目前遇到的问题如下:
按照linux4.14版本内核的设备树配置了6.1的LCD部分。但是使用的是drm方式,但是会提示如下错误:
[    0.814794] panel-simple panel: supply power not found, using dummy regulator
[    0.815406] ------------[ cut here ]------------
[    0.815435] WARNING: CPU: 0 PID: 1 at drivers/gpu/drm/panel/panel-simple.c:623 panel_simple_probe+0x578/0x6dc
[    0.815539] Modules linked in:
[    0.815566] CPU: 0 PID: 1 Comm: swapper Not tainted 6.1.0-rc6-licheepi-nano #6
[    0.815598] Hardware name: Allwinner suniv Family
[    0.815632]  unwind_backtrace from show_stack+0x10/0x14
[    0.815722]  show_stack from dump_stack_lvl+0x28/0x30
[    0.815785]  dump_stack_lvl from __warn+0xdc/0xf4
[    0.815823]  __warn from warn_slowpath_fmt+0xa8/0xb8
[    0.815860]  warn_slowpath_fmt from panel_simple_probe+0x578/0x6dc
[    0.815918]  panel_simple_probe from platform_probe+0x58/0xb8
[    0.815974]  platform_probe from really_probe+0xc4/0x2ac
[    0.816042]  really_probe from __driver_probe_device+0x80/0xe4
[    0.816106]  __driver_probe_device from driver_probe_device+0x30/0xdc
[    0.816172]  driver_probe_device from __driver_attach+0x8c/0x110
[    0.816238]  __driver_attach from bus_for_each_dev+0x70/0xb4
[    0.816303]  bus_for_each_dev from bus_add_driver+0x158/0x1ec
[    0.816362]  bus_add_driver from driver_register+0x74/0x10c
[    0.816429]  driver_register from panel_simple_init+0x10/0x48
[    0.816505]  panel_simple_init from do_one_initcall+0x48/0x240
[    0.816562]  do_one_initcall from kernel_init_freeable+0x180/0x1fc
[    0.816638]  kernel_init_freeable from kernel_init+0x10/0x130
[    0.816690]  kernel_init from ret_from_fork+0x14/0x2c
[    0.816726] Exception stack(0xc480dfb0 to 0xc480dff8)
[    0.816761] dfa0:                                     00000000 00000000 00000000 00000000
[    0.816796] dfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[    0.816826] dfe0: 00000000 00000000 00000000 00000000 00000013 00000000
[    0.816844] ---[ end trace 0000000000000000 ]---
设备树如下:
<suniv-f1c100s.dtsi>:
 * Copyright 2018 Mesih Kilinc <mesihkilinc@gmail.com>
#include <dt-bindings/clock/suniv-ccu-f1c100s.h>
#include <dt-bindings/reset/suniv-ccu-f1c100s.h>
    #address-cells = <1>;
    #size-cells = <1>;
    interrupt-parent = <&intc>;
    clocks {
        osc24M: clk-24M {
            #clock-cells = <0>;
            compatible = "fixed-clock";
            clock-frequency = <24000000>;
        osc32k: clk-32k {
            #clock-cells = <0>;
            clock-frequency = <32768>;
    cpus {
//        #address-cells = <1>;
        #address-cells = <0>;
        #size-cells = <0>;
        cpu@0 {
            device_type = "cpu";
//            reg = <0x0>;
    de: display-engine {
                compatible = "allwinner,suniv-f1c100s-display-engine";
                allwinner,pipelines = <&fe0>;
                status = "disabled";
    soc {
        compatible = "simple-bus";
        #size-cells = <1>;
        ranges;
        sram-controller@1c00000 {
            compatible = "allwinner,suniv-f1c100s-system-control",
                     "allwinner,sun4i-a10-system-control",
                     "allwinner,sun4i-a10-sram-controller";
            reg = <0x01c00000 0x30>;
            #size-cells = <1>;
            ranges;
            sram_d: sram@10000 {
                compatible = "mmio-sram";
                reg = <0x00010000 0x1000>;
                #size-cells = <1>;
                otg_sram: sram-section@0 {
                    compatible = "allwinner,suniv-f1c100s-sram-d",
                             "allwinner,sun4i-a10-sram-d";
                    reg = <0x0000 0x1000>;
        spi0: spi@1c05000 {
            compatible = "allwinner,suniv-f1c100s-spi",
                     "allwinner,sun8i-h3-spi";
            reg = <0x01c05000 0x1000>;
            interrupts = <10>;
            clock-names = "ahb", "mod";
            resets = <&ccu RST_BUS_SPI0>;
            num-cs = <1>;
            #size-cells = <0>;
        spi1: spi@1c06000 {
            reg = <0x01c06000 0x1000>;
            interrupts = <11>;
            clocks = <&ccu CLK_BUS_SPI1>, <&ccu CLK_BUS_SPI1>;
            resets = <&ccu RST_BUS_SPI1>;
            num-cs = <1>;
            #size-cells = <0>;
        tcon0: lcd-controller@1c0c000 {
                        compatible = "allwinner,suniv-f1c100s-tcon";
                        reg = <0x01c0c000 0x1000>;
                        interrupts = <29>;
