楼主 # 2023-07-25 00:27:08
Xiaoci
已发帖子: 24
V3S ffmpeg拍照出错 内核 uboot没问题
我刷了晕哥的OV2640固件,然后我自己弄了一个OV2640的内核。使用晕哥固件拍照没问题。
然后换上Debian9.9的系统,里面安装了ffmpeg。我使用指令
ffmpeg -f v4l2 -video_size 800x600 -i /dev/video0 -frames 1 out.jpg
然后报错如下。这玩意怎么解决???
[video4linux2,v4l2 @ 0x5231e0] ioctl(VIDIOC_G_PARM): Inappropriate ioctl for device
[video4linux2,v4l2 @ 0x5231e0] Time per frame unknown
[  655.763013] ffmpeg: page allocation failure: order:8, mode:0xcc0(GFP_KERNEL), nodemask=(null)
[  655.771678] CPU: 0 PID: 236 Comm: ffmpeg Not tainted 5.2.0-licheepi-zero #1
[  655.778630] Hardware name: Allwinner sun8i Family
[  655.783363] [<c010ed14>] (unwind_backtrace) from [<c010b72c>] (show_stack+0x10/0x14)
[  655.791107] [<c010b72c>] (show_stack) from [<c0699330>] (dump_stack+0x84/0x98)
[  655.798330] [<c0699330>] (dump_stack) from [<c01fbf30>] (warn_alloc+0xcc/0x170)
[  655.805638] [<c01fbf30>] (warn_alloc) from [<c01fcb40>] (__alloc_pages_nodemask+0xacc/0xcf4)
[  655.814070] [<c01fcb40>] (__alloc_pages_nodemask) from [<c0114350>] (__dma_alloc_buffer.constprop.4+0x34/0x17c)
[  655.824147] [<c0114350>] (__dma_alloc_buffer.constprop.4) from [<c01144bc>] (__alloc_remap_buffer+0x24/0x98)
[  655.833962] [<c01144bc>] (__alloc_remap_buffer) from [<c0114558>] (remap_allocator_alloc+0x28/0x30)
[  655.842996] [<c0114558>] (remap_allocator_alloc) from [<c01146fc>] (__dma_alloc+0x16c/0x2c8)
[  655.851424] [<c01146fc>] (__dma_alloc) from [<c01148d4>] (arm_dma_alloc+0x40/0x48)
[  655.858988] [<c01148d4>] (arm_dma_alloc) from [<c017c928>] (dma_alloc_attrs+0x100/0x110)
[  655.867080] [<c017c928>] (dma_alloc_attrs) from [<c0512da0>] (vb2_dc_alloc+0x60/0x104)
[  655.874994] [<c0512da0>] (vb2_dc_alloc) from [<c050ccac>] (__vb2_queue_alloc+0x184/0x444)
[  655.883165] [<c050ccac>] (__vb2_queue_alloc) from [<c050d4bc>] (vb2_core_reqbufs+0x2c4/0x440)
[  655.891681] [<c050d4bc>] (vb2_core_reqbufs) from [<c0510d34>] (vb2_ioctl_reqbufs+0xa0/0xc8)
[  655.900029] [<c0510d34>] (vb2_ioctl_reqbufs) from [<c04ecd20>] (__video_do_ioctl+0x288/0x454)
[  655.908549] [<c04ecd20>] (__video_do_ioctl) from [<c04ed280>] (video_usercopy+0x23c/0x504)
[  655.916808] [<c04ed280>] (video_usercopy) from [<c02287a8>] (do_vfs_ioctl+0xac/0x8cc)
[  655.924631] [<c02287a8>] (do_vfs_ioctl) from [<c0228ffc>] (ksys_ioctl+0x34/0x58)
[  655.932021] [<c0228ffc>] (ksys_ioctl) from [<c0101000>] (ret_fast_syscall+0x0/0x54)
[  655.939665] Exception stack(0xc3173fa8 to 0xc3173ff0)
[  655.944713] 3fa0:                   005231e0 00000000 00000003 c0145608 beab41f8 b5857af1
