楼主 # 2023-10-10 18:33:36
muxi01
已发帖子: 63
[小爱mini音响 R16 ] mtdblock.c文件的驱动是否存在逻辑BUG?
// SPDX-License-Identifier: GPL-2.0-or-later
 * Direct MTD block device access
 * Copyright © 1999-2010 David Woodhouse <dwmw2@infradead.org>
 * Copyright © 2000-2003 Nicolas Pitre <nico@fluxnic.net>
#include <linux/fs.h>
#include <linux/init.h>
#include <linux/kernel.h>
#include <linux/module.h>
#include <linux/sched.h>
#include <linux/slab.h>
#include <linux/types.h>
#include <linux/vmalloc.h>
#include <linux/mtd/mtd.h>
#include <linux/mtd/blktrans.h>
#include <linux/mutex.h>
#include <linux/major.h>
struct mtdblk_dev {
	struct mtd_blktrans_dev mbd;
	int count;
	struct mutex cache_mutex;
	unsigned char *cache_data;
	unsigned long cache_offset;
	unsigned int cache_size;
	enum { STATE_EMPTY, STATE_CLEAN, STATE_DIRTY } cache_state;
 * Cache stuff...
 * Since typical flash erasable sectors are much larger than what Linux's
 * buffer cache can handle, we must implement read-modify-write on flash
 * sectors for each block write requests.  To avoid over-erasing flash sectors
 * and to speed things up, we locally cache a whole flash sector while it is
 * being written to until a different sector is required.
static int erase_write (struct mtd_info *mtd, unsigned long pos,
			unsigned int len, const char *buf)
	struct erase_info erase;
	size_t retlen;
	int ret;
	 * First, let's erase the flash block.
	erase.addr = pos;
	erase.len = len;
	ret = mtd_erase(mtd, &erase);
	if (ret) {
		printk (KERN_WARNING "mtdblock: erase of region [0x%lx, 0x%x] er=%d"
				     "on \"%s\" failed\n",
			pos, len, ret,mtd->name);
		return ret;
	 * Next, write the data to flash.
	ret = mtd_write(mtd, pos, len, &retlen, buf);
	if (ret)
		return ret;
	if (retlen != len)
		return -EIO;
static int write_cached_data (struct mtdblk_dev *mtdblk)
	struct mtd_info *mtd = mtdblk->mbd.mtd;
	int ret;
	if (mtdblk->cache_state != STATE_DIRTY)
	pr_debug("mtdblock: writing cached data for \"%s\" "
			"at 0x%lx, size 0x%x\n", mtd->name,
			mtdblk->cache_offset, mtdblk->cache_size);
	ret = erase_write (mtd, mtdblk->cache_offset,
			   mtdblk->cache_size, mtdblk->cache_data);
	if (ret)
		return ret;
	 * Here we could arguably set the cache state to STATE_CLEAN.
	 * However this could lead to inconsistency since we will not
	 * be notified if this content is altered on the flash by other
	 * means.  Let's declare it empty and leave buffering tasks to
	 * the buffer cache instead.
	mtdblk->cache_state = STATE_EMPTY;
static int do_cached_write (struct mtdblk_dev *mtdblk, unsigned long pos,
	unsigned int sect_size = mtdblk->cache_size;
	size_t retlen;
	int ret;
	pr_debug("mtdblock: write on \"%s\" at 0x%lx, size 0x%x\n",
		mtd->name, pos, len);
	if (!sect_size)
		return mtd_write(mtd, pos, len, &retlen, buf);
	while (len > 0) {
		unsigned long sect_start = (pos/sect_size)*sect_size;
		unsigned int offset = pos - sect_start;
		unsigned int size = sect_size - offset;
		if( size > len )
			size = len;
		if (size == sect_size) {
			 * We are covering a whole sector.  Thus there is no
			 * need to bother with the cache while it may still be
			 * useful for other partial writes.