                        clocks = <&ccu CLK_BUS_LCD>,
                                 <&ccu CLK_TCON>;
                                      "tcon-ch0";
                        clock-output-names = "tcon-pixel-clock";
                        resets = <&ccu RST_BUS_LCD>;
                        reset-names = "lcd";
                        ports {
                                #size-cells = <0>;
                                tcon0_in: port@0 {
                                        #size-cells = <0>;
                                        reg = <0>;
                                        tcon0_in_be0: endpoint@0 {
                                                reg = <0>;
                                                remote-endpoint = <&be0_out_tcon0>;
                                tcon0_out: port@1 {
                                        #size-cells = <0>;
                                        reg = <1>;
        mmc0: mmc@1c0f000 {
            compatible = "allwinner,suniv-f1c100s-mmc",
                     "allwinner,sun7i-a20-mmc";
            reg = <0x01c0f000 0x1000>;
            clocks = <&ccu CLK_BUS_MMC0>,
                 <&ccu CLK_MMC0>,
                 <&ccu CLK_MMC0_OUTPUT>,
                 <&ccu CLK_MMC0_SAMPLE>;
            clock-names = "ahb", "mmc", "output", "sample";
            resets = <&ccu RST_BUS_MMC0>;
            reset-names = "ahb";
            interrupts = <23>;
            pinctrl-names = "default";
            pinctrl-0 = <&mmc0_pins>;
            #size-cells = <0>;
        mmc1: mmc@1c10000 {
            reg = <0x01c10000 0x1000>;
            clocks = <&ccu CLK_BUS_MMC1>,
                 <&ccu CLK_MMC1>,
                 <&ccu CLK_MMC1_OUTPUT>,
                 <&ccu CLK_MMC1_SAMPLE>;
            resets = <&ccu RST_BUS_MMC1>;
            interrupts = <24>;
            #size-cells = <0>;
        ccu: clock@1c20000 {
            compatible = "allwinner,suniv-f1c100s-ccu";
            reg = <0x01c20000 0x400>;
            clock-names = "hosc", "losc";
            #clock-cells = <1>;
            #reset-cells = <1>;
            compatible = "allwinner,suniv-f1c100s-ic";
            reg = <0x01c20400 0x400>;
            interrupt-controller;
            #interrupt-cells = <1>;
        pio: pinctrl@1c20800 {
            compatible = "allwinner,suniv-f1c100s-pinctrl";
            reg = <0x01c20800 0x400>;
            gpio-controller;
            #interrupt-cells = <3>;
            #gpio-cells = <3>;
            mmc0_pins: mmc0-pins {
                pins = "PF0", "PF1", "PF2", "PF3", "PF4", "PF5";
                function = "mmc0";
                drive-strength = <30>;
            spi0_pc_pins: spi0-pc-pins {
                function = "spi0";
            uart0_pe_pins: uart0-pe-pins {
                pins = "PE0", "PE1";
                function = "uart0";
            uart1_pa_pins: uart1-pa-pins {
                                pins = "PA2", "PA3";
                                function = "uart1";
            lcd_rgb666_pins: lcd-rgb666-pins {
                                pins = "PD0", "PD1", "PD2", "PD3", "PD4",
                                       "PD5", "PD6", "PD7", "PD8", "PD9",
                                       "PD10", "PD11", "PD12", "PD13", "PD14",
                                       "PD15", "PD16", "PD17", "PD18", "PD19",
                                       "PD20", "PD21";
                                function = "lcd";
        timer@1c20c00 {
            compatible = "allwinner,suniv-f1c100s-timer";
            reg = <0x01c20c00 0x90>;
            interrupts = <13>, <14>, <15>;
            clocks = <&osc24M>;
        wdt: watchdog@1c20ca0 {
            compatible = "allwinner,suniv-f1c100s-wdt",
                     "allwinner,sun6i-a31-wdt";
            reg = <0x01c20ca0 0x20>;
            interrupts = <16>;
            clocks = <&osc32k>;
        uart0: serial@1c25000 {
            reg = <0x01c25000 0x400>;
            interrupts = <1>;
            reg-shift = <2>;
            reg-io-width = <4>;
        uart1: serial@1c25400 {
            reg = <0x01c25400 0x400>;
            interrupts = <2>;
            reg-shift = <2>;
            reg-io-width = <4>;
        uart2: serial@1c25800 {
            reg = <0x01c25800 0x400>;
            interrupts = <3>;
            reg-shift = <2>;
            reg-io-width = <4>;
        usb_otg: usb@1c13000 {
                        reg = <0x01c13000 0x0400>;
