]
do
sleep 1
otg_role=`cat /sys/devices/platform/soc/usbc0/otg_role`
if [ "$otg_role" = "usb_device" ]
then
if [ $isudc == 0 ]
then
echo $udc > /sys/kernel/config/usb_gadget/g1/UDC
isudc=1
fi
isudc=0
fi
done
start &
echo > /sys/kernel/config/usb_gadget/g1/UDC
echo 0x100d > /sys/kernel/config/usb_gadget/g1/idProduct
rm /sys/kernel/config/usb_gadget/g1/configs/c.1/mass_storage.usb0
rm /sys/kernel/config/usb_gadget/g1/configs/c.1/uvc.usb0
ln -s /sys/kernel/config/usb_gadget/g1/functions/uvc.usb0/ /sys/kernel/config/usb_gadget/g1/configs/c.1/uvc.usb0
ls /sys/class/udc | xargs echo > /sys/kernel/config/usb_gadget/g1/UDC离线
插入usb后机子的打印信息如下
[ 142.870690] android_work: sent uevent USB_STATE=CONNECTED
[ 143.444380] nf_conntrack: default automatic helper assignment has been turned off for security reasons and CT-based firewall rule not found. Use the iptables CT target to attach helpers instead.
[ 143.698733] configfs-gadget gadget: high-speed config #1: c
[ 143.704992] configfs-gadget gadget: uvc_function_set_alt(0, 0)
[ 143.711516] configfs-gadget gadget: reset UVC Control
[ 143.717185] configfs-gadget gadget: uvc_function_set_alt(1, 0)
[ 143.723808] configfs-gadget gadget: uvc_function_set_alt(1, 0)
[ 143.730450] android_work: sent uevent USB_STATE=CONFIGURED
[ 148.773269] handle_ep0: ep0 setup end
[ 148.816828] handle_ep0: ep0 setup end
[ 148.838899] configfs-gadget gadget: uvc_function_set_alt(1, 0)
[ 153.874769] handle_ep0: ep0 setup end
[ 153.936786] handle_ep0: ep0 setup end
[ 158.963752] handle_ep0: ep0 setup end
[ 159.054766] handle_ep0: ep0 setup end
[ 584.116224] ERR: Operation not supported最近编辑记录 Flork (2023-04-17 19:26:29)
