楼主 # 2023-10-29 13:54:32
Alaw
v3s 播放音乐没有声音
  1. 声卡设备树修改了,下面可以看出是识别出来了
    [ 5.611330] ALSA device list:
    [ 5.614296] #0: V3s Audio Codec
  2. buildroot都播放库都使能了:alsa-utils下边全部勾选了
  3. 播放用这个命令播放,但是就是没有声音
    # aplay music.mp3
    Playing raw data 'music.mp3' : Unsigned 8 bit, Rate 8000 Hz, Mono
  4. 这个是声音的设置图片
lqqqqqqqqqqqqqqqqqqqqqqqqqqqqqq AlsaMixer v1.2.8 qqqqqqqqqqqqqqqqqqqqqqqqqqqqqqk
x Card: V3s Audio Codec                                F1:  Help               x
x Chip:                                                F2:  System information x
x View: F3:[Playback] F4: Capture  F5: All             F6:  Select sound card  x
x Item: Headphone [dB gain: 0.00]                      Esc: Exit               x
x        x
x      lqqk                    lqqk        lqqk        lqqk                    x
x      xaax                    x  x        x  x        xaax                    x
x      xaax                    x  x        xaax        xaax                    x
x      xaax                    xaax        xaax        xaax                    x
x      tqqu        Mixer       tqqu        mqqj        tqqu        lqqk        x
x      xOOx                    xOOx                    xOOx        xOOx        x
x      mqqj                    mqqj                    mqqj        mqqj        x
x      100                      43          64         100                     x
x  < Headphone >Headphone S    Mic1     Mic1 Boost      DAC     DAC Reverse    x
mqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqqj
各位大佬有遇到过这个问题吗?还是我的姿势不对,烦请指教^-^
最近编辑记录 Alaw (2023-10-29 14:00:24)
#1 2023-10-30 09:31:45
webb_2002
已发帖子: 98
Re: v3s 播放音乐没有声音
你换成wav格式试试看。
