楼主 # 2022-08-18 17:20:46
yellowboy
V3S通过TFTP下载内核,通过NFS挂载文件系统,启动后出现登陆密码错误
有没有人遇到过这样的问题:
V3S,SD卡正常启动,登陆名为root,没有设置密码,可以正常登录;同样的内核和根文件系统,使用TFTP下载,文件系统用NFS挂载,启动成功之后,同样使用登录名root,却一直提示输入密码,输入密码root或直接按回车,提示密码错误,不知道这是什么情况
[    1.365236] dwmac-sun8i 1c30000.ethernet eth0: No MAC Management Counters available
[    1.372990] dwmac-sun8i 1c30000.ethernet eth0: PTP not supported by HW
[    1.386150] mmc1: queuing unknown CIS tuple 0x1a (5 bytes)
[    1.394729] mmc1: queuing unknown CIS tuple 0x1b (8 bytes)
[    1.402170] mmc1: queuing unknown CIS tuple 0x80 (1 bytes)
[    1.407768] mmc1: queuing unknown CIS tuple 0x81 (1 bytes)
[    1.413308] mmc1: queuing unknown CIS tuple 0x82 (1 bytes)
[    1.418851] mmc1: new high speed SDIO card at address 0001
[    1.479880] musb-hdrc musb-hdrc.1.auto: VBUS_ERROR in b_idle (80, <SessEnd), retry #0, port1 00000100
[    3.446216] dwmac-sun8i 1c30000.ethernet eth0: Link is Up - 100Mbps/Full - flow control rx/tx
[    3.505645] IP-Config: Complete:
[    3.508886]      device=eth0, hwaddr=02:00:bd:ce:ea:e2, ipaddr=10.36.5.122, mask=255.255.0.0, gw=10.36.5.1
[    3.518553]      host=10.36.5.122, domain=, nis-domain=(none)
[    3.524295]      bootserver=10.36.5.120, rootserver=10.36.5.120, rootpath=
[    3.531599] vcc5v0: disabling
[    3.534577] ALSA device list:
[    3.537602]   #0: V3s Audio Codec
[    3.557495] VFS: Mounted root (nfs filesystem) on device 0:13.
[    3.565563] devtmpfs: mounted
[    3.569857] Freeing unused kernel memory: 1024K
Starting logging: OK
Starting mdev...
Starting network: ip: RTNETLINK answers: File exists
FAIL
Welcome to Buildroot
buildroot-HS login: root
Password:
Login incorrect
Password:
#1 2023-07-12 20:15:14
baimin
Re: V3S通过TFTP下载内核,通过NFS挂载文件系统,启动后出现登陆密码错误
主机配置nfs服务器需添加“no_root_squash”参数:
#打开之前配置nfs的文件,我这边是
sudo vi /etc/exports
#添加下面的内容
/home/xxx/nfs *(rw,sync,no_root_squash,no_subtree_check)
#重启nfs服务
sudo /etc/init.d/nfs-kernel-server restart