[  655.952882] 3fc0: 005231e0 00000000 beab4290 00000036 ffffffe7 00000000 005238c0 beab41f8
[  655.961047] 3fe0: 00000001 beab41b4 b6f167b7 b5857af8
[  655.966218] Mem-Info:
[  655.968511] active_anon:3427 inactive_anon:154 isolated_anon:1
[  655.968511]  active_file:3577 inactive_file:2858 isolated_file:1
[  655.968511]  unevictable:4 dirty:7 writeback:0 unstable:0
[  655.968511]  slab_reclaimable:630 slab_unreclaimable:1467
[  655.968511]  mapped:5008 shmem:429 pagetables:140 bounce:0
[  655.968511]  free:1421 free_pcp:17 free_cma:0
[  656.000905] Node 0 active_anon:13708kB inactive_anon:616kB active_file:14308kB inactive_file:11432kB unevictable:16kB isolated(anon):4kB isolated(file):4kB mapped:20032kB dirty:28kB writeback:0kB shmem:1716kB writeback_tmp:0kB unstable:0kB all_unreclaimable? no
[  656.024016] Normal free:5684kB min:936kB low:1168kB high:1400kB active_anon:13708kB inactive_anon:616kB active_file:14308kB inactive_file:11432kB unevictable:16kB writepending:28kB present:65536kB managed:56092kB mlocked:16kB kernel_stack:392kB pagetables:560kB bounce:0kB free_pcp:68kB local_pcp:68kB free_cma:0kB
[  656.051697] lowmem_reserve[]: 0 0 0
[  656.055185] Normal: 173*4kB (ME) 87*8kB (UME) 51*16kB (ME) 25*32kB (ME) 12*64kB (ME) 7*128kB (M) 2*256kB (M) 1*512kB (M) 0*1024kB 0*2048kB 0*4096kB = 5692kB
[  656.069205] 6865 total pagecache pages
[  656.072949] 0 pages in swap cache
[  656.076271] Swap cache stats: add 0, delete 0, find 0/0
[  656.081486] Free swap  = 0kB
[  656.084360] Total swap = 0kB
[  656.087252] 16384 pages RAM
[  656.090040] 0 pages HighMem/MovableOnly
[  656.093868] 2361 pages reserved
[  656.097039] sun6i-csi 1cb4000.csi: dma_alloc_coherent of size 720896 failed
[video4linux2,v4l2 @ 0x5231e0] ioctl(VIDIOC_REQBUFS): Cannot allocate memory
/dev/video0: Cannot allocate memory
#1 2023-07-25 09:20:04
ookk303
已发帖子: 37
Re: V3S ffmpeg拍照出错 内核 uboot没问题
根据错误消息来看,可能是由于内存不足导致的问题。ffmpeg在执行过程中需要大量的内存来处理视频数据,而您的系统上可能存在内存不足的情况,因此出现了"page allocation failure"和"Cannot allocate memory"的错误。
要解决这个问题,您可以尝试以下几个方法:
释放系统内存:关闭其他占用大量内存的程序或服务,以释放更多的空闲内存。可以通过查看系统中运行的进程,然后关闭不必要的进程来释放内存资源。
优化ffmpeg参数:通过调整ffmpeg的参数,减少其对内存的需求,例如减小视频处理分辨率、降低视频质量等。您可以针对具体场景和需求,适当调整ffmpeg命令的参数,以减少内存占用。
增加系统内存:如果您的系统内存确实不足,可以考虑增加内存条或更换到内存更大的设备,以提供足够的内存资源来支持ffmpeg的运行。
请注意,根据错误消息的描述,这个问题可能是由于内存不足导致的,但也可能存在其他原因。如果上述方法无法解决问题,请提供更多的上下文和详细信息,以便能够更准确地帮助您解决问题。
#2 2023-07-25 09:24:24
shaoxi2010
已发帖子: 396
cma设置大点
楼主 #3 2023-07-25 11:44:52
Xiaoci
已发帖子: 24
@ookk303
好的谢谢ChatGPT。爱来自openai。
(刚刚好准备起床去问ChatGPT,你就帮我问了)
#4 2023-07-25 11:56:26
memory
已发帖子: 628
Xiaoci 说:
@ookk303
你们是认真的吗,笑趴我了。
