# Stopping network: OK
Stopping system message bus: done
Saving random seed: [ 46.743630] urandom_read: 2 callbacks suppressed
[ 46.743644] random: dd: uninitialized urandom read (512 bytes read)
OK
Stopping klogd: OK
Stopping syslogd: OK
umount: devtmpfs busy - remounted read-only
[ 46.875991] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
The system is going down NOW!
Sent SIGTERM to all processes
Sent SIGKILL to all processes
Requesting system reboot
[ 48.891913] reboot: Restarting system
U-Boot SPL 2017.01-rc2-00057-g32ab1804cd-dirty (Dec 06 2022 - 23:52:09)
DRAM: 64 MiB
Trying to boot from MMC1
U-Boot 2017.01-rc2-00057-g32ab1804cd-dirty (Dec 06 2022 - 23:52:09 -0500) Allwinner Technology
Model: Lichee Pi Zero
DRAM: 64 MiB
MMC: SUNXI SD/MMC: 0
In: serial@01c28000
Out: serial@01c28000
Err: serial@01c28000
DRAM: 64 MiB
In: serial@01c28000
Net: No ethernet found.
No controllers found
reading zImage
4182904 bytes read in 215 ms (18.6 MiB/s)
reading sun8i-v3s-licheepi-zero-with-800x480-lcd.dtb
11757 bytes read in 27 ms (424.8 KiB/s)
Loading Device Tree to 42dfa000, end 42dffdec ... OK
[ 0.000000] Linux version 5.2.0-licheepi-zero (book@100ask) (gcc version 6.3.1 20170109 (Linaro GCC 6.3-2017.02)) #1 SMP Fri Dec 2 02:00:12 EST 2022
[ 0.000000] OF: fdt: Machine model: Lichee Pi Zero
[ 0.000000] percpu: Embedded 16 pages/cpu s34508 r8192 d22836 u65536
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 16256
[ 0.000000] Kernel command line: console=ttyS0,115200 panic=5 rootwait mtdparts=spi32766.0:1M(uboot)ro,64k(dtb)ro,6M(kernel)ro,-(rootfs) root=/dev/mmcblk0p2 earlyprintk rw vt.global_cursor_default=0
[ 0.000000] Dentry cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 4096 (order: 2, 16384 bytes, linear)
[ 0.000000] Memory: 55052K/65536K available (6144K kernel code, 301K rwdata, 1676K rodata, 1024K init, 252K bss, 10484K reserved, 0K cma-reserved, 0K highmem)
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=1.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=1
[ 0.000000] random: get_random_bytes called from start_kernel+0x300/0x48c with crng_init=0
[ 0.000000] arch_timer: cp15 timer(s) running at 24.00MHz (virt).
[ 0.000020] Switching to timer-based delay loop, resolution 41ns
[ 0.000207] clocksource: timer: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
[ 0.000450] Console: colour dummy device 80x30
[ 0.000509] Calibrating delay loop (skipped), value calculated using timer frequency.. 48.00 BogoMIPS (lpj=240000)
[ 0.000525] pid_max: default: 32768 minimum: 301
[ 0.000687] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.000704] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.001530] CPU: Testing write buffer coherency: ok
[ 0.002041] /cpus/cpu@0 missing clock-frequency property
[ 0.002065] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.002854] Setting up static identity map for 0x40100000 - 0x40100060
[ 0.003070] rcu: Hierarchical SRCU implementation.
[ 0.003609] smp: Bringing up secondary CPUs ...
[ 0.003631] smp: Brought up 1 node, 1 CPU
[ 0.003640] SMP: Total of 1 processors activated (48.00 BogoMIPS).
[ 0.003647] CPU: All CPU(s) started in SVC mode.