			ret = erase_write (mtd, pos, size, buf);
			if (ret)
				return ret;
		} else {
			/* Partial sector: need to use the cache */
			if (mtdblk->cache_state == STATE_DIRTY &&
			    mtdblk->cache_offset != sect_start) {
				ret = write_cached_data(mtdblk);
				if (ret)
					return ret;
			if (mtdblk->cache_state == STATE_EMPTY ||
				/* fill the cache with the current sector */
				ret = mtd_read(mtd, sect_start, sect_size,
					       &retlen, mtdblk->cache_data);
				if (ret && !mtd_is_bitflip(ret))
					return ret;
				if (retlen != sect_size)
					return -EIO;
				mtdblk->cache_offset = sect_start;
				mtdblk->cache_size = sect_size;
				mtdblk->cache_state = STATE_CLEAN;
			/* write data to our local cache */
			memcpy (mtdblk->cache_data + offset, buf, size);
			mtdblk->cache_state = STATE_DIRTY;
		buf += size;
		pos += size;
		len -= size;
static int do_cached_read (struct mtdblk_dev *mtdblk, unsigned long pos,
			   int len, char *buf)
	size_t retlen;
	int ret;
	pr_debug("mtdblock: read on \"%s\" at 0x%lx, size 0x%x\n",
	if (!sect_size) {
		ret = mtd_read(mtd, pos, len, &retlen, buf);
			return ret;
	while (len > 0) {
		if (size > len)
			size = len;
		 * Check if the requested data is already cached
		 * Read the requested amount of data from our internal cache if it
		 * contains what we want, otherwise we read the data directly
		 * from flash.
		if (mtdblk->cache_state != STATE_EMPTY &&
		    mtdblk->cache_offset == sect_start) {
			memcpy (buf, mtdblk->cache_data + offset, size);
		} else {
			ret = mtd_read(mtd, pos, size, &retlen, buf);
				return ret;
			if (retlen != size)
				return -EIO;
		buf += size;
		pos += size;
		len -= size;
static int mtdblock_readsect(struct mtd_blktrans_dev *dev,
			      unsigned long block, char *buf)
	struct mtdblk_dev *mtdblk = container_of(dev, struct mtdblk_dev, mbd);
	return do_cached_read(mtdblk, block<<9, 512, buf);
static int mtdblock_writesect(struct mtd_blktrans_dev *dev,
	if (unlikely(!mtdblk->cache_data && mtdblk->cache_size)) {
		mtdblk->cache_data = vmalloc(mtdblk->mbd.mtd->erasesize);
		if (!mtdblk->cache_data)
			return -EINTR;
		/* -EINTR is not really correct, but it is the best match
		 * documented in man 2 write for all cases.  We could also
		 * return -EAGAIN sometimes, but why bother?
	return do_cached_write(mtdblk, block<<9, 512, buf);
static int mtdblock_open(struct mtd_blktrans_dev *mbd)
	struct mtdblk_dev *mtdblk = container_of(mbd, struct mtdblk_dev, mbd);
	pr_debug("mtdblock_open\n");
	if (mtdblk->count) {
		mtdblk->count++;
	/* OK, it's not open. Create cache info for it */
	mtdblk->count = 1;
	mutex_init(&mtdblk->cache_mutex);
	if (!(mbd->mtd->flags & MTD_NO_ERASE) && mbd->mtd->erasesize) {
		mtdblk->cache_size = mbd->mtd->erasesize;
		mtdblk->cache_data = NULL;
	pr_debug("ok\n");
static void mtdblock_release(struct mtd_blktrans_dev *mbd)
	pr_debug("mtdblock_release\n");
	mutex_lock(&mtdblk->cache_mutex);
	mutex_unlock(&mtdblk->cache_mutex);
	if (!--mtdblk->count) {
		 * It was the last usage. Free the cache, but only sync if
		 * opened for writing.
