楼主 # 2023-09-21 22:20:19
演技担当黄晓明
已发帖子: 184
python pip 下载 pypdf2 插件报错
输入  pip3 install pyPDF2
报告错误如下
Could not fetch URL https://pypi.tuna.tsinghua.edu.cn/simple/pip/: There was a problem confirming the ssl certificate: HTTPSConnectionPool(host='pypi.tuna.tsinghua.edu.cn', port=443): Max retries exceeded with url: /simple/pip/ (Caused by SSLError("Can't connect to HTTPS URL because the SSL module is not available.")) - skipping
问题最终解决地方:
https://github.com/conda/conda/issues/8273
楼主 #1 2023-10-09 16:38:14
演技担当黄晓明
已发帖子: 184
Re: python pip 下载 pypdf2 插件报错
Windows python安装的时候一定要选中precompile standard library