[ 0.004735] devtmpfs: initialized
[ 0.008211] VFP support v0.3: implementor 41 architecture 2 part 30 variant 7 rev 5
[ 0.008520] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.008554] futex hash table entries: 256 (order: 2, 16384 bytes, linear)
[ 0.008820] pinctrl core: initialized pinctrl subsystem
[ 0.009862] NET: Registered protocol family 16
[ 0.010483] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.011751] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.011770] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.035360] SCSI subsystem initialized
[ 0.035550] usbcore: registered new interface driver usbfs
[ 0.035608] usbcore: registered new interface driver hub
[ 0.035722] usbcore: registered new device driver usb
[ 0.035959] mc: Linux media interface: v0.10
[ 0.035999] videodev: Linux video capture interface: v2.00
[ 0.036212] Advanced Linux Sound Architecture Driver Initialized.
[ 0.037537] clocksource: Switched to clocksource arch_sys_counter
[ 0.050082] NET: Registered protocol family 2
[ 0.050901] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 6144 bytes, linear)
[ 0.050942] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
[ 0.050968] TCP bind hash table entries: 1024 (order: 1, 8192 bytes, linear)
[ 0.050991] TCP: Hash tables configured (established 1024 bind 1024)
[ 0.051142] UDP hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.051193] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes, linear)
[ 0.051491] NET: Registered protocol family 1
[ 0.053387] Initialise system trusted keyrings
[ 0.053771] workingset: timestamp_bits=30 max_order=14 bucket_order=0
[ 0.090936] Key type asymmetric registered
[ 0.090959] Asymmetric key parser 'x509' registered
[ 0.091062] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 250)
[ 0.091073] io scheduler mq-deadline registered
[ 0.091079] io scheduler kyber registered
[ 0.092121] sun4i-usb-phy 1c19400.phy: Couldn't request ID GPIO
[ 0.095902] sun8i-v3s-pinctrl 1c20800.pinctrl: initialized sunXi PIO driver
[ 0.096330] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pb not found, using dummy regulator
[ 0.097027] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[ 0.198712] Serial: 8250/16550 driver, 8 ports, IRQ sharing disabled
[ 0.202058] printk: console [ttyS0] disabled
[ 0.222367] 1c28000.serial: ttyS0 at MMIO 0x1c28000 (irq = 34, base_baud = 1500000) is a U6_16550A
[ 0.745121] printk: console [ttyS0] enabled
[ 0.751087] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 0.784352] panel-simple panel: panel supply power not found, using dummy regulator
[ 0.793585] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.800254] ehci-platform: EHCI generic platform driver
[ 0.805763] ehci-platform 1c1a000.usb: EHCI Host Controller
[ 0.811443] ehci-platform 1c1a000.usb: new USB bus registered, assigned bus number 1
[ 0.819442] ehci-platform 1c1a000.usb: irq 26, io mem 0x01c1a000
[ 0.847556] ehci-platform 1c1a000.usb: USB 2.0 started, EHCI 1.00
[ 0.854742] hub 1-0:1.0: USB hub found
[ 0.858690] hub 1-0:1.0: 1 port detected
[ 0.863308] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.869632] ohci-platform: OHCI generic platform driver
[ 0.875174] ohci-platform 1c1a400.usb: Generic Platform OHCI controller
[ 0.881899] ohci-platform 1c1a400.usb: new USB bus registered, assigned bus number 2
[ 0.889865] ohci-platform 1c1a400.usb: irq 27, io mem 0x01c1a400
[ 0.962661] hub 2-0:1.0: USB hub found
[ 0.966493] hub 2-0:1.0: 1 port detected
[ 0.973841] usbcore: registered new interface driver usb-storage
[ 0.981429] sun6i-rtc 1c20400.rtc: registered as rtc0
[ 0.986493] sun6i-rtc 1c20400.rtc: RTC enabled
[ 0.991208] i2c /dev entries driver
[ 0.996161] input: ns2009_ts as /devices/platform/soc/1c2ac00.i2c/i2c-0/0-0048/input/input0
[ 1.005795] sunxi-wdt 1c20ca0.watchdog: Watchdog enabled (timeout=16 sec, nowayout=0)
[ 1.014511] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pf not found, using dummy regulator
[ 1.050183] sunxi-mmc 1c0f000.mmc: initialized, max. request size: 16384 KB
[ 1.057787] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pg not found, using dummy regulator
[ 1.069174] usbcore: registered new interface driver usbhid
[ 1.074750] usbhid: USB HID core driver
[ 1.081357] Initializing XFRM netlink socket
[ 1.085670] NET: Registered protocol family 17
[ 1.090822] Registering SWP/SWPB emulation handler
[ 1.096711] Loading compiled-in X.509 certificates
[ 1.107986] sun8i-v3s-pinctrl 1c20800.pinctrl: 1c20800.pinctrl supply vcc-pe not found, using dummy regulator
[ 1.120460] sun4i-drm display-engine: bound 1100000.mixer (ops 0xc07468c0)
[ 1.128038] sun4i-drm display-engine: bound 1c0c000.lcd-controller (ops 0xc0743bbc)
[ 1.135700] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.142375] [drm] No driver support for vblank timestamp query.
