楼主 # 2023-06-21 23:51:15
xiaoxiao
t113单独aplay可以播放语音文件但是mplayer没声音报错
mplayer -zoom -x 320 -y 240 ruguomeiyou.FLV -fs -ao alsa -framedrop
MPlayer 1.5-7.2.1 (C) 2000-2022 MPlayer Team
Playing ruguomeiyou.FLV.
libavformat version 59.17.102 (internal)
libavformat file format detected.
[lavf] stream 0: video (h264), -vid 0
[lavf] stream 1: audio (aac), -aid 0
VIDEO: [H264] 1280x720 0bpp 25.000 fps 0.0 kbps ( 0.0 kbyte/s)
Opening video decoder: [ffmpeg] FFmpeg's libavcodec codec family
libavcodec version 59.21.100 (internal)
Selected video codec: [ffh264] vfm: ffmpeg (FFmpeg H.264)
Load subtitles in ./
Opening audio decoder: [ffmpeg] FFmpeg/libavcodec audio decoders
AUDIO: 44100 Hz, 2 ch, floatle, 0.0 kbit/0.00% (ratio: 0->352800)
Selected audio codec: [ffaac] afm: ffmpeg (FFmpeg AAC (MPEG-2/MPEG-4 Audio))
[AO_ALSA] alsa-lib: pcm_hw.c:1895:(_snd_pcm_hw_open) Unknown field slave
[AO_ALSA] Playback open error: Invalid argument
Failed to initialize audio driver 'alsa'
Could not open/initialize audio device -> no sound.
Audio: no sound
Starting playback...
Could not find matching colorspace - retrying with -vf scale...
Opening video filter: [scale]
[swscaler @ 0xf2d958]bicubic scaler, from yuv420p to bgra using C
VO: [fbdev] 320x240 => 320x240 BGRA [fs] [zoom]
V: 45.5 0/ 0 178% 150% 0.0% 0 0
MPlayer interrupted by signal 2 in module: flip_page
Exiting... (Quit)
mplayer help
Playing help.
File not found: 'help'
Failed to open help.
#1 2023-09-05 16:41:07
ami7777
Re: t113单独aplay可以播放语音文件但是mplayer没声音报错
我也遇到这个问题 跟楼主是一样的 希望大佬们帮助解决一下
如果用aplay 也是这样
aplay /root/test.wav
ALSA lib pcm_hw.c:2021:(_snd_pcm_hw_open) Unknown field slave
aplay: main:828: audio open error: Invalid argument