                        clocks = <&ccu CLK_BUS_OTG>;
                        resets = <&ccu RST_BUS_OTG>;
                        interrupts = <26>;
                        interrupt-names = "mc";
                        phys = <&usbphy 0>;
                        phy-names = "usb";
                        extcon = <&usbphy 0>;
                usbphy: phy@1c13400 {
                        reg = <0x01c13400 0x10>;
                        reg-names = "phy_ctrl";
                        clocks = <&ccu CLK_USB_PHY0>;
                        clock-names = "usb0_phy";
                        resets = <&ccu RST_USB_PHY0>;
                        reset-names = "usb0_reset";
                        #phy-cells = <1>;
        fe0: display-frontend@1e00000 {
                        compatible = "allwinner,suniv-f1c100s-display-frontend";
                        reg = <0x01e00000 0x20000>;
                        interrupts = <30>;
                        clocks = <&ccu CLK_BUS_DE_FE>, <&ccu CLK_DE_FE>,
                                 <&ccu CLK_DRAM_DE_FE>;
                        clock-names = "ahb", "mod",
                                      "ram";
                        resets = <&ccu RST_BUS_DE_FE>;
                        ports {
                                #size-cells = <0>;
                                fe0_out: port@1 {
                                        #size-cells = <0>;
                                        reg = <1>;
                                        fe0_out_be0: endpoint@0 {
                                                reg = <0>;
                                                remote-endpoint = <&be0_in_fe0>;
        be0: display-backend@1e60000 {
                        compatible = "allwinner,suniv-f1c100s-display-backend";
                        reg = <0x01e60000 0x10000>;
                        reg-names = "be";
                        interrupts = <31>;
                        clocks = <&ccu CLK_BUS_DE_BE>, <&ccu CLK_DE_BE>,
                                 <&ccu CLK_DRAM_DE_BE>;
                                      "ram";
                        resets = <&ccu RST_BUS_DE_BE>;
                        reset-names = "be";
                        assigned-clocks = <&ccu CLK_DE_BE>;
                        assigned-clock-rates = <300000000>;
                        ports {
                                #size-cells = <0>;
                                be0_in: port@0 {
                                        #size-cells = <0>;
                                        reg = <0>;
                                        be0_in_fe0: endpoint@0 {
                                                reg = <0>;
                                                remote-endpoint = <&fe0_out_be0>;
                                be0_out: port@1 {
                                        #size-cells = <0>;
                                        reg = <1>;
                                        be0_out_tcon0: endpoint@0 {
                                                reg = <0>;
                                                remote-endpoint = <&tcon0_in_be0>;
<suniv-f1c100s-licheepip-nano.dts>:
/dts-v1/;
#include "suniv-f1c100s.dtsi"
    model = "Lichee Pi Nano";
    compatible = "licheepi,licheepi-nano", "allwinner,suniv-f1c100s";
    aliases {
        mmc0 = &mmc0;
        serial1 = &uart1;
        spi0 = &spi0;
    chosen {
        stdout-path = "serial1:115200n8";
    reg_vcc3v3: vcc3v3 {
        regulator-name = "vcc3v3";
&mmc0 {
    broken-cd;
    bus-width = <4>;
    disable-wp;
    vmmc-supply = <®_vcc3v3>;
&spi0 {
    pinctrl-0 = <&spi0_pc_pins>;
    flash@0 {
        #size-cells = <1>;
        reg = <0>;
&uart0 {
    pinctrl-0 = <&uart0_pe_pins>;
&uart1 {
        pinctrl-0 = <&uart1_pa_pins>;
&otg_sram {
&usb_otg {
        dr_mode = "otg";
&usbphy {
<suniv-f1c100s-licheepi-nano-with-lcd.dts>:
 * Copyright (C) 2018 Icenowy Zheng <icenowy@aosc.io>
 * SPDX-License-Identifier: (GPL-2.0+ OR X11)
#include "suniv-f1c100s-licheepi-nano.dts"
    panel: panel {
        compatible = "ampire,am-480272h3tmqw-t01h", "simple-panel";
        #size-cells = <0>;
        port@0 {
            reg = <0>;
            #size-cells = <0>;
            panel_input: endpoint@0 {
                reg = <0>;
&be0 {
&de {
&tcon0 {
    pinctrl-0 = <&lcd_rgb666_pins>;
&tcon0_out {
    tcon0_out_lcd: endpoint@0 {
        reg = <0>;
技术狂,追求技术更高层,哈哈哈
这个不是666的配置吗
