楼主 # 2023-10-09 13:59:37
lijianshan
基于vscode platformio开发ESP32的编译配置
[env:GENERIC_ESP32]
platform = espressif32
board = esp32dev
framework = espidf
; build_cache_flags = --cache-dir .pio/build/esp32dev
; build_cache = true
board_build.partitions= partitions.csv
build_flags =
    ; jobs = 8
    ; -j 2
    -Wl,-u,_printf_float,-Map,output.map    ;输出map
    ; -Werror                                 ;警告错误停止编译
    --specs=nano.specs --specs=nosys.specs
    -O0                                     ;优化等级
    -D LAST_BUILD_TIME=$UNIX_TIME
    ; -D SUPPORT_OTA
build_type  = debug ;!正式版需要屏蔽
upload_speed = 921600
upload_port = /dev/cu.usbserial-0001
monitor_speed = 115200
monitor_port = /dev/cu.usbserial-0001
monitor_filters =
    esp32_exception_decoder  ;backtrace 打印死机信息,只支持在platfomio的monitor上
    default   ; Remove typical terminal control codes from input
    time      ; Add timestamp with milliseconds for each new line
    ; log2file  ; Log data to a file “platformio-device-monitor-*.log” located in the current working directory
