T113 SD卡启动进入BOOT0就不启动了,使用的芒果派的镜像和自己编译的TINA LINUX镜像都不行。启动信息如下:
[136]HELLO! BOOT0 is starting!
[139]BOOT0 commit : adaf1174cc
[142]set pll start
[144]fix vccio detect value:0xc0
[151]periph0 has been enabled
[155]set pll end
[156][pmu]: bus read error
[159]board init ok
[161]ZQ value = 0x31
[163]get_pmu_exist() = -1
[166]ddr_efuse_type: 0xa
[168]trefi:7.8ms
进行到trefi:7.8ms就不启动了,不知道什么原因。板子各电压测试均没有问题。
是不是DDR哪里不对?我一个成功的启动log
[29]HELLO! BOOT0 is starting!
[32]BOOT0 commit : 5224261
[34]set pll start
[40]periph0 has been enabled
[43]set pll end
[45][pmu]: bus read error
[47]board init ok
[49]enable_jtag
[51]ZQ value = 0x31
[52]get_pmu_exist() = -1
[55]DRAM BOOT DRIVE INFO: V0.32
[58]DRAM CLK = 792 MHz
[60]DRAM Type = 3 (2:DDR2,3:DDR3)
[63]DRAMC read ODT  off.
[66]DRAM ODT value: 0x42.
[68]ddr_efuse_type: 0xa
[71]mark_id: 0x60
[73]DRAM SIZE =128 M
[75]PLL_DDR_CTRL_REG:0xf8004100
[78]DRAM_CLK_REG:0xc0000000
[81][TIMING DEBUG] MR2= 0x18
[88]DRAM simple test OK.
@NaClH2O
谢谢,相同SD卡放别的板子可以,目前在找硬件的问题。
