楼主 # 2023-10-21 13:48:12
rick lou
所在地: 中国北京海淀
安卓系统无法连接蓝牙耳机,求指点
咸鱼买了个骁龙8155车机,这个蓝牙a2dp默认是从机,然后我root之后,设置一下属性,把从机关了。
persist.service.bt.hfp.client=0
persist.service.bt.a2dp.sink=0
然后可以连接耳机了,但是不出声,adb抓取日志如下。
02-16 00:11:39.049   638  3890 E bt_a2dp_hw: start_audio_datapath: Try opening data socket
02-16 00:11:39.049   638  3890 E bt_a2dp_hw: ts_error_log: [a2dp_out_write] ts 1608995831, diff 02109724, val 3584 7168
02-16 00:11:39.059   638  3890 E bt_a2dp_hw: a2dp_ctrl_receive: a2dp_ctrl_receive: ret=1, error(Try again)
02-16 00:11:39.059   638  3890 E bt_a2dp_hw: a2dp_ctrl_receive: a2dp_ctrl_receive: ret=2, error(Try again)
02-16 00:11:41.198   638  3890 E bt_a2dp_hw: a2dp_ctrl_receive: a2dp_ctrl_receive: ret=1, error(Try again)
日志不断循环这几行,死活不播放,看到638是audioserver发出的,不知道啥问题,求大佬指点,谢谢。
楼主 #1 2023-10-22 13:40:36
rick lou
所在地: 中国北京海淀
Re: 安卓系统无法连接蓝牙耳机,求指点
现在折腾成这样了
10-22 13:36:53.919   592  2355 D audio_hw_primary: out_standby: exit
10-22 13:36:53.923   592  2355 D audio_hw_primary: start_output_stream: enter: stream(0xb4240000)usecase(1: low-latency-playback) devices(0x80)
10-22 13:36:53.924   592  2355 E audio_hw_primary: start_output_stream: A2DP profile is not ready, return error
10-22 13:36:53.974   592  2355 D audio_hw_primary: out_standby: enter: stream (0xb4240000) usecase(1: low-latency-playback)