[ 1.149410] [drm] Initialized sun4i-drm 1.0.0 20150629 for display-engine on minor 0
[ 1.189959] mmc0: host does not support reading read-only switch, assuming write-enable
[ 1.192214] mmc0: new high speed SDHC card at address 5048
[ 1.194049] mmcblk0: mmc0:5048 SD32G 29.7 GiB
[ 1.196565] mmcblk0: p1 p2
[ 1.209833] Console: switching to colour frame buffer device 100x30
[ 1.258926] sun4i-drm display-engine: fb0: sun4i-drmdrmfb frame buffer device
[ 1.266904] usb_phy_generic usb_phy_generic.0.auto: usb_phy_generic.0.auto supply vcc not found, using dummy regulator
[ 1.278403] musb-hdrc musb-hdrc.1.auto: MUSB HDRC host driver
[ 1.284168] musb-hdrc musb-hdrc.1.auto: new USB bus registered, assigned bus number 3
[ 1.293268] hub 3-0:1.0: USB hub found
[ 1.297173] hub 3-0:1.0: 1 port detected
[ 1.302341] sun6i-rtc 1c20400.rtc: setting system clock to 1970-01-01T00:00:55 UTC (55)
[ 1.310689] vcc3v0: disabling
[ 1.313669] vcc5v0: disabling
[ 1.316674] ALSA device list:
[ 1.319700] No soundcards found.
[ 1.342207] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.350539] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 1.359038] devtmpfs: mounted
[ 1.363361] Freeing unused kernel memory: 1024K
[ 1.368177] Run /sbin/init as init process
[ 1.506928] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
Starting syslogd: OK
Starting klogd: OK
Running sysctl: OK
Saving random seed: [ 1.745164] random: dd: uninitialized urandom read (512 bytes read)
[ 1.777736] usb 1-1: new high-speed USB device number 2 using ehci-platform
OK
Starting system message bus: [ 1.849986] random: dbus-uuidgen: uninitialized urandom read (12 bytes read)
[ 1.857128] random: dbus-uuidgen: uninitialized urandom read (8 bytes read)
done
Starting network: [ 1.990111] hub 1-1:1.0: USB hub found
[ 1.994998] hub 1-1:1.0: 4 ports detected
OK
Welcome to Buildroot
buildroot login: [ 5.444325] random: fast init done
root
# mp
mp4art mp4extract mp4info mp4tags mp4trackdump
mp4chaps mp4file mp4subtitle mp4track mpv
# mpv --fs test/badapple.mp4
(+) Video --vid=1 (*) (h264 800x480 30.000fps)
(+) Audio --aid=1 (*) (aac 2ch 48000Hz)
File tags:
Description: Packed by Bilibili XCoder v2.0.2
[vo/sdl] SDL_Init failed
Error opening/initializing the selected video_out (--vo) device.
Video: no video
Exiting... (Errors when loading file)
#离线
用buildroot,make menuconfig 之后 勾选Target packages -> Audio and video applicantions -> mplayer,再make,就可以用mplayer播放视频了