		if (mbd->file_mode & FMODE_WRITE)
			mtd_sync(mbd->mtd);
		vfree(mtdblk->cache_data);
	pr_debug("ok\n");
static int mtdblock_flush(struct mtd_blktrans_dev *dev)
	mtd_sync(dev->mtd);
static void mtdblock_add_mtd(struct mtd_blktrans_ops *tr, struct mtd_info *mtd)
	struct mtdblk_dev *dev = kzalloc(sizeof(*dev), GFP_KERNEL);
	if (!dev)
		return;
	dev->mbd.mtd = mtd;
	dev->mbd.devnum = mtd->index;
	dev->mbd.size = mtd->size >> 9;
	dev->mbd.tr = tr;
	if (!(mtd->flags & MTD_WRITEABLE))
		dev->mbd.readonly = 1;
	if (add_mtd_blktrans_dev(&dev->mbd))
		kfree(dev);
static void mtdblock_remove_dev(struct mtd_blktrans_dev *dev)
	del_mtd_blktrans_dev(dev);
static struct mtd_blktrans_ops mtdblock_tr = {
	.name		= "mtdblock",
	.major		= MTD_BLOCK_MAJOR,
	.part_bits	= 0,
	.blksize 	= 512,
	.open		= mtdblock_open,
	.flush		= mtdblock_flush,
	.release	= mtdblock_release,
	.readsect	= mtdblock_readsect,
	.writesect	= mtdblock_writesect,
	.add_mtd	= mtdblock_add_mtd,
	.remove_dev	= mtdblock_remove_dev,
	.owner		= THIS_MODULE,
static int __init init_mtdblock(void)
	return register_mtd_blktrans(&mtdblock_tr);
static void __exit cleanup_mtdblock(void)
	deregister_mtd_blktrans(&mtdblock_tr);
module_init(init_mtdblock);
module_exit(cleanup_mtdblock);
MODULE_LICENSE("GPL");
MODULE_AUTHOR("Nicolas Pitre <nico@fluxnic.net> et al.");
MODULE_DESCRIPTION("Caching read/erase/writeback block device emulation access to MTD devices");
erase_write 这个在业务逻辑上是否存在逻辑BUG,该函数执行了nand 的erase 和 write ,在erase之前会先检测该地址是否为坏块,为坏块了则返回错误,即擦写都失败。既然nand是存在坏块的可能的,那么擦地址和写地址应该自动偏移,跳过坏块才对。
#1 2023-10-11 08:51:06
duanlin
Re: [小爱mini音响 R16 ] mtdblock.c文件的驱动是否存在逻辑BUG?
不存在逻辑bug。因为函数参数指定了写入的位置,如果函数内部私自移开写位置,则为违抗指令。返回值很难描述变通行为的细节。
楼主 #2 2023-10-11 09:47:58
muxi01
已发帖子: 63
duanlin 说:
坏块,不就应该跳过吗?不跳过,指令就执行不下去了。
楼主 #3 2023-10-11 11:33:57
muxi01
已发帖子: 63
我是用mkfs.ext4格式化始终报错,我把overlayfs分区改小了,然后正常了
# mkfs.ext4 /dev/mtdblock7
mke2fs 1.47.0 (5-Feb-2023)
Creating filesystem with 89984 1k blocks and 22528 inodes
Filesystem UUID: bb8c5630-6d33-4e10-9730-50693acf846e
Superblock backups stored on blocks:
[  109.076672] nand: nand_erase_nand: attempt to erase a bad block at page 0x0000ffc0
Allocating group tables: done
[  109.087194] mtdblock: erase of region [0x57c0000, 0x20000] on "overlayfs_a" failed
Writing inode tables:
[  109.100275] blk_update_request: I/O error, dev mtdblock7, sector 562 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
done
[  109.122311] nand: nand_erase_nand: attempt to erase a bad block at page 0x0000ffc0
[  109.129919] mtdblock: erase of region [0x57c0000, 0x20000] on "overlayfs_a" failed
[  109.137513] blk_update_request: I/O error, dev mtdblock7, sector 11852 op 0x1:(WRITE) flags 0x800 phys_seg 1 prio class 0
Creating journal (4096 blocks): [  109.240616] nand: nand_erase_nand: attempt to erase a bad block atpage 0x0000ffc0
[  109.250679] mtdblock: erase of region [0x57c0000, 0x20000] on "overlayfs_a" failed
[  109.258263] blk_update_request: I/O error, dev mtdblock7, sector 65538 op 0x1:(WRITE) flags 0x4000phys_seg 32 prio class 0
[  109.269429] nand: nand_erase_nand: attempt to erase a bad block at page 0x0000ffc0
[  109.277005] mtdblock: erase of region [0x57c0000, 0x20000] on "overlayfs_a" failed
[  109.284573] blk_update_request: I/O error, dev mtdblock7, sector 65546 op 0x1:(WRITE) flags 0x4000phys_seg 31 prio class 0
[  109.295726] nand: nand_erase_nand: attempt to erase a bad block at page 0x0000ffc0
[  109.303286] mtdblock: erase of region [0x57c0000, 0x20000] on "overlayfs_a" failed
