楼主 # 2023-08-20 11:32:20
zhang21st
F133-mq_r打包时出现no user resource partitions
编译成功了,但是打包出现handle partition user-res no user resource partitions,是什么原因呢?
日志如下:
PACK_CHIP         sun20iw1p1
PACK_PLATFORM     tina
PACK_BOARD        f133-mq_r
PACK_KERN
PACK_DEBUG        uart0
PACK_SIG          none
PACK_SECURE       none
PACK_MODE         normal
PACK_FUNC         android
PACK_PROGRAMMER   none
PACK_TAR_IMAGE    none
PACK_TOPDIR       /home/allwinner/Tina-Linux
No kernel param, parse it from f133
copying tools file
copying configs file
storage_type value is 1
rm /home/allwinner/Tina-Linux/out/f133-mq_r/image/sys_partition_nor.fex
rm /home/allwinner/Tina-Linux/out/f133-mq_r/image/image_nor.cfg
copying boot resource
copying boot file
make user resource for : /home/allwinner/Tina-Linux/out/f133-mq_r/image/sys_partition.fex
APP_PART_DOWNLOAD_FILE = /home/allwinner/Tina-Linux/out/f133-mq_r/image/app.fex
Need size of filesystem
no data resource partitions
don't build dtbo ...
update_chip
sboot file Path=/home/allwinner/Tina-Linux/out/f133-mq_r/image/sboot.bin
script file Path=/home/allwinner/Tina-Linux/out/f133-mq_r/image/sys_config.bin
update:unable to open sboot file
script update sboot ok
pack boot package
GetPrivateProfileSection read to end
content_count=3
file /home/allwinner/Tina-Linux/out/f133-mq_r/image/u-boot.fex cant be open
/home/allwinner/Tina-Linux/scripts/pack_img.sh: line 1250: 20995 Segmentation fault      (core dumped) dragonsecboot -pack boot_package.cfg
ERROR: dragon pack run error
#1 2023-09-14 07:29:41
belen
已发帖子: 29
Re: F133-mq_r打包时出现no user resource partitions
mboot后再pack
